I live in WI and its currently around or below 32 degrees every day. Twice now when I go to start the car it starts and idles at about 2000rpm. Typically when it starts it revs to 2500rpm for a few seconds and then goes down to 1500rpm.
I have no response fromt he accelerator pedal. After it runs for a few minutes and I start and stop it a few times(up to 10) all of a sudden it works normal.
I am thinking its a sensor failing? Any ideas? I have been reading about the throttle position sensor, where is this located and can it be changed easily?
I am a maint mechanic and wrench on my own junk all the time so it shouldn't be a big deal, just looking for pointers. Oh yeah, I dont have a code reader YET:)
mudnstf
Meanwhile, I found that during the symptoms you described I could get it to return to normal by some pretty heavy pumping of the accelerator pedal a few times. Eventually the tach started responding. and I was able to drive away.
The car has a "drive-by-wire" system which I think has been a bit troublesome.
Good luck!
I can locate the general area of the dash rattle but have no idea how to fix it.
I have not taken it to the local dealer here in Fort Myers, first because it is not under warranty and second I don't trust them. I have no doubt it would be a very expensive fix if they even knew how to fix it.
"I have a 02 xg350l and in the maintenance log in the manual it says to replace the fuel filter every 52,000 miles.Took it to the dealer for regualer check up they said it is a part of my fuel system wich meens it is perminant or it would cost $500 to replace.Seems odd it would say to replace it in my owners manual when they say you dont need to or they are wrong. Can annyone explain? hit me back if so"
It shows how to replace the fuel filter in the online service manual:
http://www.hmaservice.com/
The service dept just keep blaming me saying I am causing the problem becuase I must not be driving right (riding the brakes) Give me a break..I have been driving for 40yrs and owned many cars and never had a problem like this.
My question is...has anyone ever had luck with Hyundai addressing this problem with owners who are continually having this problem? Now that the car is out of warranty..I am not a happy camper .
I'm not a mechanic..but can you change out the brake system to use the 12" rotors on the older XG's that had the 10.5 in?
Or is this something I am just going to have to live with?
I have 2001 Hyundai XG300. The engine light is on and I took it a workshop and was told that the code is P O--715. Please, could anyone explain the meaning of this code and what I should do? Thanks for your input.
I have been a proud owner of an 2001 XG300 since the past one year and never faced a problem. however, a couple of months ago, my malfunction light came on. I took it to the dealer and got it checked, but it had gone off by then so was asked to come back when it came back on. about a month back, i started having the problem, where the engine seemed to jerk when the car was at halt but in the drive position. when the light finally came on again 15 days back, i took the car back to the dealer and he told me that there was a problem of cylinder 4 misfiring. paid a 170 bucks for a new recoil for cylinder 4. but the problem of jerking persisted and since no light was coming on, i was told to come back when the light comes on. It came on a couple of days back and took it back to my dealers, this time, the car gave the following errors P1191, P1193. with the messages
Limp Home System Fault and Limp Home on Low RPM. I couldn't get a quote of what was to be replaced as the place was shutting down and have been told to come in next week.
Could someone please tell me exactly, if they faced the same problem, what could the problem be, what part needs to be replaced and perhaps how much would the past cost?
Amit.
Another mechanic told me it sounds like a fuel pump.
Any ideas what it could be?
Here is my main problem while Im driving doing about 4050 it bogs down like its going to stall then it kicks back or if I lay off the gas and it runs fine. Sunday, it finally died on me and wouldn't start until I put more fuel, once I added fuel it drove for about 3 blocks and died on me. I had to get it towed to the shop.
THANKS AGAIN!!!
If we don't start the car every day, the battery will be drained the next day. Have taken it back to 2 different Hyundai dealers, both just replaced the battery. Both said nothing could be found as far as the why.
Did anyone else out there deal with this problem? It's getting old.
The latest problem I have with my car is a stumper. I first noticed it while taking a gradual right turn (about 30 degrees) at about 65 mph. The car lurches laterally, as if a wheel is loose. After testing at different speeds, with no passengers, this shaking starts at 60 mph; nothing at 59 or less. If the right turn is steeper, the shaking occurs at a lower speed. If the turn is a left turn, I could go 90 mph (haven't tho) with no shake. The problem also shows up when there are more than 2 people in the car. In this case, I don't have to be turning or be going more than 50 mph. An imperfection in the road can cause the car to start rocking, not violently, but enough for someone in the rear with a weak stomach to start getting car sick.
I brought it to Hyundai for service but no luck. They don't see anything broken and advise me that it could be quite costly to search out the problem. I also went to Firestone, where they basically gave me the same answer.
Has anyone ever had a problem like this, either in this car or some other ?
DETAILS OF MY PROBLEM .
Thursday 7/2/2009 . I drove my 2004 Hyundai XG350L to a golf course 70 miles from where I live. The car sat in the parking lot for 6 hours. I got into the car and started it up, let it idle for 5-10 min to let the air conditioner cool the interior down and drove down the exit driveway ( 1/8—1/4 Mile Long) from the golf course at 10-15 MPH. About 100 yards before reaching the junction of the golf course driveway and main road the car stopped running and coasted to a stop. I tried to re-start but car acted if battery was dead and would not re-start. After waiting approximately an hour, someone with jumper cables stopped and tried to re-start us. No luck. I called the local Hyundai dealer, Riverhead Automall (631.369.2550) on Route 58, Riverhead NY. The car was towed to their location at 6 PM.
On Monday, 7/6/2009, I got a call from the service department at Riverhead Automall stating that the cost to disassemble my car to evaluate the repair would be $300. I asked the service person, Donna, about the warranty. She made the following statement to me, “The 10 Year/100,000Mile does not apply to you since you are the second owner of the vehicle. Your warranty, since you purchased the car in May 2008, was for 5 years or 60,000, and that warranty expired on 1/26/2009 (158 days ago).”
On Wednesday 7/8/2009 I got a call from the dealer stating that the timing belt was damaged due to water pump failure (locked up, as she described it) and that the cost to repair my car was going to be $1,800-1,900 BUT due to the nature of the damage to the timing belt, they could replace the parts but would not guarantee that the car will run after parts are replaced. There could possibly be valve damage, head damage and more. They would not know until the first $1800-1900 repair was done.
After speaking to other automotive technicians, both Hyundai and other brands, about Hyundai dealer technician not knowing if other parts are damaged I was told the following... All the technician has to do is to attach a breaker bar to the crankshaft nut , turn slowly and they will know if there is valve or head damge right away with NO expense to disassemble.
I immediately called :
HYUNDAI MOTOR AMERICA
National Consumer Assistance Center
10550 Talbert Avenue
Fountain Valley, CA 92708
800.633.5151
I spoke with a consumer assistance manager by the name of Ryan, and I covered all of the issues stated above. They assigned me a Case # and he told me that basically the warranty had expired 158 days ago and that they could not help me.
Having NO OTHER CHOICE, I called the dealer and told them to proceed with the timing belt repair $1800-1900. I gave them $1000 deposit to get started. They disassembled the timing belt portion and ordered the parts.
Once again I called HYUNDAI Motor America and spoke with another manager, Matt , to plead my case again. NO change in their decision, out of warranty by 158 days.
On Friday 7/17/2009 I got a call from the service writer for Riverhead Automall. She stated that the timing belt had been installed and she had bad news, the valves were bent in the heads and there was a possibility of piston damage. It was devastating news to me.
I have been unemployed for the last 11 months. My wife works and that’s how we have survived for the past 11months. I have made every one of my car and insurance payments on time.
When the dealer wanted $1000 to proceed with the examination of the timing belt I used all the money I had to give them $1000. I can’t pay my car payment now, I can’t pay my insurance payment now.
If the warranty won’t cover this total repair $3-5000+, I have no choice but to call my car finance company, tell them that I can’t pay and they will take my car from the dealer. They will sell this car at auction for whatever they can get, and then look to me for the balance. I will have no car, no way to get another car, my credit will be ruined even though I made 14 payments on this car. I can’t believe that because I bought a HYUNDAI my life is in financial shambles.
Why I Think This Should be Covered By Hyundai Warranty ..
After extensive internet research in consumer blogs about HYUNDAI and consumer problems with the “interference” V-6 engine from HYUNDAI regarding this very same repair, and after speaking with another (not this dealer) Hyundai service manager, Hyundai parts manager and Hyundai auto technician and other brand automotive repair professionals I can only make the following statements:
NO automobile with 39,900 MILES should require a $2000 (PLUS much more expense $2-3000 for valves and head ) mechanical repair of any type.
ANY BRAND AUTO .Water Pumps do not fail in 39,000 miles unless there is a defect in part design or manufacturer.
YOUR Manufacturers Warranty states that timing belt should be replaced at 60,000 miles. I didn’t get that opportunity; mine broke at 39,900 miles due to no fault of the timing belt, but due to the water pump failure.
When the car was sold NEW, the warranty was 10 YEARS/100,000 MILES to the original owner. Just because the car title was transferred to me as second owner that warranty is gone. NOTHING ELSE CHANGED EXCEPT NEW PAPERWORK WAS CREATED. That was a very deceptive marketing practice on the new car end.
In closing, I think that any reasonable and logical person would determine, after looking at the facts of this case that this just shouldn’t happen to ANY brand of automobile with only 39,000 miles.
shifts in and out of 4th gear. Does any one have any info on this problem?
Thank You
I have a GX300 with about the same mileage on it. I love it but I have had some problems. The worst was the engine cradle (the frame under the engine) had to be replaced due to rotting out. I do live in a winter wonder land where road salt is the spice of life. I've had problems with the ECM module causing windows to be inoperative and just put new wheel bearing in the front end. New brakes all around, but that is just normal wear and tear. The car seems to bog down on occasion and the check enigine light is on quite often, but otherwise runs very nice and smooth 95% of the time. Keep in mind you'll have no warranty other than what the dealer gives you. Sometimes my radio does squirrly things as well as the CD player, but not enough to get excited about it. Be sure you have a good Hyundai dealer where you can get proper service done or all bets are off.
Rog Dog
although my car is in the shop now.. i was told i blew the engine.. but i'll tell you what this car has been nothing but a complete nightmare from day ONE!!! BUT JEEEZ ... i just cant help myself.. i'm Sooo in love with my car... i'm trying to scan all of the entries about lemon laws and radiators and fan systems .. because mine constantly went out and caused my car to over heat.. then one day last oct i was on the freeway and it just puttered to a stop... thee end! well radiator was blown because the fan assembly system quit.. again!!! the 3rd time! the first year i owned the car.. i couldn't drive it for over 6 months! the battery was shot AND the alternator had to be replaced.. and i had mad issues with the computer system multiple times!!! i'm going to gather ALL of my service records .. and see if i cant get something done about this! there is way too many people complaining of the very same things as me and they got a refund!!! lemon law here i come!
