i'm going to calculate my gas mileage, as it seems in the winter i agree gas mileage seems less; what you do is fill that baby to the top, set the trip odometer to 0, then travel for a good 300 to 400 miles, then fill up to the top again, then do some long division....
The rear speaker grilles are attached to the rear shelf. DO NOT try to pry them off - you will break them.
To change the speakers, you must first tilt down the rear seat backs, then remove the clips holding the shelf in place. The seat belts go through the shelf - I have not yet gone further to see how to pull the shelf down with the belts attached so I can remove the so-so speakers and replace with some good ones. I also plan to replace at least the front tweeters with some larger ones for better midrange.
I figure it's worth the $50 to pay a local installer for the labor headache!
Sedans alone they have about 22 different models, including the ones that are sold under the Lexus brand here in the U.S.!
Here's a link. If you don't have support for Japanese, you'll be prompted to install it in MS IE or you may see lots of boxes if you have Netscape 4.7 (either way you can still see the pictures).
http://www.toyota.co.jp/Showroom/frame.html
I have a 2K SLE and have noticed a small area on the muffler where the black paint is peeling off. I purchased some flat black 'Plasti-kote' brand engine enamel that's supposed to withstand temperatures up to 500 degrees. I cleaned, then sprayed the peeling area with the paint, let it dry a bit, then drove the car for about 20 minutes to 'cure' the paint application. I recall others mentioning paint peeling from their mufflers and was wondering if the steps I took will remedy the peeling paint situation.
Other than the above, my SLE (w/moonroof, traction, side air bags, in-dash 6 disk changer, mats) has been outstanding. No pulling to the left, no squeaks, rattles, loose trim or other quality problems. I get between 26 & 27 MPG with 95% highway (60-65 MPH). I now have about 12,500 miles and expect to accumulate many more trouble-free miles.
Still smooth & creamy -
MMCCLOSKEY - 2K SLE V6 - Silverstream
I love my Solara otherwise (and highly recommend the car). Mine is a '99 Diamond White SLE.
If you let go of your wheel and it pulls hard, that is an indication of an alignment problem. If it takes effort to keep in a straight line, that is also an alignment problem. Be careful not to confuse the two.
The service dept mgr has been working with me on this problem for over a year and has been unable to solve the problem. I wish it was as simple as an alignment or tire problem, because then it would have surely been resolved after 2 years of attempts from 3 different dealerships.
Any solutions/recommendations anyone has would be appreciated. Thanks in advance.
An alignment specialist may find one setting that will cure your pulling problem. Unfortunately, you will have to pay for this yourself. Since the car is with Toyota's alignment specifications, it will not be covered under warranty but I'll bet you can cure this outside a Toyota dealership.
thanks for any response
solara1
will it work?
also, anyone have a comment on mille miglia wheels??
brian
Will
99 DE V6
sand drift metallic
The problem is in the strut towers - the mounting hole for the struts is a LITTLE oversize, so the bolt can move a little in the hole, making the clunk. Other than the noise, it causes no harm. My dealer brought this to my attention, and offered to make the changes, and now - no more clunk! There must be a TSB on this, but I am not sure.
Automophile is correct about the strut tower problem. I had the same "flunking" sound on my '99 DE V6 5-sp. I brought it into the dealer to look at that and a small leak in my transmission. The etch said that there is a TB for the '98-'99 Carry's but not the Solara's. They change some mounting brackets, since the factory re was in that day and thought that the faulty brackets might have been installed on early model Solara's. As for my transmission, at 57K, the dealership ended up replacing it with a new one. Apparently my leak was a faulty transmission casing that was cased at the factory incorrectly.
Happy Motoring!
Automophile is correct about the strut tower problem. I had the same "clunking" sound on my '99 SE V6 5-sp. I brought it into the dealer to look at that and a small leak in my transmission. The tech said that there is a TSB for the '98-'99 Camry's but not the Solara's. They changed some mounting brackets, since the factory rep was in that day and thought that the faulty brackets might have been installed on early model Solara's. As for my transmission, at 57K, the dealership ended up replacing it with a new one. Apparently my leak was a faulty transmission casing that was cased at the factory incorrectly.
Happy Motoring!
'99 SE V6 Diamond White Pearl
thanks solara1
Well, I explained to my service rep. the clunking noise problem when going over some bumps and asked them to check the struts, strut mounts and strut towers yesterday . HOWEVER, the technician instead tried to duplicate the problem and could NOT. So he DID NOT inspect the struts, etc. as requested!!!
ISSUE #2:
He said that the clunking noise occuring in the rear end when accelerating from a complete stop, was normal brake pad noise! Does that mean that the brake pads "stick" the the rear drums and when I accelerate, this is noise of the pads breaking loose from the rear drums? HAS ANYONE ELSE EXPERIENCED THIS CLUNK when accelerating from a complete stop?
They did replace my "seat track" which resolved the rocking motion in my driver's seat.
'99 SE V6 Diamond White Pearl - 23k
Sorry for the delay in getting back to you, but I have been out of town for a few days. Here are the current specs following my recent alignment...
Left Front:
Camber -0.60 degrees, Caster +3.40 degrees, Toe 0.00"
Right Front:
Camber -0.70 degrees, Caster +2.60 degrees, Toe
0.00"
Front Totals:
Total Toe 0.00", Cross Camber +0.10 degrees, Cross Caster +0.80 degrees
Left Rear:
Camber -1.10 degrees, Toe +0.11"
Right Rear:
Camber -.90 degrees, Toe +0.10"
Rear Totals
Total Toe +0.21", Cross Camber -0.20 degrees.
These numbers do not make sense to me, but it does seem odd that the specs on the left and right do not match. Perhaps that's they way they are supposed to be, but to the common man (like myself) it looks unusual. However, I also take the word of the service dept that if it's in specs, that it's in specs. Therefore I conclude that it's not the alignment causing the pull.
Any thoughts you have would be appreciated.
Also, Cliffy1- I'll take up your advice and look into locating an aligment specialist.
Thanks-
PNC
a pulling problem,see if the caster can be adjusted higher on the right side.
The clunking noise I experience is in the wheel wells when going over railroad tracks and some pot holes. No problem with my dash.
'99 SE V6 - Diamond White Pearl (23K)
fairway green 1999 SE V6 5 speed, 30K miles, new coinbox, dwight yoakam in the JBL in-dash CD 200 watt singing The Heartaches Are Free, with accord V6 coupes disappearing through the rear view mirror...
Here is Cliffys response to Cblake2 on another Toyota's Steering Problem (Sienna V, message 612, July 31,00)
"Cblake2, I know of no commonly recurring problems on the '99s. In fact the only problem other than this latest one was on early '98s that had a suspension issue that made them IMPOSSIBLE TO ALIGN. This covered a small number and most have been handled".
No mention here of Independent Alignment Shops.. the small number is 715. Sienna's Steering racks re-designed by Toyota Engineers as a result of a Government Investigation (NHTSA Case PE99-070(1998-2000) Failure of Steering Wheel to Return to Center(steering locking into a left turn)), triggered by 13 Sienna owners complaints. Sienna shares the same powertrain and platform as the Solara.
I have taken my Solara to Dealers to get it aligned to keep the steering from locking into a left turn( 6 times) and they cannot fix it, changed Bridgestone tires that Dealers said were the cause and that didnt fix it, now Cliffy says we should take them to Independent Alignment Shops....Are you kidding?..., like the Sienna, this is A JOB FOR ENGINEERS.
But Toyota ENGINEERS can only Fix the Solaras Steering defect IF you let the NHTSA know at: WWW.NHTSA.COM
http://users.ev1.net/~gunpilot/misc/spring1.jpg
Neil
'99 SLE
Red\Gray
27,800 miles
How has the ride changed? One thing I love about the Solara is the super-smooth cruise on the freeway. Is it rougher with the new springs?
Also - The car will look even better if you de-badge it. I feel that the side badges really break up the long lines of the car.
Rawn
2000 SE V-6 5spd
(the turn mentioned here is 3 lanes wide, and I use all three when doing this
