Mercedes-Benz E-Class Sedans
The primary advantage of using 18" wheels over 17" wheels is the handling difference, which in my opinion, can only be felt in a race track or in an extremely smooth highway with quick turns that require precision handling - like race cars that go over 200 mph. With less rubber between your rims and the pavement, the car will be more responsive and stable during turns. However, that handling comes at a price. The ride is harsher, and the rims prone to dents. On city streets the 18" wheels becomes a detriment since the minimal rubber between the rims and the street will not protect your rims from potholes and pavement cracks. I have known 17" inch wheels to get dented in New York city potholes. Furthermore, tires for 18" rims on sedans have limited weight bearing capacity and are not always all weather. Unless, you are bill gates nephew, or if you use your E class in a race track every day, I cannot find any logical reason why anyone in this world would want to replace 17" wheels for 18" in his E class. Oh, I almost forgot the last reason - the "look at the 18 rims on my E Class!!" reason.
W and S mode,
Read your manual! The only difference between the W and the S mode is starting the car from second gear (in W) instead of first gear (in S). This is for use only when you are starting from deep snow, since you don't want your rear wheels to spin from too much torque in first gear. Starting in second gear will avoid this. When was the last time there was a snow blizzard in Florida and why would you want to start your car in second gear when it rains?
Yours truly,
President of the read your car manual club.
do not need to be answered in such a manner. IMHO, simply ignoring the question is much better approach.
As to the 18" tires and wheels question, the stock E-55 comes with them as standard equipment.
Since my next vehicle will most likely be the new E-55 with 18" wheels I wanted to read some comments about them. My 17" wheels have no dents or dings and my roads are in good condition.
Perhaps, someone else on this board with an E-55 would respond to my question. Thanks.
This website has the best photos:
http://www.news24.com/News24/Wheels24/Archive/0,3999,2-15-890_1131559,00.html
There is a lot of information already available on the web, plus mbusa.com has info up now on this car.
I think it's gorgeous! Can't wait to get mine!
Another wet weather observation not found in the owners manual: My E320 with MXV4 tires is much more stable in strong cross winds at highway speeds with the tire pressure increased to 31 psi front and 34 psi rear. Ride quality is minimally harsher and alloys are better protected.
Any thoughts on the end of lease purchase price - $35k? The car will have about 14k miles. Any experience as to whether Mercedes Credit negotiates the purchase price at lease end? Any thoughts are appreciated.
I have Michelin tires on both cars. At 60+ mph the noise is noticable over the stereo. Noisier than on my prior Lexus ES300.
I previously said, these are minor bitches. I plan top trade in my 98 for an '03 when the new model comes out sometime after August.
I like the size and compromise of driving control (handeling) and comfort in the E model. I hope MB tightens up on quality control. I had to replace the transmission on the '98 model right at the end of the 4 year warranty period. I bought an 8 year extended warranty (4+4) for the '01.
Jean
Jean
If you haven't tried Zaino on your silver E-Class, do yourself a favor and try comparing it with Zymol. I think you'll be amazed!
As for looking very old in two years... Is the gullwing that old looking? Ugh.
Just be happy with your car - and don't worry too much about what is a good price or not. Since, for the most part, no two people ever paid the same exact amount for a car.
Good Luck,
Ed
There very well may have been some suspension fine tuning, as in 2000 MB made quite a few changes to the E. Most of them were cosmetic. however, I'm sure some mechanical changes were made also as they tend to make subtle changes every year. Depending what tread pattern you have on the Michelin's, they can be noisy also, but not as noisy as the Goodyear Eagle F1's. By chance did you change the wheels to 17" from 16", as that can make the suspension feel different?
Wally
I believe they changed a fan speed regulator and possibly temperature sensors.
If the condition matches the very low mileage, it sounds attractive to me. But I'm not familiar with market specifics.
My pool little arms get tired after one coat of Meguire's as it is.
I don't want to ask this in the Zaino topic because some of those posters are a little too fanatic about it.
If your paint doesn't feel smooth when you run your fingers over it (when the car is clean), you may want to use a clay bar. I've never used one, but I've used Zaino on my silver E320 since it was new -- I probably have 15 coats by now. But I understand that claying is a breeze and can be done in about 15 minutes -- IF it's needed.
Recommend that you wash the car thoroughly with blue Dawn dishwasher detergent, dry, apply Z-1 and allow to haze (the Z-1 when applied, and later the haze, will both be very difficult to see on a white car), then apply Z-2, let dry completely, and merely wipe off. Don't apply more than one coat of Z-2 in a 24 hour period unless you use ZFX instead of Z-1. Follow with Z-6 (optional). After several coats of Z-2, you'll be amazed at the deep wet-look shine, even on a white car! You'll also be amazed at how long water keeps beading, especially if you renew the Z-2 every so often (after a thorough wash with Z-7).
Biggest mistakes using Zaino: Using too much, especially on light colored cars (a little bit goes a looooong way!) and not allowing the Z-2 to dry completely.
Hope this helps. The Zaino web site (www.zainobros.com) is worth reading thoroughly, especially the "tips."
Louis
Jean
Louis
IMHO, Zaino will do more to protect your E-Class's paint than anything on the market. My brilliant silver 2000 E320 looks better than new, and it's seen nothing but Zaino since I removed the dealer's prep wax just after I took delivery.
I would add several cautions about NOT buying the 2002 E-Class. First, the 2002 is now a proven product that underwent a major face lift with the 2000 model. Most likely all the "bugs" and problems have been eliminated or minimized by now.
Second, many people avoid the first model year of any new car. Often there are problems that the manufacturer will fix in the second and subsequent years of the model's life. So, you may want to wait a year and then buy an '04 model E-Class (if you don't opt to go for the 2002 model).
Finally, from the photos I've seen, the new '03 E-Class strongly resembles the previous 210 generation. However, the new car also has many improvements.
It will be a tough decision either way. But with MB's increased emphasis on quality, you won't go wrong either way.
Hope this helps. Let us know what you do and how satisfied you are with your decision.
But, for me the cost and labor of the Zaino is not worth the difference.
Please check out this site
http://www.nsxsc.com/nsexcitement/waxtest.html
This NSX owner did his own testing of the two products and Zymol did very well. Yes, the Zaino is better but not by much. If I had a dark colored car I would spend the extra time and money
on the Zaino. Zymol is cheap, easy to apply and readily available at Wal-Mart. As the test shows, it is a good product. M-B recommends a Carnauba based wax on their paints: Zymol is Carnauba based.
So, those of you who want a good alternative to Zaino should seriously consider Zymol. Zaino is not available at stores but can be purchased easily online.
The service manager said new brake pads are usually needed every 20,000 miles or so. The rotors should last 40-50,000 miles and he recommended new rotors be used. What is the usual cost for new front brake pads at the dealer?
Can anyone with similar experiences help? I'm going to call my dealer on Monday.
1)clean the car with dish washing detergent;
2)applying Z-1;
3)applying Z-2 and
4)wait for the waxing completely dry and remove with 100% cotton towel.
Is that the right procedure? Your comments and advice would be appreciated.
Louis
I use Zaino on my own cars as well as offering it to my customers AND I provide a 3 month warrantee with it. I will re wax the entire car if the shine or protective functions fail within that time. I know there will be no claims because I redo my own Lincoln every 4 months with no adverse effects! I have total confidence in Zaino's products.
The primary difference between Zaino and Zymol is that Zaino is a synthetic wax, that is, it is man made. As such the qualities the "Designer" wants is made molecule by molecule. This is why it lasts so long and produces such an intense shine. Zymol is a "natural" carnauba wax. It produces a much "warmer" or subtler (if that is a real word) shine. It will also melt/evaporate if exposed to direct sunlight for any extended period of time. At best I would never go longer than 3-4 weeks without re waxing with Zymol. The choice of which is "better" is an individual one.
Please feel free to email me directly if anyone has any detailing questions. I have provided my personal email address in my profile so as not to confuse your questions with my business. Thanks for allowing a "lowly" Lincoln LS owner to post here (I am looking at the '03 E class to replace my wife's Infiniti).
http://mbspy.bacosys.be/c219.htm
Now I have new problems, the center vents sometimes stay shut and will work normal again in a few minutes. Took the car to the dealership, but they couldn't service it if the vents work properly at that time. Have to go there more ofter, I guess.
E320 is a great and balanced car, I really enjoy driving it. Just wish it were as reliable as my Toyotas.
Since I have so many problems with my E320, I would avoid a 2003 E320. Buy it now or wait a little bit for 2004 model.
and know everything about the car and try your luck. Sometime it is all timing.
http://www.canadiandriver.com/articles/jk2/03e-class.htm
I wish I had a pro detailer in the family. I used to do a bit of it on the side for extra cash, and it was brutal work for what I was charging.
Valueguy: in case you haven't gotten any more brake job pricing info...my dealer quoted about $550 for the front pads, rotors, and labor.
I had my local mechanic do the same job for about half that using genuine dealer parts (though it took half the day just to get the parts delivered). The parts themselves are rather pricey themselves, but I'm hesitant to use aftermarket stuff.
http://www.mercedes-benz.de/mbd/html/interak_betriebsanl/e_klasse/betriebsanleitung_start.html
Jean
The E model will undergo a change in the '03 model comming to the US in a few months. You might want to hold off and make another comparative test until then.
Yesterday there was a change of servers (I think it was yesterday?) Maybe somehow you got caught up in that and it won't happen again.
However, if it does happen again (or any other strange event), go to the Help link at the top of this page and find the Feedback form link to report it.
Glad you found your way in, anyway!
Pat
Sedans Host
