I don't think it is necessary to use the term "stealership" or refer to dealers as "stealers" - please feel free to speak candidly about your experiences with Chevrolet dealers here - positive and negative - but that kind of derogatory label interferes with a polite and useful conversation.
With that said, let's remember that we ARE talking about the Impala here and not the general state of the world of salesfolks.
The one I got is made by Hidden Hitch (#90025); it's a 1-1/4" Class II hitch (even though the Impala isn't rated to pull that much, many of the bike racks that mount in a reciever hitch require a Class II hitch). The info stated that it required no drilling, and would take about a half-hour to install. It took me closer to 45 minutes, and I've got a couple of holes that didn't align just right that I'm going to have to drill out a bit, but all in all I'd say it was an easy installation (especially considering I did it with no assistance, and at night in my garage with just a shop light and a couple of wrenches).
Granted, I haven't actually put the draw bar on yet, but with it removed and the cover in place, the hitch is really not noticeable on the car at all - I was afraid it would look really large and tacky under the car, but unless you're looking for it, you wouldn't notice it at all. I've still got to drill out the couple of holes and finish the installation before I can actually put it to use, but it's held on with four other bolts, so I'm not worried about it falling off or anything (I'm not going to put any weight on it until I get the final two bolts put in).
I'll probably also install a wiring kit, so I'll have the option to rent a small trailer from U-Haul should I need it. I occasionally need to haul something, but not with enough frequency to justify my selling the Impala to buy a truck (especially with gas prices on the rise).
Anyway, I didn't remember seeing anything else posted here about installing a trailer hitch, so I just wanted to confirm it can be done pretty easily (and fairly cheaply, I think I paid @ $135 including shipping).
Any thoughts as to whether this is a "normal" cycle, or if the seemingly short life span of batteries is any type of sign of a bigger problem?
Also, FWIW, my airbag light has come on again...I had this dealt with a couple of years ago too, and it involved a problem with wiring related to the side airbag - Has anyone else had this experience of having the airbag light dealt with, only to have it return after some period of time?
nascar - have you had any trouble pulling the 4x8 trailer with your Impala? I don't really have anyplace to store a trailer, but I can rent a 4x6 from U-Haul for @ $10 a day...but I think that trailer weighs @ 700 pounds. Total towing weight allowed with the Impala is something like 1,000 pounds, so that doesn't leave much margin in terms of what I can haul.
maybe youre not driving long enough to fully charge your battery on the weekdays to/from work. on my beretta, i was only driving 10 miles round trip to work and noticed that my battery would be weak after a couple of years and would need a good charging or a long drive on the weekends.
you may try a long drive on the weekends to charge the battery or hookup to a trickle charger. did you check the acid level or the specific gravity of the acid?
worst case, you have a short somewhere.
bty, the 2nd battery, how many months was it good for and how old was the battery when you bought it?
Problem is, I don't know what I need - obviously I don't want to spend $70 if I can spend $10, but if I NEED to spend $70 to avoid causing problems to my wiring system down the road, then I'd rather pay now than pay later.
Even though I only have 1600 miles on my car, I'm taking it within the next few days to get those terrible Goodyear GA's taken off and get the Yokohama Avid Touring tire put on which I had on my 01 Impala and really loved.
I'm working on replacing the plugs and fuel filter on my 2000 LS. I was able to get the front plugs with no problem, however, the back three look like its gonna be a real [non-permissible content removed]. Anyone have any suggestions on how to get at them.
I'm also replacing my fuel filter. Are there any gotyas I should look out for?
BRAD
The Impala has a fuse and relay box under the hood and one of the relays is a starter relay. Try pulling it out and looking at the contacts. If they appear a bit corroded, you can clean them with the abrasive side of a dish washing sponge. You know, the side that is normally green for scrubbing pots. It's non metalic and works great for cleaning electrical contacts like that. After it's clean, spray the male and female contact points with something like marine grade silicon spray to keep them clean for awhile. It would be a good idea to do them all at the same time.
I had pre-mature "battery failure" that really was just dirty starter relay contacts. I did the above procedure and my bad battery works like new now.
Hope this helps.
Thoughts??
As far as the harness, I let the dudes at Franklin Trailer worry about that when I purchased the trailer. I had got the hitch and installed that on my own. I let them recommend the trailer and wire the harness.
I would, however, suspect wheel balance and/or a bad wheel(s).
I have a 2000 LS 3.8 with about 86,000 miles. I drive it 100 miles a day total to and from work. I've recently noticed a strong burnt rubber smell coming from the engine compartment. I've looked all over and don't see any wires/hoses that could be leaning against the block or exhaust.
Does anyone have any other suggestions on what I should check?
BRAD
#01-02-32-001C Clunk Noise from Front of Vehicle During Turning Maneuver/Steering Wheel Rotation (Lubricate Intermediate Shaft) - (Sep 12, 2003)
#00-08-61-003 Clunk/Pop Noise From Front of Vehicle (Shim Rear Frame/Cradle Mounts) - (Oct 17, 2000)
BRAD
NOTHING is free. You pay for it all. Either early or late.
You got your money's worth from the car (or bought it used at a price reflecting the market).
There comes a time when WE have to pay repair costs.
I know these things. You see, my Impala LS has 167,000 happy miles on it.
I bent at least 2 passenger side and one driver side tie rod in the 4 years I have my Impala.
Just got the two front Goodyear Eagle HP's replaced with Goodyear Assurance (80k mile version) and the car is noticeably quieter. Also a little better responsive with these tires in hard turns.
Glad to hear your input on the Goodyear Assurance tires. Did you get the "Triple Tread" or the Comfort ??Ride?? version of the Assurance tires? I'm glad the noise level is noticeable quieter.
Anyway, love my impala, waiting till 2006 to get a new one!
A question for you. Do you actually have the problems described in the two TSB's you mention? Or do you want to fix them as a preventative measure?
Dan
The Impala is overall a good car. Major things I liked:
Quiet smooth transmission and engine, virtually no wind noise. These items were quieter than my Taurus, though the Impala had appreciable road noise on the Seattle freeway system (do they allow studded tires in the winter in that area? It felt just like the stud worn roads did in Wisconsin before they banned studded snow tires.) Road noise is hard to compare directly unless you drive the same roads in both cars. Impala ride and handling was smooth but not too floaty and handled well in the moderate twisties leading up to the Mount St. Helens observation center.
Nice individual temperature controls for driver and passenger.
I liked the trunk hinge system that did not intrude on luggage. Trunk was very spacious.
Nice large outside mirrors, bigger than my Taurus.
Dislikes:
Center armrest too far back. I am 5'7" and with seat adjusted for my height, the center armrest was useless. Door armrest was hard as a brick. I thought my Taurus door side armrest was too hard, but the Impala was irritating.
Steering wheel spokes required hand positioning either too low or two high. Fat spoke seemed mispositioned. Steering wheel was large diameter compared to my Taurus, but I could get used to it.
Why put the cruise control on/off switch on the wiper stalk and all others on wheel? They should be all on the wheel.
Why no shift position indicator on the floor shifter, only on the dash? They might as well just put the shifter on the column and free up space to move the arm rest forward and then move the cupholders further forward, as they are an awkward reach.
Noticed occasional suspension creaking in city driving over rough, uneven streets.
Lumbar adjuster seemed to do little from min to max, all felt about the same.
Why the oval inside rear view mirror? Cuts off the corners of the rear view. Would have worked well with the ovoid 96-99 Taurus rear window!
No upper windshield dark tinted band? The black perforated area above the rear view mirror I can see working OK to block sun in that area, but it was kind of distracting. My Taurus has dual visors, which are handy at times, the Impala does not.
Seemed to run out of torque when accelerating from higher speeds, but was adequate. Low speed torque was good, as it should be with a pushrod V-6.
All in all a good car, but the armrest issues and the steering wheel spokes were my only major gripes. the rest are my minor nitpicky opinions and may not bother most people.
Apparently Lutz thought deleting these things would save GM money.
I ordered a car Friday last. I have over $3500 available to me on the GM card, and there are large incentives on the Impala right now.
I ordered an AWD Ford Five Hundred.
The deletions were a major factor in my decision.
I have over 168,000 miles on my 2000 LS. All it's ever really asked for that wouldn't be expected is a headlight switch and an airbag sensor!
But with the things GM has deleted that I CAN see, I couldn't stop wondering what they had deleted that matters that I cannot see.
So, the decontenting resulted in at least this customer not being content. My last three cars had all been GM products. The last two each had respectively lower levels of equipment than the one before them.
It's been a fun ride. But, for now at least, it's soon to be over.
Still a great car for the price, but I would miss too many of the things that have gone bye-bye.
2000 Chevy Impala, goldish/beige color, 3400 engine, power/heated leather seats, 51K miles.
Few Questions
1. Anyone ever replace the clear plastic that covers the instrument cluster? How did you do it? The one in this car is cracked
2. I have the compass/temp display. The compass works fine but the temp reads 0C. Anyway to recalibrate/fix this?
3. Anyone ever hear a gurgling noise coming from the coolant tank? I was told this is just the tank refilling. I have never heard any other vehicle do this. It did it once tonight out of the 5 times I drove it.
Anything else to be aware of? Its a very nice car. Drives great and is very quiet.
Ryan
