Automatic Suzuki Grand Vitara Stalls when it is put into- D, R,N. Battery was disconnected for 15min
I disconnected my battery trying to get my cruise control to work. Now my car stalls right away when I put my automatic it stalls- Drive, Reverse, Neutral. The battery was disconnected for 15min to try to get cruise control to work on advice but now I'm having this problem. This was never an issue before. I tried to reset the computer by disconnecting the battery again for 15 min then turn the ignition to on position but not starting it I let that be for 30 secs and then shut it off for a while then started the car. it did it again. I then turned it worked some but stalled on occasion. in between, it would work then stall. the odd thing is the cruise control worked. then I shut the car off the check engine light came on the car did the stalling thing cruise stopped working. please help! I have no clue what to do. Just bought the car. A code did show up after the battery was disconnected but doesn't make sense. I looked it up doesn't really go with my problems-P0031. Any ideas? any advice? Automatic Suzuki Grand Vitara Stalls when it is put into- D, R, N. The battery was disconnected for 15min
Best Answers
Mr_Shiftright
Member Posts: 64,481
I would suggest just driving it around for a little bit. It may have to re-learn some basic routines.1 -
Mr_Shiftright
Try not to do that again. If you have to disconnect the battery , Autozone sells this little "memory saver":
https://www.amazon.com/VSTM-Emergency-Alligator-Cigarette-Extension/dp/B01MPY0DNI/ref=sr_1_1_sspa?crid=19LNLH7JMOU9Z&keywords=battery+memory+saver&qid=1555982789&s=gateway&sprefix=battery+memo,aps,192&sr=8-1-spons&psc=1
1
Answers
