Mercedes-Benz E-Class Sedans
17879818384131
  • haspelbeinhaspelbein Member Posts: 227
    Greg,
       okay, I hope you used a trim tool to compress the sides of the plastic rivets, otherwise you can possibly damage the trim itself. (No need to panic, you're probably fine.) But I highly recommend spending the $5 on the trim tool.
       Actually, pulling the trim is not the first step. But let me list the steps in order:
    Tools necessary:
    a) Trim Tool
    b) Drill and 4.8mm or 3/16 inch drill bit.
    c) Riveter
    d) Assortment of screwdrivers.
    e) Torx bits (or driver) for electric motor mounting.
    Steps:
    1.) Use a very small screwdriver to pop the hard plastic shell behind the door release handle. Use a large phillips screw driver to unscrew the screw behind it. Its probably very tight.
    2.) Do the same with a small round plastic cover under the actual (big) door handle. The same kind of screw needs to be removed.
    3.) The door has a small clear light in the bottom. Use the small screw driver to remove the light. Disconnect the two connectors.
    4.) Use the small screwdriver to remove the window switch in the rear door. Gently, oh so very gently, use the screwdriver to release the clasps that hold the switch.
    5.) With the trim tool, pull the lower part of the trim away from the door. Feel the plastic plugs with the trim tool, compress and pull them. Be careful not to damage the moisture barrier.
    6.) Unscrew the door lock pin and remove it. Also remove the small plastic trim cover from the door lock itself.
    7. )The top of the trim is held by metal clasps.
    Gently lift the trim up. If you can reach, gently push up the horizontal part of the trim from below. Completely take off the trim.
    8.) The door release cable is still connected. Disconnect it from behind the release lever.
    9.)Now your should see just the moisture barrier. Gently pull it off. Be careful, it rips easily. Pull it just far enough to expose the regulator mechanism.
    10.) Unclasp a small plastic clasp from where the window connects to the plastic slider of the regulator. Move the window slightly to the side until it unhooks, and push the window all the way up. (It should support its own weight in that position.)
    11.) Presuming that the regulator mechnism took a hit and is responsible for the power window failure, take a 4.8 mm (or 3/16 inch) drill bit and drill through the 4 metal rivets holding the regulator. Drill straight through, and dont use any larger bit,or you may damage the door.
    12.) Unconnect the electrical connector on the regulator, tilt the regulator and pull it out. Mine looked like this.
    13.) Use the torx bits to remove the electric motor from the old regulator and transfer it to the new one.
    13.) Install the new one by sliding it into place and push the new rivets into place. (I would suggest connecting the motor and the window to the regulator and testing the assembly at this point of time, before the rivets are set.)
    14.) Use the riveter to set the rivets that came with the new regulator.
    15.) Steps 9 to 1 in reverse.
    Good Luck !
  • r1_97r1_97 Member Posts: 181
    It seems each year Mercedes improves the handling on the E model. The acceleration of the 3.2 is about the same as our '01 model but steering around the cones is a bit improved. I'm not sure, but I think the E320 test models had the standard (not air) suspension. The brakes stop really fast. I jammed on breaks at about 65mph and made a very fast and controlled stop.
    The 500 definitely was faster, but I don't think it would be of practical use except on a race track. The air suspension was only marginally better zipping around the cones.
    Bottom line: Both are excellent cars and I plan on buying the E320. I don't see the marginal benefits of the 500 worthy of the additional costs of purchase, gas and insurance.
  • microrepairmicrorepair Member Posts: 508
    Martin,
    That repair sequence is awesome! Since I too have the 96 E, I may need that in the near future..
    So when are you going to publish the other 286 chapters in how to fix the "E"...??
    Fred
  • pathdocpathdoc Member Posts: 126
    I attended the event on Sat. and second the impressions posted in # 3986 above. As far as the E320 went it was hard to directly compare to the E 500 since the course was slower and all the E 320s had the standard suspension rather than the adjustable. When I did my runs in the E500 I kept it on the firmest and the car was quite impressive on the autocross. I also kept it in 2nd or 3rd which made it significantly faster around the course.
    I doubt that you'll see the other 286 chapters any time soon. I only post what I've done myself, and the E is simply a pretty reliable vehicle. So not too much comes up.
    The only other thing I could offer are the steps of how to remove the instrument cluster...
  • gmacostagmacosta Member Posts: 14
    Thanks very much for the great directions and pics.lots of people here will surely use it. you must be some kind of engineer over there? btw where did you get that trim tool?. i will invest in one? many thanks!
    Gmacostca, you're welcome.
    Actually, any autoparts store will sell you one. They are pretty generic, looking like a thin miniature crowbar with a handle at the end. I got mine at PepBoys, I believe.
    No, I'm not an engineer, unless you'd count a physics degree, and I'm not really over there, unless you're referring to California.
    Anyhow, with the release of the W211, the repair & service manuals for the W210 should be released on CD pretty soon. Has anybody any details on when that would be ?
  • rayscarrayscar Member Posts: 70
    The TV show Motorweek will be doing a road test of the 2003 E Class on October 25th. Check the listings in your area for the time and channel. It's on PBS. They usually do a good job on their tests and will probably be a 5 minute or more spot.
  • matthewhmatthewh Member Posts: 19
    I have a 2000 e320. I hear a whistling/whinning sound when the AC first starts. It is kind of stop and go for the first 15 minutes. I took it back to the dealer and they replaced the fan. The problem is still there. Any comments or suggestion? Is it normal?
  • maui19maui19 Member Posts: 31
    I have a 2002 E320 and would like to get a roof rack to carry skis, bikes and the occasional snowboard. I need something that's easy to install/remove since I will take it off when not in use.
    Does anyone have experience with rack systems on their E Class?
    TIA
  • mcqueen4mcqueen4 Member Posts: 6
    I am looking to purchase snow tires for DH's 2000 E430. What brand would your recommend? Thanks!
    I am by no means a Michelin fan, but last year I got a set of Michelin Artic Arpins for my wifes car (based mostly on Consumer Reports' recommendations). These are exceptional snow tires. They are quiet and very sticky on ice and snow. They seem to wear very well, too.
    They handled a New Hampshire winter without any problem at all. I plan to get 4 for my E-320 this winter.
  • paulchiupaulchiu Member Posts: 378
    Car & Driver did a full road test on a loaded E500 in their Nov 2002 issue. There is also a complete road test on the SL55 AMG, which is more than 2x the price of the E500. Needless to say, they liked both.
    Reading the charts and numbers, the only ratings that troubled me were the 3 comfort ratings for the E500. Rating only "good" for general and Fore-and-aft support "Comfort", and a "fair" for lateral support. The comfort ratings for the last E class the mag tested was for the 2000 E55, when they rated as "good", "excellent", and "fair". So it seems the fore-and-aft rating has actually dropped for this last model change.
    The all important 0-60 is an impressive 5.8s. The 2001 E55 had a 5.5s time.
    Paul
  • et610et610 Member Posts: 40
    Paulchiu:
    What does the ratings measure. "General; Fore and Aft; and Lateral"
    What do they measure and how does it affect the ride and confort.
    I will look for the November issue of Car & Driver.
  • merckxmerckx Member Posts: 565
    The "General" rating is just that-a meaningful yardstick for how much you'll like the seat.
    But "Lateral" and "Fore-and-aft" are ratings of how planted you will remain during aggressive driving. So it isn't a comfort factor at all. Cheaper cars often have quite narrow,bolstered seats. The thinking is that only younger,still in shape guys will be driving then. As in the little Accura coupe-fabulous seats.
    But in expensive cars,often middle-aged and older drivers buy them. And few of of us middle aged guys are still wearing size 40 suits.
    I find the ratings by Car & Driver to be pretty accurate. They rarely give excellent on all 3. In fact, the 3 Exe's they gave to the SL55 AMG was a first for a Benz from my memory. I don't remember any under $30K cars ever receiving 3 Exe's.
    While the 2000 E55 had only 1 Exe, I found the seats more comfortable than my 2001 S500 seats. C&D did give the Lexus LS430 3 Exe's, but I have never driven longer than a test drive in those, so I can't say how great those seats are.
    C&D once said that the seat comfort ratings is from the average of 3 reviewers. If all 3 have the same physique and different from ours; then these ratings are useless. All in all, I found these ratings to be good in scanning before buying.
    Paul
    i will tackle this window project this weekend. some quick questions. your step #2, is this the outside door handle? i have no small plastic coverings but i do see a small screw which requires a phillips. and step #4 where is the clasps that hold the switch?left,right, top, bottom? i pry it out carefully on the switch or that hard plastic shell? i'll get part at thousand oaks mercedes tommorow. the 96 part with motor was $212 and 98 w/o motor was $92. just reply here or just email me. thanks
  • kkopskkops Member Posts: 14
    You question regarding a 2001 E430 4 matic, is it worth it? I have been driving mine for about a year now and the car is marvelous. It performs in dry weather and rain and snow incredibly and I am an agressive driver. I live in NJ and in the mountains, so I need a car that has AWD, its a must. This car is great since it works well in all weather yet also performs like a sports car. When I first got the car, within two weeks, we had a 17" snow storm and cars were stranded all over the road. While the Lexus's, Jaguars and BMW's were either spinning out or left on the side of the road, I was driving home comfortably and smiling with my OEM tires (Pirelli 7000 Supersport).
    In addition, I have driven non 4matic mercedes such as the S430 as well as the E320 and the ML320. I believe you get a much better feel for the road with the 4matic. Probably because when you take your foot off of the gas, you get a little drag due to the 4matic which you don't experience with a non 4matic.
    Good luck!
    I don't think you have you e-mail address published, so I will respond online:
    1. It's the inside handle. The whole operation is on the inside of the door. You won't even look at the outside.
    2. Pry out the whole plastic shell around the power window switch. It's actually easier. The clasps I was referring to hold the actual electric connector in place.
    Hey looks like the parts are cheaper where you live. I wasn't sure what part I needed, or I probably would have ordered it online.
    Good luck !
    my email addy is now public. inside the door handle i saw that big screw to loosen but i didnt see the small plastic covering and other small screw. i'll look harder. hmmm i know we have the same car. did you buy rivetor? i think my uncle has one anyways. email me back, dont want to bother other people on post with all my questions. thanks!.
  • jjsanijjsani Member Posts: 14
    Anyone know what the cost for the Nav system option is going to be, without any pre-paid discounts.
    MB or Edmunds doesn't list the Nav system as an option.
    Any comments from owners who have the Nav system in their 2003 E320...
    The MSRP will be $2,125. But as you posted if you prepay now you get $500 off and installation is included later and it's under full warranty. I am taking the discount. Since it won't be available until the first quarter of 2003, you won't find anyone who has it in a 2003 E.
  • marsha7marsha7 Member Posts: 3,703
    Thanks for your response...any other comments about the car are always appreciated...does it spend much time at the dealer for service, or does it have the supposed reliability of the Japanese imports???...
  • rtcjrrtcjr Member Posts: 3
    I have a 2000 e320 and just recently I also have a low whistling sound with the AC. It usually starts after about five to ten minutes of driving. Also, the fan speeds up and slows down in the non-auto mode. I have not yet taken it in for repair. The noise is annoying.
    Also I have the MB roof rack system with two bicycle holders. It is fairly easy to use. It requires a screwdriver to install. On the top of the door jams at the roof, there are arrows to indicate where to align the racks. After a couple of times, I can put the racks on in about 10 minutes. They come off quickly. I have not had any problems with the roof rack. I have not had any marking or scratching on the car. With the bicycle rack component, the strap on the fold up arm for attaching to the bicycle is a little difficult to undo. Also, the key is a little hard to insert and remove. Generally, I have been pleased with the rack. Sometimes it does whistle while driving. Since the trunk is so small, the rack system has come in handy for carrying oversized items. I do sometimes get looks from people that seem to question why am I carrying that stuff on an E320.
  • spirollispirolli Member Posts: 50
    Well I thought I quieted the rattle/vibration in the front end as mentioned in my previous post. I was looking at the engine and saw that one of the metal brake lines was out of it's track. It was allow the entire master cylinder to move. As I said, I thought I quieted the noise but it's still there. I am convinced that it is something mechanical in the engine making an adjustment or something like that.
    As far as my brother in law's car... the dealership came and picked it up at the office. Called him later that day and told him they were giving him back his car because the parts he need (SAM & Amp (the SAM needs to be programmed by the factory)) Unfortunately, neither part is available in the US and has to be shipped directly from Germany taking 10-14 working days. I would be crazy. He has to drive around for the next 2-3 weeks with a radio that just squeals. Today, his SRS Warning Lamp came on. The malfunction indicator says "requires dealer service". Amazing considering the car is less than 2 weeks old.
    Steve
  • franman23franman23 Member Posts: 4
    After two weeks and 350 miles, my brake system malfunctioned in my 2003 E320. It's been at the dealer for the past 4 days as they wait for a new control unit for the braking system. Has anyone else had the same problem with the 2003 E320. I'm a little disappointed having waited two months for the car and then the brake system goes out after two weeks. I guess new technology has its caveats. I guess I'm just unlucky. Hopefully its just a fluke and knock on wood I'll have no other problems.
  • jawandajawanda Member Posts: 30
    Also, check out Yakima or Thule racks. They're both well made, easy on and off, with fittings for most cars, and therefore interchangable among your vehicles. They have a wider variety of options available for carrying anything.
    Taking an ad-hoc survey here. Can those of you 2003 E Class owners tell us how the ride and interior noise levels compare with your previous Mercedes? As most E and S class are such quiet cars, one can often hear tiny sounds from frames and consoles; especially when driving with no radio and in the middle of the night.
    Any help here is appreciated, as I begin my next upgrade cycle...
    Paul
  • jim256jim256 Member Posts: 14
    I picked up a 2003 E320 on October 2. Noise is less than my prior '01 C320, less than my prior '98 E320. Very, very quiet mechanically and no wind noise, no interior clicks or ticks. Very well assembled, more solid feeling than either car mentioned. I did have an SRS fault at 340 mi., taken care of with an overnight part (Gateway Control Module), no problems with any other electronics although I expect like any computer they will fail early if at all. I just went to the Mercedes "On-Track" experience and was very impressed with the E320 in a slolom and track environment. The ESP is seldom appreciated in normal driving, but on the road course and track at Richmond International Speedway you could push as hard as you wanted. It would not spin out, I never hit a cone! It was especially nice to practice with something other than my own. All 2003's: E320, E500, SLK320,SLK AMG32,CLK320,C240,C320,SL500. The SL was by far the best but the E with and without the electronic suspension was very similar. I have no regrets. My thanks to Tysinger Motors in Va! (options: E2, heated seats, rear shade, full leather).
    Yes, the 2003 is much more "sure footed" compared to my 1999 E320. The 2003 is rock solid. No wind noise, road noise or any other noise for that matter. The interior is amazingly quiet and that's without the stereo on at 50-80 Mph.
    I drove home from work last night in a pretty bad rain storm and at 65-70Mph, the car felt glued to the road. Very sturdy and confident.
    The ride is different compared to the 1999. It's much tighter and responsive. It feels as if the wheel base is shorter... maybe it's not but it feels that way when you hit bumps. My 1999 had more of a slower, longer more cushy bounce. The 2003 has more of a BMW type ride. Barely any bounce, more firm but still gives a very nice comfortable ride.
    The breaks seem much more sensitive compared to the 1999. Softer to the touch and much more accurate.
    I really haven't tested the performance as of yet since I only have 700 miles and I don't want to start pushing it until after 1000 miles (as per the owners manual break in period)
    Steve
  • jean7of9jean7of9 Member Posts: 192
    Just placed an order for a 03 BMW 330xi Orient Blue with Sand Leather: PP, AWD P, Nav,PDC, RS,6CD. I was amazed how fast BMW Germany accepted the dealer's note and sent the car into production for an expected delivery at the dealer's lot by the second half of November 02. I have never forgotten your note about the "3.0 litres engine will grow on you". Will keep my 99 E-320 4matic until the new "Direct Injection Engines" are available.
    Jean
  • joeadpjoeadp Member Posts: 68
    When is the new engine coming for the E320?
    How much more HP than the current version?
    New E owners: How do you rate the brakes on your new E in regular (non-panic) stop situations?
  • valueguyvalueguy Member Posts: 210
    After a few weeks of driving a BMW with the inline 6 you come to appreciate the smoothness of this engine. It rev's willingly to the red line and power is continuous throughout the RPM.
    A great engine when mated to a 5-speed or manumatic tranny. But, nothing beats a V-8 for pure low end grunt (except maybe a V-12) and city driving.
    Jean, the BMW will also feel more sure-footed on the highway at triple digit speeds. I Still prefer my E430 for comfort and routine driving around town. I hope you enjoy your new car.
  • linardlinard Member Posts: 59
    Top Gear Magazine just rated the E-Class as first compared to the Volvo S80, Jaguar S-Type, a Renault, and an Alfa Romero, and they concluded by saying it was obvious the E was going to win. Anyway, they rated quality as being much higher than recent Mercedes and especially over the old E but they thought the value equation could have been better as the options can get pricey. All in all, a really good article!
    I thought this was a Mercedes Benz discussion group. Why are you talking about the BMW. Isn't there BMW discussion groups for that ?
    In non-panic situations, I honestly cannot determine any performance or "feel" differences in the Sensotronic brakes. I expected to experience some difference. The manual does advise that you conduct a "hard stop" periodically if you have been using light braking in order to improve brake performance, but I am not sure what that does to the system. Perhaps it is only to improve pad grip in case of glazing.
    MB is expected to make the Direct Injections engines available by fall 2004. More power with more milage. Also BMW is expected to come with similar engines (Valvetronic)around the same period. My present E 3.2 litres engine is running so well that I am motivated to keep it for a while.
    Jean
    Jean I agree with your thoughts.
    My E2000 is running great and I still like
    the style.
    I looked at the new E but am willing to wait for the new Direct Inject engine. The new E did not move me enough to say I want it now.
    Joe
  • mbe2003mbe2003 Member Posts: 12
    I think the brakes on my E 320 perform well but I feel they took a little getting used to. A little of this may be in my head since I am paying attention to them since I am interested in how the system works. A little of this my be because I am used to driving a stick shift so I am used to letting the engine wind things down and just stepping on the brakes at the very end.
    To me, they stop great but it seems like I need to put a little more pedal into it (press a little further) than I would otherwise. I think I need to take my wife's C out and do a comparison to be sure.
  • stvirstvir Member Posts: 13
    The "chauffeur" stop takes some getting used to. I am used to lifting my foot off the brake pedal in my old car to soften the stopping action as I get close to a complete stop. But, now, the E320 does the same action for me automatically. However, by not lifting the foot off the pedal, the final stop becomes jerky. To avoid this, I've learned to re-apply the foot-lifting action AFTER the SBC has done it's job and just a few feet from where I want to make the final stop. Once I've made a complete stop, I then have to remember to apply the brakes firmly again. Otherwise, I will start coasting forward because of the creep action of the vehicle. It has happened to me twice and, luckily, I always leave enough space between me and the vehicle in front. I pressed on the brakes in time to stop my car (again!).
  • shaunsshauns Member Posts: 24
    Re: 4032:
    Can any 2003 owners comment on how much the noise
    increases when traveling over coarse roads, such as worn asphalt? Most luxo cars I've tested are quite quiet over new asphalt, but some become really loud on worn/rough roads. The previous generation E-class had a resonant boom at 35-45 MPH. Lexuses, by contrast, suffered little noise
    increase.
    Also - anyone have any comments on the E320 with Airmatic Suspension? The E500 is overkill for my needs and the tires may be too aggressive for good noise control - so I'm wondering if the Air suspension will compensate for most of the body roll of the E320 standard suspension.
  • dermartindermartin Member Posts: 4
    This past weekend I reserved an E320 sitting off the coast of California (who knows when they will get it off the boat). I had a choice of 2 E320s, one w/ more options (Keyless Go, E1, Wood Steering Wheel, CD Changer, E2). My wife did not like color combo, so we went w/ E2, cd changer model. The dealer commented that they can no longer order the wood steering wheel, as MB has taken it off the options list. Is anybody aware of this or why this is?
    The factory wood steering wheel is not on the "build your own" list at MBUSA.com, although a few early arrivals at the local dealership had it at $700 on the factory Monroney label. Now, the wood wheel is shown only as an "accessory" listed at $705 along with the notation "Actual prices vary by dealer and do not include labor, installation charges or local taxes." No reason given by my dealer.
    I picked up my E320 on 9/30 with the Wood/Leather Steering Wheel. The dealer charged only $500.
    Was it installed at the factory or by the dealer?
  • ccmguyccmguy Member Posts: 1
    I recently took delivery of an E500, to go along with my trusty 380SEL. Today's E-Class certainly advances the art of the comfortable, quiet ride to my mind--and by a wide margin over the last decade. I think M-B captures the art of evincing relaxation and confidence better than any other marque.
    Having just discovered this group, however, I wanted to say a word about the postings by that ilxman fellow a while back. He was certainly obnoxious, but I think he said some very important things about the future direction of M-B that are critically important. I'm a gray-haired marketing consultant and I'd bet a dollar that this guy is an under-35, highly compensated business exec. What he said tracks exactly with the views of some of the most desirable demographic groups for a luxury brand like M-B: namely, BMW has been setting the bar for what the "best" driving experience should be for these youngsters for the last decade. To these people, BMW is the best "luxury" car marque (not just with "sports nuts"); M-B is the "best" only at the S-Class level, which is relevant to them only when they get old. In fact, the C-Class rates so far below the 3-Series that it's not even close.
    Hence, BMW (and others who have focused on the post-baby boomers) has done a much better job in setting the standard for the younger crowd. M-B meanwhile, has done a fantastic job in catering to us baby-boomers. What that ilxman character is saying is that M-B had better not assume that his demographic cohort is just going to go from cars like the 3-Series to the E-Class just because of the power of the 3-pointed star--M-B is going to have to demonstrate a superior driving experience. But what I call "relaxing", his cohort calls "boring" and "not fun to drive". My 31 y.o. son (he and my 2 daughters are BMW fans) just showed my a review of the E500 in Car and Driver magazine where he noted that it was considered very nice but not up to the BMW 5-series standard. He also noted how M-B's highly touted new braking system failed to stop the car better than BMW or even the Lexus G430. He, too, then asked why the M-B cost $63k. I don't much care, but these types of reviews--monotonously showcasing BMW superiority at the 3- and 5-series levels--do filter out to the younger crowd over time.
    In the end, ilxman called for better steering precision, simpler ergonomics, better road feel, and better quality control. I'll agree with him that those would be improvements. I have better road feel with my 380 vs. the E500--but I call that progress over the last decade in giving me the cocoon I crave; my children call it engineering out all the fun. What we saw with that ilxman episode, I believe, was nothing less than a generation gap exposed. As a 20-year M-B fan, I'd also challenge Stuttgart to start paying more attention to the younger crowd. Let's make M-B #1 across the board--as long as we don't forget about the M-B faithful that have been happy the past 20 years. [A good start would be taking some of that AMG know-how and putting it in the entry-level 320's and C-series.] Happy motoring!
    The steering wheel was installed at the factory. It also came with the E5 option package.
    "My 31 y.o. son (he and my 2 daughters are BMW fans) just showed my a review of the E500 in Car and Driver magazine where he noted that it was considered very nice but not up to the BMW 5-series standard."
    You must have read a different article than I did. I don't recall that statement anywhere in the latest issue. I thought it was a very positive piece on the E500 IMHO.
