Do you know what sealer they used?
RR
As for the Amp, I hesitate to give that info, at least until I actually have my new amp in the car. If they get hit with more of these, they may decide not to do ANY of them. I believe you will have a good chance of success if you arm yourself with posts from this board and go to your local dealership...
How do you post a picture, anyone?
By the way, you can get to the Owners Club by clicking on the link that appears under the discussion title at the top of this page - sometimes folks forget that.
Hope this helps.
Pat
Sedans Message Board
I am also going to have them seal the roof trim. I mentioned to the Serv. Dept. that I didn't want them to replace the trim, since it would just come up again.
RR
I HAVE to have this thing tightened. It's driving me nuts.
Next oil change.
Cookie.
LRCobra
IIIIIMMMMM BBBBAAAAACCCCCKKKKK
In other news I got my tinting done, found a nice place that all the dealers go to, got Solar Guard Tinting. Also modified my exhaust, it looks awesome. I have to get some pictures up. Got the floor mats like 00impala's, and am waiting on 4 wheel caps from the 96 impala to replace the bowties.
The only thing I am thinking of doing now is maybe replacing the tires, going to stick with the same size, I just am tired of all the road noise. What do you all recommend as a replacement?
That's what I'm looking forward to getting next.
LRCobra
Chris
After putting it back in place, I eventually got it to stop making that irritating noise by sliding the top half a few times until I found the right position for it. It's been about two months and it hasn't come back. Hope this helps
As for the shaking mirror, there doesn't seem to be anything you can do about it, but that problem goes away as soon as the interior cools..
BTW, I've noticed the roof strips are coming up a little in the back. It seems the only way to fix it would be better adhesive, but what would work? If anybody finds something that works long-term, please let me know. Thanks.
Mine reads 2-4 degrees high.
Read your owner's manuals..
Welcome back LR.
LRCobra
Call Chevy's 800 resolution number again. The Malibu has a known problem with their brake rotors. You should be able to have them completely replaced, along with new pads, under warranty. Do not accept resurfacing. That is probably what they've been doing until now.
Check the NHTSA or ALLDATA websites, which list recalls and TSB's for all cars. I'm sure there are listings there for Malibu brakes. Also, MSN Carpoint, Edmunds, and Carreview.com have many user reviews describing Malibu's brake problems, and their possible solutions.
Info is available at www.michelin.tireselector.com/
Michelin tires are best suited for all vehicles. If the tires performs well, gives good gas mileage, long lasting, and good handling, why not use them on all vehicles?
Does it really matter what suspension is underneath, Base vs LS? Absolutely not.
according to the service manual page 6-478
3.4l (RPO K34) 102 AMPS
3.8L (RPO K43) 102 AMPS
3.8L (RPO KG7) 125 AMPS (MAYBE FOR POLICE PACKAGE)
Check the sticker in the trunkn for the RPO #
My point is: a few degrees either way is not worth worrying about. It's probably the correct temperature for where your are at the moment. If it's off by 20 degrees or more 'consistently' then by all means have it checked. By the way, if you're comparing it to a "household" thermometer, when was the last time you had "it" calibrated? Why, never, you say...hmmmm. Temperature measurement devices for the regular consumer market are notoriously subjective (read inaccurate). Temperature measurement tools just like any other "measurement" tool need to be calibrated regularly. This only happens in the professional environment. Sorry for the rant, but I felt something needed to be said.
There may also be Onstar issues.
I'll post what I find.
The mid-profile tires on the LS are well suited for the stiffer, higher performance tuning of the LS suspension but are still soft on the bumps, hold the road well, etc.
The high profile tires on the base Impala are well suited for its softer suspension settings and more economical cost scheme.
Michelin and many other manufacturers make all three types of tires. My feeling is that any tire that matches the OEM size will work pretty well. I just believe that Michelin tires provide a better overall value than the others in the high and mid-profile size ranges. I've never had a racecar so I haven't any experience with low profile tires.
Low profile tires DO give the driver better handling, cornering, traction, and acceleration. It's not just for looks.
If anyone is interested in low profile tires, I recommend Dunlop SP8000. But for touring sedans, I recommend Michelin MXV4.
zoom zoom
My solution was to replace them with Yokohama AVS dB's. They are Z-rated performance tires, so I no longer get squealing and even skittering on simple turns and entrance ramps. They are available in 225/60ZR16, so they fit the existing rims. They are incredibly quiet, the quietest tires, touring or performance, that I have ever driven. For $96 each, they are an excellent value. The GA's are usually more expensive!
If you are due for new tires, or just want to improve the ride and handling of your Impala, I highly recommend the Yoko AVS dB.
If long tread life is important to you, in addition to a smooth quiet ride, you might consider the Yokohama AVID Touring which has an 80,000 mile warranty, and is an incredible $49 at TireRack.com. Your local discount tire dealer should match that price.
Of course, it's not as high performance a tire as the AVS dB, but still a much better all-around tire than the Goodyear GA (which apparently stands for God Awful).
See for yourself. Go to tirerack.com, choose Shop By Size, 225/60-16 Standard Touring, check the boxes by both tires, and click compare.
However, everything else about the Acura is superior to the Impala, except for the exterior appearance, of course.
My only dilemma is that I'm not sure it's worth the extra $$ for z-rated tires. The Impala LS is too big for me to do any sharp cornering or drive in super high speed.
By the way, I recently installed the K&N filter. I"m not sure if it produced extra horsepowers, but I do notice the quick acceleration. Nice throttle reponse. Didn't hear any "whistling" when I put the peddle to the metal.
If anyone is interested in buying my old air filter, let me know. It only has 5,500 miles. Still looks new and good for another 10K miles. My e-mail address is hvan7756@aol.com. After Aug 15, I'll be cancelling AOL. Moving on to Earthlink.
Somehow I felt you owned a foreign car; so who gets to drive the not-so-great Impala????
