Thanks for commenting. If the new unibodies aren't having a lot of chassis alignment problems in police service, it unravels my thesis that they're too weak. You're right about Chrysler's early unibodies but those cars had heavy side rails and crossmembers that looked like a real frame. The body was welded to them instead of on rubber cushions. I think they had a separate stub frame in front like the new ones. I had a 64 Chrysler that was as rigid as anything I've owned but it had too much road noise. I believe that Lincolns in the late 50s were unibodies too.
I think what I'm grumbling about is replacing the frame with U-channels pressed into the floorboard in the name of fuel economy. That's an oversimplification, I know. I read that major body work has become less common because it's more difficult. Collisions that in the past just needed Bondo and paint now require a chassis bending jig to move the wheels back to where they belong. Too often the result is a car that's unsafe to drive. Insurance companies prefer to call it unrepairable and not take the risk. They're becoming disposable.
True. I agree 100%. I was being a bit picky I guess--they are all unibody, but they're structurally different today in terms of how the car is put together (frame rails, area forward of the cowl).
I think the drivetrain/suspension problems were all rolled together (at least for Baltimore and the Tauruses). Jump a couple of curbs, and you can foul up a lot of stuff up front on a FWD car.
I think you are right, and the cops tended to feel that way too. The Impala was supposed to have fixed that weakness, with an HD cradle and suspension for the 9C1 (police) cars. Maybe it has and now there are other problems showing up. The complaints for the Impala around here concerned mainly the transmissions, and lots of other little bugs (electrical, I believe, that didn't take cars off the road).
I am not really a car fixer upper kinda guy, but figured out how to get the damned battery out of that tight spot they get it into. 2 questions for the group...
The battery is smaller in size than the original one, but once tightened into place does not move. What does concern me is it is labeled 630 Crank Amps. Is that enough? or is that a direct replacement for the old Battery?
Next question is about the spark plugs. I bought a set of plugs, and know that I have to gap em. What is the proper gap on plugs for the 3.4l Base Impala? and any opinion on replaceing the wires at the same time? I wanted to keep up with preventative maint. on this car and not sure what else needs to be done (aside from regular oil changes, tranny flush at 75k miles, new tires , brakes and rotors at 50k miles).
The battery will work fine. Physical size isn't meaningful anymore. Cold cranking Amps is a sham IMO.
The reason I'm answering you is about the plugs. What you're going to do isn't trivial. The heads are aluminum and there are rules that must be followed. You should try to get servicing literature about replacing the plugs before you start. 1. You're probably supposed to do the job while the engine is hot (if that's what the instructions say). 2. Apply anti-seize compound to the threads before screwing them in. Buy a tube of it at a parts store. 3. You must use a torque wrench to tighten them. This may be difficult to do in the rear bank because you don't have much room to work. If you don't have a wrench or the room to use it or don't know the correct torque don't do it yourself. To get to the rear ones, I've always removed the upper mount (also called the torque strut or dog bone) and pulled the engine forward with a rope to get space back there.
If the wires are undamaged they're probably okay. A replacement set of that quality could cost $100 from a dealer. They're usually replaced singly as needed these days, not in sets. They're weak so don't pull on the wire, only the boot.
Plugs are pre-gapped these days. The gap is probably at the end of the part number. The emission label under the hood should give it to you.
Forgive me if you knew all this but I felt like I had to say it.
Thank you much for the info. I didnt realize so much was involved, you saved me from screwing up big time. I think I will bring it to the auto repair place and have them do it. It's not worth buying the torque wrench just to do this one job on my car. I really dont do too much to it anyway (aside from light controllers and XM radio). Thanks a lot for the info. Any idea on how much they would charge for the install (and plugs?).
I just received a recall notice in the mail for my 2k impala ls. I called the dealer and he mentioned something about a coolant leak and some tabs in the rediator. Does anyone know what this might be about?
Well, just about everything I said the last time is wrong. I looked up the car in a set of GM Service CDs I have here. The plug threads are supposed to be dry and the engine is supposed to be cold. It would take a mechanic an hour or less to do it but I can't guess what he'd charge.
Here are a couple of observations on your first post. 1. The plug replacement interval is 97,500 mi. Why do you want to do it now, anyway? 2. The transaxle fluid change interval is 50K mi. under severe conditions, otherwise not at all. Fluid change means remove the pan, change the filter replace the pan and add fluid. It isn't a flush. When a shop advertises a flush they mean stick a hose into the filler pipe, suck out as much as they can and replace it. That shouldn't be done because it doesn't service the filter and it can stir up sediment and send it to places you don't want it to go. It's also less work for them. If you're going to change it, do what GM says. 3. There's no regular maintenance for the brakes. Wait for them to wear out.
Here's something you didn't mention but I will. The replacement interval for the air cleaner element is 30K. mi. Don't do it more frequently. Filters become more effective as they clog up and your engine will stay cleaner. Trust GM about how often to do it. Trust their recommendation for everything else, too, including oil change.
I saved the maintenance schedule in a zipped file. Send me an email if you want it. My mailbox is in my profile. It may be in your glove compartment because it's provided as a pamphlet with the car. Hope you enjoy your Impala.
I had the flush, but also had the filter changed at the same time. It did feel a little better in shifting for the first couple hundred miles. As for severe use, i leave my base impala idling a lot of the time, especially when I was driving 82 miles a day round trip to work. The roads here and the stop and go traffic in Brooklyn and Queens should constitute severe use. Thank you for all your advice. I plan on replacing my 00 Imp with a 2004 LS as soon as i save up the money for a decent down payment. Or just go for my dream car, an 03 or 04 unmarked police package Impala.
I was by my dealer today for an oil change on my 2000 LS & they performed the recall for the manifold (only took 30 minutes). I never received the notice in the mail & was pleasantly surprised when the dealer brought it to my attention. 85000+ miles on my Y2K LS and my only problem is the heated driver seat doesn't work - - you can't just replace the element, you must get a new $eat cover . . . LH
I have had my black 2003 impala ls sports for 2 months now, and no issues to date, but from what I have been reading on this board, it is a problem I do not want to get. I mentioned it to my dealer when I bought the car, and of course, they were in total denial of the problem. And then THIS arrives today in my mail from GM Canada:
July 2003 Dear General Motors Customer:
This notice is sent to inform you that General Motors is conducting a voluntary customer satisfaction program that affects certain 2000-2003 Chevrolet Impala, Monte Carlo, Pontiac Grand Prix, Bonneville, Buick Regal, LeSabre, and Park Avenue Model vehicles equipped with 3800 Series II (L36) V6 engines.
We have learned that your vehicle may develop an engine coolant leak at the upper intake manifold to throttle body gasket, or at the lower intake to upper intake gasket. This condition may result in a low engine coolant level and higher engine temperatures.
To prevent this condition from ocurring, your GM dealer will replace the engine throttle body fasteners with redesigned fasteners, and add cooling system sealant to the radiator tank. This service will be performed for you at no charge through July 31, 2005.
If you have already paid for some or all of the cost to correct the engine throttle body fasteners, and you have not received reimbursement under a Vehicle Service Contract, you should contact your dealer to seek reimbursement. Please provide your dealer with your original paid receipts or invoices verifying the repair, the amount charged, proof of payment, the date of payment of those charges, and proof of ownership of the vehice at the time of repair. Your request for reimbursement, including the information and documents mentioned above, must be received by your dealer by July 31, 2004.
You may be contacted by a dealer other than the dealer who sold or is currently servicing your vehicle. Please be advised that you may take your vehicle to the General Motors dealer of your choice to have the recall service work completed. Please contact your dealer as soon as possible to arrange a service date.
If parts are required, ask your dealer for details regarding their availability. If parts are not in stock, they can be ordered before scheduling your service date.
This letter identifies your vehicle. Presentation of this letter to your dealer will assist their service personnel in completing the necessary correction to your vehicle in the shortest possible time.
We are sorry to cause you this inconvenience; however, we have taken this action in the interest of your continued satisfaction with our products.
Customer Support Department General Motors of Canada Limited 03034 /il
I just received the same exact notification letter in the mail. It applies to all 2000-2003 Impala/Montecarlo models with the 3800 engine.
I no longer own the car as I just sold it a couple of days ago. The upper manifold was replaced back in December and the coolant was flushed already under warranty. I am sure that at the time of the repair the revised fasteners were also available. No issues after the manifold replacement was performed.
If you own a 2000-2003 Impala 3.8L base or LS model, you will receive the recall notice.
Good question. I myself don't have any further details on these new revised fasteners and as to why they are still adding sealer to the coolant. I'll pass this info along to the new owner of the car but I think this has already been taken care of as of the last time when the upper manifold was replaced.
Within the recall notice there is also a separate form for the owner of the vehicle to fill out if the repair was performed outside of the limited new car factory warranty and if it was paid out of pocket to cover for said repairs. They list all required supporting documentation (Repair receipts, etc) in order to receive your check refund from GM. I still think your best source of info is either your dealer's service manager and/or the 1-800 Chevy customer relations number.
If anyone's interested, my local Chevy dealer told me the '04 SS is supposed to be available on September 1st. The only color will be black. Supercharged 3800 Series II will be the stock motor. Pontiac will not be sharing their new Series III engine (260 ponies) with Chevy this year.
I received my recall notice in the mail today. My guess (although I haven't really looked to see how this might work) is that perhaps they've determined the warping of the intake manifold might be due to uneven/undue torque placed on it by the throttle body fasteners? If so, by replacing the fasteners with new/improved ones, and then doing a CYA by putting in cooling system sealant in the event there is already some damage done, they can fix the problem without having to replace the intake manifold on every car.
FWIW - I had mine replaced outside the warranty period for @ $800; sure hope I get reimbursed for it all (PLUS hope the new fasteners will eliminate the problem in the future).
I am going to ask my friend the GM tech. what this sealant is. I wonder if they have to use it if there is no leak. I agree that could cause more problems
FWIW - I just got back from a 2000-mile trip in my wife's 2003 Honda Accord 4-cylinder EX; just thought I'd give some random comparisons in passing.
I missed the dual-climate control of the Impala; I didn't realize how nice this is until we started fighting over the single temp control.
Steering wheel cruise/audio controls weren't as well positioned (may just seem that way because I'm used to the Impala layout), also do NOT light up at night, and there was no "mute" button (which is nice when traveling with kids in the back seat).
Being used to a bench seat Impala, I found the console to be a little confining to my right leg (but I haven't driven a bucket Impala for comparison).
Best gas mileage was just over 33mpg on this trip. That's primarily Interstate driving at 65-70mph, with the AC on. (Best I've ever achieved in my 3.8l Impala is also @ 33, but that was at a 60mph average on flat terrain without the AC on).
Front end of the Accord felt light on some corners and in some strong cross-winds we encountered (I don't think I've EVER noticed cross-winds in the Impala).
The console cupholders in the Accord sit one in front of the other (as opposed to side-by-side in the Impala), which made it difficult to get to the rearward one (which practically butted up against the armrest).
Tilt steering in the Accord is of the "adjust, then leave alone" variety, whereas that in the Impala is easy to lift up every time you get in/out of the vehicle. Being @ 6-ft tall, I would have found it easier to get in and out of the Accord if I could have readily tilted the wheel out of the way.
Trunk space served us fine on this trip for a family of 4; however, had it been a winter trip (when we'd probably have had another suitcase to carry), it's questionable as to whether we could have gotten everything in.
Also missed the automatic door locking feature of the Impala (and the automatic headlights). The Accord has an illuminated dash, which is almost illegible if you turn the lights on during the day (like during a rain storm). So, you crank up the brightness. Then when you get in the car again at night, you're blinded by the brightness, and have to turn it back down.
Seats were comfortable enough, and I do like the fact that the fan controller has more detents ("speeds") than does the Impala. Also nice to have a 6-disc in-dash CD changer.
Given a choice, if I'd known I was going to do all the driving, I'd have taken the Impala. But logic said take the newer (and presumably more reliable) car, so we took the Accord. I wasn't unhappy driving it, but I'm still impressed that the Impala offers so much more in many areas, for less money.
This program is in effect until 7/31/05. Condition: General Motors has decided that all 2000-2002 and certain 2003 Chevrolet Impala, Monte Carlo; Pontiac Grand Prix, Bonneville; and Buick Regal, LeSabre, Park Avenue model vehicles, equipped with 3.8L (RPO L36-VIN-Code K) engines, may have a condition in which engine coolant may leak at the upper intake manifold throttle body gasket, or at the upper intake manifold to lower intake manifold gasket. This condition may result in a low engine coolant level and higher engine operating temperatures.
Correction: Dealers are to replace the three throttle body fastener nuts and add cooling system sealant to the radiator tank.
Service Procedure: Important: All "W" cars and "H" cars require a total of 16 grams of coolant sealant pellets per vehicle engine cooling system. The Buick Park Avenue ("C" car) requires 20 grams of coolant sealant pellets per vehicle engine cooling system.
1. Remove the engine intake air snorkel assembly from the throttle body (t/b) and air box. 2. Remove the bolt from the t/b support bracket at the throttle body. 3. Loosen the bolt from the t/b support bracket at the cylinder head and move the t/b support bracket away from the throttle body. 4. Remove one of the 3 t/b nuts. 5. Apply thread locker (p/n 12345382 U.S./10953489 Canada) to the stud. 6. Install a new t/b spring nut (p/n 11517293) and tighten finger tight. 7. Repeat steps 5 through 7 for remaining t/b nuts. 8. Torque the 3 t/b spring nuts to 10 Nm. 9. Reinstall the t/b support bracket into position. 10. Reinstall and torque the t/b support bracket bolt to 10 N. 11. Torque the t/b support bracket bolt at the cylinder head to 10 Nm. 12. Remove the vehicle radiator cap. 13. Remove an appropriate quantity of coolant pellets from package and pulverize the pellets in a plastic bag. The Park Avenue cooling system requires 20 grams of pellets and all the other vehicle cooling systems require 16 grams of pellets. 14. Install the crushed pellets through the radiator neck after adjusting the coolant level to accommodate the pellets. 15. Add coolant as required and reinstall the radiator cap. 16. Install the GM Identification Label.
Labor hours allowed are 0.5 plus 0.1 for administration for a total of .6 hours
My Pontiac dealer told me that it has taken an average wait time of 30 minutes per customer. My Chevrolet dealer is still waiting for the parts and if he doesn't get them in in a week I will have this procedure done by my Pontiac dealer.
Ivan overtightened the fasteners. The problem may not be the thermoplastic parts at all. The sealant will probably lessen the efficiency of the radiator.
Actually a vegetable formula composed of, I kid you not, ginger, almond shell, turmeric-CAS#456-37-7 and sal soda. The torque on the original fasteners is only 7 ft.lbs, very easy to over torque.
In a pinch (at least in the old days), you could pour some black pepper (the stuff you keep on the table next to the salt) into the radiator if you had a small leak somewhere, and the pepper would often be enough to clog the opening and stop the leak. Don't know if it's advisable in today's cars, but it used to work.
I had a friend that had this problem and he suggests the following:
"Get it done now. If the coolant leak did happen, it could go into the engine and seriously damage it. The coolant is so corrosive to an engine that it can eat the bearings and screw it up permanently. No real way of knowing whether coolant is leaking into your engine until it's too late. By then the serious engine damage has occurred and you will then have to get a new engine. What happens a lot of the time is the coolant will leak slowly and then GM will stop the leak by fixing it, but some engine damage may already have occurred. You will never know until your car dies at 50,000 miles because the bearings went out. That's not something to fool with. I'm familiar with this cause Saturn used to have the same problem. People kept driving their cars, damaging them without even knowing it. GM would only replace the engine if it seized."
Today I took my 2001 LS in for the recall issue. It only took a half hour to do the procedure. Three small bolts were replaced on the throttle body assmembly and sealant was added to the radiator. I asked the technician what was the difference between the bolts, and he showed me that the new bolts have spring fasteners where the original bolts didnt. The original bolts could loose torque with heat and create the coolant leak mentioned, where the new bolts with the fasteners keep the torque at all temperatures.
My turning signals started living their own life (i.e. signalling without telling it to), and I took it to a shop to have it looked after. They said the turn signal switch & electronics was broken and that I'd need a new one.
As luck would have it, I live in Finland and the local shop gave a $800 price for the part. That's somewhat too much, considering gmpartsdirect.com sells it for less than $200.
Now, I _think_ the part I want is GM part# 26093873. I've been unable to really find any information or pictures on it anywhere. I wonder if someone could help me and say whether this is the right part for a 2001 Impala LS.
I have a 2000 Impala base that I bought used. Love the car and put 20,000 miles on it already. One thing I don't like is that the rear seat on my Impala does not fold down. the previous owner bought the "base" model without this feature.
Is it possible for me to purchase through a Chevy dealership a fold down style rear seat back and replace my non-folding seat? I have had the rear seats out before while changing the 6 x 9 speakers so getting it the old one out won't be a problem. I am hoping that there isn't much difference in the hardware and that with a few nuts I can secure the fold down seat (if I can get it).
Thanks for the info. That much I had managed to dig out, but now I'd want to be sure that's the correct part before I go ahead and order it.
So if anyone who has the service manual (I was dumb enough not to buy it ) could you scan the page with the steering column assembly and the part numbers, that'd be great. So that I'd get some kind of picture of the part.
Apparently, thermoplastic is being used for the wings of the next generation joint strike fighter airplane so I wouldn't obsess too much about having a thermoplastic part in my Chevrolet when pilots will soon be flying at mach 3 with thermoplastic wings. Just MO.
Hi all, I haven't been here in quite a while. Its time to replace the tires on my 2000 Impala LS. The original Goodyear tires were pretty noisy, has anyone found a good tire that's gives a little less road noise?
I hate Goodyear tires...noisy and short life/soft tread. My Firestone tires are amazing. Any of their UNI-T tires or the Bridgestone 910's are awesome compromise of ride and wear.
I am satisfied with the Goodyear Eagle GA's but expect to replace them before 25K miles. Ordered the Kumho winter tires from Tirerack so I will only use the Goodyears as summer tires.
My 2003 LS has been in the shop eight times since I purchased it in January. I complained about a high pitch noise when braking. They did not hear it. I have complained about a pulsation in the steering wheel whne braking and a vibration in the seat and floor when traveling at speeds between 35 and 50. SInce I am filing under the lemon law in my state I would like to get copies of other repair orders which pertain to the same problem. The dealer that I purchased my LS from says that I am the only having a problem yet they also say they are unable to duplicate it. If you have repair order I can get as copy of please contact me
I test drove an Impala LS Saturday. It had plenty of power, excellent handling, & I didn't find anything I didn't like about it. I floored it while doing 70mph hands free, & there was no torque steer. The vehicle tracked straight as an arrow. I also drove a Crown Vic LX Sport I'd been considering, but found the rear end tail happy. Reluctantly I waited a day too long as my local dealer already sold the fully optioned Impala I'd been eyeing. The car I drove didn't have enuf goodies for me to consider a purchase, but at least I got the test drive out of the way. Anyway, guess I'll have to wait for the 2004's & hope GM is still wheeling & dealing.
Automotive News has reported in its August 4 issue that the 2006 Impala will have an optional V8, probably a 275 hp 4.8L V8. The car will probably remain front wheel drive. The article did not say what the other engines will be, but I would not be surprised if the 200 hp 3.5L OHV V6 from the 2004 Malibu were standard. GM is also introducing a new 3.9L OHV V6 for the 2006 model year that could go into the Impala.
Hey, I received a letter from GM. They are offering me an additional $1,000 if I buy another GM vehicle within the same division (Chevy). Since I now have $1,500 in GM points, my total GM rebate will be $2,500. My father, who drives a '98 Camry, is looking to buy an Impala.
I've been looking in the newspaper lately. A "California package" Impala with a retail price of $23K can be had for $15,990 (one at this price). With the $2,500 GM rebate, our final cost on the base Impala will be $13,400!! That's cheaper than a fricking Civic!! LOL
Now, I have to find out what the heck is a California package. I think it's probably bucket seats with some fancy 16" rim. I much prefer the LS 5 spoke wheels though.....
Drew
July 2003
03034
/il
Well, better late than never, I guess..
Now, where's that phone number for my dealer..
Cheers,
Torque
Service Procedure:
St. Louis, MO
Any input would be appreciated.
Without Cruise Control . 26093874 $359.47
With Cruise Control . 26093873 $359.47
Hope this helps..
http://www.planetsalvage.com/
The irony is that Dunlop is owned by Goodyear. Go figure.
