Hyundai Tiburon Clutch Problems
deangarris
Member Posts: 5
BUYER BEWARE!! I have a 2003 Tiburon and have had nothing but problems. I have replaced the clutch & flywheel with after market parts because the dual-mast flywheel that is standard in these cars is defective, I have had to replace the transmission and now I believe the starter has just bit the dust, this is of course after I have had problems with the sunroof, power windows & brakes... AND this is all under 60,000 miles. This is the absolute worst car purchase I have ever made. I will never buy a Hyundai again! The service dealerships (I have been to 3 now) are inept and apparently noone knows how to fix these cars to make them last more than a month without something else breaking. BUYER BEWARE!!
I have contacted the Hyundai, consumer affairs and made a formal complaint. The representative advised she was submitting a request for reimbursement for the bill. I truly doubt that they will do anything. However, your Buyer Beware has really been an eye-opener, and of course, I am planning to get rid of my car asap. The fact that you mention the standard flywheel is defective really caught my interest. My opinion is that Hyundai is an inferior automobile, but our horror stories are not being shared.
Thanks for sharing. Alan Pavloff
Thanks for sharing your experience. I have heard their is a class action lawsuit against Hyundai for the clutch on their 03 & 04 Tiburon's. Best of luck.
-Derek
:lemon:
We have submitted the info the to attorneys in CAL and are waiting to hear from them.
Dumped out Hyundai for a Honda!!
We have been spreading the info to everyone that owns a Hyundai in the neighbourhood. We will never buy another Hyundai not only becuase of the Tiburon clutch, but because they knew ofthe problem and didnt do anything!!
However today I had a problem with the clutch. I had just exited the interestate and depressed the clutch to disengage the gear to stop for a traffic light. When I did that the clutch pedal did not spring back up! I wasn't able to put it into any gear.
After checking if there was anything holding the clutch pedal down (there was nothing) I put my foot underneath the pedal and pulled. The clutch then came up to its normal position. I was then able to drive the car normally.
I called Roadside assistance and they towed my car to a nearby dealership (South Blvd in Charlotte NC). After waiting 1 hour I was told I was 'ready to go' because they could not reproduce the problem and therefore they could not 'fix it'. :mad:
Obviously I am not happy with this, the risk is too high if the clutch gets stuck again while driving at high speeds.
Is there anybody out there with the same problem, with a new or old Tiburon?
I inquired about the many complains regarding the clutches for Tiburons in 2003/2004 and was told those were bad drivers.. but it's hard to believe there are so many bad drivers.
In your case, what was the reason to replace the clutch, was it just worn out? Did it happen suddenly or it took time?
see my earier message. 3 clutches in 28,000 miles...not good.
had many standard clutch cars in many years of driving including a mitsubishi with 176,000 and never an adjustment.
will never own nor recommend a hyundai again.
(have a Honda & Acura now)
AGP
My resolution: I bought a Honda
agp
I found the link for the complaint:
http://www-odi.nhtsa.dot.gov/ivoq/index.
I would ask everybody that has have an issue with any year Tib clutch to put a complain, if there are as many as it seems we might get some attention. :mad:
I don't mind the clutch so much, but who ever heard of a flywheel being worn out at 49000 miles from a 160 hp car? The flywheel is pure trash. Learn from my mistake and DON'T BUY THIS CAR. A flywheel should not be a wear part at 49000 miles unless you're driving AND abusing a 400 hp+ race machine. To top it off we also found the bearing to be bad and the dealer knew of the 'click' before they tore the car apart and replaced all the other parts. Now we need to go back in and replace the bearing "under warranty". Double labor charges for the service dept. Hyundai's "best warranty" is in name only in this case.
Like I said in my note above, my bad for not looking before I leaped. But the company should warrant faulty parts that are clearly NOT wear parts. And it looks like they still have some serious clutch issues that are not 'normal'.
I'm glad that some folks did get a car that works well and that you are one of them. We need our medics to be able get to work safely!! Thanks for doing it!!
Please help -
Stranded in Georgia
"Hyundai says it is normal wear and tear so not covered under warranty."
And:
"Kottman Transmission dealt with the service rep for the company that makes the flywheel in the Tiburon and was told there is a problem with early failure on the fly wheel."
The interesting thing to me, is that there are two different statements, regarding the same problem. Apparently, the Hyundai dealership is telling you it is due to normal wear (bogus, i.e. b.s. and lying) while conversely a service Rep for the part being made is factually saying that the problem is with the fly wheel product itself.
This defect has been going on for sometime, it appears that Hyundai is turning a deaf ear to the matter, and it definitely subtracts any respect that I would otherwise have had for the company. I will not say anything good about Hyundai in future, but rather I will dissuade anyone I know of from buying Hyundai, and mention to them, this problem which they (business smarts = NOT) refused to resolve. Come on! They have 1 problem with one part for car, and can't fix it after 3 to 4 years of mention? They can add an entirely new "luxury" car to their line, but can't resolve a defect in the one and only 'sport line' assembly they already have?? Going forward with Hyundai . . . up the hill, and down the cliff. Again, 'Business Smarts' = Not, when they insult the intelligence of the customers they seek to allure with simple gloss and market exaggeration. That is how they encourage young or enthusiastic drivers? Also, all of their parts are overly expensive. Thank you for sharing what the flywheel rep said.
Also, you might want to use spell check and avoid gangsta spellings of words like "duz" as it makes you sound like a complete moron.
Obviously there are serious issues with the new Tiburons.
one upset tib customer!
As i have been driving the same driving over the past 19 years with various cars, i said i have never had any clutch or gearbox problem. He just said wear and tear. I think in Australia the problem hasn't come to their notice yet. I am taking my car to a Hyundai
spear parts man tonight to have a look at it. I love my car and cannot fault it up until now. I have 139000 k on the clock
julie2
A couple weeks later, still mad, I wrote the Better Business Bureau who responded VERY quickly. But I had to fill out about 5-6 pages of information and they wanted a bunch of other info. I figured it was too much time and work so forgot about it. In Dec, I decided what the heck, it's just 42cents postage and a bit of time. After filling it all out, making copies of my first bill, and then the copy of the second occurance with the paid bill from the transmission company I sent it all in. BTW I also included all the messages from this site that everyone is complaining about the same issue, and the info about the 2003 class action lawsuite regarding the same problem. I expected nothing to happen... however the BBB responded back very fast saying they were going to investigate. I had several dialogues with the BBB. The end result for the BBB was that Hyundai was refusing to do anything. BUT, the BBB advised me I still had 1 more alternative. They could arrange for a 3rd pary outside arbitrator to hear the case. I would have to appear in their offices presenting my side with all documentation. Hyundai would also have to appear and give why it was my fault and not theirs. I was not going to do it, but decided lets do it. BBB told me the date and said they were going to advise Hyundai that they would have to appear for the hearing. 1 hour later the BBB said I would not have to go, Hyundai was agreeing to reimburse me for the $1,800.
I don't know if it will work for you, but what the heck, it''s worth the try and you just might get your expenses reimbursed. Persistance paid off for me
BTW, the BBB will only step in if you still own the vehicle.
Good Luck
Not to mention my defective airbag and seatbelt sensors, this car is the epitome of a lemon and I regret the day I ever bought it..Hyundai USA is a horrible company and one day they are going to lose all credibility which is really a stupid business move.. :mad:
I am looking into just dumping this car and getting into something more reliable because I simply can not afford another HUGE problem. In the economy we are living in today, how in the world am I supposed to have enough money to get all of this fixed???? :lemon: :lemon: :lemon:
.00
