Oldsmobile Aurora
194959799100112
  • HenryHenry Member Posts: 1,106
    in the PHOTO GALLERY!
    Nice job on the car Rob.
  • rjs200240rjs200240 Member Posts: 1,277
    I almost stuck them in "Care and Maintenance" but didn't at the last minute. :)
    Hey Robert (Hammen2) did you do some mods to the Aurora? You said in one post you were enjoying the new sounds from your classic. Do tell... :D
  • hammen2hammen2 Member Posts: 1,284
    I just did the Classic airbox mod, or a derivative of it. Took out the lower chamber, the top liner, and put a 2" PVC pipe cap in place of the side chamber. I did not take the Dremel to the bottom of the airbox, nor did I trim the plastic ridges down (which Greg's post on another forum seems to say isn't really necessary/helpful). Your reflectix experiment seems interesting...
    She was really loud when I put my foot into her. I subsequently disconnected the battery and it seems the TPS has reset so it's not quite as loud. Still sounds great to put my foot down - but I know I'm only half done. I make my last payments in April, then it's "save up for Corsa" time :-)
    I know my mileage is down, and I'm sure of it's because I'm getting more air, but I'm also sure most of it's because of how much I'm putting my foot down :-)
    I'm also supposed to get my car clayed and then wet-sanded for free (work next to a snowplow factory, and they had a paint overspray problem - my black Aurora has orange, yellow, and blue spots, a little smaller than the head of a pin, all over - had a similar problem when I got my '96 Lumina, only the spots were about 3x the size - very noticeable). So I'm holding off doing much more than washing it until this is done...
  • mike98cmike98c Member Posts: 293
    The paint crew that was working on the railings of the building at work got paint overspray on the car last year and had to have the truck and vehicle division wet sand it in shop. That was when I wasn't posting because they put me up in Rochester, MN. I was depressed until I got the car back (lol).
    It took them a while to remove the paint by sanding and claying the car because the brown paint was EPOXY! If I hadn't waxed the car just before I went down the shop said they would have had to strip and repaint the car. Some DuPont Imron pearlescent might have been nice! At least they polished the tail reflector to a better than new shimmery luster!
    A newspaper reporter aims to interview people who are dealing with vehicle recalls, especially of GM products, such as the recent problems with the back gate on the pickups. Please send your daytime contact info to farataye@yahoo.com or jfallon@edmunds.com by Wednesday, April 7, 2004. Thanks, Jeannine Fallon PR Director Edmunds.com
    MODERATOR /ADMINISTRATOR
    Review your vehicle
  • garnes1garnes1 Member Posts: 33
    Tomorrow is exactly 3 years with my 98. I've put about 37,000 miles on it and the total on the odometer is about 50,000 now. I had a bunch of stuff done under warranty (some of it was being picky - but why not?), but in 3 years the repairs for the car have cost me $0.00.
    I know I'm tempting fate by posting this - I have a feeling the AC may go this summer.
    Bottom line is that I still really enjoy this car as much as the first day I had it - actually more now that it's a bit customized. I checked out the new GTO, and while it's a great car, it isn't visually exciting inside or out like the Aurora. I have my doubts about being excited about the new STS too. For a car that came out about 10 years ago, the Aurora has held up amazingly well - especially when you consider the wave of improvements from nearly every manufacturer lately.
    -glad the air box mod is fun. I liked the sound too. Look in the duct. You will see that there is a sleeve in there to give some rigidity to the bend. You will also see that it creates a big fat lip or bump. Maybe it's so minor it doesn't matter, but you can pull the sleeve out and file the end down so it makes a nice smooth transition with the outer duct wall. It should reduce turbulence somewhat. It'll cost $0 too and takes less than 30 minutes.
    Good luck with wet sanding. I had this done too when I parked under an incinerator stack (nasty stuff from the fallout). It came out pretty good but I had to do a lot more buffing at home. After sanding, they didn't do the best buff job, so I attacked it with the orbital buffer and Meguires No.7 and the rough spots came out. The finish now looks a little better than factory because it's a bit more glass like.
    How about the CTS? Not tempted even a little? I'd take a CTS-V, no problem. It will be available in red for 2005. The 2005 CTS will have a 6-speed manual with the 255hp V6, so that should stir things up a bit.
    Actually, I'd probably take a 1990 ZR-1 in red for 1/3 the cost of the V, and then drive the Regal as a daily driver (I know the wife would work the angle to get the Aurora).
    I hear you though, the car really does stack up well against the current crop of cars. And the price is the best part. I bought my Aurora brand new and I ordered it specifically for me. I paid about $32,000... What kind of car could I get now for that? Nothing remotely that good, that's for sure.
    Well, I drive the 200SX to work now when I want to keep the Aurora in the garage. I have a sort of highway/city mix in that I really don't hit city traffic, but neither do I get on all-out highways.
    In the 200SX, I usually only get about 24-25mpg between fill-ups, whereas in the Aurora I get about 19-20mpg. Granted, the Aurora uses premium so the cost is a bit higher, but I just find this interesting. The 200SX has a 25-26% increase in fuel economy over the Aurora.
    But here's the thing. The Aurora has a 117% improvement in peak horsepower over the 200SX. And it has a 141% increase in peak torque. If you could look at total hp/torque numbers, I'm sure this would skew even more in favor of the Aurora.
    I just thought that was interesting. The Nissan could get pretty good economy if you drove like a total sissy, but to drive normally you really have to floor the crap out of it. I wonder how close the Aurora engine in a car the weight/size of the 200SX would do economy-wise. Probably pretty similar to the sissy 1.6L 4-banger.
  • woodranch1woodranch1 Member Posts: 35
    About to hit 130K on my 98 classic with autobahn. Leased it new and bought it at end of 3 year lease.
    But hear this.....Leased a new 2003BMW 540i with 6 speed, 7 months ago. Rotate with Aurora on 90 mile roundtrip commute. EQUALLY SATISFYING PERFORMANCE!
    Cannot bear to part with the Aurora!
    I looked at the mileage of 12-19 mpg with the Eldie compared with the 20 to 24 with Aurora. With the Riv already having crappy mileage, I see no reason to add another to the flock. Maybe two cars is enough for one man.
  • 95mushroom95mushroom Member Posts: 230
    I totally agree. I driven my friend's 325 and a co-worker's 330 w/sport package. Though the feeling is totally different then in the Aurora. (I wanted to hit Sebring w/the 330). I would prefer my Aurora everyday if it ran is smooth (in the process of trying to fit that).
    P.S. I'll been in a CL600 that would take anyday over any Aurora though :p
  • ethinkethink Member Posts: 32
    re: #5071 of 5075 Greg... by rjs200240 Mar 30, 2004 (5:13 pm)
    In my opinion, the Cadillac CTS is an UGLY vehicle.
    There is no comparison, between the visual appearance between the Aurora Classic and the Cadillac CTS.
    Considering that the Aurora Classic was designed in the 1992 timeframe, it is still an attractive car today, 12 years later. On a side note, it's sister, the last-generation Buick Riviera, is also a very attractive car.
    Getting back to the Cadillac CTS-V, I find it rather depressing that the engine used is NOT the Northstar engine, but an "old technology" OHV engine. This is NOT "world-class" technology!
    The interior of the Cadillac CTS is also unattractive and unremarkable. In may ways, it is as ugly as the exterior design of the CTS.
    I'm not actually sure where that even got started? I know magazines like to call OHV old-tech and act like OHC is real new. When was the first OHC engine made? I'd bet not all that different from when OHV engines first showed up. OHC is not a new technology.
    OHC has advantages for higher rpms because the valvetrain is all close together. However, while pushrods don't have any real advantage in low-rpm operation to a 2-valve OHC engine, they do have a huge advantage in weight, size, and cost to produce. According to the R&T article, the LS-6 only adds 60 lbs over the DOHC V6 (they don't say which one) motor.
    The LS-6 is hardly a low-tech engine. It has a very high-tech design and manufacturing process. And it is remarkably efficient in power delivery (especially total power) and fuel consumption, and it has a fuel shutoff at 6600 rpm vs 6700 or 6750 for the FWD/RWD Northstar. It makes more power and gets better mileage than the RWD Northstar motor would. And being a V8, it is a very smooth motor.
    I can see how the CTS might be ugly to some people and pretty to others. I didn't say I prefer the style to my Aurora (which I prefer to the classic) but I think it is a stylish car. The fact that you hate it at least means they went out on a limb with the style.
    I like the Riv too, though, I find it depends on the color and sometimes the angle/lighting as to how it looks. Sometimes it really looks absurdly long for a two door. Other times I think the style is really sharp. I always find it surprising that it is about 8" longer than my car.
    I think the Classic looks better than the CTS. The Classic looks as modern today as it did back in 94 when it was introduced. That is why it is called the Classic - classic design never goes out of style. Anyone here think the Gullwing design is dated?
    That being said, I would not say the CTS is ugly. I think it represents a new generation of GM design that has an edgy appeal to it. My vote for ugly Caddies would be the early 1980's "bustle back" Sevilles. I hated that cut off trunk then, and over 20 years later I still hate it.
    If you want to see modern GM looking ugly, take a look at the Pontiac Aztec. Hmm, now that I think about it, there is no reason to stop at the Aztec. Just look at Pontiac (excluding the no longer made Trans-Am).
    Henri
    H
  • mrdubyamrdubya Member Posts: 200
    i too used to hate the styling of the cts, but i like it now, in some colors at least. saw a cts-v at the autoshow, THAT was a good looking car, and it had a little more love under the hood than a aurora, never hurts :D.
    at least cadillac is starting to do there own thing for styling, no other car looks like them, just like the classic aurora. both are love it or hate it.
    i don't get why everyone calls the Ls1/Ls6 low tech just because it isnt dohc. even IF it was low-tech, its powerful, reliable, smooth, gets good gas mileage and relitivly cheap. sounds like a good combo to me. if they put a northstar in the cts-v, it would perform like the xlr, a 14.0 car, hardly competiton for M series bmw, S/RS audi's, AMG's. pretty sweet there's a ton of aftermarket for it already.
    i agree with the riv too, needs to be like right color to look good, ive seen some that i was like 'wow', others i was like 'yuck', i can say the same for aurora's too, but not as much as a yuck, more of 'its ok' or 'wow'
    If you also factor in the weight difference between your Aurora and the 200SX you will probably see that the Aurora is superior overall - or that the SX has rather dismal economy considering its such a light car. Of course this is true of many small cars today that are performance oriented. As far as economy goes, they are an engineering disgrace. Then consider a car like the Corvette which will outperform almost anything - and can probably even best the pocket rockets at the gas pump too. So much for "old tech" and "hi tech".
    By the way, it is interesting to note that these cars with the "hi tech" engines often suffer a lot in performance from any kind of a rolling start (no torque wonder machine while you wait during the turbo lag intermission)and like I've already mentioned, their efficiency is pathetic.
    Anybody that thinks the Corvette LS1 or LS6 is "low tech" has a shallow understanding of engine technology that ends at pushrods and counting valves. As RJS pointed out, the LS engines can do anything the OHC engines can do - and do it more efficiently to boot.
    Wasn't the engine on the Write Brothers plane an overhead cam engine - homemade too. I could be wrong on that, but that was 1903.
  • blk97aurorablk97aurora Member Posts: 573
    A few facts on OHV and OHC dates --
    For the 1948 model year, Olds and Cadillac had the first OHV V-8s in US production automobiles. Pontiac had the first US SOHC motor in 1967. It was an in-line 6 available in Firebird and Tempest/Lemans; the high-performance version was called "Sprint." Jaguar XK-120, XK-140, and XK-150 were DOHC starting in the early '50s. Norton and Velocette motorcycles were OHC in the 1920s.
    Les
    In the US, Mercedes Benz, BMW, Audi, Lexus, Infiniti and Jaguar all sell V8-engined sedans for over $50,000.
    Does any expect that the Cadillac CTS-V will be sucessfully sold in Europe or Asia?
    The CTS-V is not a world-class vehicle. Part of the reason is that is does not have a world-class engine or world-class fit and finish.
    As many on the board know, the original Aurora concept vehicle (1991-2) was a Cadillac.
    This original Aurora concept had all wheel drive as well as the Northstar engine.
    In 2004, the Cadillac CTS-V, which is supposed to a world-class vehicle has neither the North Star engine or All-wheel drive.
    It makes me wonder if GM has really changed. I doubt it.
    I think Chevy had the first OHV V8 in 1917. I don't believe it was very mass-produced, and may not have been high-compression (the Olds/Caddy motors are often called the first high-compression OHV V8's).
    Also, I think there were some motorcycles in the 1910's that had OHC engines from Peugot (sp). And I believe that Italian cars especially used OHC and DOHC engines in the 1920's like Alfa and Ferrari.
    They are just a different way of opening and closing valves. 4 valves helps higher end breathing, but often 2 valves breath/flow better at lower rpm, and are also more centered in the cylinder. Since 2 valve operation is usually geared towards lower rpm's, pushrods work just fine, are simpler, lower the engine's center of gravity, lower the overall weight, and are highly reliable.
    I don't really see how complicated vs. simple is the same as high-tech vs low-tech. They are just different, each with different advantages and disadvantages.
    Ethink, what's a world-class engine? And the CTS-V is a V8 sedan for $50,000, so how is that different from the criteria you laid out for MB/BMW/Jag/etc? And who cares if a car meets that criteria? That's the magic formula for sales in Europe and Japan? Except for the part about fit/finish, what was your point with that post?
    I realize this isn't really about the Aurora, but hey, we got 5000 posts people can reread about the Aurora's wonder if they want (provided this doesn't get way out of hand)... ;)
  • mg11mg11 Member Posts: 29
    Hey again everyone,
    I haven't had any problems in a while now, thanks to keeping up with regular maintainance and these posts. Lately I have had a whining noise that seems to occur when I shut the engine off. I have seen a couple of "whining noise" posts but nothing specific. Any suggestions?
  • kayaman420kayaman420 Member Posts: 207
    Is an ugly car to me. The only way it looks good to me is if you look at it straight ahead from the front. Any other angle, especially the profile is not very attractive to me at all. There are countless cars I would spend my money on before that.
    The CTS is probably one of those cars that will look good 5 years from now. I dont like the direction Cadillac is going right now, but maybe they are a little ahead of their time.
    I have to disagree. The SRX and XLR look nice (I think the SRX is just short of stunning). I have one already if one w/my options weren't $60k. That's the wrong direction Cadillac is heading. If it was the 10k cheaper then the X-5, that it should be, it would definetly outsell it. (I'm comparing V-8 to V-8, the V6 SRX is a better buy then the X-5 3.0)
    I looked at both in the Caddy dealers showroom while I was getting some plastic trim clips for the air dam. The SRX interior blows the CTS interior away.
    That said I also think they're over pricing the vehicle. Look at the Lexus introductory strategy.
    Start with a quality vehicle and don't try and make a killing off of it at the intro. Build a nice loyal customer base to talk up the line and then move farther upscale in price as more people realize what a bargain they got at the intro. price and are willing to pay more for a vehicle thats still perceived as a good value and that can have more features added as the development and tooling gets paid off.
    I hope they don't run into the problem with the Chrysler Pacifica where they produced a bunch of the premium loaded v8s with a premium price and no history to back up the model and so the upscale model sits on the dealer lots while people are trying on and taking home the v6 for substantially less of a financial risk.
    Ok, I think I am going to chuck my stock exhaust. I don't see the point of keeping it around. At first, I just wanted to make sure I was happy with the Corsa, but oh yeah, I'm happy. No way in the world I'd swap it back now. Plus, the Corsa has a lifetime guarantee.
    So I guess I'll take it down to the dump. Maybe I'll cut the tips off and hang on to them just in case. My dad wasn't interested in swapping the chromed tips onto his 2001. The hanger is on the tip, so this would probably be a pain anyway. If it wasn't perfectly snug then the mufflers would droop.
    Maybe I should put a dual exhaust on the 200SX. :D
    If the car got wrecked or something but was fixable and you ended up wanting to sell it, you could swap the exhaust and keep the Corsa. It's a stretch reason for keeping it. If you have any attic space just toss it up there. That's what I did.
    I think out "football" friend has been reborn as "ethink".
    Lexus - offering value? Paying 33k or more for an ES and over 40k for a GS is not such a value IMHO. Maybe the new 330's are much much better, but my experience in an older 99 ES left me with the impression that it's a very nice, but very expensive Camry.
    "The CTS-V is not a world-class vehicle. Part of the reason is that is does not have a world-class engine or world-class fit and finish"
    its not just a old pushrod in there, just because it isn't dohc doesn't mean its not world class. its a very complicated engine thats very smooth, reliable, economical and extremely powerful. the cts is a world-class car, it was designed to take the would be european car buyers away! you may not like the styling, but that doesn't mean its not a worlds class car, i think the lexus sc430 is one of the if not the ugliest cars ever made, doesn't mean someone doesn't love it.
    I was perusing the EPA's website as I was curious as to the environmental impact I was making by owning a V8 powered car... Heh, well not really, but I was curious. I was pretty amazed by what I found.
    The 2002 Olds Aurora 4.0 in 48-state trim has exactly the same emissions impact rating as a 2002 1.0L I-3 Honda Insight in 48-state trim. They both are rated at 12.3-12.8 pounds of smog-forming pollutants per 15,000 miles. This rating scale is something the EPA came up with to compare any vehicle of any size/class and from any year. So this is a directly comparable number.
    I think I'll start wearing sandals to work...
  • setzersetzer Member Posts: 127
    I read somewhere that the Aurora is a pretty good American sedan. It's sad that Oldsmobile is dying. I talked to the local Oldsmobile dealer and he said after Olds dies he is going to try to switch over to a Buick dealer so he can keep the same group of customers. But Buick just doesn't have an Aurora-like car!
    I should have stressed I was talking about the original strategy for the original halo car for Toyota... I mean Lexus. The 400 sedan. That helped them get away with a cosmetic redo of the bland Camry with a not so bland major price hike.
  • cwiley1cwiley1 Member Posts: 82
    I just talked to the Olds dealer in Wichita, KS today about the fuel rail recall for '95 thru '97 Auroras. He said they would be on a VIN No. recall only. And so far my VIN No's for my '95 and '97 weren't listed. This Olds dealer is also the one trying to tell me that my rear shocks for the '97 were going to cost more because I have the 'Sport Suspension.' I don't know if I believe him anymore. I will try them again in about 2 weeks to see if the recall is in.
    For the rear 'sport suspension' shocks, could it be that the 97's rear shocks (they were a stiffer shock then on the 95-96s) were used on a different GM that had an available sport suspension?
    I work in a pretty big place. Plus, I park in three of five different garages here since I like to ensure the Aurora is protected, but don't care when I drive the Nissan. Anyway, I've never ever seen another 2001+ Aurora here. But the other day there was a silver 2001 3.5 in the garage, and now there is a blue 2001 3.5 that parks out in the open area in front of my building. The blue one has a trunklid spoiler that is interesting looking. It is like the spoiler on a 2000+ Taurus. It isn't bad looking, but I wouldn't put one on my car. It is basically flat, then angles down to the edges of the trunk, and also has a middle support. I'll bring my camera someday and grab a photo.
    So you telling us that there is an Aurorian out there making his car look MORE like a Taurus.
  • javidoggjavidogg Member Posts: 366
    D'OH!
  • sdasda Member Posts: 7,697
    I can't get over how few 01-03 Auroras I see on the road. If I see two a week that is a lot. This is in an area of 1+ million and an area that loves cars including domestics. I love the fact I don't see myself coming and going. Can't say that about the wife's Odyessey. Just had the transmission fluid, and anti-freeze changed, and the fuel filter replaced. At 58000 miles, my 01 4.0 drives as if it was new. This is one of the few cars that I've owned that I would buy again.
    LOL sda! I've been noticing in the last few weeks that there must have been some huge recent production of '01 and '02 Auroras or something. I see 3.5's and occasionally 4.0's on a regular basis now. Here's the funny part, I must see them once or twice a week! To me that's a ton compared to previously. I used to see one once or twice a month over the past two years. And they used to be the same two or three cars that must have had a similar commute.
  • stickking1stickking1 Member Posts: 247
    Good to hear that she's running smoothly. I'm beginning to feel special since I see more Auroras driving around than anyone on the board, I think. Certainly not as much as the ubiquitous Camry, Cavalier, or things like that, but I easily see a handful a day. Many classics and a lot of '01 or newer 3.5's...but for one reason or another, not a lot of 01+ 4.0's.
    This surprised me last time I made a long trip across the country. My brother and I were driving to Houston from Lansing and I counted 4 Auroras on the entire trip down and 2 while in Houston. It struck me as funny because I can see that many here in town in a few hours.
    I actually saw a Collector's Edition on the road the other day. I had previously seen one on the dealer's lot here, but this was the first I had seen driving around town...it didn't hit me until I saw the wheels (first thing I always look for). Cool stuff.
    -Brian
    First _ Brian thanks for posting the picture.
    Now my question: I saw a 98 in a Ford dealer's lot. The funny thing was that the trunk was wet at the bottom where the donut is located. Second thing was that the trunk piece that covers the spare did not lock down on the spare like in my 95.
    Question to you 98 guys out there: Does you spare tire cover attach to the trunk with a plastic handle, or does it just lay there? I suspect the car was hit in the trunk and the original OEM piece was damaged and replaced. This theory would explain the wet trunk and the lid not fastening to the floor of the trunk at the spindle on the donut.
    Brian, that's funny too. That's the only time I see Auroras (until the last couple weeks when I've strangely seen a few a week). Whenever I take a trip up to Cleveland, I see more new and classic Auroras than I do almost the whole rest of the year!
    Around here, though, people would rather pay $40,000 for a 323 (the BMW, not the Mazda) or 325 with as much interior space (and style) as a Civic, than to buy something so unstatusy as an Oldsmobile. It's sort of amusing too that they tend to be guys and gals that are too busy with other important tasks (they are important people, afterall) like talking on the cell phone or doing makeup or reading the finacial pages or whatever to drive properly. A far cry from the ultimate driving machine, around here they are far more often the ultimate road block.
  • dred98dred98 Member Posts: 16
    I have a 98 and the spare tire cover is loose, it just sits there, no screwdown or anything.
    It's not really loose though, it fits good and doesn't move around any.
    dred98
    The trunk tire cover doesn't lock down on the 98 and 99. I noticed this when I was originally shopping around for an Aurora.
  • 2k1olds2k1olds Member Posts: 98
    While coming out of a restaurant here in Cincy today after lunch, the were THREE 2001+ 4.0 Auroras, not counting mine, in the parking lot. I haven't seen that many since i bought the car in December. Just thought that was strange, but a great sight to behold!
    Beautiful picture....I'd love to be able to see the full-size one. Maybe I can get down to the museum and snap a few pics when it gets over there.
    By the way....that's my hometown paper! Go State Journal!!
    I'll plan on it. I don't imagine they'll have an issue with me taking pictures in there, and I haven't been to the Olds museum in years...so I'll drop in on Thursday afternoon and check it out.
    -Brian
    So sad.
    Javs
