At 37K I took the car to my mechanic who is authorized to perform repairs under a GM extended warranty. He replaced the ISS with the caveat that it might only be a temporary fix. He said that some GM cars were having trouble with the rack and pinion and that could be the problem.
At 41k the noise returned. The rack was replaced
under the GM warranty. I also had the tires replaced with a set of Goodyear Eagles.
Finally the car is performing as smoothly and as quietly as I had expected when I bought it.
I have my fingers crossed that the fix is permanent.
As far as interior components, you may just want to take a look at that yourself. The stuff that seems to be squeaking, try to tighten up the fasteners. Maybe yours just wasn't tightened up very well...
Time for a tonic. Olds hopes the wholly redone Aurora is it.
If not, don't blame the car. It's terrific, another fine take on parent General Motors' best car platform, the one that underpins Cadillac Seville, Buick LeSabre, Pontiac Bonneville. The 2001 Aurora might be best-looking, best-balanced, just plain best of the bunch. While not as potent as the Caddy with the Northstar V-8, Aurora is plenty peppy. It is the least adorned, thus most elegant, of the GM sedans. Firm ride and responsive handling give it a pleasing European flavor missing from the others. The 4-liter V-8 generates 250 horsepower. It's a smoother-running, less-polluting version of the previous Aurora's same-size engine. The V-8 howls with the blended voice of old-days Detroit and nowadays Euro-tech, a lovely harmony. It snaps the sedan from rest to 60 mph in 7.8 seconds, vs. 8.2 seconds for the previous Aurora. The new-to-Aurora 3.5-liter V-6, from the smaller Olds Intrigue, has 215 hp. Less thrilling than the V-8, it nevertheless supplies lively performance and sonic reward. Overall: Compelling. Tasteful, powerful, pleasant and comparatively low-priced. Ofcourse the entire article can be read in the USA TestDrive Archives. But I couldn't help smiling when I read this, and thought you would too.
http://www.usatoday.com/money/perfi/columnist/healey/0001.htm if anyone wants to read the whole thing.
http://www.domesticperformance.com/default.php?cPath=26
Just click on the Aurora logo.
The sizes I am looking at are slightly smaller or larger in diameter....plus or minus 1/2 inch overall. (245/45zr/18 or 245/50zr/18 . There is one that is almost bang-on (235/50zr/18) , but I'd like to go 10mm's wider if poosible
THX - 99 - black
I don't know the answer to how much of a difference in diameter will affect the computer. I suspect that as long as all four tires are nearly identical, there would not be a problem; after all, how would the computer know? The speedo and odometer would be off, but +/-0.5 inch is less than 2% difference. If the diameters are staggered, then ABS and traction control would complain.
Have you looked at 255/45-18? That diameter is 27.0" compared to 27.1" stock Classic. The 20mm wider than stock is not a problem. I am running 255/50-17 on my '97 and javidogg has 255/35-20 on his Classic.
I run tire size 20, but you should be fine.
Peace.
Today I watched a (bad) Harrison Ford film where he played a cop that also had a real estate practice on the side. The high points of the movie were Smokey Robinson, Gladys Knight and a few other recording artists that had cameo roles.
Anyway, the point I am making is that there were a number of Aurora Classics in the movie. Actually, on closer examination, I think its the same Classic over and over again in different scenes.
We now have the Matrix - part 2, Harrison Ford, Lethal Weapon part??, and a few other movies using Classics in the background of highway and street scences.
I cant believe this was GM's idea of product placement. What was GM's slogan?
"AURORA - THE CAR IN THE BACKGROUND!"
I think someone said that it was a 3rd party company that supplies cars on films. If that is the case, the guy at this company LOVED
aROARa. Too bad he was not in charge at GM.
Henri
Also I noticed, the size of the tires looked HUGE! They looked like rear viper tires mounted up. There was an Lincoln LS behind the Aurora and its tires looked like spares. lol
blk97aurora - What brand of tire are you using with your 255/50/17? This doesn't seem to be a very popular tire (exept toyota supra).
THX. - black 99 -
You're right, 255/50-17 is not a common size. Mine are Continental ContiExtremeContact 100W; I think they are awesome. They are rated 2 out of 18 in Tire Rack's survey for ultra high performance all-season tires. Their speed rating is W (168 mph). Tread life rating is 400 (all the Goodyears I looked at were <300). They are not cheap, but less expensive than Michelin Pilots and other similar tires.
My experience after 8000 miles has been excellent. Dry, wet, and snow traction are excellent. They are no harsher than the 235/60-16 100H ContiTouringContact tires they replaced. I have noticed no increased noise. They are uni-directional. I have experienced no high-speed vibration problems, even though I did not get road force balancing.
BTW, I am running stock 2001 Aurora 17x7.5 wheels.
Good luck with whatever you choose.
1864: Ransom Eli Olds is born in Geneva, Ohio.
1900: The name Oldsmobile is adopted after R.E. Olds ran a "Name the Car" contest, won by his timekeeper.
1904: The first Oldsmobile to have a steering wheel instead of a filter rod.
1908: Oldsmobile becomes a part of General Motors Corp.
1924: Olds makes steel wheels an option.
1934: Oldsmobile makes hydraulic brakes and independent front-wheel suspension available for the first time in the industry.
1950: Ransom Eli Olds dies.
1955: Olds makes the industry's first four door hardtop.
1966: Oldsmobile leads the industry with the introduction of a front-wheel drive vehicle.
1974: The industry's first air bag appears in an Olds Toronado.
1987: A.J. Foyt sets closed-course world speed record of 257 mph in an Oldsmobile Aerotech.
2000: GM announces that the 2004 Olds will be the last.
Source:Histomobile
This was an article I happen to run into.
Http://www.cardomain.com/id/javidogg
Peace.
I haven't driven the Aurora too much. Now with the Regal, I drive the Nissan my wife used to drive when it is salty and yucky out. I drove the 'Roara the other day just to enjoy it a bit. What an awesome car! But I cringe about all the sand and salt on the road impacting the bumper and dusting on everything. Hopefully it will rain really hard and remove all the salt and the last traces of snow.
Hey Javi, that thing should mention the 1st hydraulic automatic in like 1944? Also, the first onboard navigation system in like 1995 (called GuideStar).
So, my question is how does the odometer work? If it is in a front wheel type trailers, will the rear tires spinning build up the miles?
I think towing an automatic with the drive wheels on the ground can ruin the tranny, as no fluid gets circulated to lube it. I'd bet the 4.0 still runs strong with 100k miles on it. It's a very solid, precise engine.
What kind are they? Wow...
I am currently only able to live vicariously through him and the other guys with it on their Auroras.
You can search around here for some reviews and such. Bottom line, everyone who got it absolutely loves it. Greg also has it on his classic, and Taylor had it on his Aurora before he sold it for the SSEi. I don't think anyone else here has it, but I could be forgetting someone (sorry if I am).
You can hear my car here, and see it from the interior here (no doppler shift or anything that way).
Then again at 97k thats only 10.7k a year. Way under the 15k a year.
Henri
Is that a special order / formed Corsa system. Up here it probably costs a ton. We get ripped here in Canada for things like this. Even good tires are double the price up here
I now have a shortcut to that interior clip!
That's still more then the best "builder exhaust" I built (all Magnaflow stuff, my friend's and I seem, to like them for some reason). cat, racing muffl. as resonator, y-pipe, and 2 muf. and tips. It was around $550 and I have no idea how much pipes and install would be. Anyone else have an idea? I figured $200, so that would be $750 which is at least 200 cheaper then a Corsa. But you wouldn't be as cool.
I am quickly approaching the end of my 5yr 60K warranty on my 2001 Aurora 6 cyl. I have 45K miles on it along with a new transmission and some other fun stuff.
What can I say, I was overwhelmed after 9/11 so i bought American. I like the car, but I will be lucky to walk away break even if i trade it in.
So I am contemplating getting an extended warranty to take me to 100K. I figure if I keep it 100K which will equate to 5yrs I can consider it not a complete financial loss.
Can anyone here suggest a place to get an extended. And should i get it now? or wait until I approach the 60K end?
Thanks for your help.
After looking at the tires that are on my 16" wheels, I think I'll be picking up a set of dedicated snow/ice tires for next year. The Turanzas I have on there are a couple years old now, and it'd be nice to have winter tires to go with the winter wheels.
It's crazy here in Michigan. When my parents heard the forcast for tomorrow, they insisted that I come over and we grill some steaks. I can't pass that up. Heck, 50 degrees is almost shorts/T-shirt weather up here.
-Brian
I'm thinking about taking out my 20 inch summer wheels out of hibernation.
With this nicer than usual weather, It's given me time for some projects on the Aurora.
Peace.
So my wife dropped me off at work today so that I could bring the 'Roara home. It turned out to be a beautiful day here, almost up to 70F, so I decided to take a windows-down drive to get lunch. Man, talk about heaven... The smooth operation, the quietness of it all punctuated occasionally by a deep raspy gurgle, the smooth brisk purposeful shifts, everything about it was just incredible. I'm taking the long way home tonight and I can't wait to park the car in its new home for the first time...
It's amazing how much nicer the car drives even than the Regal. The Regal is a nice car with a smooth tranny, but the Aurora's tranny seems so much more in control. And the part-throttle in the Aurora is more satisfying and the throttle is more linear. The Regal is pretty sissy off the line until you give it more and more gas and then it's barking the tires and tearing off. It's hard to just start with medium authority. In addition, the tranny always feels confused when shifting from 1st to 2nd, like it can't decide whether to shift or to stay in 1st a bit longer. Man I love my Aurora...
So I was slicing through the traffic, gunning it a bit every now and then. I love how smooth the car is, so comfortable for just cruising with the pack if you want. But then it's so capable and crisp when you want to leave the pack behind. It handles sharply, accelerates effortlessly, and really works the lanes. It doesn't even seem that large while doing the slice and dice. It really makes the commute enjoyable (though not being in stop and go traffic helps too).
On the way in, I also ended up at a light (on another 6-lane divided road that has much less traffic) next to a black CTS with tinted windows and some 18-19" super flashy wheels. I was looking over at the guy and creeping the car a bit trying to bait him, but the light was close to changing so I didn't gun it at him or anything. The light changed and he didn't take the bait, so I stayed next to him a bit and gunned it forward a little a couple of times. He didn't bite so off I went. I figured if I can't enjoy a good race, I can at least enjoy hearing that sweet motor running through the rpms.
By the time I got to work, the temperature had warmed up to almost 60F, the sun was shining, it's Friday, and I was in a very good mood...
I was quick detailing the Regal and the Aurora last night, and the differences are subtle yet very noticeable...
Like the roof on the Regal is very flat, but the Aurora curves with the body/shape and curves into the glass. The rear glass also curves better, while the Regal glass is flatter and then curves back out at the bottom (which makes for pretty fair distortion at the bottom). Then the trim on the door is so much cleaner on the Aurora. Seems like the panels probably are full size and probably cost more to make, but the result is cleaner and nicer. The bottom half of the Regal is tacked on. The panels around the headlights are nicer too, on the Aurora the panels run up to the housing, while on the Regal the panels go over the housing. All the moldings around windows seem a bit nicer too. I dunno, it's hard to explain, but the Aurora seems a lot nicer. Maybe some Intrigue upgraders have noticed this too?
