Anyway, as for the car itself, it is nice. In fact, I was somewhat hesitant about ordering the 3er when I knew that the new A4 was just around the corner. In the end, I think I made the right choice. The new A4 is sharp but I still think the E46 looks better. The new A4 is very similar to the A6. It's nearly impossible from the front or rear to tell them apart. The only way to really distinguish the two is from the side. Then you can see the extended length of the A6. I've never been fond of the A6's looks, and I think the reason is because the shape looked odd because it was not dimensionnaly correct (too long). The new A4 solves that by shortening the length, yet keeps the other dimensions similar, and is thus more pleasing to the eye.
I also saw several new A4 Avants, which would be my preferred wagon if I were in the market. The new A4 Avant 3.0 Quattro would be a great car for weekend ski runs to Lake Tahoe.
The A3 was also very cool - especially with a sporty rim/tire package (as in the pictures).
Europe also gets the A2, Audi's version of MBZ's A-class. Kind of a homely looking thing, it looks like a miniature minivan. I wished I would have snapped a picture of one.
its easy,
go to bmwusa.com
click on "owner's circle" at top right corner
then click on "sign in"
you will need to set up an account the first time for which you will need Production # or VIN #
then sign in as many times as you wish using ur username and password!
Try it!
good luck!
Just looked at Dinan and all of his upgrades for software and cold air kits are 49-State Legal and can not be used in California except for racing and never on the street. This could present a fun situation when its brought in for the bi-annual smog inspection.. Oh well, maybe something will come along that will give you more ponies AND be smog legal in California..
DanF
1) Manual mode gives similar control (minus the ability to self-modulate!!!) in terms of being able to choose and hold gears. This is good for keeping constant wheel torque around curves and for engine braking. Also, I'd encourage folks to use the Manual mode as much as possible during break-in, as engine braking supplies the back pressure necessary to ensure good piston/ring sealing within the cylinders.
2) Manual mode "delay" (about 0.5 sec. on both up and down shifts) can be annoying, but if you plan for it, you get used to it.
3) In Manual, if the throttle is depressed past the "kickdown point" (at about 95% of throttle travel), the tranny will not shift manually, for whatever reason. Also, the Manual will not allow "dumb" (over-revved) downshifts, but is smart enough never to upshift -- ignition is retarded instead. This presents a dilemma: when throttle is fully depressed, the only way to manually shift is to back off the throttle past the kick point, or hit the rev limiter...
4) I especially enjoy (this is true of both Step and manuals) low-speed cruising in 1st gear (e.g., in parking lots). With the windows rolled down, the exhaust gurgle during engine braking from about 10-5mph is entrancing.
5) The Manual mode is really just an auto with what I call a different "user interface". Just as traditional autos allow the manual "P-N-D-3-2-L" shifting, the Manual mode does the exact same thing, but with a flick up or down, rather than moving between D, 3, 2, and L. Same tranny, different interface. This is WAY different than F1-style sequential shifts (the M3 will have one), where there is no torque converter and the clutch is computer-controlled, making shifts faster and more precise.
6)Sport mode is great -- will hold gears when the car is going up or down hills and around curves. The shift points are also much higher in the rev range for a given throttle position, and downshifts occur with less throttle position delta.
7) Auto mode -- good for my wife.
8) General observation: BMW makes some of the best, most efficient transmissions available, auto or manual. I estimate the the hp loss at the rear wheels (vs. at the flywheel) in a BMW Steptronic is comparable to the hp loss in competitors' manuals. That said, the BMW manuals would be even more efficient, due to the lack of the torque converter. That is why BMW's straight-line performance/acceleration is better than the power-to-weight ratio would suggest. Hence, a Step-equipped 330i is equally as quick, or even moreso, than a CL-S, when the CL-S has a clear power-weight advantage. More BMW "unquanitifable" magic at work here...
Overall, I still yearn for the joy of rowing the gears and slipping the clutch to achieve a perfect launch. But given my situation (and the situation of many others, I'd assume), the Step is a decent compromise. However, you can bet that when I move up to the 540i, I'll be ordering the six-speed, thank you very much!
Also, if I just ordered my 330xi on 5/4/01, when do you think I can expect delivery by in NY? I went to the BMWusa site and can only get info that the car is "on order." Do you guys think that the dealer I ordered the car from would know which week my car is slated for production?
I would strongly caution anyone who does drive in NYC style traffic on getting a stick (there are exeptions to every rule...). I have many clients who live in L.A. area and the ones who have done a stick swear they'll never do it again. If you're in rush hour traffic every day, shifting gets old real quick!
BTW you just gave more info and pics then all the auto mags and online lol we need someone to travel Europe every month lol
TAKE CARE DL
The loaner that I am using has the Step Trans and burrsr's post is right on! In the "manual Mode" it's, at best, an adequate substitute to stick.
Bottom line, it's all a personal preference's and what you are comfortable on a daily basis.
IMO
I have had the CAI, Stg. 2 software and Dinan exhaust on my Z3 for about 8 month's now and I love it!! Definately not the cheapest but IMHO it is the best. Besides if you are in the least bit nervous about warranty implications, definately go with the Dinan they not only stand behind the product, but most of the upgrades are generally installed by a BMW dealer.
I just loved your car racing fantasies! Maybe you should tell us about the time you beat an M5 with your light blue Gremlin. And Dale Earnhardt was driving the M5 and had a 3 mile head start. Give me a break. You've been spending way too much time at the Playstation (in front of the Sony Vega you can buy since you won't have to fork over 40k for the Bimmer).
Also, I find it hard to believe that your friend has a fleet of BMW's and he's never let you drive one (by your own admission you've never driven one). Especially since you must be Mario, given your ability to outrun a 740 without coming close to redlining your car. 40 to 1 says you have a little crown on the dashboard of your 1974 Datsun, which you wax every Sunday in a pair of leather chaps....
How does your car pass the tennis ball test? Just put a tennis ball in your exhaust pipe (your car should be in a poorly ventilated area or the test results could be biased), rev the engine in neutral and see how long it takes your car to stall. My 330xi lasted for 38 minutes. How long can your car last?
(I figured that this was a pretty neutral question that a Lex OR Bimmer owner could answer)
Looks like our friend Mr. V-Tech is back with a vengeance. However, his writing was such illogical, unintelligible, nonsensical babbling that I frankly lost interest, regardless of the intended content. Here's a little advice: when you tell a story, HAVE A POINT. It makes it SO much more interesting for the listener! Also, I feel most of the folks on this board are intelligent people who are persuaded by FACTS and well-supported opinions, not this "...duuhhh...give me a break..." (repeated incessantly) strategy that is of absolutely no substance. Well done, Mr. V-Tech -- I'm sure your un-witty, un-factually-based ramblings have changed the opinions of exactly no one. Before typing any more nonsense, consider saving your fingers for the PlayStation for which they were intended.
http://www.riceboypage.com/
It's just not worth the effort to argue with ignorance.
jesus, I guess YOU are the one who really don't know a damn thing. F-1 is the ultimate racing. The drivers are the best of the best in the world, the racecars have the highest standard and technology. Just the US doesnt cover much F-1 doesnt mean it is second rated after NASCAR and CART. It is actually the total opposite. Ask any NASCAR driver, what F-1 is about.
While we're at it, have you realize the Ferrari's, M-Benz's and Porsche's are not in NASCAR and CART either? But they are ALL in F-1?
The IS300 is very comparable to the 3 series. I use to own BMWs and it's handling is a dream. I never test drive an IS300 before so I don't know how it handle. But with all the review from magazines, I think it's pretty much on par with the 3 series.
But the thing is IS300 is more appealing to the younger crow where BMW is appeal to a broader age range. I would not mind owning either car, but I prefer the interior of the BMW 3 series. If Lexus change the interior of the IS300 .. I will definitely check it out.
Back the the 3-series pricing. Do you all think with the introduction of the new A4,Jaguar X-series, ne I35 from infinity and new ES300, pricing for BMW would be more flexible toward the end of the year ????
On the styling front, the IS300 uses things that are specifically designed to appeal to the younger set. Clear tail lights and white dial faces, the metal shifter, and the 'chronometer'gauge set-up, are all targeted younger people. Nothing wrong with that. You either like them or you don't.
I think that the Lexus will hold its value, unless Toyota makes changes that make the current model undesirable - styling changes, a bigger engine, a 5-speed (perhaps,a factor, perhaps not), or the things that are so stylish now go out of fashion.
Anyhow, I view them as playmates on the skyline drive. I haven't encountered one to duel with on my favorite road, but I look forward to it. There's a decreasing radius turn that I like to introduce people to....
Burrsr--2460, Enjoyed reading post #2460 on your Steptronic Perspective. Haven't used it much but looking forward to trying the sport mode on the hills. thanks
On the IS. I ordered one, waited 7 months (pre bimmer) and when it arrived I was totally disappointed. It drove NOTHING like a BMW. But it looked nice. Seats felt great. The hesitation in the computerized accelerator was just dreadful. I drove 4 different IS's to make sure it wasn't just one bad one. They all drove the same way. Like a ford.
My dealer is supposed to call me today to clue me in on the sport seats special order price. I still don't know how much extra I'll be willing to pay for the sport seats. I wish I liked the M aero package. It would save a lot of hassle if I could bring myself to just order the sport package and be done with it.
I've messed around alot with tire pressure. When I had Turanzas on the car, I settled on 41 rear and 35 front. I know that sounds high but that's what felt best. Now that I'm running RE 730s, I am using 36 rear, 33 front. This seems about right.
Okay, we're all entitled to our own opinions here, but you come across as someone who's got a serious anger issue. Most of the people who post here actually think about what they write--you have decided, for some reason, to forego that option. I think you MAY have garnered some degree of respect had you not come across as someone who has an extremely large flagpole up his a**. Make your arguments intelligently, not like someone just kicked you in the balls and told you that you had ugly children. Calm down already. None of us is saying that the Lexus IS300 doesn't have its merits. But, AGAIN, it's not just about speed. And when you reply to the "balance" issue, it has nothing to do with your a** (sheesh, man. Bone up on your terminology--balance refers to weight ratios, not the comfort level of your butt in the seat.)
My suggestion...take the money you saved on your Lexus IS300 and buy either a new attitude, anger-therapy sessions, or a dictionary. Come back when you've actually made some progress.
PS 227 hp/217 lb ft tor for $23K.
I think my eyes are bleeding from trying to catch up.
Tire Pressure: The last time I looked at the issue was in the mid 1970's. The rule (for comfortable freeway cruising at least) was, the fronts should have less pressure than the rears (per the manufacturer recommendations). However, an old sage that I was learning my engine overhaul skills from told me that for sustained high speed driving on curvy roads (or tracks) you wanted higher pressure in the fronts than the rears. His advice was based upon years of turning wrenches on cars over at the local track for a number of SCCA racers. He said that if the tires were inflated to the standards for that car, handling would suffer and tire wear (especially the fronts) would be extreme. His recommendation was to bump the rears a few pounds over spec and then to bump the fronts about 5 pounds over the new rear pressure. Then start testing.
Modern tire technology has progressed so far since then that I suspect that advice is no longer as relevant. In my case, I follow the manufacturers suggestions for the most part, and that is probably as good as it can get without extensive testing.
The only potential problem with manufacturer recommendation that I am aware of is the Ford Explorer / Firestone issue. In this case, Ford recommended a lower tire pressure spec (to improve the ride) than Firestone designed the tire to cope with. This, in my opinion, is a HUGE contributing factor in the failure of all those tires.
As far as our pet troll is concerned, I was curious to see where else it posts, so I clicked on it's name. You guessed it; our 3-Series board is the ONLY place it posts.
Brave1heart; your words regarding the community here on this board were very well spoken. Here, here!
Best Regards,
Shipo
As far as driving in stop-and-go traffic, yeah, it's absolutely a matter of personal preference - auto vs. stick. I'll still take the stick in any traffic because it allows me to have the car in the right gear at all times and dash for that opening in the other lane. The clutch definitely does not like it when you don't switch gears fast - it is suited for more aggressive driving - I love that!!! However, even in traffic, you can go like 2-3 mph only on first and the band is so wide, you don't need to shift gears all the time and the car is still very smooth. My old Jetta VR6 would snap your head off in first and was a lot more uncomfortable in stop-and-go.
I am also excited to have hit 1200mi. Now A can really Open it up.
Btw, at the dealer isaw a 323 wagon which allegedly was rearended at 45mph on a test drive. The rear end was accordioned but the passenger compartment was intact. A good if unintended ad for bmw.
The bolstering of the regular seats is definitely less formidable looking than the sport seats. However, it is still incredibly firm and supportive. While the sport seats literally fit like a glove, I found the regular seats to be almost as supportive and confortable.
I think I am going to stick with the regular seats. I know you are all breathing a sigh of relief. LOL Sorry to be blathering, but I need someone to bounce all this crap off, and my wife sure as hell doesn't want to hear it.
As far as this K&N air filter goes, am I to understand that this air filter will add several horsepower to a 3 series engine? Does anyone know if K&N makes one for the 3.0 liter inline 6 in the 330??? Please advise, I will definitely get one if they make one.
