Overheating
asappington13asappington13 Member Posts: 1
edited October 2016 in Buick
Need help still running hot I took the thermostat out the radiator is leaking will stop leak work and are the heads blown even if no water in oil or smoke
    Diagnosing overheating can be very tricky. There are a lot of inter-related components.
    Answer some questions:
    Fast overheat or slow overheat (how long does it take from a cold engine)
    Overheats at idle only and ok on highway, or ok at idle, overheats only on highway, or both.
    Is coolant currently leaking out somewhere.
    Can you hear/see the cooling fans kicking in at some point?
  • Jamesfay60Jamesfay60 Member Posts: 1
    Im trying to change the heater hose assembly it has one blot holding it on but its behind the exhaust sheld
  • BurningfireBurningfire Member Posts: 1
    I am a dubious owner of a Buick Rendezvous 2002 CXL that consistently overheats after flushing etc.. my question is, " is it possible to swap out the 3.4 motor and replace it with a 3.8 motor, which is a tried and proven motor? Adding a rear facing hood scoop".
  • rickdonrickdon Member Posts: 123
    I would check the water pump also.
  • ABWAHABABWAHAB Member Posts: 1
    LE MANO DE TEMPERATURE SUR LA BUICK RENDEZVOUS a quelle température IL DOIT déclenché les vontlateur
