Oldsmobile Aurora
17879818384112
  • fjk57702fjk57702 Member Posts: 539
    My 2002 Seville also was recalled to reprogram the PCM for misfire. I can't say that I ever noticed anything. Now and then (at night) I have noticed that the headlights seem to flicker but I wondered if it was real.
  • kayaman420kayaman420 Member Posts: 207
    I just came across a dealer in AZ that sells AC Delco parts at wholesale prices. About half as much as my dealer not to mention no sales tax.
    VAN-Chevrolet- (www.gmpartscenter.net/) -1-800-477-9233. Shipping was only $9 to Minneapolis. Below I will list the items I purchased today and the comparisson to my dealer. These are unbelievable prices or my dealer has been raping me.
    PART**********DEALER*****VAN-CHEV
    EGR valve*****$275*******$143
    Coils(ea)******$80********$38
    O2 Sensor(ea)*$98********$46
    I purchased the EGR valve, 4 coils and 2 sensors. My total savings was $404 unbelievable dollars.
    These prices are real and they are AC Delco. I ordered these a few hours ago. Make sure that you check their website first because what ever the price is there is what you pay even if they have raised the price when you call them. The EGR valve on the website said $143, when I called they said $198. They gave me the website price no hassle at all(their suggestion even). I found this site by accident and it looks like a god sent to me. I hope it helps all my fellow Aurorians that are getting the shaft from the dealers.
  • garnesgarnes Member Posts: 950
    Hmmm. I wonder what they would charge for a set of Aurora chrome 17's?
  • rjs200240rjs200240 Member Posts: 1,277
    Well, it only does it during that 20-second warm up. I could only barely hear it with the stock exhaust if I got right up next to it. With the Corsa, it was much more apparent if you were standing anywhere near the back of the car. But I think it was just part of the warm up routine to get the cat heated up. Have you taken it in for the recall yet?
    Yes I had it done a couple of days ago. It took about half an hour. Can't say that I notice anything different. I have not driven at night yet. I thought the problem was that the ignition system would shut down while the transmission shifted for just a moment. I am not really sure about my lights flickering, it did seem like they would now and then. Now that summer is nearly here, its light out when I am driving most of the time.
  • ygo2workygo2work Member Posts: 5
    I ordered a replacement for my lost keyless remote for my 99 Aurora on eBay. The part number is the right one, but will I have to take it to a dealer to get him to program it for my car? I've read where it's as easy as pressing one of the buttons while turning the key in the ignition??
  • hammen2hammen2 Member Posts: 1,284
    On some '98 and up GM cars, you can program the keyless entry fairly easily from inside the car (do a Google search). However, the Classic Aurora well predates that.
    It's supposed to be possible to program it using a fused jumper - I've seen the technique described on another forum which Edmunds would not like me to mention here. Before I read that, my dealer charged me $20 to program my remotes (car only came with one, did as you did and bought another on eBay).
    --Robert
  • pizza442pizza442 Member Posts: 110
    Anyone go through this yet? I guess the side tanks on the newer radiators are plastic, not brass. I smelled coolant in the drivebelt area right after having the dealer do a compressor job (warrantybynet). Thought the tech may have bumped the radiator or had to remove and reconnect a hose to work on the compressor and a leak had developed. After basically standing on my head to look in where the upper hose connects to the rad, I could see the trail going down the tank. When I removed the top plate to get a full view, I saw that the leak was not at the hose inlet but cracks at the top of the tank on both the front and back side. Covered by the aftermarket warranty--after bugging for maint. records. Luckily I had the waterpump done at that dealer last summer and the sys. flushed and a new thermostat done there, the summer before.
    The tech didn't add the GM coolant sys sealant tablets that I had for him. Any opinions on this? I hear the tablets come with the flush package for the Northstars.
  • mike98cmike98c Member Posts: 293
    a lot of the tanks crack in that area on the seams and also on the bottom oil line inlet on the earlier models with that inlet. The side tanks can be replaced by themselves or try something like g.m. parts direct for a complete unit, I believe some other posters have gotten radiators for a good price from various sources. The tabs should get added. The aluminum can have porosity issues where the sealant weeps through over time otherwise. There has also been speculation that the fibers in the tabs keep the waterpump seals clean so contamination doesn't cause the seala to fail.
  • blk97aurorablk97aurora Member Posts: 573
    Those plastic radiator end tanks are not so new. Both my '86 Toro and '86 Fiero had them. The Fiero was fine when I sold it in 2000. But, I had to replace the Toro radiator about 1997. Both end tanks had developed leaks; kind of hard to describe -- it was like an over-ripe fruit splitting apart at the molding lines. I decided to go for a new aftermarket radiator rather than taking a chance on repairing the old one.
    I'm interested to know others' experience and/or opinions about the coolant sealing tabs. They were definitely specified in the contemporary service manuals of our cars (Classics; I don't know about Gen 2). I have seen references that GM later rescinded the advice to use the sealing tabs, but I have never actually seen anything official on the subject. Bars Leak sells the same product, and I'd be surprised if they aren't the source for the GM package.
  • ffreysffreys Member Posts: 12
    I guess you can just rack this up to spring fever...but the moonlight reflecting off my Aurora tonite from the full moon sure makes her look sleeker and sexier than ever....swoon.....LOL
  • HenryHenry Member Posts: 1,106
    You noticed that too.
    I always said the car, especially the Classic, looks better at night.
    You can't see all the car's lines during the day.
  • sdasda Member Posts: 7,694
    My mother has a 98 Aurora with 46000 miles. It is champagne/with neutral leather, sunroof and autobahn. It really is a nice car, and she loves it. Other than having the AC compressor replaced under warranty at 34k, the car has been trouble free. The car still is on its original battery. I feel she is pressing her luck, but the battery still turns the engine over quickly everytime. Short of having it replaced at a dealer, any suggestions where to get a replacement at a reasonable price? I understand because the battery is located under the back seat, the battery is specific to the car. Thanks!
    sda:
    My 1997's battery failed about 18 months ago at about 67 000 miles. I bought an AC Delco replacement at a discount distributor for $110 and installed it myself. It is the largest passengar car battery sold by AC Delco -- 56 pounds. The venting arrangement required because of the location makes it (almost) unique. After I purchased the AC Delco, I did see a couple of references to sealed batteries that may work as an alternative.
    Had my 95's factory battery finally die after just over 7 full years, and this is not unusual as it lives a perfect life under the seat. At $100-150, you might want to wait until it gives you a hint of dying (slight pause on initial crank) before coughing up for one.
    Yeah, crushed walnut shells, etc. Ended up putting them into my 86 442; I just blew that little thermostat-housing bypass hose so I replaced that and the thermostat and noticed the alum intake was moist at the corner where the coolant passage in the intake mates to the head. Figured it might help.
    As for the Aurora, I wish the tech would have put them in while he had direct access to the radiator as there is no traditional radiator cap on the radiator; its on the plastic overflow deal'y and they say NOT to put it in there, only directly into the radiator. Oh poo.
  • gisomgisom Member Posts: 144
    Try Global 4 auto parts. Battery sells for $75.
    I just ordered one myself. Battery is 8 yrs old but is starting to feel the strain now.
    Greg
  • musclecar97musclecar97 Member Posts: 111
    lol rjs, I really do still have my own hair, plus some new stuff coming in in the ears and nose, it's ruff getting old...plus it only takes me a month to respond. I left the last of the verse out as I had the windows up and the AC on.
    Have now had the fuel gauge go gunnybags. It was the sensor in the tank. Replaced under warranty, but now when the tank is full I'm smelling gas when the car's parked in the garage. Guess I'll have to take it back in, I imagine they didn't tighten some fitting or something.
    Taylor, Glad you came to your senses.
    Still waiting for somebody to go to the track again.
    Henri, glad to hear you've been shop free lately.
    I'm cramming alot into one posting, it seems to take me awhile to get back here to post. I do keep up with the reading though.
    Howdy Garnes...did I forget anyone else?
    See you all in another month.
    This year was something of a disappointment. I think the NY show is now the officail step child of Detroit and Chicago.
    GM did not have the hydrogen powered car in New York, but it was in Detroit and Chicago.
    Olds was not there at all (as I suspected it would not be). GM has no class! It shold have sent Olda out with a bang at the show by bringing in all the Olds Classics throughout the years (ending with the Auora of course). The Toronando, the 442, etc.
    But that would have required too much foresight for the general. And GM has never been accused of foresight and vision.
    The Caddi CTS V looks nice. The XLR could use some work in the looks department. The XLR looks like they took the back of the Deville and the front of the CTS and said "abbra cadabra" convertible.
    snorzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
    Henri
    My friend just bought a 2003. I got to do a little test drive. I was quite impressed. My overall impression is that the new Aurora is a bit more refined. The interior is absolutely beautiful. The engine and exhaust note seemed different than mine (as I can remember) when it was stock. It actually seemed to have more of a growl or exhaust note or something - but it was different. Also, he has the standard stereo and we did a side by side comparison with the Bose in my 98 with the same cd. The standard stereo sounded every bit as good as the Bose in my 98. The bose has no EQ options, we set the 2003 to "jazz" which bumps the low and the high a bit. He loved the Corsa on mine. Maybe there will be another Aurora/Corsa in the neighborhood in the future.
    Cool. Is that the first time you've been in a new Aurora, or have you test-driven them before? When I took that '99 Autobahn for a test drive I noted the engine sounds too. On my car, the exhaust seemed to be the more prevalent sound whereas on the classic, the intake was more prevalent. They both sounded good, but definitely different.
    What color did your friend get?
    He got the white diamond - the pearly one. I like that color a lot. It has to be way better for a "felix" to own. Black is difficult to keep looking perfect.
    I sat in one before, but driving it is the real thing. That was the first drive in the new one. Wow was it nice. Your description of the sound difference is what I think too.
  • mcclearyflmcclearyfl Member Posts: 149
    I inspected, but did not drive, the cherry red Collectors Edition 2003 Aurora, and felt the car was more modern and less in-your-face than the Classic. At $39K it seems a good match in value for the previous model.
    The problem is trying to justify such a large capital outlay when my '95 continues to propel me with much of the style and performance of the '03. Our family income puts cars in this price range well within reach, but I stick with my '95 valued at less than $4K as a trade-in.
    I guess it's what the marketing folks refer to as your "market basket", but until the '95 actually becomes a basket case I don't see any point in trading. Mine is a Florida car. I just went through the Kentucky emissions inspection, where the technicians initially recorded it as a '99. They were astonished at its condition and appearance. It easily passed the '99 emissions standard.
    When you are driving a $4K car, all kinds of economies show up -- no collision insurance (why bother), no car payments -- yet the Classic draws all kinds of approving glances and remarks from neighbors that my late-model Buick never got.
    I think that 03 was only optioned with heated seats and I think that's it. It was had for somewhere in the 33's. No kidding.
    About what I would say that it is worth.
    For 33+ I don't think you could get anywhere near that much of a luxury/sport type of car - especially if you looked at an import. But yeah, that's about the right deal on a new Aurora.
  • shifty4shifty4 Member Posts: 53
    My 1995 original battery was still going strong after 8 winters. I replaced it simply because of age and the difficulty of finding a replacement if emergency replacement was required. I paid $102 for Delco at parts dealer. I am now using the original battery to run electric motor on my fishing boat. Last week I ran it continuously while trolling for over 4 hours. Olds put a fantastic battery in the Aurora.
  • larryfllarryfl Member Posts: 214
    You and I are definitely on the same page.
    My '95 looks and drives like a dream. I have 98K miles on her, a new quality paint job, everything works and no marks or blemishes on the inside. No rattles or squeaks AT ALL. She looks and drives brand new. I have the dual power seats, moon roof, bose, etc. -every thing except autobaun. Add the dynomax mufflers' incredible sound and there's no way I can see trading her.
    Having said that, of course, I'm still staring the engine block oil gasket leak in the face ($1500+) and I'm sure I'll have sporadic, $$ repairs, but I was just telling my wife this weekend that I see no reason to trade. Other than the oil leak, the engine / tranny are in great shape (knocking wood) and I know have tens of thousands of miles left in them. I actually think I'd take more of a bath on a trade-in now than all the repair bills combined over the next 40-50K miles.
    I love the car, the way it drives, and plan on keeping her for at least 2+ more years.
    BTW, I'll located in Clearwater. Where are you?
    Larry
    After I went through the crankshaft seal (engine block oil leak) repair Larry mentioned (thankfully I have an extended warranty, though it still cost me $500 out of my own pocket), I contemplated getting rid of my Classic. I even located a new 2003 optioned just the way I would have liked it (black/dark gray, chromes, sunroof, Bose, all of the convenience/power packages).
    With my mother-in-law's GMS discount, plus my $2k in GM Card dollars, and with all of the incentives (GM owner discount) going on in March, the car (which stickered at $39k) would have gone for $29k + tax (not including selling/trading my Classic) - a pretty good deal.
    Except I wasn't ready to buy a new car (with my wife off work for 9 months, I didn't have a lot of cash laying around for a down payment); I have 11 months of payments left on my Classic, and would have just received what I owed on trade; and my car payment would have gone up by $100/mo., and I'd have 4 more years of payments, just to have basically what I have today. And, the resale hit one would take on the 2003, even considering the discounts, is huge (face it, everyone thinks Olds is dead already/few people want to buy their cars). This is a consideration if, say, the car was totaled, and the insurance company paid the book value (you'd be upside down almost immediately).
    I still have a warranty (for another 3 years and 39k miles, which is likely to happen sooner) on my Classic, so that's not really an issue. Bottom line, it just didn't make sense to me to pull the trigger on the new Aurora (a car that, despite its improved reliability and refinement, just doesn't give me the same thrill as the Classic).
    Now, in two years, when my Classic is long paid for, my warranty is up (I'll have 100k+ miles on her), Olds is long dead, and (the few) 2002/2003's are on the used market for a song, then I'll probably pull the trigger (and probably not trade my Classic in). I like the CTS and the Bonneville GXP, but can't see buying a $40k car when I can get a good/better value like the Aurora for less than half that (only, adding a decent third-party warranty).
    --Robert
    Hi, Larry, I was living in Palmetto Bay, just south of Miami, until we moved to Louisville, Kentucky, this January. Previously we had lived in Tampa and Gainesville. Love Florida, and miss it.
  • stickking1stickking1 Member Posts: 247
    Well, after reading all of your stories, I had an experience of my own. While checking my trans fluid in the parking lot at work (as part of my trans issue that you can read all about in the "Problems" board), one of my coworkers comes up and starts to talk to me and says, "That's a pretty sharp car...what is it?" (I almost couldn't contain the laughter). "Olds Aurora", I said. And he said "I can't believe I've never noticed it before, it's really cool looking" We talked for a minute while he circled the car and said that there was no way it could be a 95 (it looked too "new"), and asked other questions about it...Actually, I was kind of embarrased, it's been a week since I last washed it..but I guess it got his attention anyway. She is a looker, that's for sure. At least he didn't think it was a Honda or Toyota, or something like that. :-)
    Dear Edmunds, I never thought anything like this could happen to me......
    Whats up guys? These boards are getting awfully thin. No one is writing anything. Is everyones Aurora running perfect accept mine? Either that or a lot of people have sold their Auroras.
  • refinow2003refinow2003 Member Posts: 5
    I have a 2002, bought from a dealer who apparently got it from Avis. Seems people are writing about the older Auroras.
    This I will tell you. It has a V-6 and had 13.5 k on it and now has 28k. Bought on 07/04/02, thought dealer was closed and wasn't expecting to buy. Gotta go.
    There is only a one-day difference between your post and the one directly before it. How much posting do you expect to see? However, yes, my Aurora is running perfectly.
    If you look back in the posts from some months ago there were numerous posts everyday. Now we maybe see 1 new post a day if that. I went back and read all the 4000 or so posts from the past and there was a lot more communication. If someone had a problem numerous people would try and help. I just dont want this board to die. I am trying to make people feel guilty, this board is about all that us Aurora owners have. No one besides us knows anything about these cars.
  • cwiley1cwiley1 Member Posts: 82
    Tomorrow I take my '97 in to have the traditional northstar oil leak repaired. It is going to be covered by my extended warranty, I hope. If not it won't get fixed. I'm also having them replace the main drive and water pump belts and the shifter light so my wife can see what gear she's in. The mechanic said more than likely it is the wire and not the bulb. They will have to put a new wiring harness on if it is the wire that is broken.
    Since having my '95 seals and gaskets replaced it has not used a quart of oil in 3k miles. It was using a quart every 1200 miles. I never did see any oil on the floor in my garage. You would think using that much oil it would surely drip some. I could see oil on the pan and the side of the engine but that was all. I hope they do as good of a job on my '97. Both cars are running excellent, knock on wood. I have 57k on my '97 and the shocks seem to be getting really weak. My '95 has 100k and still has the original front shocks, I replaced the rear shock with OE at 88k from the Olds dealer.
    I will let you all know how the '97 turns out.
  • seth042280seth042280 Member Posts: 65
    I personally stepped away because I got a second car as back up to the aurora . .My RORA needs new tranny .new ac compressor..It was cheaper for me to buy another car,but I have been hooking that one up too.
    I was thinking the same thing last year. When spring arrived it seemed like the boards slowed way down for a over a month. Then people started to take their cars to the track and talk more about mods. and things picked up again.
    I have three sweet IRL Aurora posters in my garage, but now feel left out while at work. I think I am going to see if I can find a local place that can scan and reprint them in a smaller format so that I can decorate my cube (yeah, yeah) with them. There are also some nice pictures from those IRL books that I have that I'd love to be able to hang up (without butchering the books). If anybody has any suggestions, I'd love to hear them.
    Hey guys, I'm not normally the one to start a rumor, but I was chatting with a friend of mine from Saturn about the Aurora, and he slipped something out about GM bringing out a 6-speed automatic in the near future. I asked him who was making it for GM and what car we'd se it in, and he tried to dodge the question. I finally got him to tell me that he thinks its BOSCH...he wouldn't tell me too much after that, but I thought it was worth mentioning to see if any of you had heard anything about it.
    GM and Ford have gone in together on a venture to produce a 6-speed automatic for FWD cars. They will share the development costs of the basic transmission, and each of them will then tune it to their liking and produce it themselves.
    It is unlikely that GM would turn to an outside company for an automatic tranny, as GM pretty much rules in this area. Even BMW buys automatics (for the 5 series) from GM.
  • zinc1zinc1 Member Posts: 133
    Hey, guys! Long time no read. I see many old names are still here :)
    I just thought I'd drop a line to make those with the chronic Aurora clinks and clanks feel better (you know, the back-firing, oil leaks, freaky electricals, $2k/yr maintenance costs, etc.)
    It's been about a year since I traded in the '96 Aurora for $6k (a steal) and bought the '02 Sonata (for the warranty and gadgets - it's a good car!) and now have 20k/mi on it. So far it's been hit in the front (replaced the hood, bumper, one headlight assy under insurance) bent the antenna pulling into the garage ($40, not covered). My wife backed into something and scratched the rear bumper's paint, which revealed black plastic under the white paint. The front newly painted, newly replaced, bumper and hood began losing paint to reveal black plastic under the white bumper paint (the shop redid the bumper, but wouldn't do the hood - said it was normal road wear). I noticed a new baby oil leak which goes away for a few weeks after an oil change. And the air bag light has been on for two weeks now.
    Actually it sounds worse than it is. This car runs great after taking out the resonator and putting in a K&N air filter. It's amazingly fast and reliable (bumper to bumper 100k warranty!!!). But... if the Aurora was half as reliable I'd have kept her. She looked soooo nice, and was fun to drive.
    Take care and good luck!
    Oh, I haven't touched the Classic site for years but it crashed so I reloaded an old backup which lost some good stuff, like the Polish Aurora and the IMSA pics (Fortunecity messed up the top frame anyway). If you noticed it, sorry bout that.
  • benjaminhbenjaminh Member Posts: 6,720
    Harsh for zinc to go from an Aurora to a Sonata, but he sounds like he's happier.
    The Auroras, as you all know, are some of the best looking American cars made over the last 30 years. I got my first close-up look at the new ones today, one of the last of the 03s and last of the Oldsmobiles, when I went in to pick up a part for my Olds 98 at the dealer. It was a really sweet looking car, in and out. I was filled with some saddness, yet again, for the death of Oldsmobile, as I looked at this $38k list price machine. Olds really was heading in the right direction with their styling, although from some of the posts here it seems like reliabity was so bad on the Aurora it was almost time to let the brand die... Rest in peace, Oldsmobile--although please make sure my 98 keeps running for many more years to come!
    Well, my 1998 Aurora did not cause me a lot of trouble while I had it. I did trade it in last Halloween when it had 52,xxx miles on it (if I remember right). I wasn't looking to trade either. I liked the first generation for looks more than the second.
    My 98 has 41k - not a lot, but it has been a pretty solid car. No complaints here. You see more problems here because this is a great place to come if you have a problem. There are a lot of people here with reliable cars though.
    Look at the Lexus ES300 board. They have their share too and it looks like the new 300's have some nightmare-like problems with the transmission that are not being addressed.
    Oh - I have to add that it sure seems like those 2001+ Auroras have not been posting many problems at all.
    I was going through the old post and found a hilarious juke that 800watts had posted. Whoever hasnt seen it yet should give it a read.
  • mtpockets1mtpockets1 Member Posts: 4
    I've had my AroarA (95') for 4 years and was'nt sure if I had the Autobahn pakage or not. Well, I e-mailed Olds/gm gave them my VIN# etc. They E-mailed me back saying I DID NOT have the Autobahn Package.....You see,I thought I had it because it had the V-RATED tires and the Sticker on the Door jamb calls for V-RATED tires. I had read somewhere on these boards that that was a way to POSITIVELY IDENTIFY the Autobahn Package. I guess it's not,according to OLDS/GM, All AroarA's with the Autobahn Package came with the CHROME WHEELS. Mine DOES NOT have the CHROME WHEELS.......hmmmm....I wonder why it calls for V_RATED tires then??....I bought it used...do you suppose somewhere along the line they switched the Wheels on it?.....Then again I assume they ran my VIN# through their Data base and could tell that way......AWWW...The HELL with it!...I didn't plan on driving 140 MPH anyway..........
  • autobahn95autobahn95 Member Posts: 62
    Mtpockets1-
    The chrome wheels on an Aurora don't necessarily mean that you have the autobahn package or not. Mine came without chrome wheels but i do have the autobahn package. The one way to tell for sure, is to check your option code sticker. On my '95, it was located inside the trunk, on the inner right rear fender. You have to pull out some of the trunk liner and stick your head way inside and look upwards to see it. The codes you want to look for are FV4 and QQX. The FV4 means you have the 3.71 ratio in the transmission. The QQX code means you have the speed limiter raised to 139 miles an hour.
    I hope this helps clear things up.
    Pete
    Also, if you can cruise nice and steady at 2000 rpm on a flat stretch of road, an autobahn will be doing 62 MPH. A non autobahn will be doing about 66. Even if things are perhaps mislabeled or you get bad information, this test will prove it one way or the other. It's a little tricky to get everything steady for this test.
