Pontiac Bonneville
Welcome to the continuation of the Pontiac
Bonneville topic. Those of you joining us from
that topic are welcome to continue your discussion.
If you're new to this topic, you may want to
follow the above link for additional archived
posts.
L8_Apex
Sedans Host
posts.
L8_Apex
Sedans Host
Intense and dmckeown are both mia. I'll shoot them an email and see what is up.
Let's see - I've been driving my new SSEi about four months now, and I have 23,000 miles on it. The new Michelins already have 20,000, believe it or not.
So, who's going to be the SSEi exhaust guinea pig?
I laid under the car and did the rough sketch. I was hoping someone else would have reworked his exhaust by now...
I've got an idea on Cold Air. I saw a Mustang the other day with a cold air inlet scoop tucked right in front of the front air dam. We could do something like that, starting right under the left driving light. The oval or rectanglar shaped hose could go back about a foot (maybe less, can't remember) and then take a 90 degree turn and go straight up. From there it could go through a low restriction airbox of some kind (maybe from an LS1 T/A), and then take another 90 into the Throttle Body/Mass Airflow Sensor. I think the results would be simple to construct, and produce very cold, unrestricted airflow. What do you folks think of this concept?
Headed away for vacation in a week. Hopefully when I get back I can finish my CAI.
"Nope, we're not replacing the alternator under warranty because this exhaust system isn't stock."
The modified exhaust system won't be under warranty, and anything (emissions control, ect,) it messes up won't be, but everything else should still be covered.
Just FYI
I bought a 2000 Bonneville SSEi and love it. I touch to much body roll, but I am taking care of that.
Should say "I drove a LeSabre..."
and "A touch too much body roll..."
That the english problems. Grammar?????
We had some cold mournings recently here in upstate N.Y. Last week it was 42 deg. out at 6:00 am and Bon was unbelievably responsive . At a stop a new Audi A6 was a head of me and with no other car's around he really got on it . Sorta got me in the mood so I pulled out and when I saw 24 mph on the heads up I thought I was safe to floor it but she brook the tire loose big time and I had to let up a bit , it must of been heard by the guy in the Audi cause about a half mile away we entered the expressway on ramp he really took off .I was happy to see no other cars any where so I went WOT and Bon had him by the end of the ramp , three big green digits on the windshield . I let off , set the cruise and watched him keep going . I had just filled up with 100 octane the day before so it was a little skewed in my favor . Intercooler is needed here
Snickle - how is the platinum injection working ?
I rented a 2001 Grand Prix while vacationing last month and experienced the same driver's side mirror vibration and steering column noise; must be a 2000/2001 Pontiac thing. My dealer (who is very good) stated that the mirror can't be improved and they aren't going to take apart the steering column unless there is a functional problem. I've learned to live with both.
Before you put the new bar on, go out on an empty highway and do a few transient response tests (super quick lane changes). Note how much understeer and body roll you have. Not bad for a four-door.
Now go home and jack the rear end up plenty high, and set up a couple jack stands.
The old, small, hollow, wimpy, rubber jointed bar comes out in about five minutes.
The new large (hope you went with the 1"), solid, polygraphite jointed bar will slide in with some jiggling and wiggling.
Use pliers to compress the frame mounts together before trying to bolt them on.
I had to invert the end link bolts to get the nuts started.
The whole job will only take an hour. In my opinion, this was a GREAT INVESTMENT. Low price, easy installation, serious performance enhancement, and no side effects.
Go back out and redo the transient response tests. You won't believe the difference. Mine feels like a different car!
I've had my 2000 Midnight Blue SSEi since March and love it. No real problems yet other than slight door panel squeaks that don't seem to happen in the Florida summer heat, but will probably be worse when (if it ever) gets cold. Also noticed that the side mirrors don't always return to the programmed position when unlocking with the remote of Driver 1, but will when the door switch is pressed. Still a blast to drive, although I think there is too much torque steer off the line. Can't get enough of that great Bose sound system.
Sway bars for a SE should not be a problem. Still a G body. Just don't go with a 1" as with you smaller front, you would get oversteer. Unless you swap both.
You do not have a rear. Your front is 20 mill I think.
The new one took some work to get in place, would be alot easier with a lift.
Got the 1st clamp on no problem, left it loose.
Manage to cross thread the clamp bolt on the other one and mess up the bolt and the socket. Tried to switch the bolts between side an force. Dumb, Dumb, Dumb!!!!!!
No both bolts and both sockets are messed up. And I do no have a tap and die set the right size. I will call the dealer tomorrow to see if the have the bolts and then try to track down a tap.
My 2000 SSEI is also Midnight Blue (with dual thin gray pinstripes). I also have the door panel squeaks and the same occasional non return of the driver's mirror. You are right that it will return with a touch of the switch on the door. It is a blast to drive but does have torque steer off the line (lots of power for stock front wheel drive). I agree, The Bose sound system is awesome!
Since I was so disappointed in the Bose system (no upper door panel tweeters) in my '97 SSE, my standards were low. Compared to that system, this one is fantastic.
Approx 10% improvement in case mileage.
Autotap readings are suggest improvement in KR, but hard to tell for sure without back to back testing.
I'll keep the unit for a while and let you know.
Hopefully I can get the new bar on this afternoon.
I got new bolts, and a tap.
When I get back I will put on the new front end-links.
Doug - You need to replace your rear sway bar. You will love it.
And...
Got to a 3.5 pulley. They will never know. If you are really conserned, swap it back before you return it.
You would love the increased performance.
Why don't you do a couple 'logged' runs with the Autotap, and see if you can do better than the previous numbers you submitted for horsepower and torque. I think that will be a truer test...
CD player in my 93 SLE finally died . Called the used parts places and they didn't have a CD deck . Called United Radio and they would replace it with rebuilt unit for $195 ,one year war. and 48 hour turn around . Went to take it out and the thought hit me to disconnect the battery to reset codes. Sure enough that fixed , at least so far . Always try the easist thing first . Trouble with CD deck started after I had to jump start car , and got worse as time went on .I wish I had tryed this earlier
As far as tips go: Intense's were pretty good. Mods I would make are as follows:
Put the rear up on jack stands.
Pull the current bar.
Put a jack under the driver side rear wheel and compress the suspension. Insert the new bar.
Attach the frame clamps Finger start the bolts.
Attach the endlinks, but don't tighten.
Lower the car anbd tighten the endlinks
A little more detail water injection would definetly help KR. Well proven technology.
Platinum vapor is definately a little questionable, but the basic chemistry/physics is sound. A catalytic convertor is basically a platinum coated muffler. Platinum does affect cumbustion. The big drawback to this system (assuming it does anything) is it relys on vacum from the TB to draw the vapor. Not a real consistent volume.
It seems to me that when I drive gently my mpg does increase beyond normal for the change, lots of throttle does not show the same improvement, but power seems better.
I will try to get real number, but it is not an easy change to test before and after, without showing lingering effects.
