jetta tdi wont crank
2000 jetta tdi cranks but wont start. no engine light or glow plug light
1. Check your fuel shut-off valve to make sure it's not stuck in the off position. This can be moved by hand. You can check in with the TDI club about this:
http://www.tdiclub.com/
I would also check any fuses related to the fuel pump
And last of all, I'd change the fuel filter, if you haven't done so in a long while. This sometimes will cure the no start.
