If you haven't already, you might want to look through the various Town Hall discussions on leather. Most of them are archived, but they still have good information. There is one active one where you could also post. Just put "leather" into the keyword search on the left side of the page to find them.
Heres the final problem tally:
water pump & seat heater
carpet pulling out from sides
oil and valve cover leaking
Water in headlights had to replace 1 driving
light after the OEM bulb burned a whole in it and it filled up with water.
Dash display would go haywire.
Fan/AC would only work on high or not at all.
Various broken trim pieces.
Various rattles and sqeaks.
Windows creak if only halfway down.
Check emissions light would come on after any extended highway time. Nothing found wrong?
Worst paint on any car I have owned if they put any thinner of a coat on they would have to take some off.
Automatic lights would click off an on then go out sometimes had to manually turn them on.
You have to be standing next to the car to use the keyless remote.
Thats all I remember, it will be a long time before I will consider another GM and I know everyone will say there are always lemons but I have been in two other Regal/Century's one with only 1k on the clock and it exibited some of the same problems as my 97.
According to Edmunds, the typical trade-in price for the make and model, with typical options, are about $3375 for LS trim, $3800 for GS. Given the discussed car had (broken) heated seats and auto climate, it probably was loaded. The $2500 trade-in means that either the dealer haggles better, the car was in really bad shape, or/and it have much more than 90k miles on speedometer.
Regal was updated in 1999(?) or possibly 2000: water bottle was moved to different side, some changes with not supercharged engine, less chrome, etc. According to recent Consumer Reports, Regals are the most reliable used cars. It means that less problems were reported by CR subscribers who own Regals than by Camry or Accord owners. However, it is for 99 or 2000 and later years, not 97-98.
Yurakm if you really want to go by CR they also list about 10 GM products as worst picks. I personally don't hold to much faith in CR or JD Powers for that matter as the data gathering methods can be somewhat suspect. You can make statistics say whatever you want.
This car was not abused my wife drove it primarily as a family hauler.
Jpstax1 yes no car is going to be problem free but this car was rediculous! And as I said I drove 2 others one was a 2001 with similar problems.
Jack44 we didn't buy a Honda we bought an 03 Explorer. Do I think Fords are perfect no, but for me and a lot of my relatives and friends they have been the best of the domestics.
Our car, a 98 Malibu, requires serious repairs about two times a year. Between the repairs it is fan to drive: very nimble, precise steering, holds our twisty hilly CT roads very well, and is tight as a drum. Great in city traffic and good on country roads. The only complain - it is bit underpowered on highways, especially when merging or when passing uphill.
However, the repairs are annoying. We had to replace transaxle at 47k, two different parts of A/C at about 55k+ and 65k+, alternator at about 65k, coolant tank fell apart at about 55k. A coolant leak developed from intake manifold soon after the original warranty expired. $500+ in labor to replace the gasket. Another gasket cost $200+. Water in rear right lamp. Several items were covered by the original warranty: speakers, sensor of closed door, resistor in fan switch, etc., etc.
However our second car, a 2000 Regal GS, is fine. Not impeccable, of course. There were two initial problems: a defective multifunction stalk switch in steering column and warped dash which rattled like mad. Dealer replaced the switch and, after some pressure and unsuccessful attempt to fix it, he replaced the whole dash. No single problem since.
Yes, we put only 35k miles on the car, but these are mostly city miles. The car was built 4.5 years ago, in November 99, and bought in October 2000. Enough time for problems to develop. It sat on a dealer lot for almost whole year, but we do not see bad consequences. It also withstood an accident without problems. The regal was rear-ended on highway; only muffler and bumper cover were replaced.
We bought the Regal new, while the Malibu was bought used, with 15k miles. With the experience, I would wary of slightly used cars: Often it is something wrong either with the vehicle, or with the previous owner, or with the both. Probably an abused car repossessed early, or the first owner dumped it, because was unhappy, or it was a lemon bay-back... I also would avoid new models for the first year or two.
Concerning CR. Their user surveys definitely are somewhat skewed. However, it is better to have imperfect information, than no information at all. By the way, the "soft" data always are not precise.
I know several poeple in the autobody business and there is one general consensus when you start taking them apart GM's are not put together that well. The major parts are good but they are surrounded by cheapness.
I now have a 96 Ranger, a 2001 Mustang Bullitt GT and the 03 Explorer Limited in my garage. For better or worse at least none of them are leaking oil on the floor.
For us Regal owners, just 3 topics...
Make what you will with that...
Don't need an extended warranty for that kind of item.
To remove, they used a long knife blade to lift the flat metal prong sticking down from the relay so that the prong slipped forward over the ridge or catch. This allows the relay to come forward and out. When the new relay goes in the metal strip sticking down rides up and over the catch. But to get it off required knowledge of the "barb" effect holding the relay on. Try a steak knife to lift the metal prong.
The other relays in the group may control the air conditioning compressor and the cooling fans at the radiator. You may be able to track the color coded wires to the connectors to find the one that goes to the heater blower. That would be your only way of telling which one is the blower control -- other than removing one at a time and seeing which one stops the blower -- battery would have to be charged for this to work of course.
If you identify the relay for the fan, you can switch for one of the other relays and verify the problem is the relay. These were a generic looking relay. The numbers on them will be the same as well as looking the same. They go bad occasionally from use.
Let's see...Regal and Explorer in same class???...But they've sold more Camrys that Explorers...So There!!!
Dan1 had a bad experience with his Regal and he's happier now. That's a good thing for him.
His bad experience with his Regal certainly does not mean all Regals are bad things - and using numbers of postings to judge reliability (or lack thereof) on any vehicle is nothing less than folly.
In any case, this is not a Regal vs. Explorer forum, so let's get back to our subject.
Dan1 - good luck. Glad you've solved your problem and sorry that your specific Regal was not a good thing for you. Let's respect the fact that not everyone will have or has had the same experience that you did.
Enjoy your Explorer!
$120.00 that included everything. Anyway thanks again for all your help. These forums are really great.
I have a 2001 Buick Regal ls with 36,000 miles. This problem started about a month ago. My brakes would pulsate every time I applied the brakes, more so at high speeds. I had the front rotors turned down at a local Auto parts store, the pulsating went away slightly. Today I changed the pads, there was no difference. I'm puzzled, does any one have any idea what the problem is.
If the blower resister set blows, the fan won't work on lower speeds at all. The only time it would work is when on high speed, which is when the relay is operated to connect directly to battery power.
Is it an automatic temperature control system?
One thing that can warp rotors is washing your car after driving it hard...The cold water sprayed on the rotors will warp them...
My next step is to get new rotors. Is it possible to tell if they are warped when they turn them down?
BTW, I also started to feel the pulsation at brake pedal when driving on highway recently. 2000 Regal GS. The current mileage is something like 35k, + or - 1k. My wife, who usually drives the car, also noticed the pulsation. She thinks, though, that it happens only on some road surfaces. Even knows several places where she feel it. She hopes the rotors did not warp. I do not drive the car often, probably once a month or so, and am not 100% sure yet.
Local radio talk show (real) mechanic recommends replacing rotors -- he doesn't waste time turning them. He has his own mechical and body repair shop in an upscale residential part of a city. He's been a mechanic since vocational school. I've learned he's usually right about what costs less trouble or less money in the end. Do it right -- one time. Replace everything.
Oh and don't press the pistons back in without opening the bleeder. You don't want to push the old fluid back through the antilock brake system. That can cause problems
My father had the car fixed on Tuesday, and so far it has been fine. The description you gave was exactly the problem he was having with his car. I guess I did not explain it very well, sorry.
I always see a condensate from A/C in summer time under all kinds of cars. High air humidity, and cold parts. Do not need to drive 1350 miles; 5 to 7 miles is more than enough to see a plenty of the condensate in our places, Southern Connecticut. Regal is not different from other cars in this respect.
My wife and I have a 2000 Regal GS and 98 Malibu, and had a 1988 Taurus before. All of them produce puddles of waters from A/C. What car did you have before your GSE?
By the way, a couple of years ago we had a short vacation in White Mountains, NH. Criss-crossed the mountains in different directions, and drove around them. Were in Conway, NH, and crossed about 10 miles into Maine. Fryeburg, East Fryeburg - I remember the names. According to the map, it is very close from your home.
It was a pleasure to drive our Regal GS on the mountain roads. Looks like Impala LS is very popular around the White Mountains. We did not see many Regals, though.
any tips for most important Regal issues to look for when considering a used one? I'm talking about one with 90k miles
The problem areas are transmission and some of the electronics, heater/AC control module...But if taken care of.....OK...
What year...From private party or dealer???
I'm surprised about the transmission. some kind of ongoing problems? Seems like most GM trannies are pretty good. I have 192k on my '90 Cavalier...never an issue with the tranny.
interesting point about it possibly being driven harder. Does Carfax give demographics of previous owner? Otherwise, the car is immaculate. Kind of a l ot for a high miler but teh regal seems to have a good rep as well as the 3.8.
GS and other supercharged cars by GM have a heavy duty engine. Not exactly the same as the 3800 in Regal LS, Impala LS, Grand Prix GT. Beefed up to match the supercharger. Stronger internal parts, bolts, etc. Not sure about the block itself.
I heard only good words concerning GM transmissions. Regal GS (and Grand Prix GTP) have a very good, beefed-up, heavy duty transmission, to match the engine. No ongoing problems with the tranny. Some complaints that it is not very reliable when racing with substantially modifying engine, after upgrading its power 300 hp or so. Hardly relevant to the average owner.
However, everything happens. Especially with used cars.
Do you know how often the previous owner serviced the transaxle?
GM recommends 100,000 miles between services for ideal conditions: highway, flat terrains, etc. 50,000 miles for "severe duty", like driving in hilly/mountain areas or in the stop-and-go city traffic. Personally, I changed the fluid after 33,000 miles or so. At first, dealer suggested to flush the transmission only, without replacing filter. However, when flushing mechanic saw dirty old fluid coming out, dropped the pan, and replaced the filter. So, 50k miles between the services looks too much for our car, driven mostly in city, in hilly Connecticut.
The general population of Regal owners looks very solid. At least in Connecticut. Judging by driving style, and by drivers look.
I doubt Carfax provides the data. However, you can ask your insurance company for insurance rates for GS and GP GTP, and compare them. I saw some insurance statistics: Buick beats Pontiac easily. Less accidents, less injuries, and way less theft. The two cars are basically the same under the skin. I believe, the difference is due to different population of owners.
Assuming it's a wise move, what would you ask an uninvolved mechanic to look for prior to purchase?
I went through this on my 93 Lesabre when the sensor wires to the resistor in the key started breaking.
Do you have a service manual about how to remove the steering wheel and disable the airbag and then diassemble the parts down to the cylinder? I recommend reading that FIRST before deciding if yo're going to do it yourself. I "believe" the cost for my replacement was $188.
Have you determined that the cylinder is the problem and not the rotating parts around it in the column nor the wire leading down to and including the switch for the ignition itself???
The ignition switch is above your brake pedal on top of the steering column. You could loosen it and remove the rod from it and try turning the key to see if the resistance is at the top of the column or in the switch at the bottom... Perhaps I've missed a message here where you've already explain your diagnosis. I'm just nervous about working anywhere around airbags in the cars.
I have a 96 Buick Regal. The car runs great, but past 4 months there is this Squeaking noise coming out of the hood. I have sprayed the belt dresser on the serpentine belt (The belt and the tensioner are new). The noise does not stop. Any idea..? Please help.
Other thought...Water pump going out?...
