01 Camry turns over no start
![chunkylover23](https://secure.gravatar.com/avatar/f21420da3f95db9dd8a685319b67f196/?default=https%3A%2F%2Fvanillicon.com%2F5299694a9d45a70729612baf54140445_200.png&rating=g&size=200)
Hi
I own a 2001 Toyota Camry ce 2.2 4cyl i accidently put the battery backwards and now my car turns over but won't start . I changed the car battery alternator fuse 100 , crank position sensor and both ignition coils with no luck . I also took apart the ecm computer and it dose not smell nor looks burned . I tested the spark plugs and ingnition coils with no spark . What's the problem ? Where can I look for no spark in the ignition ? I'm all out of options and need pro help. Thanks
Answers
If that's okay and there's no spark from the coil, then you have to work back to crank and cam sensors--I'm not sure on your car which one of those sensors controls spark.
