Visitor Agreement.
What would be a reasonable price for local mechanic to repair ???? Also should i let him switch to the standard coolant ! I'm at 80,000 miles so I doubt if GM would offer an $$$ assistance ! Clearly is a GM issue though.
I don't buy Fords due to transmission and A/c problems. May avoid GM because of the Dexcool!
Good thing there are imports ! Latest car is a Toyota powered VIBE with Toyota transmission !
Decided to try some stop leak first before going for the $450. replacement of gasket.
Now after putting in the stop leak the Check Engine Soon light has come on ???? Since he had torn down some of the connection to find the leak could this be a poor connection ??? Van seems to run fine !
Do these lights come on at a set mileage ?
I'm at 78,000 miles.
Could it be from the Stop leak ????
Will the light go away if codes are read then reset ? Tonights temp is expected to be -20 for all of you in the warmer parts of the country !
This van has been almost trouble free, only tires and a "Check Engine Soon" light about a year ago that only needed resetting by the dealer ($100, ouch!). Still running original brakes, I check them at the tire rotations, and they still look really good.
No coolant leaking, though my wife's 97 did have the intake manifold problem about three years ago, fixed to the tune of $800. We have also had the transmission rebuilt due to a bearing failure in the fluid pump. The horn on her van quit working a few weeks ago. Checked fuse, OK. Replaced the underhood relay, and that fixed it (only about 10 bucks at parts store). Another oddity on her van was last month when the wiper blades hit each other and broke one of them. I think one may have been slightly frozen to windshield and was slightly bent, causing them to hit.
I would again recommend that anybody looking for replacement tires consider the Michelin Symmetry.
Rides like a dream, fantastic treadwear, and very quiet. Only $84 at WalMart. Have them on both vans, couldn't be happier. Original General tires were absolutely terrible.
Mikey
A lot of the auto parts stores now read CEL codes for free - I wonder if they can reset the light too?
Mikey
Actually, if I could find a used GM van that I knew the intake gasket and water pump had just been replaced, I'd be more likely to buy it.
Our 97 with the replaced gasket has been fine for the last two or three years since then.
Mikey
Recalibration would be another ball of wax though and that didn't occur to me since I usually relate recalibration to the PCM (Powertrain Control Module) and other computer controlled stuff. Thanks!
I also found out that the A/C compressor was also replaced at 35,000 miles.
We have the towling package.
Not any other problems with this van however.
If you have oil dripping down, this is something else. Could be an oil pan gasket which is not serious at all.
Try to find the highest point on the engine where you see oil. Hopefully it is not the main seal.
Make sure that this leak is not transmission fluid. That might be the source of the noise your hearing when in reverse.
I had a noise coming out of the engine on my 97 that sounded like a water pump bearing going out, but if turned out to be a transmission pump!
(bad, very bad).
Mikey
-"they don't build 'em like the used to...they never have."
DD
No shifting into gear - deadsky! We have 37k on the vehicle, and have been informed that I am SOL without the extended warranty. For the life of me, I cannot locate any info on drivetrain or tranny warranties. I know the B2B warranty is only covered up to 30k, but do we not have a little more on the tranny?
Also, has anyone had any experience dealing with GM on getting them to share the pain? Suggestions comments, rants and raves are all appreciated. Thanks, Ted
Did trans give any problems prior to just not going into gear at all? Most problem auto trans that "go out" completely have problems--slipping, difficulty going into certain gears, noises, etc. before just suddenly quitting. If no previous symptoms at all, could be something external to trans, hopefully cheap & simple to fix. Does tranny fluid look good--proper fill level, not dark & burned looking/smelling? If you're good there, that could be a good sign.
Otherwise, gm should give you some sort of slack on repair cost if only 1000 miles out of warranty (what they should do & what they WILL do, I don't know!). good luck, keep us posted on outcome
I've got a new Silhouette with about 500 miles on it. Got our first major snowfall since purchased. I had no problems before the snow came along. But today, I'm hearing (and feeling) a fairly loud knocking noise coming (I think) from the rear of the van below the floor. It seems to only occur while on the gas pedal, and becomes audible at around 30+ miles/hour.
Also, the AWD disable light came on. I restarted a bit later and drove for 15 minutes and the light never came back, but the knocking is still there.
Any ideas? The only other symptom I've had is a slight burning smell once parked in the garage, but I've heard that's somewhat typical for brand new vehicles.
Broken window switch passenger side
bad rubber seal on driver side slider
That's it.
Complaints:
GM please make the middle row of seats slide back further! I can't put the drivers seat all of the way back with my 2 year old in the seat behind me.
Otherwise it's all good, this car is nearly as comfortable as my living room! Great mileage to.
After looking around underneath, I noticed the spare tire was not properly winched up, and it was swinging around hitting things!
The jack was also not properly stowed. I just figured somebody had a flat on a test drive and didn't put things back right.
Mikey
Anyway, as I was leaving, I noticed the "Service Engine Soon" light was on. I figured something must have happened during the servicing.
When I got home, I started poking around underneath the hood, and found that an electrical connector was not hooked up to the hose that conducts the filtered air to the engine. There is a small rectangular box with some electronics inside.
After reconnecting it, the light went out after a few minutes.
This must have something to do with the pollution control system. Since the hose has to be moved out of the way to get to the filter, they just forgot to reattach it.
Mikey
Based on what Pontiac and Chevy dealers (and Honda for that matter) were shooting me, I think it's a steal. Is it true that Buick is getting this van?
We experienced the dreaded intake manifold leak at about 45K miles. We also have had to replace the rear brakes. The van has had one recall on the door. The transmission <often> makes a loud clunk noise when shifting into gear, but no obvious problems. When turning the steering wheel hard to the left results in a loud clicking noise, no problem when turned to the right.
The General's were replaced at 32K miles with Michelin Symentry's - a great tire and well worth the extra few dollars.
We live in the Washington DC area. Mr. Goss (of Goss' Garage fame) broadcasts on the radio here every Saturday and Sunday. Just yesterday, he railed against the 3.4 L GM engine and the Chevy Venture. He cited coolant, long term life and safety problems with GM vans. NHTSA rates the Silo van a one star for offset crash testing -- yikes!
My question? Is it time to dump this baby before the tranny, steering and other systems go nuke on me? A Toyota is a potential - I know several folks that own Toyota vans/cars/SUVs - our GM problems don't seem to happen to them!
Still lovin Olds, but wandering (er, wondering)
As far as longevity, there is no reasonable measure. I could say the music teacher our town's middle school has over 225,000 miles on his 1997. Does that mean you will? "I" think there is plenty of Olds lovin' in your future, but if your are unsure then go looking now.
The newer toyotas have a tendency to sludge up the V6 motors unless you use a synthetic oil or change a lot. Some change they did to the head from what I read. Toyota is replacing a lot of engines. you can scan these Edmonds boards for tons of info on that.
I'm not totally in love with my 3.4 but once you get the intake fixed, I think it will provide a of service and great fuel milage. A well used vehicle also saves on insurance and deprecition, and your kids are going to trash it anyway. You can get places that will sell you a replacement rug if you need to, and still not have a car payment.
A Honda would be nice but I couldn't get one without nearly doubling my paid price on a used 98 GLS with everything.
Agree with the poster on offset crash. How can it be top rated in front crash and not do decently in offset? The test results vary. The olds has side air bags, you're more likely to get hit in the side I'd guess.
Tires are the biggest handling improvement you can make! Love my michelins, even if they are a France based company.
DD
What bothers me about my '03 Sil is the amount of rattles. The van drives and handles very well and is very comfortable for both driver and passengers. It just seems to me the build quality could be better. Maybe GM will get it right for the next generation?
About once a year, I spray silicone lubricant on the door seals and wipe them down.
This stops the noises.
Mikey
The van has 78000 kms (40,000 miles)
good luck
You are right and I was wrong. Pat Goss of PBS Motorweek fame hosts a very good radio call in show here in Washington on Saturday's and Sunday's.
His rap on the GM vans regarding safety is the IIHS Offset crash - nothing to do with NHTSA frontal crash. The IIHS 1998 Silo rates a poor, the Toyota a good (the best possible rating).
I'm hoping to keep the van for 100K miles, my wife is a safe and sane driver, she puts about 10K on the van every year. I hope that with frequent fluid changes, the van will make it.
Since I was saving money on the tranny, I had them do a full tune-up on the van. That ran me about $394. I also had to replace my 100k mile platinum spark plugs, since 3 of them were fouled. So, is that becuase I use Arco gas, or is it because the plugs do not last 100k miles. In any case, be advised that the 100k mile spark plug claim is not a warranty and they are not guaranteed! It cost $125 for the plugs alone!!
On the ride home, the car hesitated an bucked a little. The dealer was already closed, and I was figuring that this was because the van was on empty...hey guys, couldn't you put a gallon or two in just to keep the crap from foouling my new platinum plugs??? After I gassed up, I still had a lurching in the engine. It was not the tranny, and I figured that the fuel line was clogged or something. The next AM, the engine light came on. Back to the dealership and two more days without a car. Turns out that "they missed a spark plug wire". I couldn't get any more out of the tech and he was not there when I picked it up. I did not get to inspect my parts, but then again I did not ask too and they were closed...but then again - I did not waive my right to inspect either. So, let's just say that the dealership is nice and friendly, but the bottom line is that I am having problems trusting the quality of the product, as well as the workmanship (dealer and GM).
I am not sure if I mentioned this, but we purchased the van and the alero at the same time. The first month we had the alero, it was in the dealership 4 times because the engine light kept coming on. They told me it was because I was not closing the gas cap correctly (it requires three clicks minimum) So I gave 10 or 50 to make sure...still the engine light came on. After having the car in the shop 4 times, they finally replaced the gas tank. That solved the problem. Customer service??? Not really, just a lot of customer PATIENCE!!! I never once received a loaner car (and I did ask) I have worked in their waiting room a total of 20-30 hours in the last 3 years. That sucks folks.
As far as passenger comfort, well I have had no complaints even with seven adults on board. The back seat folds flat and out of the way. It has come in very handy during the move to our new house back in February. While it does not have the hide-away feature of the Japanese vans it is still very convenient.
In all I would rate the Silhouette a 9.3 out of 10.
Since the brakes disengage the cruise, it needs a completed circuit to work properly. If a bulb is out, the circuit is broken, and the cruise becomes inoperable. This may be a safety related thing.
It's also good to know that your CC works, all of your brake lights work.
Mikey
My fuel gage has stopped working. It always registers full. When I turn off the ignition, sometimes it moves to the correct level and sometimes not. When I start the engine it always returns to full.
Any one have any idea where the problem is? Sensor, relay, ????
I don't understand the infield fly rule either. Or most of the rules in hockey.
Mikey
Ain't it the truth! As a layman/shadetree mechanic who has progressed, over the last 25 or so years, from working on old late 60's/early 70's Fords & such, to late 70's/mid 80's Subarus (all of which were relatively simple to work on & figure out), to now trying to figure out my 01 silo, let me just say that looking at wiring diagrams/schematics for these late model vehicles can leave you way more confused than before you opened the manual!
its good info to know about that odd brake light thing though
I am new to the van world. Tomorrow,Saturday,June the 7th. I am going to test drive and look at a white,2000 model with almost 40,000 miles. Any suggestions will be appreciated. Need a van for the family is growing and have limited income right now. Is this year good? Any recalls you know of? Thank You. What price seems reasonable for this clean van? Only 1 scrape on lower spoiler below bumper from a dip probably? What should I check for as to most problems associated with this van? If anyone knows?
I have a 1999 Silo and with 81000 kms - (approx 50,000 miles) and these are the issues I've had with mine. These appear to be common to the Venture, Montana and Silhouette
INTAKE MANIFOLD GASKET
Most of these vans develop leaks (both external and internal to the motor). Very expensive to replace. Check and see if this one has been done.
Cost $100 - GM offered assistance. Actual cost was $700
TRANSMISSION PROBLEMS
My torque converter went at 75000 kms and so did a selenoid. Total cost with GM "goodwill" assistance was $600
FUEL GAGE
Stopped working recently. Starts to move off full when the tank is about half full. I haven't fixed it.
Norm
I like the van very much. It runs perfect, rides good, lots of room, good gas mileage. Mine is the Premiere with all the bells and whistles. The TV/VCP is a lifesaver with small children.
Basically I think these vans are good. Maybe they aren't as "perfect" as Toyota/Honda/Madza, but they are also less expensive. Right now I would say I would buy another one. There is also a huge, emotional debate about safety. If you desire you can read dozens of posts about how safe or unsafe these vans are. The more you read the more confused you will get. Good luck.
The others van aren't perfect, they have their fair amount of trouble, tranny, sludge etc etc.
On the safety side, understand that if you reproduce exactly the NHTSA test on the road that you are going to die. Other than that,you can have all kind of accident and you dont have to worry since it is the the van with the best records in regards of insurance company.
I'll say go with it, it's a great value
Bob
