I've never been denied a warranty service claim on many new cars I've owned.
But now, I am not so confident that these Korean warranties are worth anything at all. Which is a shame since that is why so many of us bought the Korean cars in the first place.
The other things you wish for would add cost to the car. I like the car very much just the way it is for the prices at which it can be bought.
Amazing car for the $.
Period.
I agree that the warranty is clouded by a "smoke screen". I don't blame Hyundai as much as our government for allowing such deceptive wording to be used. Have you ever heard a TV add for a car? The speaker speaks very clearly until he talks about the "small print". Than they speak so fast you can't understand anything. Printed material is the same. The small print is so small that even with a magnyfing glass you can't read it. I never hear anything except 100,000 mile warranty. 5 years 50,000 miles bumper to bumper. What exactly does that mean? Isn't the radio, cd player, battery, seals, adjustments, etc, etc between the bumpers??? Many words no longer mean what they say except "let the buyer beware".
I have XG30 and I change the spark plugs last week. It is a job you need to remove the intake manful to get to the back side for the other 3 spark plugs. It has and electronic spark discharge and you only need 3 wires that go from the front to the back. Good luck and take care
Phdrashed
I want to collect as much background information on this problem before the car goes in for its 3200 mile checkup.
Any help to translate this phenomenon into mechanical terms (that the service writer or mechanic would understand) would be appreciated.
BetterSafe
BetterSafe
I had several people approach me and ask if it was a Daewoo. A pleasant loaner, but I can see why the sales of the XG were lackluster over the past few years.
I hope you enjoy your Sonata.
BetterSafe
1) turn car eng off.
2) Turn eng key to start; BUT,do NOT start the car, then turn off.
3) Wait a few seconds (15) should hear a click that appears to come from the glove box.
When this happens the fussy- box is reset. You may need to do this servial times to reset the box.
The second time this problem happened I took the car in for them to check out. They found no problems or error codes. It has happened several more times. I called the dealership again, to report the problem and see if their was anything they could do. They were willing to check out car again but that was all they could do. I was trying to get problem fixed before it caused me to have an accident. The dealership suggested that the problem be reported to HYUNDAI MOTOR AMERICA (1-800-633-5151). This I did. HYUNDAI said to have the dealer check out car again. This I did. The dealership checked for error codes and test drove car. They found nothing to indicate any problems with car. I called HYUNDAI MOTOR again and reported the dealer's findings and wanted to know what else could be done to resolve this problem. They said that I should leave the car with the dealership to drive until the problem reaccures, which could be a short time or a long time (hours, days or months). HYUNDAI MOTOR
said they were willing to fix any defects with car, BUT, would do NOTHING until the dealership experienced this problem in MY car. I hope you have better LUCK at getting this fixed than I did. You should report this problem to the dealership and HYUNDAI MOTOR AMERICA (1-800-633-5151). Maybe if enough people complained they will look into fixing this problem. I know of at least one other XG350L from this dealership that has this problem also.
But if it does, I can imagine Hyundai will have a hard time defending the lawsuit if enough owners have the "unfixable" problem.
BetterSafe
The XG is so complex with computer technology, there could be several factors at play. Since the XG has drive-by-wire fuel control, there are several possibilities: 1) the computer is being told bogus information about the position of the gas pedal. 2) the computer commands to the engine's throttle are being ignored. or 3) the computer algorithm is flawed. or 4) the computer itself is flawed.
If I ran the service shop, and I had an irate customer, I would replace the accelerator position sensors by the gas pedal first. They are most likely to get wet and dirty, and most likely to be bumped by shoes /canes / packages / dogs / cats / etc. {My cat loves to snoop around the gas pedal for some reason.} If that did not fix the problem, I would change the wiring from these sensors to the computer. There could be an intermittent wiring fault that was random, or temperature sensitive. If that did not fix the problem I change the throttle control valves which are operated by the computer.
Since the dealer cannot recreate the problem, the solution may require you to record every detail of when the car misbehaves to try to get some correlation. And the next step may be to complain, and complain, and complain until something is done. Ask to speak to the regional service rep. Ask to speak to the national service rep. Join every Hyundai web site and forum to give voice to the problem. If my car was seriously misbehaving, I might even offer to pay for the replacement sensors if the dealer would pay for the time to replace the sensors.
I now have the habit of starting the car with both feet on the floor. (i.e., neither foot on the brake or gas) I then tap the gas pedal and insure the RPMs move. Then I put the car into gear, normally reverse to back out of my driveway or parking spot. The problem has not reoccurred in two months. Trying to debug a problem on my vehicle would be nearly impossible if it only happens once per two months.
Hopefully this will not be like the transmission hesitation problems reported in Toyota/Lexus forums, where very little has been done by the manufacturer for several years.
I wish you success.
BetterSafe
One odd thing about your story, which relates to my experience, is that the problem did not happen after the initial start of the morning. In both cases, we had started the car, driven for miles without any problem, parked the XG in a store parking lot. . . . . did some shopping, and then returned to the car. The problem happened after we backed out of the parking spot, and tried to go forward in the parking lot. Backing up is ususally done without any gas pedal pressure. The car normally backs up by itself. In both cases, the engine should have still been "warm" and ready to go.
Do your problems happen first thing in the morning or after a bit of driving?
Back to another point. My car still lurches/lunges several times a week. I can only wonder if the cause is the same as the problem so many of you seem to have with no power. Something with the electronics?
Thanks for all the interest in this problem and I only hope that Hyundai will be a big enough company to offer a recall on them soon.
What is 15 months of depreciation on an XG350L ?
Probably more than $1248 is my guess, but then again, your dollars are worth less now than those paid back then. Its always nice to buy with cheaper dollars if the price does not go up.
The rebates are: $3000 from Hyundai, $5000 from dealer.
The car was a demo one, with 3251 miles on it.
I am not qualified for any other discounts.
It is a new car, and the color is my favor one, bright silver.
Also, due to the inflation factor, it is supposed to be more expensive than 15 month ago.
Or, said another way, if the January car was traded in the day after it was bought, it would be a new model year car with less than 100 miles on it compared to other cars for sale at that time. If your car was traded in a day after you bought it, it would be a fifteen month older car with over 3000 miles and not be as new compared to other cars on the market because the 2006 models are out, and even some 2007 models. I am talking about depreciation due to time here, not only miles. Get it?
And yes, I understand that your car was "new" at purchase since you are the first registered owner, and that you probably negotiated for a full factory warranty too (to 63,000+ miles and 103,000+ miles?).
I already touched on the dollar devaluation (inflation) issue in my previous answer. So far as car sales go, the devalued dollar has not hurt U.S. buyers much yet, since other nations are also devaluing their currencies to gain or maintain desirability of their exports.
The silver is a very pretty color on the XG.
Was the 10,000 off of a 350 or 350L? Where did you see this ad? I am looking for a 350L right now and need to know the best price it is selling for. Thanks
I'm on my way to arbitration...any advice?
