Visitor Agreement.
JazzerMP
Do you think there's any possibility that the repair costs (that are quoted)are inaccurate due to warranty coverage being in place on the 5th generation and probably not in existence on the 4th generation?
Have you called the local Nissan dealer and ask them to quote their prices for these repairs?
The numbers just don't seem to make much sense to me either. I guess the good news is that the odds of having to get these repairs done on a Maxima are much less than most FWD cars.
FYI, my 95 GLE with 190,000 miles has only had the shocks/struts from your list and is still in excellent condition.
The most frequent repair has been for oxygen sensors (twice) and brakes (twice).
I would approach this pending purchase cautiously.
The 2000 Max had what has been widely characterized
as a "fuel cut out" problem w/ the manual tranny.
The existence of that problem caused me to buy my
SE w/ the auto transmission. Nissan has since cor-
rected the fuel cut out issue (though if my memory
serves me correctly, they never "formally" ac-
knowledged its existence) Maybe some others on
this board can be more helpful regarding this.
I do know this.........at the time, early 2001,
there were numerous posts on this board about
the problem. Good luck.
berbel
"The primary benefit of high-octane fuel is its anti-knock characteristic. In addition it may contain higher grade additives that help keep fuel injectors and intake valves clean.
Modern engines deliver far more power and fuel economy than their predecessors by employing a higher compression ratio and utilizing sophisticated combustion chamber designs and valve, fuel and ignition management systems.
Operating the engine on a lower octane fuel than specified will invite engine-damaging detonation and reduced power and lead to expensive repair bills. Premium fuel burns more slowly than less costly 87 or 89 grade. The air-fuel mixture burns at a lower temperature, providing a smooth and controlled flame front, lessening the chance of a hot and stressful explosion. Detonation can damage pistons, valves and head gaskets."
1. The Max is a sporty car that is also a practical family sedan. In this price range (around $25K), what other midsize sedan is as sporty while still being practical? The WRX comes closest, exceeding the Max for sportiness, but failing in the family sedan area (small trunk, no folding rear seats). The Grand Prix is another, but is neither as sporty as nor as practical as the Max. Plus, the Max has a better interior than both.
2. Front wheel drive. C&D complained about torque-steer and wished the Max was RWD. For those of us that have to live through winter, this would eliminate the Max from many people's list. Yeah, you can get winter tires for your RWD machine, but it's an added expense and hassle (two more visits to the dealer/mechanic per year - yay). Hmmm, I can get this vehicle that'll cost me a couple grand more in tires and about 10 extra visits to the garage, or this one that'll do fine in most conditions without buying new tires. Tough one.
3. C&D stated that the G35 would be a better choice. Sure, if I've got an extra $4000-$7000 (depending on the Max trim). But what if I don't? Plus, the RWD issue.
Basically, I think they want the Max to be a BMW with more cargo space. Well, guess what - a 3 series goes for like $35K without adequate cargo space. I'll take my $23K Max and be very happy, thanks.
The numbers in the Consumer Guide book are NOT related to warranty status. I also have a three year old version of the guide when fourth generation Maximas were still on warranty and it contains the same repair costs.
I haven’t spoken to my Nissan dealer about this because they haven’t given me very straight answers in the past.
I’m glad to read that you’ve had good luck with your Maxima. How much did new struts cost you? Was it in the ballpark quoted by Consumer Guide?
My 1997 SE 5-speed has 135,000 trouble-free miles. The potential cost of replacing struts, a clutch, a pitted windshield and brakes in the sometime future has me rationalizing a possible trade up to a used 2002 with remaining warranty.
Make sure that you review its repair history.
Steve
Seeya
Mine computer needed reprogramming twice in the first year (about 4 months apart). The dealer was unable to tell me why the light came on.
Steve
That said, however, I think the current Maxima is a very good car, except for the rear suspension, particularly in light of its reliability record and engine design, which I recall has been rated 10 best in the past 7 or 8 years.
- many squeaks and rattles
- rear bumper was re-painted due to misalignment of trunk
- reprogramming of ecm due to problem on cold start
- reprogramming of ecm due to "fuel-cut" problem
- replacement of front brake rotors after 15,000 miles
- transmission problems after 5,000 miles (stranded on side of highway when car would not go into 1st gear)
- power drivers seat switch was replaced
- all 6 ignition coils were replaced (it was tough convincing the dealer to do this since no tsb was ever issued for this problem in Canada even though one was issued in the US and the cars are virtually identical)
- axle seal was replaced when transmission was leaking
- axle seal was replaced once again when transmission was leaking
- faulty altinator was replaced (this one stranded me while on vacation and over 150 miles from nearest dealer. Thank God that Nissan roadside assistance picked up the CA$700 towing charge)
- leaking transmission (for the third time in under a year) prompted the dealer to overhaul the transmission. Fault bearings were the problem.
- other minor adjustments and problems
While I have had many problems, I know of at least 3 friends who have 2K+ Maximas and none of them have had any problems at all. Maybe I have a "Friday" car. I am not sure. Hopefully the problems will not continue as my warranty is about to expire.
GLE has "wood trim" and 55 series tires (I think), but what else is different than SE?
service dept. knew me on a first name basis....I
was there so often. Maybe their build quality is
better now that seven years has elapsed but that
experience left a very sour taste in my mouth for
GM products.
Incidentally, rumor abounds that they are bringing
out a new Gr. Prix called the "G Force." It is
supposed to be some whiz bang new sports sedan.
We'll see.........!
berbel
4- door sports sedan ) since Mon. 9/6 has been over 33. The Jetta board had
over "30" in one day.
This board has had 6, and 3 of those referenced Pontiac's. What the
" H " is going on ??
Let me try to resurrect this virtually dead board. Why does the VQ35
engine take a smaller oil filter than the VQ30 ? Don't say it's an economy
move because the VQ30's filter is already quite small. Do the engineer's
want the oil pressure to come up faster ? Are there any Nissan Tech's
out there that could answer this ?
come loose over time. This has not been a common complaint. ( at least
not on the drivers side ).
another brand of car on the Max board.
Roarl.....don't be so hard on mirth and I......
we've had a long week!
Mirth.....what else do you know about the G Force?
Just curious!
berbel
Pontiac board. Just a thought !!
which would save me the time and effort of going to
the Pont. board. Give me a break, Roarl!
Pat
Sedans Host
I'm hopeful that by the time I need to replace my 1995 SE, BMW will still have it's European Delivery program intact.
I had been shopping used hondas, new Toyotas, and now used Maximas in an attempt to get the best bang for my buck.
Fell in love (danger will robinson) with a Black Special Anniversary Edition Maxima. The dealer has listed it as a 2000 model, but 2 things strike me as weird:
1. Edmunds (and other sites) only list the Anniversary edition as a 2001 model year.
2. The carfax report he let me read over (just to prove the car was good) had decoded the VIN to a 2001 model.
Was the Anniversary edition only a 2001 option? If so, that's cool that the dealer has it listed improperly I would think.
Its a Mercedes dealership, and they sell their trade-ins. They gave me an offer of 19,900. It has 26,400 miles. The offer is below what Edmunds says to shoot for, so I love the offer. The car is a very sweet ride. That thing purrs.
So if anyone could answer the model year question, that would be great. Oh, and of course, what they think of the deal.
Look at the Dunlop SP sport A2. Well regared at tirerack.com. I just put a set on my wifes Quest, and they work well.
Also check out the Yokohama Avids (tourings probably). Supposed to be a good tire at a very good price.
TIrerack is a good place to start to narrow down what will work for you, based on your criteria.
There is also a "tires, tires, tires" topic on one of the boards in TH where you can ask the same question.
03 Max,
Majestic Blue, black leather
Meridian, Titanium, traction control, sunroof,leather & trunk mat.
2. I just bought a brand new 2003 Maxima SE for ~3k off a 26.5k sticker. NISSAN is overloaded with Maximas and they are dealing. Your price of 19.9k for a 2001 seems a bit high considering that. 3. If you do like the car, ensure that you are entitled to the balance of the 3/36k factory warranty. If not, what warranty do you have? GOOD LUCK...
For me there's a big difference between 26.5 and 19.9 (me personally and my budget). I did ask for opinions though, and congratulations on your drive! Sounds like you got a great deal.
Dealer said it was a 2001 (like you confirmed) and had misprinted something.
For the area I'm in, and the amount of shopping I've done, I'm happy with the deal. Its the first time on any car I've shopped that I've gotten a below TMV/blue book value. Oh, and it comes with the remainder of the 3 year/36k warranty. Hopefully though, the "bullet proof" status of these engines that I've been reading about and the reliablity rating is good.
That, and I think I look cool in it.
Thank you for replying, I appreciate it. Have I mentioned I'm excited and happy? The car in close running for this was a camry that nobody was moving down in price on, so the Maxima wins...and I think I got more car for my money.
