2015 Wrangler 17" rim and 33" tire
mmulero77mmulero77 Member Posts: 1
edited June 2017 in Jeep
Hi, I was wondering if someone can tell me if a XD Wheels XD 811 Rockstar II 17X8 with 8 on 170 Bolt Pattern tire (XD81178087710) will fit a BF Goodrich All Terrain T/A K02 tire with no spaces and or lug nuts on a 2015 4DR Jeep Wrangler. I called a tire place but they told me the best bet would be to find a forum and ask here. Thank you for your time.
    You'll probably have better luck asking on a Wrangler forum.
    Yeah, that's a good idea, to go to a Wrangler forum, because there you might find someone who has actually successfully done this, rather than just a speculative answer.
    If that doesn't work, I do know that a good tire shop will mount that tire and wheel for you on a lift and let you check out clearances (presuming of course you are buying something from them).
    But even lift clearances don't tell you what might happen in a dynamic off-road situation. That's why you want to find the person who "went before you" and did this already.
  • rubiconfreedomrubiconfreedom Member Posts: 6
    edited November 2017
    Typically all higher end 2007-2017 Jeep Wrangler come standard with either 16'' or 17'' wheels & the 31'' to 32'' all terrain tires. So the 17'' + 33" should work.. However, your issue would be the bolt pattern. Current Jeep Wranglers have a 5x127 bolt pattern with an ET around 44. The wheels you've selected would not work Unless one was to acquire a wheel adapter/spacer. Not saying it's impossible, but it would be very difficult to mate these wheels up on the current JK Wrangler.
