Also, the transmission seems to be a bit noisy. Whenever it shifts between 2nd & 3rd gears, it make a should that I can best describe a chirp, similar to when a car ‘chirps’ its tires in a parking lot when driving a little to quickly. Other than that, the shifts are smooth & timely.
Any info would be appreciated. Thanks
Our 96 Civic does that. I think it's just the clutch slipping. It's been doing that for about the past 3-4 years so I'm not too worried about it being a major problem.
I'm sure you can get it fixed pretty easily if it bothers you but I don't know who could do it for less $$$.
I'm in the market for a used car. I'm a serviceman near a military base in Germany and there are only a limited number of US spec cars here to choose from in my price range ($10k-ish). I'm down to 2 cars which are the only realistic choices since they are really the only ones with a warranty that is at all substantial. They both come with a 5/75,000 mile bumper to bumper.
The first one is a 01 Prizm, white and 3 SPEED AUTO, with power everything, cruise, 17,000 miles on it, and CD player for $9000.
The second one is an 02 Focus, also with power everything, CD player, cruise, and 10,000 miles on it, for a cost of $11,000.
I like the sportiness and unique looks of the Focus, it's OK on fuel economy, but the quality/reliability is infamous for this model, and this is what is holding me back from really being excited about it.
I like the reliability, and fuel economy of the Prizm, but the bland looks and the 3 SPEED auto trans are a turn off. Plus, I hear that the 3 speed has much lower mpg than the 4 speed. I would probably have no hesitation if it were a 4 speed with overdrive.
Can anyone give opinions as to which one they would choose were they in my shoes, and why? I will post this in the Prizm forum also and see what they say. Thanks.
Dean
FWIW, I used to work as an engineer for a Ford supplier, and Ford typically reacts quickly to fix problems. If you look at F150 reliability studies, it got better every year it was made. The same can be said of the Focus. The latest J.D. Power study had the Focus scoring slightly above average for its segment. It deservedly got bad press in the beginning which has proven very difficult to overcome.
--So I recommend the Focus heavily. (full disclosure -- I'm a 2003 Focus Wagon owner)
Dean, I used to drive a 1996 Prizm with 1.6 liter/3 speed auto drivetrain. It’s my daughter’s car now. It was fine for 125,000 miles, now it is suffering from old age. The tranny has been replaced, it has a cracked exhaust manifold and other numerous problems that happen to cars with high mileage. My only complaints about the car when it was new, was lack of power and gas mileage was okay, but not great (about 30-32 mpg highway driving, the same as my Focus which has way more power). Plus, without the overdrive gear, the Prizm was LOUD on the highway – lots of engine & exhaust noise.
As for my Focus, which has 46,000 miles, it has had more than its share of problems. The brakes squealed loudly at first until the dealer replaced the pads, the engine was replaced (yep, replaced) because a “bad cam” left me stranded one night, the alternator would drain the battery dead whenever the car sat for 2 days, the passenger footwelll leaked rain water (cause: cowl was bad). The one good thing was all of this work was done under warranty and didn’t cost me anything. The car itself is a blast to drive, which is why I’m still hanging onto it. All of the recalls affect the 2000 & 2001 models only. Since 2003, Ford feels confident enough to offer the 5 year/100,000 warranty here in the states so I wouldn’t worry about quality to much.
It's new car time, and the Focus is about to leave my possession.
The car is now out of the shop after going in for the first time in nearly three years. Got my recalls done, resurfaced the front rotors to get rid of the shimmy (they were warped), replaced the clutch pedal return spring, and had a sensor in the exhaust replaced. I don't rightly remember if it's the recently-mentioned DPFE (or whatever it's called), but the above items are the only things that have "gone wrong" except for the check engine light coming on once two years ago and then not recurring until the exhaust sensor needed replacing, and a flat tire about two weeks after taking delivery of the car.
That's it. So... For those considering buying a Focus and are turned off by the negative comments coming from this board, thought I'd be one of the few to give an unequivocal recommendation.
The reason I am getting out of Focus Land is that I wanted something bigger and nicer, so I've made the switch to a Mazda 6S. The Focus SVT was on my short list, but I decided for the same price I'd get a V6 and more room instead.
So, my work is done here, I'll miss the Focus but it was time to move on.
Good luck to you all and your Focii!
-SHOV6
-paid $8800($8000 plus $800 buyer's premium...got it at an auction) for it...good deal? Has Leather, manual tranny, CD, all the goodies pretty much.
-I have until next June on the warranty, has there been any recalls on this car that might have slipped by the original owner(was an estate sale so the car sat for a little while).
-What's the common problems seen with these cars, what should I look out for?
-I see that there is some rust on the muffler that might be premature(the car sat outside so maybe thats why? I also noticed a some rust around the fuse box housing that sits under the left end of the dash..this normal?
-Whats the usual milege? Sticker said between 25-31. Can't always trust those however. Just want to know what to expect.
-Only came with one key....how much will it run me to have another one made....I read in the manual that you need two to make an extra by yourself so looks like the dealer will have to be involved.
So far I love it, drives great, runs great, handles nice, if anyone can be of help on these questions(and the others that come to me later) I'd appreciate it....thanks all.....masshoosier.
What you should do is take the car to the dealership and get them to look it over before the warranty expires. Also, get them to run the VIN# in their dealer database, so they will find any recalls that were issued on the car.
I would also bring up the rust. There should be no rust on a model year 2001 car this early. The dealer will also have to make you a key, since the Focus has a chip in the key for the theft system.
It seems that the fuel pump becomes a problem on these cars, so it might be worth it to price an extended warranty on the car if you tend to keep it for a long time. Since you got a really good price on the car, you will have some cash left for the warranty.
Good luck with the car, and let us know what the dealer says.
How much should the an extra key run?
Thanks vocus...appreciate the feed back
The dealer is the only place you're gonna get the key, unless you can find a blank key from Ebay and have the dealer cut and program it. VWs are the same way, the keys have to be programmed and cut by the dealer only. Makes for an expensive replacement, but peace of mind that your car's not easily taken.
Would a Ford Tech be able to activate this feature on a Focus - or is that only available to activate on Ford Vehicles with Automatic Headlights?
Do you Focus owners know that, with the exception of the original Motorcraft battery, it is virtually impossible to obtain a new battery for your car. I have checked at least 15 major battery suppliers with no luck. Anyone out there find a seller of Focus batteries?
Well rated and seem to be a solid company. Rates are competitive and cheaper in most cases. I have two policies with them. Never used them yet, so I can't comment. Check out their site, their BB rating, etc. Then check a couple others and make a decision you're comfortable with. I recommend them based on the research I've done.
Hope this helps.
driving larger cars or SUVs, despite whether you traded from big to small or if you still have the larger vehicle. He's especially looking for drivers of the Mini Cooper, Honda Civic, Ford Focus, Dodge Neon, Hyundai Tiburon and Mazda Protege. Please respond to jfallon@edmunds.com by Tuesday, October 28, 2003 with your daytime contact info and the type of vehicles you had and have.
MODERATOR /ADMINISTRATOR
Review your vehicle
It's a Ford dealer in CT. I saved several hundred dollars buying from them versus Ford ESP. I called Ford ESP to verify that I was signed up with them per my instructions and everything checked out.
PS. I have a 2000 ZX3 with 29K miles and have had zero problems. I purchased the extended warranty for peace of mind. I plan to drive the ZX3 two more years and than sell the car while it still has 6 months or so of warranty coverage. It's transferable.
My son's 2001 SE is about 2 1/2 years old and has over 45,000 trouble free miles including a round trip from NY to LA last spring. Recalls, yep...he had a couple done on them and I have no problem with that (heck, in the old days a problematic car was your problem).
Would I buy another Focus? Yep, I think I would because it is a small car that has a great ride, good power, a nice interior, and pleasant styling. Does it have lousy press??? You better believe it does and some of it was justly deserved but for all the people driving a problem Focus, I would venture there are hundreds if not thousands of very happy Focus owners.
Sorry if the sarcasm of my last posts was lost on some of you.
I saw an ad recently for the Focus, which said something like, "look again at the Ford Focus, look again now that it has a 5 year 100,000 warranty on the engine." That whole "look again" tag-line seemed almost an admission that an above average number of people who bought the Focus in its first and second years got sub-par cars. As far as I've heard, the engine of the Focus (either one) has not had any reliability issues. It has been other elements of the car that have been problemmatic.
http://www.detnews.com/2003/autosinsider/0311/04/c01-315932.htm
Focus hater's can not use reliability as a weapon any more.
I know that taking a car to be repaired is a big hassle, but I do wonder whether paying $2K extra now in hopes of avoiding a "possible" $1K problem several years down the road is worth it.
Of course, while this does reduce demand (referring to another poster who said the bad rep reduces demand), it also reduces resale values. Everyone with older Focus models still will get crap for resale (either trade or private sale).
Meanwhile this does NOTHING for me and my 2001, which is plagued with problems. I'm bringing it in tomorrow for the second time for a non functioning A/C. I hope it costs a lot of money to fix because I bought an extended warranty and I want Ford to pay.
In Ford's credit, the last time I had to get the car fixed, I had vowed I was going to dump it. I drove a Matrix, a Corolla, Civic and Scion. They CAN'T TOUCH the Focus handling!! There is N-O-T-H-I-N-G in this price class that comes close to the combination of handling and ride comfort.
So, I will continue on my love/hate relationship (love the car, hate the company) until the extended warranty runs out. At that point, it probably would be better to donate it to charity and take the write-off. I don't imagine it will be worth much at 100k miles.
The new euro Focus is BEAUTIFUL, but even if it ever does make it to the US, I've already sent too many nasty letters to Ford to ever consider buying again.
Just to recap, since Jan 2001:
3 DPFE sensors
1 EGR sensor
1 Clutch Spring
1 Radio
1 Rack and Pinion
1 A/C cycle switch
2 Sway bar endlinks
1 Set of sparkplug wires
Rust around the sunroof (factory)
Worn seat fabric
Still hesitates
And finally, bringing it in tomorrow and I'm guessing the compressor is gone.
