BMW 3-Series 2005 and earlier
1242243245247248585
  • badger11badger11 Member Posts: 5
    I need your help.
    I bought a 1994 325 in May. 2 months ago it would not start. A specialty BMW garage (not a dealer) said "the spark plugs were flooded" and wondered if the car had received the BMW factory replacement chip. I did not know. They replaced the plugs with "hotter running plugs and hoped that would solve the problem as the factory-paid program has expired". The problem has now reoccurred (plugs smell strongly of gas and look wet). I am no mechanic but suspect that this chip is essentially an "electronic choke" that is feeding too much gas when engine is cold. The problem only started to occur in October (I live in Illinois) when weather turned colder. Any one know of that factory program? Was it a recall or a technical service letter/program in response to some problems? If factory admits to a design flaw, then I presume I should still be covered. ANY details would be much appreciated. Overall gas mileage is fine (about 26 mpg) so I suspect the problem is just when engine is being started when cold.
    Well, you can't correct for EVERYTHING, but there are fairly standard temperature and barometric correction factors which can be used to adjust the acceleration numbers.
  • riezriez Member Posts: 2,361
    div2... Are you saying the major car magazines are publishing only the "corrected" numbers? Can't say I've ever seen any. Seems like they have always published the actual numbers they have achieved, the average of their actual test runs, unadjusted. If you have seen some recent "corected" numbers, please point me to a recent issue of C&D, MT, or R&T.
  • brave1heartbrave1heart Member Posts: 2,698
    What are these "fairly standard temperature and barometric correction factors which can be used to adjust the acceleration numbers"? And if you can explain these, can you also tell us what black holes really are and whether they are caused by warped time zones.
    Sincerely funny
    humble1heart
    P.S. Do cars equipped with all-season and summer tires end up in a black hole during the winter? Barkeep, it's snowing out - pour me another drink and make that a double scotch.
    I'm sorry that you are unfamiliar with this concept. I suggest that you examine the "Road Test Digest" found on page 138 of the 12/01 CD. The small print states that all performance figures are "corrected to standard atmospheric conditions". I'm surprised brave, I was certain that it was you who wrote:"Everything I Know About Cars I Learned From Reading Car and Driver".
    div2...
    Motor Trends' "Road Test Results", 11/01 appears to have no qualifying language.
    Road & Track's "Road Test Summary", 1/02, has the following qualifying information: "Factors that affect test numbers include air temperature, barometric pressure, condition of track surface, tune of test car... Acceleration numbers are obtained using drop-clutch starts and lift throttle shifts." R&T is then kind enough to discuss what is a "significant difference": "the amount of difference that is meaningful". For example, .3 seconds 0-60 is considered such a difference.
    Think R&T's qualifying language points out the plethora of variables, many that cannot be controlled for, that can significantly influence test results.
    I'm truly sorry that you are having such difficulty grasping a relatively mundane concept, so I'll state this as simply as I know how: I have never said that it is possible to adjust every test result for every possible condition. That said, there are standardized correction factors for temperature, barometric pressure, and some claim to adjust for RH. Even with these adjustments performed there can and will be differences in test results due to track conditions, driving technique, and vehicle to vehicle variation. Got it?
    This is brave1heart's wife. Brave1heat has been banned from this board from the foreseeable future. The only "standard atmospheric conditions" he will be learning about in the next few months are those related to infants. Quit 'ya quibbling, kids, there's a lot more to life than weather and black holes... Oh, and one more thing - 2 of brave1heart's car magazine subscription rights will now be revoked and he will be reduced to 1 page of C&D for every diaper he's changed. And that's if he behaves!! After all, he keeps saying every day that everything he learned about cars he learned from reading Car and Driver. C'est la vie...
    P.S.
    He must have said something interesting if you can find and paste his quotes from last Spring. I will allow him to take le Schtroumpf out during his paternity leave if it's not snowing :o)
    See what you guys did - I am in serious trouble here.. And above all...aaaaahhhh, OK, I'm banned from the board too now...Guess I'll go read Calvin and Hobbes instead.
  • twoof1twoof1 Member Posts: 308
    If you have not read the C&D comparo in the current (Feb '02) issue, I suggest you do. It compares the 330i against the following: Audi A4 3.0 Quattro, Cadillac CTS, Jaguar X-type 3.0, Lexus IS300 (stick), Lincoln LS V6, Saab 9-3 Viggen.
    C&D knew they were going to catch some flack for again rating the 3 series as the best sport sedan in the world, yet they stuck to their guns and voted for the best.
    Many of the other cars had several high points. Only one car rose to the top. The best line in the entire review was the closing line.
    "But when the brakes cooled, there was one clear choice. Live with it."
    I do not buy a car because some auto rag said it was the best, but it is reassuring to know that virtually every car mag in the world has rated the 3 series the best sport sedan in the world.
    Enjoy what you have for we are indeed fortunate....
  • orkwisorkwis Member Posts: 82
    Having a couple of degrees related to fluid mechanics I'm somewhat qualified to talk about possible corrections they might use for engine performance. That said, I'm going to assume some things to speculate about these corrections, since I'm not an internal combustion expert.
    First, engines burn mixed fuel and air. The fuel is incompressible and changes very little in terms of density (mass) over the normal range of test conditions. I'd assume, for sake of argument, that the fuel mass is constant. Air, on the other hand, can be very different. The mass of air passing into the engine could vary a bit with changes in temperature and pressure. The air density is the parameter to worry about, it is the mass per unit volume. So if you have a given volume of air passing into the engine at a certain speed (wide open throttle, choked flow condition, i.e., maximum possible intake) the mass of the entering air would depend directly on the density. Density goes up with the pressure and down with the temperature. But wait, it gets more complicated.
    The engine really burns oxygen and fuel, of which air is about 21% (I think). The amount of O2 can change slightly with humidity, so there may be a small correction for that.
    The basic idea is that you could correct the current conditions to standard day conditions and see how much more oxygen would come into the engine. You could, in theory, then tweak the horsepower numbers, and assuming losses being equal, come up with a corrected acceleration number.
    The losses in this case being mechanical (the car's moving parts) and aerodynamic. My gut feeling is that they don't correct the drag numbers or the mechanical losses, with the exception perhaps of the tire frictional losses. I assume tire friction data are available from the manufacturers. They'd want to know if their tires lose traction on a colder day, etc. However, I think even that's a bit of a stretch.
    Best guess on this engineer's part is that they adjust the engine horsepower, assume similar losses and apply Newton's laws. Hope it helps! I'd be interested to learn from a real automotive engineer if I'm right (I'm just an aero engineer).
    brave1heart... Sorry about your current situation. Will you be "cheating" if you sneak peeks here? Can you do it from work? (Be very careful there, though.) How come I can picture you sneaking up to the counter at your local bookstore, buying a car mag or two, and then asking the clerk to put the latest issue of C&D & R&T into a brown paper bag, which you'll be hiding at home or reading out in your back yard behind the storage shed? Just don't get busted!
    I suspect that Brave will sneak his laptop into the "Dads to be" area in the hospital while Mrs. Brave is delivering Brave Jr. (or will it be Bravette Jr.?). I can just see him now, Laptop wired to his cell phone and hitting his subscription list instead of pacing the floor, chain smoking, with the disheveled-hair-partially-hanging-out-shirt-tail look wondering "How she's doing". I'll tell ya, that Brave, he is one cool customer. ;-)
    Seriously though, I'll bet that Mr. Brave will be right in there helping with the breathing, offering encouragement, telling Mrs. Brave how much he loves her and how beautiful she is... and catching some serious abuse in return. Such is life. ;-)
    Best Regards,
    Shipo
    It is infidelity - I will have to spend a lot of time in the bathroom with the door securely locked reading my favorite magazine :o)
    BTW, isn't "I'm truly sorry that you are having such difficulty grasping a relatively mundane concept" a line from Frasier? Sounds like something Niles would say on his first day of basic auto repair class :o)
    On a more serious note, the latest C&D had a lot of interesting articles. The sport sedan comparo was great - it seems that there are a lot of good competitors in this segment now but the 3-series still beats all the competition squarely. There was also a great radar detector comparo in which the V1 stood head and shoulders above the other entries. Another article I found very interesting was Csaba Csere's thoughts on where children should be sitting in a car and the surprising (to me at least) conclusion that older kids will be just as safe in the front seat as adults, just as long as they sit on a booster seat and their seat belt is properly adjusted for their height.
    BTW, I drove from Boston to Albany this morning to find out that Albany had record 24-hr snowfall (~13 inches). I got lucky - they had cleared the roads very well by the time I got here and the highways only had slightly more than a dusting. Still snowing heavily right now - guess I won't have to go to a deserted parking lot to try out driving on snow tonight.
    I plan on helping with everything I can in the delivery room. I only hope that instead of me helping with the breathing, I may pass out and need CPR myself :o)
    P.S. It's a boy - I'd be happy with either as long as it's a healthy baby.
  • tenet1tenet1 Member Posts: 354
    Got to go guys. I better rush to the dealer and get on the wait list now!!! This is funny.
    http://money.cnn.com/2001/12/20/autos/wires/q_caddy_krt/
    My favorite quote from the article: "When you go into 75 or 80 percent of their dealerships, it will feel like you're transported back in time," he said, from the ambience of the showroom to an older sales staff and the rest of Cadillac's lineup."
    In all fairness, though, the CTS seems like a pretty good effort.
  • genie1genie1 Member Posts: 398
    My best wishes to your wife. (to you as well, but she will be doing most of the work, right?)
    keep us posted if you have any time to spare over the next few weeks. :)
    Genie
  • ccotenjccotenj Member Posts: 610
    you tried... it WAS worth a shot...
    to others: heloc's - ummm... i personally wouldn't collateralize a depreciating asset with an appreciating one, but that's just me (not to mention, as one other poster pointed out, you'd feel kinda silly losing your house because you feel behind on the "toy" payments)... the heloc would be a better idea if you were doing that instead of paying cash, but only if you maintain that amount of cash in liquid enough funds to pay it off if you lose your job or so on...
    defaulting on a car loan leaves you carless...
    defaulting on a heloc leaves you homeless...
    -Chris
  • mfeldmanmfeldman Member Posts: 140
    Happy New year. Her's my first question for 2002:
    Just saw some dried gum mixed with sand on the rear carpet. My daughter must have stepped in it some time ago in a playground. It's well baked in. Any solutions? Thanks
    Put the kid up for adoption ;) When my seven year old left his glitter crayons to melt into the back seat of my wife's 5er, he told her that he thought he just might survive his punishment- since it wasn't Dad's Club Sport...
    Yes, but I'm learning so much about the British Motor Works from all the enthusiasts around here...
    hmmm... there used to be a really good topic over in news and views for problems like this...
    have you tried taking a long needled comb and kinda "combing" it out? possibly in conjunction with some type of weak solvent?
    also, you can make the gum pliable by heating it with a hair drier. i'd avoid using a heat gun (it's not real easy to control your temperature that way). the drier and comb method will probably do it if you are patient.
    -Chris
    yea, i know what you mean. i feel so much more edu-macated than i was before. 'specially after i unlearned all that stuff you taught me before that i foolishly believed... :)
    -Chris
    ps. that reminds me of when my wife drove mine into a curb and rashed up one of the winter wheels pretty good. her comment "well, at least it wasn't the really expensive summer ones"... right...
  • szellersszellers Member Posts: 22
    Just received a price of 33270.00 for 325i, automatic, Premium package, Xenon headlights. This price was 600.00 under MSRP, plus free BMW floor mats. Is this a good price? The car should be here by the end of the month from Germany.
    Not the kid's fault. I dont let her eat in the car and she is very respectful as she knows it is a bmw and "cleaner than mommy's car." It was some other jerk who spit out gum at the playground. I guess i could trade the car in, but no 4 door m3.
  • derprofiderprofi Member Posts: 250
    Honestly, that's a pretty bad deal you're being offered. You could be in a European Delivery 330i for about the same price, and it will include floor mats for free. Tell your dealer that you'll take it for $1500 over US invoice price.
  • eugeug Member Posts: 46
    Can you email the dealership and dealer you got that great ED quote from? I'll have to check them out on my next 3-series. Thanks.
  • rpadillarpadilla Member Posts: 53
    2002 BMW pricing info....(got this from bimmer.org)
    http://cuttermotors.com/bimmerfest/bmw_pricing/
  • dej0dej0 Member Posts: 36
    Hi Gang,
    I have been trolling for a while now, but I enjoy reading this forum. Y'all are very nice to one another. My wife and I finally decided to replace our Miata after two years of only one car with a backseat and three people in the family. We have an Audi A4 also as the main kid transport. We have ordered a 325 w/ sport/xenons/power seats and sunroof. Probably should have just gotten the lux. pkg. The colors are blue steel metallic with the sand leatherette. I did not really care for this color combo until I saw it in person. I was very impressed, and I hope it is relatively easy to keep clean. We are also considering upgrading the A4 from a 1.8T to the new '02 with the 3.0. I really like both cars, though they drive very differently. Since I live in NC, we are going to do the Performance Center delivery. I am really looking forward to it. The guy would not budge off of $1k below MSRP. That is the problem with Edmunds saying the TMV for the car is MSRP.
    Have a good day.
    Ned
    I agree with Derprofi. The price is too high. You should be getting around $2K or less over invoice for most parts of this country.
    Where do you live?
    I'll give it 2 years, and then Cadillac will go back to focusing on it current market, after the hype dies down.
    Yeah, let's hope it's 2 years or less. I'm not sure I could bear to see more than one or two of them on the road per week, which is my rough estimate of Aztek sightings in this area.
    And when you consider that I'd always be looking at the front-end of the beast (after all, I'm in the 330i so you know I'd only ever see one in the rearview mirror) even once or twice a week might be too much for my sensitive stomach :)
    You should be able to get at least another $1,000 off.
    We are also planning on using our '01 A4 1.8T as the main kid transport. I installed the car seat base last weekend and was surprised to find out that the rear-facing child seat does not fit comfortably in the back seat of the A4. We bought a Peg Perego system which comes with a slightly oversized car seat and you can only use the car seat if it is in the middle of the A4's rear seat. It is impossible to install it behind the driver seat (with either me or my wife driving) without compromising driver comfort. Same goes for the passenger side. It fits OK in the middle, as the open space between the two front seats allows the top of the car seat to fit in between the two headrests. Are you using a forward-facing or rear-facing car seat? BTW, the 3-series' rear seat room is much better than the A4's
    and the child seat fits comfortably everywhere.
    I live in N. Va also and strangely enough I see a lot of these "beastly" Azteks everywhere because my wife always points out how ugly they are.
    Oddly, I have never seen anyone using the "tent" option. I figure it would have been pretty handy when transporting furniture in the rain this past wekend.
    We just bought a full size car seat for my son this weekend(upgraded from the Peg Perego infant seat). Since this full size seat has to be installed rear-facing, I find that the passenger seat has to be moved up quite considerably to get it in the back. But there is still enough room for me in there.
    The sales guy I bought this seat from told me that the Audi A4's and some VW's usually have problems with the room in the back seat for the full-size seat. You may want to consider the 3er for the baby transport when you need to upgrade.
    Or better yet, consider an X5??
    I think we may well end up using the 3-series as the main kid transport. My only concern at this point is the stiffer suspension (no sport pack in the A4) but the Peg Perego car seat has so much padding that it should almost feel like a cradle to an infant. Will have to try it and see how it goes but I am pretty sure we'll end up doing that.
    An X5? No SUV's in our family, even if it's a BMW... A mid-size sedan like the 5-series should be enough for two kids, probably even the 3-series. If we have a dog, we'll have to get a wagon, possibly an A6 but that's in at least 4-5 years...
  • shap1shap1 Member Posts: 77
    Hope this helps...at the beginnning when the car seat has to be facing the rear, it is recommended to put it in the center position of the back seat. This is the safest place. Granted, when I was at that stage, I had a Volvo which has three point belts in all positions. I would be a little concerned with just the lap belt in the BMW center position.
    Later on (where I'm at now), you can put 'em on either side. I have a car seat and a booster seat currently in my 325 and there's even room for a third kid in the middle seat.
    Thanks for the heads-up. That's good to know!!
  • dantlodantlo Member Posts: 106
    Wagon is a good choice. We returned the 528 and get a Vovlo V70 2.4T, it does not drive like a bimmer but it sure is practical and roomy. I put my 2 year old girl behind the passenger seat. And there is still plenty of room.
    Now the car seat just stays in the wagon and I drive the 325 daily.
    Dan
  • denrightdenright Member Posts: 285
    Your insistence on avoiding SUVs -- even the X5 -- is so consistent, so dogged, that it inspires admiration while inducing laughter.
    My wife and I will be starting a family this year, and we have two labradors, so an SUV is pretty much a must for us. Once you have the dog(s) and the kid(s) for a while, you may reconsider... but I will admire you more if you stick to your idealogical but impractical guns.
    brave1heart... Keep up the scepticism. The only good SUV (or pickup truck or minivan) is in someone else's garage or driveway! High performance sport sedans and coupes are where the action is really at. (Convertibles are OK, I guess, but I've never had one nor had a hankering for one.)
    My wife and I had no trouble raising our two kids in sedans. Our kids love her 323iA and my 540iM.
    I'm not sure what the fuss is all about. Why not get both the SUV and the sedan?
    I can tell you after 13k miles of trip driving the last two Summers that three rows of seats is a definite must when you have kids. A TV, VCR and lebensraum (and I mean enough room that a flying fist cannot reach its target!) is all you need to remain sane (that and a reasonably loud stereo).
    No question, the performance stinks, but you can't take a sedan off road, even if it is AWD and you can't fit a couch in the back of a 3-, 5- or 7-series. You are also much safer in an SUV, at least the Expedition I have. Crash tests are done against same size vehicles; mass always wins, no one changes the laws of physics via design! As far as gas mileage goes, the SUV is much worse per vehicle, but figure it out per person and you'd need 72 mpg in a two seater or 36 mpg in a four seater to match a fully loaded 9 seat land yacht. Lastly, you get to see the road much farther forward than in a sedan and that means your reaction time is a lot better, so at least you compensate for the extra inertia. It also beats the heck out of sitting behind an SUV in traffic when you can see what's causing it.
    That said, I miss driving a performance machine and am getting ready to put my order in for an ED 325i this week. Found my $1500 over in Ohio! But for sure, there is going to be an SUV parked next to it!
  • dl7265dl7265 Member Posts: 1,381
    Dont know about a caddy, but the G35 pricing was released today 27,100. 260 hp , vented 4 wheel disk, .26 in the wind tunnel, 6 cd in dash, more room than a 5er whew.... maybe the 330i will drop to 27,100 to compete, ummm then again maybe not.
    DL
  • g_carg_car Member Posts: 46
    I'll buy a wagon before an SUV. 1 kid, wife and dog (its a small one) we do just fine thank you in our BMW 5er and Honda Accord and I have a 1995 300ZX-TT for the weekend. I wonder how folks got along before this SUV craze came along. Size of the family has decreased but the size of the vehicle has increased. I was at the Philly Auto show this past weekend and took a look at a couple of SUV's first I was shocked at the price of the ugly brutes and then more shocked at the MPG. What a waste. The Lexus RX300 and BMW X5 would be the only 'utes I would even consider buying. At the auto show very little foot traffic around the SUV models/displays while the MB, Audi, BMW, Jag car displays were being mobbed. People buy 'utes because of the "Utility" but in their automotive heart they would rather be driving an M3 Convertible!
    Happy Motoring
  • nobeenobee Member Posts: 194
    Just picked up my new 325i yesterday and loving the car to death. At first, I was a bit scared driving the car in the snow, but should be fine once I put snowtires on it. However, to be brief, drove the car back to work and left it there for a couple of hours. When I got back into the car, I put it in reverse (STEPTRONIC) and it goes ! What the hell! The car has less than 10 miles on the odometer and I'm already having problems. Then I noticed when I turn the ignition over, I hear another funny noise-the noise you get when you crank an already turned engine...not good...I waited two months for this? Well, I guess it goes in the shop and I'll have to drive the 5-series for awhile =(
    I took some interior/exterior pics of the Mini and the 7-series (beautiful high-tech automobile). I'll post once I scan the pics. in.
    -nobee
    do you have the SP?
    I agree, tell me what soccer mom needs a 2ton excursion, to go to the mall in. Know how many accidents we get cause they cant even see outta the blasted things , and end up backing over all kinds of poles, cars, ect...its rediculas, whats ever worse is the bumper match would just about take your head off in a 3er, good thing we got the side drop down air bags. OK im done ranting ,,,,hehe
    DL
    Again, I don't think you guys get it. Need and want are two different things. No one actually needs a car, look at Europe and how they live (with high automotive costs) if you want some place that's going to decide for you what mode of transportation is best. Maybe its a kids thing or perhaps I live in Catholic heaven here in the midwest (I'm Catholic, I can say that). My street has 15 houses and a little more than 50 kids. I've got 3 myself and a few of us have 6 or 7! My kids will be the ones bailing our Social Security! When you have numbers you need space. The soccer mom doesn't need the SUV or van to go to the mall, she needs it to haul all the friends from soccer game to soccer game and event to event. They are very practical automobiles especially for stay at homes. Fun to drive? Sometimes. Take that 4x4 off road and see what fun is or take it backwoods and see something you can't from your airline seat or the interstate. Different strokes for different folks. Keep an open mind, rent one one day and try this stuff, you might get hooked?
    However, you can't say that because someone needs/wants an SUV that they can't appreciate a fine automobile. They've both got their good points. Why not have both? It's like growing up saying you will only date a blonde and moving then to India, when you need some it ain't gonna happen! Like enjoying Moet with your date and then drinking (so long as there is a designated driver) Jack with the boys. Okay, I'm getting too philosophical now. Carpe diem.
  • rutegerruteger Member Posts: 60
    There may not be much activity in the 'real' truck-based SUV market these days, but there's plenty of action in the quasi, car-based 'SUV' market. That's the group that includes the Escape/Tribute, Sante Fe and Forester.
    Truck-based SUVs are normally rear-drive, rough-riding, true off-road vehicles. Car-based are primarily front-drive vehicles that offer a decent on-road ride with limited off-road capability. Frankly, they *are* nothing more than wider, taller station wagons with AWD systems that just 'look' like a truck-based SUV, but no auto manufacturer is ever going to call one a station wagon.
    Another key ingredient to tell the difference is the absence of a transfer case (AWD vs. 4WD). Automatic AWD is great while on the highway, but it's not designed for the rigors of off-road duty like a transfer case-equipeed 4WD vehicle.
    The best example is the Subaru Legacy/Forester. Both of those vehicles have the exact same automatic AWD drivetrain. However, the Legacy is longer, narrower, and classified as a station wagon, while the Forester is wider, taller, and called an SUV. But it's still just a rebodied Legacy station wagon.
    DC made a serious marketing error with the new Liberty because of the unwavering Jeep credo of all their vehicles being 'true' SUVs. As nice and capable as the Liberty might be, it still rides rougher than any car-based SUV. Given the limited amount of time that the vast majority of SUV owners ever take their vehicles off-road, DC has certainly lost many sales because of this requirement for any Jeep-branded product.
    Station wagons that look like 'sporty' SUVs is where the sales are these days. There isn't really a leader in the class, either. The BMW X5 is great for the well-off, performance-oriented group because of its rear-drive layout but it's not quite as good as a front-driver when the weather turns foul.
    The vehicle that is closest to being a perfect SUV for most consumers is the Escape/Tribute from Ford. The only trouble is the abyssmal quality with which these vehicles are assembled. They're selling a lot of them, but you stand about a 50/50 chance of getting one that may qualify for 'lemon-law' status (and that includes current 2002 builds). But don't take my word for it. Just check out the NHTSA website or any Escape/Tribute board. They're filled with horror stories. Nothing fatal, but certainly some potential vehicle disabling issues. Stuff like vehicles mysteriously stalling and transmission failures of brand-new vehicles.
    And for those who say this is just a small percentage of a large group of products assembled, one need only look to anything written about the Toyota Highlander. Nary a gripe on those boards...
