Visitor Agreement.
The car has only 3200 miles and started to have acid like smell since 2750 miles.
I took it to the dealer and they spray something in the A/C. The smell
does disappear for a few days, but it comes back every time I turn on the A/C.
If I set to AUTO (cool air only), there is no stinky smell (well..actually it
happened once when it's on AUTO mode).
If anyone has similar experiences with the Infiniti I3X A/C, please tell me.
In April of '01 I bought an I30t with zenon headlights. Within a week I was back at Beaverton Infiniti (Portland, OR) to have them adjusted. They told me they were set to factory spec and I needed to learn to "live with it". The problem is that there is intense light within 10-15 feet of the front of the car, and then nothing. Turning on the fog lamps (even in the fog) does nothing because of the intensity of the beams immediately in front of the car.
My opinion is that the lights need to be adjusted up so they at least illuminate the back bumper of the car ahead of me at a stop sign! Driving in the dark rain of Oregon is like driving blind in this car.
Does anyone have any words of advice for me? Unfortunately there is only one Infiniti dealer in the area.
Jim J.
So anyone considering purchasing an I- may want to wait it out.
I think the service rep blew me off he said the computer shows all the shift limits are correct, the fluid is the right temperature and there is nothing wrong. When I asked if he drove it he hesitated and said yes and couldn't see a problem. He then said if it happens again bring in right in with out turning the engine off so he could check the computer codes.
What do you think! Sounds like BS to me
Craig
98 I30?
"How do I get rid of the musty odor from the AC system?
The musty odor is created for the moister and dust built on the evaporator (A/C system component inside car). If is a lot of dirt built up on the evaporator the only solution is to removed and clean. But you can also try to use the A/C system on "Econo" mode more often, especially 5-10 minutes before you turn the A/C off. This will dry out the evaporator and wont let dirt stay on it."
End of copy---me talking now. The evaporator is kind of like a sponge---if it stays damp too long it begins to mold & mildew and that causes a stench. I had this problem on another car (Honda) and found that running the heater for 20 minutes dried it out. Then I sprayed (non-aerosol) Lysol into the vents to keep it smelling nice for a month or so.
My general req's are reliability, ride comfort, smooth acceleration/passing power (in that order).
The Millennium Jade is pretty much the only annoying item... and should I just save a few $$$ and opt for a Maxima GLE?
at any rate, i complained, the dealer said the same thing, but i insisted they raise it, they ended up raising both of them way too high and i proceeded to get yelled at and flipped off etc.
went back, they 'put back at spec' and yet this time they were perfect, as opposed to the wacked out spec they claimed the lights to be previously
i will say the headlights are a little odd, if you pull up to a wall, you can see the spectrum of each headlight raises from left to right at a slant, if you're lights are not focused straight ahead, and/or are too low you're vision range is focused on the lower left hand range of that beam's spectrum
if you can get someone to set it right, you will be very pleased and won't get annoying gestures from other drivers
good luck
karz
noise (screeching) when we braked, so of course,
called repair place to find out what the deal was. We were told that the pads would need to be replaced with genuine Infiniti brake pads, because there aren't any aftermarket brands that will work properly for them. The person even said that this was verified thru Nissan. I find this very hard to believe. I thought that wasn't even legal for only a manufacturers part to be suitable for replacement AND work properly. I'll try and read through some of the posts in here to see if I can find my answer, but I would like some help here on figuring out what is fact and what is "fiction" in this situation.
Did you know it was basically the same vehicle as the other?
Why did you choose it over the other?
Please submit your response to jfallon@edmunds.com no later than Wednesday, May 15.
MODERATOR /ADMINISTRATOR
Review your vehicle
Car is mildly noisier than I-35, and handles like a real sport sedan. Back seats don't fold down to provide pass-thru, but have a mild recline feature. Has a neat +/- shift gate.
Priced similar to I-35.
M-35
I'm was thinking about purchasing an 99' I30t(55000miles) for $16,000 b4 taxes and fees. Is this a good price? Can anyone send me some feedback on this, it would be greatly appreciated.
PB
The skyline is one of the best cars in Japan and if we ever get the all wheel drive version, which they say will be out in early 2003, it will be a world beater. We'll see???
PB
Have you seen the Letter from the Town Hall Manager on the Town Hall Welcome page? If not, you might want to follow that link to have a look.
And hang on to your seats. Change is never easy - for any of us - but resolving the Search problems we've had will be worth the pain.
Pat
Sedans Host
Few weeks ago when I came back home from a short trip and ready to park and was backing up. Once I backed up I put it in Drive, the car stopped. The engine completely died on me. I try to restart and drive, same thing happened around 3 times. Then I started the car again and while in Park, I accelerated the gas pedal and it started and worked fine ever since.
After that episode, I noticed that once in a while the car hesitated to start while stopping on a red light(always in Drive mode) or stop sign.
The original problem occurred today too. I was waiting in a parking lot to park while someone was backing up. I have had the car in Drive mode. The engine died on me. I restarted and while in Park, accelerated the gas pedal and it drove well.
Anyone has experience the similar problem? What could be going wrong? Do you guys think this could be a transmission problem or fuel injector problem?
Any advice will be valuable.
I am planning on keeping the car for another 3 or so years.
Is the price of the Extended warranty negotiable? (Last time I asked the dealer I was told it's fixed.)
Please comment.
Anybody else had any experience of buying extended warranty?
I bought a 98 I30t with 26k miles on it in dec 2001 from the only infiniti dealer in town. I dont have very good luck with used cars and hence went ahead and bought an extended warranty from the same dealer with a 0 deductible for 4 year 60k miles, so basically it is covered upto 86k miles, upto 2006. Moreover, being a 98 model it was going to be out of the basic warranty soon.
I had done my bit of homework before making my purchase. Reliability was my top priority and this model has had good ratings.
However have been a few complaints from other people in this board and others, about problems with the sunroof and the stock stereo system on the long run. Fixing atleast one of these components would cost the total amount we'd invest in an extended warranty. In my opinion it was worth the money invested. My car has about 7k miles after i bought it. So far no problems.
The only problem i've had so far was the trunk opening intermittently while driving. The dealer replaced the whole trunk module under the original warranty (ofcourse, there was a TSB).
I'd go with an extended waranty, just to be on the safe side.
3 yr/ 45K miles from the date of warranty purchase at $1755. This is from the third party that they sell. It supposedly covers bumper-to-bumper with roadside assistance.
Infinity's warranties: 4 yr/48K miles extending existing warranty at $1927; and 3 yr/ 48K at $1691.
He claims that all these are fixed prices take it or leave it.
Is this sound right?
Jim
Paul
Now that the car is really getting old and has 90,000+ miles, the clunking is becoming more obvious. But there aren't many Infinity dealers left around Seattle any more. Just wondered if Infinity USA ever "fessed up" to the problem and what the fix was?
2nd issue, ck engine light, as blackhawk said, most likely is an o2 sensor, he was smart and tightened his, i don't know if i could have done that, but i know replacing mine did the trick, my light would go on for a few weeks or so and then shut off, even though there wasn't anything really wrong w/ it, this happened a few times over the course of my last 2 yrs w/ the car, it came on again right before i sold it, and this time made it to the dealer before it shut off, they replaced the o2 sensor for almost $200, and i sold it for $9,300 w/ 130k mi on it later that week
As for the clunking sounds, can't say I relate to that one
good luck, I got good service out of my 96 Max, and so far my 01 I30t is great
karz
