Transmission issue
billlplbilllpl Member Posts: 1
edited April 2016 in Ford
Edge, 2003. 250K miles, runs excellent. Problem, when transmission shifts from 2nd to 3rd, about 35 mph, Engine revs high, overdrive light starts flashing, vehicle stays in 2nd gear. You must let up on gas, and it may shift in to 3rg gear. Drive and runs fine from there up to 80 mph+. Problem is in Transmission, WHAT IS IT?
Answers
  • bdymentbdyment Member Posts: 573
    At 230,000 miles the transmission its probably worn out. Best get to a good transmission shop.
  • mrbizness1mrbizness1 Member Posts: 93
    did you check the trans fluid?
  • maxima8maxima8 Member Posts: 14
    i have problems with code PO745 i put new line pressure solenoid and still same code Maxima 1996
    @maxima8 -- your question is being address in Answers, where you also posted.
