Visitor Agreement.
AeroAV8R
I went to www.saabusa.com and did not see any references to ED. I thougt tha Dhanley might have bought his Saab via European Delivery. Can anyone point me to websites or provide deatils?
Hope this helps.
The Saab dealer has been very helpful, and just today replaced the ECU with yet another unit. Still now have the problem. Next step will be to try 93 octane, but I shouldn't need to do this. Do any others out there have any pre-ignition ping problems with the new ECU module? Maybe my dealer has a bad batch of replacements? Any other ideas/suggestions.
Thx. Rich
I don't know if Saabs have the sensors which automatically retard timing when detecting ping. If they do have the sensors the car shouldn't ping.
I have a 2000 9-5 and I usually run 89 or 91 octane but I tried 87 for one tank. No pinging but it didn't perform as well under heavy throttle. Hope this helps
A little pinging under initial heavy throttle is OK though, it takes a second for the car to adjust to changing conditions.
to jeff: 2-3 seconds of lag sounds like too much for the 2.3L, on the 2.0L it's normal though, unfortunately. On the six, it should NOT be present. If your '99 9-5 a manual transmission? This helps a lot!
dave
AeroAV8R
I'm seriously considering leasing a base 9-5. I'm concerned that by adding 15 hoursepower this year someone may have mucked something up. Is there anyone out there in Saabland, USA, who can simply confirm that they purchased a 2001 base 9-5, and that it works fine and is a blast to drive (and maybe even that it lays a patch taking off from a stop). Thanks for your input, Jeff
I do have to say that the pinging I've had is very slight and only heard with windows open and accelerating hard up a hill. Experts have told me that this "limited" pinging is not a problem. With BP Premium I NEVER have pinging.
I remember many years ago BMW did a study on the fuel quality of various brands. BP was the only brand that passed on all three grades. I didn't beleive it until I experienced this problem. I went from never using BP to almost always using it.
Bottom line- you may want to consider what brand of gas you've using before you have another ECM installed. Have you switched between brand?
Hope this helps
Drew
AeroAV8R
Doug
I am assuming that they also replaced the gas cap since that might be the source of the vapor leak. If not, I would make sure there is a good seal at that point.
Dave Kovacs
sirpoon, this sounds like the gas vapor removal system which is a component of the OBDII specification. This problem occurs on all premium cars and is actually a feature and not a bug! The system will register a fault if you don't put the gas cap on tight (happens often at full service gas stations, top off the tank with too much fuel, or fuel the car with the engine running. The 'Check Engine' light will reset itself automatically with a few days of typical driving if it doesn't encounter another fault. Have any of the abovementioned conditions happened to your 9-5 regularly?
-rdo
rdollie@home.com
The only way to keep the wheels clean is regular maintenance. It's the type of brake pad that is generating the dust. Although this is a different issue I do not recommend switching brake pads just to minimize dust unless a specific pad has been recommended to you by a Saab tech or a brake expert. Dirty wheels are safer than lousy brakes.
Having said that, there are several excellent brands. Eagle One is one of the pioneers of wheel care products. Their A2Z cleaner is safe for weekly use. P21S is highly recommended by European mfrs but it's fairly expensive and usually has to be bought thru mail order. Other brands like Zymol, Meguiars, etc make fine products, but the best is elbow grease and soap. It's a pain I know but it's the most effective and safest for the wheel finish.
Hope its this simple.
Maybe try again with the TCS switched off?
i am on the road but have my notebook and nothing to do now.
i had the 2001 9.5 as a loaner .
i did a psot on it about a week ago.
overall i found the power good ,and for regular driving i found that the car was a good alternative to the aero.
the tires are 17 inch and not the 16 inchers that are prone to cuts or blow up as a result of the thin sidewall.
if i had to buy again i would probably get this one over the aero.the aero is faster,but the tires ,the low frontal aerofoil (which breaks easily when doing frontal parking),makes the 2001 9.5 easier to live with.
Well anyways, the cars have totally different drivetrains, mercedes is 3 valve per cyl naturally aspirated v6, RWD, the saab 4 valve per cyl turbo 4 with FWD. Similar luxury features? Offhand i'd expect the saab to be more fun the c240 to be less fuss, but as a first year car in a new cost cutting era, you never know. If you like the c240 i'd look at a bmw 325i also/instead. A larger straight six with more valves, not in the first year of production, etc.
dave
Good Luck
Drew
You're kind of stuck in the meantime having to go w/ 16s. I'd do a search for 9-5 takeoffs (try dealers and Ronal, for starters, along w/ perhaps some wrecking yards). They'd have the correct offset, etc. I don't know of any 17-inch snows--even if there were, you'd still have that pothole issue.
i have an aero and did get the saab dealer's package.it is a great deal.
1) the wheels are being sold way below list as part of the pack.
and the snow tires are good.
2) if you ever decide to change tires for the 16 from the 17 ,you have now a good set of wheels to do this.
also,if you do it. be careful the first few hundred miles. the car will feel like it is riding on chewing gum.you will experience less control until you wear in the tires.
L8_Apex
Sedans Host
I just wanted to point out that the The Saab Network bulletin boards are 'problem solving' bulletin boards. We expect only problems on the bb's, not "I'm not having any problems' postings. Considering the millions of Saabs on the road, the site gets relatively few reported problems (number of bb posts vs number of Saab owners). Which is amazing because JD Powers APEAL study showed that Saab owners are the most active Internet users of any car owner group. So, when anybody points to The Saab Network as a point of reference that Saabs have problems, they've got their argument backwards. In fact, this is posted on every page of every bulletin board:
"This is a problem solving forum for over 100,000 Saab owners, so expect to see problems discussed here even though our cars are generally very reliable."
-Scott
http://www.saabnet.com/
Total cost was $440 for the repair package. Winter in New England equalls even more hidden pot holes. Buying less prone to damage 16" wheels and tires @ $850-$900 delivered, seem to be the cheapest insurance (unfortunately).
It appears there are no 16" steel wheel alternatives. FYI, the 15" Tire rack Blizzack and steel wheel package for 9-5's is half the price.
Thanks rtd1,ffb13 & bretfraz for your help.
http://www.abbottracing.com/home/9-5chassis.htm
18-inch wheels, anybody? (The sump guard sounds like a good investment!)
a narrow snow tire is best,better,anytime. the wider the tire the less of a snow tire it is.
i know that they make 17 inchers---snow tires.but,if you do go this route you will find yourself regretting it if you ever do get into a snow situation--
suggest that you speak with tire rack guys on this one.
FWIW, they still show the 1999 9-5 as having a "much better than average" reliability rating (in the section with the reliability charts), BUT overall they now rate it as "average" (in the section where with the mini-reviews for each car).
Has anyone outside of the U.S. experienced this option on a Saab?
Dave Kovacs
Enjoy your new Saab.
Drew
I have found that there is a higher percentage of Lexus owners who pick their nose when they drive -true - - it is a non statistically valid sampling but it definitely something I have observed in my rearview mirror. I guess the Lexus drivers are also in a relentless pursuit of something too ;-)
Enjoy your new car . . .
Dave Kovacs
I've had my SE for almost a year and am very happy with my choice. The GS300 didn't rank too highly on my admittedly large list of candidates, and after a brief look I never seriously considered it again. But the Lexus dealer was the best of the bunch in my area--something worth considering on an otherwise close contest.
Good luck with whatever your choice is.
I didn't even consider a Lexus, I have to have a car different than the crowd and a car with a personality. It also had to be bigger and better handling than the 164S. As Alfa doesn't import anymore (I've had 3), that left me with Saab and Audi. I bought the Saab because it better fit my size, price and performance requirements. The upshot of this patter is that if you need to fit in and want Japanese Quality, buy the Lexus, if like driving and want to make your own statement, buy the Saab. I didn't even test drive anything else but a Viggen and rejected it only because of size. My life with the Saab has been trouble free and it is better than the Alfa 164S in every respect.
Drew
