How to keep the engine as quiet as new
Engine will become noiser after couple of years. Except damage and defect, what makes the noise? If the engine is defect free, is it possible to bring it back as quiet as it was new? What kind of tune-up can achieve it, valve adjustment, spark plug replacement, or timing adjustment?
Please share your experience. Thanks.
-Kent
-Kent
even if you over-change the oil and fuss with it like it was a show car, if you drive it, it will wear.
You gotta start from day one with quality oils changed often [every 90 days] and super bypass [external oil filters] to keep an engine quiet over 250,000 miles.
Well, I think q45man is a rather well respected contributor to these boards. I believe he is a Lexus and Infiniti mechanic.
In 250,000 miles that's 10-15 years of driving you won't care what it sounds like as long as it runs.
I used to drive an older car a few years ago. I sold it at 220K+ miles. And I very much cared how it sounded. (It sounded great!)
And this can be done with regular good maintenance.
You got this one right!
I have a solution to keep the engine quiet. Don't worry about maintenace too much, but when your engine gets to about 100,000 miles and gets louder, just use some ZMax or a similar additive, that will restore the engine like new!
Haven't seen one of those in awhile!
