-June 2024 Special Lease Deals-
Has your car suddenly developed this sluggishness or has it always been
this way. If you have in excess of 40,000 mi. on it , you may need the
throttle body cleaned. Sometimes it gets carboned -up. Of course with
so many computer controlled devices on these cars, I think a good, and
reputable dealer would be your best bet.
Another option would be to drop in the 3.5 litre VQ engine . :-)
Zoom , Zoom !
Pretty soon it's due for a tranny and coolant flush, so maybe the throttle body is another thing to put on the list.
Anybody wanna trade for a 6sp ;-)???
Seeya
disassembly ) and a spray cleaner was used. I'm not sure what's used now !!
Actually, on the 2k2's there's sometimes a very slight throttle lag on
initial acceleration , but I believe this has been attributed to the "throttle
by wire " system. ( not on the 2k's )
You seem to indicate that the problem is (front-end) vibration when breaking. If so, you probably have warped brake rotors. This was one of the warranty problems, as I recall. I have the same on my 2k GLE. Will have to see the dealer for the first time ever (I do my own filter and oil changes).
Any difference in features between '02 & '03?
No. There is no difference. The only thing is there is a Titanium Edition SE available which has some color & inside finish differences and the rear-view mirror has a compass built-in.
I have a 2003 Maxima GLE and was even able to get the same pricing I was quoted on the 2002 the month before. Great Car !! Anyone looking for a Max... you really can't beat the overall product for money scenario.
Member of http://www.maxima.org & http://www.nissanx.com among others.
regards
happy motoring!
There was some discussion on maxima.org about 5th generation maximas benefitting greatly from a new set of spark plugs at the 40-50k mark. (I believe they were a 60k replacement part on the 3.0 5th gens...)
I have a Maxima 2002 GLE, and was wondering
about oil changes...
I've always changed oil in my previous cars
about every 5000 miles. A friend of mine who
works with trucks told me that if I use Synthetic Oil in my car, I can aviod chaning the oil every 3-5k miles, but can rather do it every 12k miles or so.
So a couple of questions:
1. Is this true?
2. If so, I'm sure the dealer sent me away with
regular oil, how do I switch to Synthetic or
does that just happen with my first oil change?
3. How often do people recommend getting an
oil change for this car?
4. Can Synthetic Oil do any damage or cause problems further down the line for me?
Thanks for all your help..this is a great board
and learning experience!
I have 2 nissan maximas, a 1996 GXE and a 99 SE.
I bought the GXE new, and after 1000 miles, I changed the oil with regular oil but when the car hit 5K miles, I changed it to mobil one synthetic, and every 5K miles, I change the oil.
150K miles later, the car is running like a champ. engine is as good as new. So I would use synthetic after 5K miles, and change it every 5K miles thereafter. A few bucks spent on oil changes is worth it.
My 99 SE has 46K miles and I do the same thing. I basically buy a case of Mobil 1 and Nissan oil filters and take it to the local lube place and have them change my oil using my filter and oil. Since I am right there, I do see them use the oil and filter that I supply.
Also if you use synthetic oil later down the line, there will be no damage since cars these days have much better gaskets than cars of 20-30 years ago so that means, using synthetic wont make the gaskets leak.You should have nothing to worry about.
Good luck with your Maxima! Excellent purchase :-)
Anyone out there who's driven both of the 2002/3 model (6 speed and auto). Is the manual significantly quicker than the automatic or are both as fast as I would like?
I searched the board a little for prior postings regarding knocking, but those dealt more with persistent pinging. Most of those seemed to involve ignition coil issues.
So my questions:
1) Anyone else experienced this type of behavior?
2) Is this normal, or something to be concerned about?
3) How sensitive are knock sensors? I assume the reason it goes away after a split second is that the sensor detects it and makes the appropriate adjustments. But the fact that I hear it at all is surprising - I would think the sensor is more sensitive than my ear. But I could be wrong.
One possibility is that I got some bad gas - I only started noticing it since my last fillup. Another remote idea I had is that it might be caused by the the heat/humidiity (but that could be a completely incorrect theory).
Grand High Poobah
The Fraternal Order of Procrastinators
Grand High Poobah
I posted about 30 posts ago that I get a vibration every time I come to a stop in my 00 SE 3.0 Auto. I wasn't clear enough. The vibration is in the steering wheel. It starts vibrating on deceleration at around 5-10mph and lasts for a second or two until I stop completely. It feels like electric motor mounts or something. It doesn't feel like brakes at all. I can feel it start buzzing, and if I'm in stop and go rush hour where I never come to a complete stop but I hover around 2 to 5mph, sometimes it'll continue to vibrate constantly until I either stop dead or speed up above like 10mph. I don't even have my foot on the brakes and it's buzzing. It's highly annoying and reproduceable every time. Any ideas on what it could be, or if there's anything that can be done? A TSB perhaps? I just hit 34.5K miles and could try to get it fixed before the warranty runs dry.
Sweet car, but wish I would've waited til the 3.5 6sp. I figure I'd get crushed on a trade in.
Seeya
I have a 2002 6 speed with just over 6K miles and have never experienced knocking. I would agree with kennyg5 that you got some bad gas. I don't know whether temperature has anything to do with engine knocking. I live in Northern Calif. and it can get pretty hot out here (suppose to be 110 degrees this week)but not too humid.
noise , but I think the mounts only made a noise AFTER the engine
was shut off. It still could be a related problem. If so, the dealer will
pay for it.
Check out " maxima.org." and " alldata.com" for their TSB's.
Just bought a 2002 GLE. When I test drove the car I did not realize how a slight difference in road surface would bring so much unwanted noise into the cabin. Have the Bridgestone Turanza EL42? tires in 215/55R17. Does anyone know if the noise is related to the tires or is this just the nature of the car. If it is the tires, any recommendations for replacement? Thanks
It's been over a year since i've been in here and I need to buy a new car! I had an 01 GLE with 14,000 miles until it got totaled by an Oldsmobile Cutlass. Insurance gave me 24,720 for the loss and next week, i'm going to go buy a new car. I test drove the Acura 3.2 TL, Passat V6, BMW 325ci, and man the 6 speed Max killed all of them in accleration. IT EVEN DID A BURN OUT AT 2ND GEAR. I am heading out next week to buy an 03 GLE and just curious if this is now a good time to buy? I was thinking about a GLE with sunroof,meridian package and floormats. You guys think I can get it for 26,000-26,800? Any feedbacks would be appreciated. Also, is there still a paint problem for the 02,03 maximas? With my 01, I felt like the paint had problems in it.
thanks!
~Jerry
I have a 02 Max SE 6sp with a little over 6K miles. I drive approx 80 miles round trip to and from work 4 days a week. I have noticed quite a few spots where the paint has been chipped off in the front area of the hood due to road debris. I can't imagine what the hood is going to look like 3 or 4 years from now (without some touchup paint). Is it a paint problem, design issue (the angle that the hood is sloped), a combination of the two, or would it be considered normal for the type of driving I do? I think it probably is a combination of all three. This issue aside, the Max delivers great performance for the dollar and is a fun car to drive. If you end up buying the Max, I would be aggressive on the price you are willing to pay.
I have them inflated at 33 psi all around and they are soft and squishy around corners.
Noisy??? I'm not sure you can find a less noisy tire than the EL42 which is (as far as I know) the only Grand Touring tire available in the 215/55/17 size category. The Good Year RSA's used on the G35 is absolute crap, the Pilot A/s are great tires if you're looking for performance BUT you will pay the penalty ride/noise wise. You will feel everythnig on the road.
Other Michelin's ....the MXM4 & MXV4's will ride rougher and noisier. But these are available only in 225/55/17's (closest).
Btw .... I blew out one of my Turanza EL-42's last week and had no choice but to get it replaced at my Infini dealer if I wanted to make my 4th of July weekend roadtrip.
I was quoted $205 + $45 installation for the same EL 42 that is priced at $105 at Tire Rack! While I don't mind paying my dealer a few extra $'s for an oil change the difference of $100 for ONE tire pretty much amounts to daylight robbery.
Moral of the story: get your tires done at Costco Discount Tire or ANYWHERE else but the dealers.
Unfortunately 215/55/17 is not exactly a common size and not many discount retaliers will stock them. If time is of essence, as it was in my case, then you're left with no choice but to go with the dealer.
If you're shopping for Michelin's or Bridgestones Costco is the way to go. Haven't looked at Sam's yet but I'm sure their prices are comparable.
Any suggestions what the problem might be? Car has 20,000 miles on it.
Jim
Good Luck
Jim
Dealer tire installation - anoter alternative is to purchase the tires from tirerack, or any other discount place and then bring them to your dealer to install. I did this a couple of years ago, and my BMW dealer was very reasonable with the price of installation. In this way you ensure the job is done properly, yet you get the tires cheap.
.... the I35 is basically a GLE w/ a few extra bells and whistles.
They are fixing the problem in the U.S.A. but said they were not doing anything with the cars in Canada.
They are now?
I have lost all faith in Nissan and their dealers
Two recalls and the hood bounce is three visits. That is more than I had with my Ford Focus Wagon and it drives better than my 02 GLE
My next vehicle will be a Saturn
I had called Nissan Canada and they called back and said no action would be taken in Canada regarding this problem.
They did react after Transport Canada was contacted.
Please carefully read messages on this board as it will help you comprehend the disussion.
