Burrsr, thanks a lot for the recount of your experiences. I found them enlightening.
As quickly as this topic moves, it's easy for posts to get lost in the shuffle and, in some cases, that may be a good thing. Although I'd prefer it that everybody's forgotten about the recently deleted posts, I'd like to clarify the position of Pat and I on this subject.
There may be some confusion as to language that is allowed and language that isn't. In the past, hosts enforced a "guideline" to a degree that they thought appropriate. Naturally, this created some variance from board to board. To eliminate confusion and address concerns that were raised by some members, a more defined policy was created and the hosts were asked to more uniformly apply it. I apologize for any confusion caused by this change as it does differ from the rule-of-thumb I've applied over the last few years.
It should be noted that this is not something that was implemented just recently. We were asked to start applying these rules last fall, prior to the first failed attempt to move to the new discussion software. In a number of cases, I sent emails to long-time members who posted somewhat inappropriate material informing them of the change and, without removing their post, informing them that, going forward, I'd have to remove similar material. Unless the post is completely off-topic, abusive, etc., we always include it with the email along with an invitation to kindly edit and re-post.
I don't think we can be faulted for not accomodating you with regards to confusion anybody might have regarding why any posts were removed. If any of you have corresponded with Pat or I, you know that in most cases we'll take more than enough time to explain our position and reconsider our actions if necessary. Again, post removals were accompanied by an email contain both the post and an invitation to edit and re-post.
I also apologize for posts that might slip under that wire. The hosts are required to read each and every new post in every discussion on their board, every day. It's only expected that, from time to time, we'll miss something that should be removed. If you notify us, we'll gladly look into it.
For the most part, Pat and I can count on this topic to be problem-free, on-topic and a great source of information for owners and buyers. Having three friends who recently purchased (well... one of them, his M3 is due Sat.) BMW's, I refer them to this topic (among other resources) for it's generally helpful and knowledgeable atmosphere. For that, thanks.
That being said, I'd like to make it clear that you are most welcome to address issues regarding topic management off-line. Pat and I will take the time necessary to explain our actions and reconsider if necessary but don't want to make the topic the place for disputing our actions.
Thanks for your time and understanding,
L8_Apex
Sedans Message Board
I think the set up is like this: Front 17x7.5, 225/45 ZR17, Rear 17X8.5, 245/40 ZR-17 (so that's 2 different sizes and big sizes at that!) I called and talked to a tirerack.com guy but he was relatively vague about it. Some dealers tell me I can get away without a new set wheels (only tires), others say I won't and will need a new set but those can be steel ones (yikes!)... I don't know who to believe. :-(
My "problem" is that I just ordered an Orient blue 330xi with tan leather but I still can change a few stuff around for the next few days (according to my dealer). So I figured that instead of leather I could maybe go with SP.
PROS are: they (SP vs leather) go for about the same price here in Canada (~$Can 2200), 'ette is perfectly OK, I'm not sure I like the radial spoke, I like the M double ones, I like the sport seats and steering wheel.
CONS: if I need to buy (nice) wheels on top of the mandatory winter tires, the equation is not the same anymore.
Knowledgeable help appreciated :-)
I'd think that we can definitely get a set from other tire places beside Tirerack. Actually, that's what I'm planning to do if I get the 325i w/SP.
Thanks for the advice. Which did you chose: 225/45-17 with OE wheels or new tire/wheel pack with 205/50-17? If you went with the 1st option isn't it a not-so ideal choice (ie a compromise) in terms of tire/wheel fit or is it perfectly OK?
hippo,
Just checked Bridgestone site and indeed they got Blizzak LM22 at 225/45-17 and even 245/40-17! The question I guess will be whether any locals here will have those....Hmmmm
Best Regards,
Shipo
Best Regards,
Shipo
add123
My dealer is telling me otherwise. At least, that's what her first story was. She told me that the features I were requesting required the purchase of the alarm at $480 (parts/labor). I continued to insist otherwise until finally she asked a technician while I was on the phone. The tech. told her that they could do the parking lights for me, but not the clown nose.
Does this seem right? Thanks,
platypus
Yes the 330xi SP comes with standard 205/50R-17 with all-season tires **in the US** but NOT in Canada (trust me I checked this thoroughly).
Options are different up here (see www.bmw.ca) and why they put the performance tires and different wheels size on the SP xi is a mystery to me. Perhaps they thought that most(?) of us canadians go for snow tires anyway in the winter.
Also I'm perfectly aware that SP is mostly an aesthetic choice for the AWD (except for the sport seats).
My rationale was that since I was prepared to go for leather, why not substitute that with SP since it's about the same price and I don't really care for leather anyway. But now if indeed I need a new set of wheels then the price rationalization doesn't work anymore (as my budget is capped)
-eug
I was very busy today; didnt get a chance to check on the ship...will do tomorrow. i am sure it docked today! lemme know if u hear anything.
veekay1
koaladude, I live in Colorado and we get plenty of snow. Most bimmmerites(?) here switch over to snows in the winter (at least the RWD ones). I haven't yet, since I have a second 4WD vehilce. However, the day will come when I will need to use the snows. I can't decide if it would be worth getting nice wheels or just steel rims and hub caps. Anyone have an opinion about nice wheels or just go with cheaper steel through the dirty winter?
firebird, can't get four tires in the trunk, not even 16" tires. That is one reason why it's nice to get another set of rims so you can just change over each season in your own garage. Otherwise it's the back seat (but not on my leather!).
Anyway, I did ordered my car (330i, Steel Grey/black leatherette, sports package, CD, xenon, floor mats, and alarm) through Crevier for $35175 before tax and license. Talk to Jerry Cohan, the fleet manager and tell him Stanley Cheong referred you.
DL
Now where's gurumike at?
Here are a couple of in-depth discussions regarding this topic. Be sure to read all of the follow-ups in these links.
clown nose 1
clown nose 2
In the US there is a luxury tax on cars costing over $38K. My car will run $38,475 as it is. Rather than have the alarm go further over the $38K threshhold, I will buy it in a separate transaction and save myself some tax $$$.
So, I have a question for the forum. How does one calculate the luxury tax on a car costing $38,475? What is the percentage? Does it apply to the entire purchase price or just the amount above and beyond $38K (in this case, $475)?
Any input appreciated.
Denright - I was in a similar situation. The lux tax is calculated from the amount OVER $38,000, although I'm not sure of the exact percentage. Any updated lease calculation spreadsheet will have it in the formula bar area for the lux tax cell. Also, the lux tax is supposed to be gradually phased out (decreasing percentage to zero) by 2003.
No "Top 10 Hot Discussions" entry for us -- first time in a long time...
P.S. - don't tell her you talked to someone else at the dealership. She mentioned BTW that you can do the whole deal over the phone - you don't even have to go in.
In my case, the percentage is about 4%.
BTW, we need more posts...we are not in the 'top 10 discussions' anymore
koaladude - it seems that you are very confused about the sport package on the xi. awd cars require absolutely identical tires (tread pattern, size, everything) and i cannot believe any dealer anywhere would sell you an awd car that has different size tires front and rear. you do not need snows for awd - this is definitely overkill even if you are in toronto. as far as tire width, 245 would be too wide for driving in snow and i would not recommend them. the wider the tires, the less they would be able to dig into the snow for traction. just get your 330xi with the same setup as denright's - you won't go wrong with it.
fitting tires in the trunk - no, it's not a pickup truck. there's plenty of room in the back seat. if you are concerned about the leather, just buy a $5 cover that you can drape over the seats to use for transporting the tires (or anything else).
btw, shipo's 328 does not have the sp and his tires are made of harder compound that will last longer than any tires that come with the sp. the sp tires are more expensive and last about half the miles - still worth it in my mind but you do pay a huge premium for performance tires.
platypus - just get the alarm, you won't regret it. you saved a lot of money on the ed and should be able to afford it.
mmcerio - is yours the Step AWD? That's the only steel grey 330 I saw for N. Haven, CT and it's in 111 at the moment. Ask me again in a week or so.
VPCs - approx 5-7 days plus however many days driving it is from your local dealer to New Jersey or S. Carolina or Oxnard.
eug - it's in 152 today, so it will be a finished car by the end of this week!
pilot16 - I'm afraid I can't answer your "deal" question on the board as I work in sales at a so cal dealer. You can email me (Michael@dcninternet.net). Are you a pilot? I was just about to get todays DUATS weather report before I go over to the airport this morning. I'll probably fly over to Oxnard to make touch and gos! I'm at 60 hours and I'm expecting I'll take the checkride with in 30 days now !!
One last thing.....
GO LAKERS !!! Whaa-hooo!! Look out Philly - here comes the steam roller !!
I'm still planning on installing a trunck CD player myself...but am now also considering the glove box mounted one, although I heard that that will eat up my entire glove box. I would have gotten the in dash, but many audio educational materials still come in tape form only. I did miss your post. Thanks for reminding me about it. I'll check it out!
snowtires: I live in Chicago and plan on buying snowtires in the original 325i size (205 55/16 I think) for my wagon. TireRack and mount them (Blizzaks, but I might opt for Alpins as they have much better dry road handling) on steel wheels with hubcaps for about $400. I'm pretty sure that they have them at the 330i size as well, as I was briefly considering a 330i sedan at one point.
I drove my mom's '84 500SEL (no traction control, no ABS), a car notorious for terrible winter handling, in the snow with Blizzaks this past winter in Chicago and it drove through snow and ice like it was dry. My only comment about the Blizzaks is that they are very squirmy on dry pavement and wear extremely fast if you leave them on in above freezing temperatures. Because you only _really_ need snow tires in Chicago maybe 5-10 days out of each winter (and my garage opens onto an unplowed gravel alleyway), I'm probably going to opt for the Michellin Alpin's, which, according to tests, have much better dry handling characterists and wear while sacrificing a small amount to ice and deep snow traction.
Does your car need to go to Passport BMW first? Or just go straight to TX?
and anyone-
So far, Joern (my dealer rep.)hasn't asked me to sign a contract. He also said I won't get the production # until beginning of July. Does this sound right?
He said my car will be July production at the beginning. Then, last week he said it'll be August production. Do you know (or can you guess) what this indicates? (I told him as long as it makes to September 3rd pick-up, it will be fine.)
Any answers will be appreciated.
Do you live in a snow area (I don't recall where you live)? How does the slightly tail heavy wagon handle in the snow? Have you used snow tires? With my SP and living in Chicago I will definitely be buying snow tires (even without SP, I am buying them).
This option (330 xi SP) in Canada is similar to the 330i or 330ci SP option in the US (i.e. includes perf tires + different front-rear tire/wheel combo)
Trust me I wish it was like the US SP on the AWD xi where you get same size wheel/tires and all-seasons, a more logical proposition if you ask me.
Now you also get me worried when you say "awd cars require absolutely identical tires and i cannot believe any dealer ....". Care to elaborate ?
Now, its the final leg, the trip to the dealer!!
Good luck!!
