Visitor Agreement.
car is making slight mechanical noise when turn left or right, they lubricated the iss; noise seem to gone away but now re-appearing when making a lane change over a bump.
Air cond. was sealed and recharged a month ago, it was really cold for a few days, now feel about the same.
engine light came on, they fixed it.
I love the car otherwise, plan to keep it for a few more years. Just had the brakes done 2 weeks ago.
BTW, these have to be the easiest lights to chang on the planet. REmove two clips, pull the headlight asembly forward and take off the rubber cover. Even I can fit mybig mitts to change the bulb.
Good luck!
I noticed the other morning if the car was cool inside, the A/C would stay on. Later in the day when the interior was hot, the system would cycle on and off with the resulting on/off of the light on the button. As the interior would cool off, the cycling would slow down and eventually stop.
Explain that one!
Deke
I think the 16" chrome rims for the 2005 Buick Century special edition are the same chrome rims from the 2000-2002 Olds Intrigue. I was driving in Lansing, Mich. this evening (on s.b. Waverly Rd @ St. Joseph for those in the area) and pulled up next to a silver Century and though it was an Intrigue until I looked closer. The center lug cap has the Buick shield instead of the Olds symbol. I have an '01 Intrigue with these rims (minus chrome) and like them, but am surprised how GM used leftovers from Olds on Buicks.
Can anyone confirm this? Is this new for MY '05 or are these from the '04 year too?
This was confirmed by someone on the Century board.
A CENTURY OF ALL CARS GET OUR COOL RIMS
I could not find the posting?
Anyway, here's a repost:
It's just to the passenger side of the license plate. It faces the outside of the radiator. You can get to it without lifting the car. Good luck and let us know how it goes.
dpete4 -- Ambient temperature registering low. Had same trouble. Replaced Ambient temperature sensor P/N 10248414 located in front of radiator and behind bumper. No tools needed. Cost $8.45 + tax.. Good luck..
In 2002 I had the dashboard cover replaced to fix the warping around the center air vent. Even the second cover warped there, but I did fix it by inserting a couple wedges under the center air vent.
Compared to my 1996 LSS, this car has had a few more problems than I would have liked.
On the bright side, with the steering fixed, the car is fun to drive again. The car no longer uses too much oil ( I guess it is broken in), there are no rattles, and the mileage is about 20 in the city and 30 on the highway.
If I remember correctly, the intermediate steering shaft was a common repair?
Bryan
Regarding ISS: Yes this was a very common repair. I believe now they only recommend lubricating the steering shaft.
The problem I had was twofold.
One, turning, especially at speeds less than 30 mph, produced a clunking feeling that radiated up the steering column. Hard to explain, except it felt like the tires might fall off : ) The entire front end just felt loose.
Two, the power steering unit was going bad, so not only did I have the clunking/loose front end, but at low speeds, I had not power steering.
For the first problem, there was no noise, just a feeling that my $25000 car had a $50 front end.
The intermediate shaft restored the solid feeling to my car. It is amazing. With the problem, going over bumps caused the front end to feel like it was going to fall apart with the tires going in seperate directions. Now the car literally takes bumps like they aren't there. You can't even feel the slightest of vibrations in the steering column.
Of course, it is also nice to have power steering when backing out of my driveway now.
If I remember correctly, the intermediate shaft was a big problem for 98/99 models apparently some 2000 models.
Luckily, my dealer turned its service department around. Each of the 3 times I brought the car in, they have found all of the problems I mentioned and fixed each of the problems, the first time. The last time, I was really hoping they would replace the intermediate shaft. When I looked at the invoice, I almost fell over. It is just so unusual to have a competent service department.
Bryan
When I get back from vacation I will pop into my dealer and order one.
Still love my Intrigue. It's my daily driver actually and I have not seen another car that I would rather have yet though the Pontiac G6 with a 3.9L V6 is getting close. If I can swing it, I dream of the CTS but I have to get a better job.
the problem that i have is not that bad yet, but i'd like to fix the slightest problem before my warranty is up. Next time i'm in the shop, i'll insist that they fix 1) the clunking noise (getting more noticable), 2) occasional non-starting, 3) the driver's side window making noise when going down.
coonhound: Sorry to say, unless you have a bolt-on supercharger the Intrigue won't be smoking any Maximas at 70 mph or otherwise. My '03 pulls hard all the way up past not-really-legal speeds.
VS. Nissan of 2000 222 HP and 217 ft. lbs was somehow a winner in any contest I had. I think the torque curve got them. Also this is 3.5 in the Intrigue and 3 in the Maxima. But as far as I know the Nissan still requires premium juice.
Many believe that Nissan fudges a little on HP claims. Maybe so.
After 3 hours, they told me that didn't have the tool to remove the hook that's hodling the filter, and the guy decided my tire does not need any rotation at all.
he also removed my air filter to show me how dirty it is, then he stuff it back in by just lifting the cover by force!
Crappy tire, now i know how you earn this reputation.
crappy tire is one of the largest, #1 national store in Canada.
it's ok if they don't have it, but they should check availability when i check in, not after 3 hours. Don't you folks agree?
I would take my GP to a GM dealer but they always take so long. Costco is cheap, but again, it's usually a long wait.
anyone knows of a cheaper source in canada?
Going to see the appraiser/adjuster on Saturday AM, but with $500 deductible, I doubt the bill will be more than that. Also checking in with a body shop known for doing amazing work on customs, rods and muscle car restos recommended by a close friend to see what he'll charge.
Aside from a couple of door dings (normal NYC battle scars) this was the only damage to the car in the 6 1/2 years I've had it...
Still have "only" 38960 miles on it and will most likely be trading it in on a new Dodge Magnum once the house is sold.
Mention noise no driver side problem, they clean and lub. the assembly and is now noiseless.
Called the part dept for price of air filter and was told $14.95, had it replaced and was charged $22, went back to the parts dept. and the price is now $19; at least they washed my car. Oh well.
they suggested a Power steering flush next time.
Fender can be repaired rather than replaced, if I read the report correctly.
Also will replace the cracked front license plate bracket - was broken for about 4 years; one of the weakest pieces of plastic I've ever run across!
To paint one scratch on the bumper, the entire assy needs to be removed and repainted.
Most of the cost is labor and paintwork - restripe the fender, matching, etc. Hope I get a full body detail out of too.
Picked out the shop and will go Wednesday. Guy works on the local street rods, customs and restorations. Owner has a customized 62 T-Bird in orange with scallops, airbag suspension, lots of neat period bodywork and has flame throwers.
Three of my friends recommend him hands down. Maybe he can jack up the cost to cover my deductible.
First claim I've ever had in 25 years driving, second car I've owned that was hit, but first "anonymous" hit and run...
Deke
She will be missed...
The Intrigue currently has about 81K miles on it. Believe me, when it comes to actually selling her, I'll be interviewing for the best candidate for stewardship! With any luck, I'll sell it to a family member (a few have expressed interest) and I can always check up on her health from time to time. : )
akitadog, A Mini in place of an Intrigue? Strange, but they are way cool cars.
