It's not a fatal problem, but it will get worse with time, and if you have emissions testing, the car may not pass.
It would be unusual if that were the result of a light, or even fairly heavy, e-nrake application. Someone will, can. correct me if I'm wrong but most cars have e-brake implementations that are separate from your normal brakes. But yes, even so, the rear brakes may have become overheated due to the e-brake application but seeing as how the front brakes always do about 70-80% of the actual braking...
Today I resolved to change oil on my own. It'll be absolute first for me to do anything like this. I'd like to know kind of stuff I need. Tools, accessories, safety practices etc.
Along with oil change, I'll also change the oil filter and cabin air filter but I dont know specifications/types of filters available.
Also, how can I reset MAINT REQD indicator?
Stuff I already know:
My engine specs is 2AZ-FE
I need 5W-30 oil.
I need short ramp to lift it by 1 ft.
I need sun glasses so I look cool
Thanks in advance.
And it can be messy and very frustrating -- hard to get enough leverage while lying on the ground to loosen a stubborn oil pan bolt or oil filter, splashing or spilling hot oil on your hands or on the ground, fetching the drain bolt from the bottom of your drain pan, etc.
I learned to do it the hard way, by myself 30+ years ago. Now, of course, it's routine, but I'm lucky because for the last 16 years, I've had access to a lift and a waste oil drain tank inside the air-conditioned building of my employer. When I retire within the next decade or sooner, I'll have to think long and hard about getting under the car again in my garage with ramps, oil drain pans, and no heat or a/c.
As for resetting the indicator light, it's spelled out in detail in your owner's manual -- this is very easy to do.
- an oil filter wrench cap. You buy them at any autoparts store where the oil filters are. They are made to fit over the end of the oil filter, and you put a 3/8" square drive extension in it. Buy the wrench which specifically fits your oil filter. Should be about 3 bucks.
- a socket wrench, and extension, to fit the above oil filter wrench
- either a socket to fit the oil drain plug, or a closed end wrench. The wrench for a 2007 LE-I4 is 14mm, don't know what size your's will be.
- ramps, you already know about
- an oil catcher. It's a big container which catches the oil dripping down when you take the filter off, and when you pull out the drain plug. Probably about 10-15 bucks at an autoparts store.
The instructions to reset the maintenance light, are in your owners manual. Mine involves setting the odometer to a specific trip A, then turning off the key. Then turning on the key while holding the odometer button it, hold it for about 5 secs while the dashes count down. Your model may be different.
My filter is on hand tight the drain bolt is not over torqued, so I can easily get it off with a 14mm box wrench.
I put the car up on a curb on the oil pan side, (RH tire). Under the car I use a piece of carpet to lay on. I use a shoe box size plastic container to catch the oil, its $1.00 at Home Depot, comes with lid. When I remove the filter I have a spout made of cardboard to channel the oil away from the engine parts and into shoebox. I then use carb cleaner to spray clean the engine if oil got on it. Replace the drain plug with a new washer gasket and snug tight it. Put the filter on hand tight and add about 4.5 qts.using a small wide funnel.Place extra oil in cleaned out jelly jar. Use the same funnel to put the oil back into the 5 qt jug it came in or a gallon milk jug and recycle it.
First time kit; gasket for drain plug, drain pan, carpet, funnel, 14mm box end wrench, filter wrench.card board, 5qt oil jug.1 pint jelly jar.
When loosening the drain bolt, turn it in a counterclockwise direction. Same with the oil filter. Have the engine warm not hot to get better drainage. Just before removing drain plug put the drain pan in place. Put on latex glove to protect your hand from oil. Pull the plug out fast and have the pan under the bolt so it catches a 6 inch stream of oil to avoid a mess. Place bolt on lid. When drops of oil are all that's left, slide pan out of way and use the lid of the pan to catch drips of oil while re-installing drain plug. Have plenty of paper towels ready if you need to do any quick clean-ups.
Then move on to the oil filter. Loosen it a 1/2 turn and let the oil drain out of it. At this time I start to put oil in the car. When finished adding oil, I completely remove the filter. It may still have oil in it, so be careful not to get it all over engine. l usually let it drain some more after completely unscrewing it from its mount, before pulling it up and out of engine. Get new filter and rub oil around seal on bottom of filter. Install it hand tight. Spray clean engine with carb cleaner. Remove pan from under car. Back car off curb. Start engine check for leaks and re tighten if necessary.
The 14 mm socket size is correct for the oil pan drain bolt. If someone put it on too tight before, you may need to use your leg and foot to get it loose.
You can't drive a Camry over a normal-height curb without scraping the underbody. If you're going to use a curb, get the right front wheel onto it by driving over a driveway curb cut first, or use various-sized blocks of wood to make a ramp. Do NOT get under the car until the front tire is on concrete though and firmly chock the rear wheels! (And put the gearshift in park and firmly apply the hand brake.)
You won't be able to get the Camry's oil filter off by hand -- there's simply not enough clearance between the engine oil pan and the plastic splash guards under and behind the front bumper to get a firm grip. As Kiawah stated, you'll need the properly sized oil cap wrench and at least a 6-inch extension for your socket wrench.
But only hand tighten the new filter if at all possible. It should be turned 2/3 to 3/4 of a turn after the gasket makes contact with the oil filter mount on the engine. If you don't have enough hand strength, find someone who does OR gently tighten it with the oil filter wrench. Don't overdo it, or you'll find it almost impossible to get the filter off the next time, which is why hand tightening is preferable.
Check for leaks before driving off -- run the engine for a few minutes and look underneath for drips. I'd recommend doing the looking after all 4 wheels are on firm, level ground. Recheck the pavement again after you park the car overnight.
As you can guess from the above, I'd still recommend having someone else with experience to help you the very first time.
I gave my car procedure with only a wrench. His experience will differ slightly. He will need those other tools, in the previous post you gave. My filter wrench is a heavy steel with a spring loaded fingers that open to size of filter then grab on as you turn it to the left. The normal extensions and a rachet are needed though to use it. Its 3/8 drive. It never slips, bends, or breaks like the wrenches. Another thing like you said If the oil pan bolt faces the left side of the car I guess you could use your foot to loosen it. If its the other way around your pulling with both arms toward the front to get it loose, much harder. Our guy at Toyota used to use both hands and really press on the bolt when tightening it. He was 6'2 200# standing under the car when he did this.Crazy. I always said it only requires 20# torque, not the 45-55 he was applying.
I haven't seen a 2002-2006 engine yet. I know older Toyota's the filters are easy to remove and really accessible. It sounds like he might need to remove that plastic piece. Another tool. 10mm bolts? I remove mine when it is time to find oil leaks under the car. I use a sheet of bathroom wall board, its a plastic sheet a few mil thick, to cover the ground while I monitor it for hours while parked. It wipes clean when done.
Here in Vegas, there is concrete everywhere. The residential streets mostly have sidewalksright on the edge of the street, with drop downs at your driveway. I park in front of the driveway then drive slightly on the sidewalk keeping my tire right on the edge of the curb. I only do this if its a emergency and I cant get my car to my garage on level floor with AC, heat, lighting, and my heavy duty commercial floor jack used in pro garages.
I want to know what the first timer is going to do? To change or not to change. He has more than enough info I think. Dont want him to try the screwdriver hammered through the filter route, if the filter wrench dosnt work.
Thanks for your advice. I just finished on oil change and air filter. I'm going to work on cabin filter now but thought I'll take a break (and beer) and reply you all.
Stuff I bought (all prices are approximate):
Oil filter wrench - $3
mechanics tool box - $22
6" wrench extension
Oil drain can $3
Hydraullic Jack - 20
Jack stands - 20
Castrol GTX SAE 5W-30 can - $13
Mechanics gloves - $1
Wheel wedges - $10
Toyota Oil filter - 10
Toyota Air filter - 20
Bosch Cabin air filter - 22
Earlier, I bought short ramps and nearly crashed trying to get my car up. I'd strongly advise against using ramps; hydraulic jack and jack stands are much better and safer.
Everything was as I expected. Except it took less time and was easier than I thought. My old girl is back on her wheels and her whine is replaced with a soft satiated purr.. )
Thanks all.
I like the 2x10 idea. I'll have to try it out someday. Congrats on the oil change success. I never use my filter wrench again, but my filter is easy to get to, and spins off by hand.
As for getting the filter off, contrary to wwest's assertion, I CAN do this consistently every time with my Nissan Frontier's oil filter. It's hard to get a wrench on the filter due to its location, but I've found with rubber gloves on, I can get enough leverage on the filter to get it to come off.
And no, it does not leak oil from the filter base -- I do have some slight leakage from the 10+ year-old oil pan gasket though.
More than an "ounce of prevention"....??
Usually requires a wrench to get it off too.
After driving the car for 2600 miles, it died and had to be towed to the dealership that did the original job. They said they found a "failed crank sensor" which they replaced. The invoice said the following were also replaced: tensioner assembly for the timing belt, thread insert, and bolt.
Do you think the original job was not done correctly or is it just a coincidence that what was fixed the second time had do do with the timing belt.
Thanks in advance for your response.
Thank you for confirming my wife's and my initial gut reaction. We appreciate your response.
See you there!
Well at least I think it is a brake issue. Here's what happens. In the morning the brakes are either soft or normal (haven't figured out why the difference), as I drive to work and make the stops along the way the pedal starts to tighten up to the point of me barely touching the pedal and it is as if I were trying to do a quick stop. Once it gets to this point whenever I take my foot off the gas it is as if I were braking, and I haven't touched the brakes. Sometimes this condition will correct itself while driving and other times I am forced to stop the vehicle and turn it off in order to continue down the road. This seems to be getting more and more problematic.
I've checked the brake fluid and it is fine. All other indications are that everything is normal from my visual inspection (albeit an untrained eye).
So that I am not spending time with the dealer in trying to figure out what is wrong what things come to mind as to what is going on. I've thought of the master cylinder, but thought that it would be more consistent in is symptoms. I've thought there could be air in the lines, but everything I have read indicates that the brakes would be continually soft, which makes sense because the the ability to compress air. As I was looking into this I found that the car probably has proportioners, and this seemed to be a good fit for the issue.
Could any of you give me some further insight so that I can get this resolved with the dealer in short order?
Thanks so much!
You don't give any important info like how many miles do you have on the vehicle, whether you've changed the brake fluid, and most importantly whether you've replaced the front pads.
The pistons in brake calipers, are meant to float. When you apply the brakes, the pressure behind them force them out, to apply pressure to the pads to squeeze the rotor. When you take your foot off the brake, the slight variance in the rotor spinning should press/vibrate against the piston, allowing it to float back in. As the brake pads wear, the piston's normal working range is further and further out of the cylinder.
What can typically happen, is after a couple of years and if you don't flush brake systems, is that the brake fluid absorbs moisture and crud. That moisture settles behind the piston in the front calipers where it's hottest (they do the most braking), and can pit the cylinder wall. If you then eventually change the disc pads, the installer squeezes the piston back in to the caliper to enable the now thicker brake pad to be put in. When the piston moves back into the cylinder, the wall being pitted and the crud behind the piston jams up the piston, so that it doesn't 'float' freely any more.
So when you put the brake on the high pressure is able to overcome this resistance and the piston pushes out applying the brakes. However, the piston doesn't float back in when you take your foot off the brake. So then your pads are always rubbing, and the rotor overheats and expands. When it expands, the pads grip it even tighter, causing it to overheat and expand even more.
I think you'll find when you have this problem, that if you smell the front rims they'll have that overheating brake smell, and they will be VERY hot. Be careful you don't get burnt in touching them.
The fix is to replace the calipers, which is relatively cheap. I also replace the rotors and pads on my vehicles, as the rotor when it gets hot like that will warp and you'll have pulsating brake pedal later, and the pads are usually worn out. All of those parts are cheap to replace now adays, so to me it makes sense to just go ahead and replace everything and be sure to completely flush/bleed the system with new hydraulic fluid.
Welcome to Edmunds by the way; please note you're highly unlikely to receive a response from a post that's almost 7 years old.
Overall I like my 2005 LE Camry. The best car I ever own.
The noise varies in intensity from car to car and as you stated the Toyota technicians promise that the noise is part of the Toyota driving experience.
Too bad that Toyota does not still produce the 2000 Avalon (which I still own).
TomUSAF_Ret
My 2010 Toyota Camry with 1,500 miles has a clicking noise since day # 1. It would happen only once and after the car has been on (P) park and then shifted to (D). Exactly at 10mph as the car is going forward it comes the clicking noise from somewhere underneath the front by the wheels. The noise I would describe it as a clicking spring.
I didn't pay any attention thinking it's normal, but the clicking noise is not persistent meaning sometimes is louder than others but it's always there. It comes only once as I'm taking off and then is gone until the next time I park it again.
It's a brand new car and I called the dealer and asked a tech. He said it's normal due to the ABS adjusting itself as the car moves forward. I don't know about that, of course he said I have to drop it off to have it checked out.
I posted this issue on another Toyota enthusiasts forum and two replies said it's normal. By the way one of them seems to be an expert with Toyotas.
This is your ABS system doing an initial self test. It is documented in the owners guide.
If you want to absolutely prove it to yourself (which I did), you can have someone else drive the vehicle in the morning first thing with the hood up. You walk along carefully next to the vehicle, with your hand on the ABS pump up in the corner of the vehicle. Look for the thing with the hydraulic brake lines going to it. With your hand on the pump, you will actually feel it click when it does its' test.
For some reason it is very noticeable on a new car, but you should find as the vehicle ages, you will no longer hear it. I haven't heard it in a number of years on our 2007.
thx!!
Joel
Fuses in the circuitry are:
- 50 Amp Htr, in the fusible link block...it's up in the engine compartment on the drivers side fender wall
- 10 Amp Heater, in the cabin, by vehicle drivers left knee
- 10 Amp ECU-B (auto air only), engine compartment left fender wall
thx!!
Over all I'm very happy with my new Camry.
