Steve
Steve
We are heading back on May 5th! Should be a blast!
The MDX is probably worse than the subarus in the sand and what not since they at least have power to all wheels all the time, whereas the MDX is FWD til there is slippage etc.
-mike
What is the distance between Potter and Richboro, PA (dealer)? It sounds like a haul, even by Pennsy standards.
As for the fluid refill time, it is a matter of seconds. So theoretically you could suck out the old and refill. You could start the car for only a couple of seconds and repeat the process and probably get out mostly old fluid when you redrain the reservoir. At least when I pulled the refill hose one time my 99 it seemed like it would have refilled the reservoir in only a couple of seconds.
I know the percentage of old fluid in my suck-out batch decreases as the procedure is performed more times, because you have a higher percentage of new fluid in there from previous iterations.
With the basket out it is very easy to vacuum up all the fluid and any small particles that could have been on the very bottom of the reservoir. In addition, I was able to wipe off the screened areas although I didn't see much of anything adhered there.
I had disconnected the line and really flushed it well a couple of times back. Therefore the fluid still looks very good so I am not too concerned, at least at this point, as to the percent of old fluid removed. Next time I probably will drain, fill and start the pump a couple of times and take some measurements.
If I tap on either piece at the corner they will slightly rattle. The problem seems to be that the retaining bolts are attached to some rather flexible metal brackets. Thus, while I can tighten up the bolts the pieces will still vibrate into one another and rattle. My temporary, maybe permanent, solution was to just wedge a 1/2" long piece of rubber vacuum tubing in between the two trim pieces. I did this on both sides. It stopped the rattle, is basically invisible and sure seems easier than reengineering the mountings.
If anybody else has this problem you are welcome to my "solution" and I would appreciate it if you have a better fix to pass along.
On the driver's side of our 98 Trooper, the gap between the top of the bumper and the wheel fender flare is about 1/2" larger than on the passenger side.
Any ideas? I've crawled underneath and looked around for a while. Even tightened a couple bolts down there. But I couldn't figure out where exactly the bumper can be tightened as a means of raising it slightly.
-mike
If it isn't those, there is also the sheet metal that holds the plastic on? If you take the bumper completely off, you could check to see if the sheet metal/plastic attachment is loose also? Once you break the bumper bolts it should only take 15 minutes to take it on and off.
paisan, you gonna paint your bumper Red Rock Mica and THEN sell it to me for cheap?
Nothing holds the bumper on the left and right ends, except for it fitting behind some plastic trim by the wheel wells.
-mike
I'm not so sure that your experience is consistent with the general consensus on oil consumption with synthetic (Mobil 1, a "true" synthetic) vs. petrol-based (Castrol Syntec is marketed as full synthetic, but it's really just exremely processed dino juice).
Usually, especially in older vehicles, you might see more consumption with synthetic as it's a bit more slippery.
IMHO: Extended warrantees are not a good idea in general and particularily a waste of money on a Trooper.
If you must have an extended warrantee shop more than one insurance company because it is nothing other than break down insurance.
-mike
-mike
-mike
The genuine GM factory extended warrantee was written through a third party insurance company. It came complete with all the small print that says everything is covered unless it breaks. Basically consider the extended warrantee only for catastrophic failures such as the timing belt broke and wiped out the valve train or the transmission needs replaced. Anything that can possibly be attributed to wear and tear is not covered. We had a $250 deductable on this one.
We eventually after 26 returns for repair sold the Silhouette and bought another Silhouette. My wife likes the Silhouette and I like the dealer, we are on first name basis with the shop there. This one is a 2002 which has 5/60 as the warrantee period. Even this standard extended warrantee comes with its own fine print etc... We were told by the dealer that the Silhouette that we bought had traction control, but found out it does not, I asked for traction control to be installed, they said that would be a complete overhaul of the braking system and a new engine computer, so they offered to make the warrantee 5/100 and I took it and another set of fine print, since the warrantee was extremely important on our first Silhouette. Now I am pretty confident that we can make this one last the 5 years without too much repair expense out of my pocket.
So far 6 months have gone by and we are abut to take the Silhouette in for its first warrantee repair. It will not restart if started and shut off, the battery light stays on too long after a start. The other Silhouette was on its third battery (1st two cracked at the plus terminal) in 45K miles, so I guess this one was made the same.
Sorry for the non-Isuzu topic, but the subject is warrantee repairs which my Troopers have not needed.
-mike
I think we got a better value from the extended warrantee when we sold it, it helped us to get top dollar 1998 Silhouette 45K in Dec 2001 $14500. Because of discounts and incentives on the 1998 Silhouette we paid $19900 including tax and liscense plate while the sticker price was $27600. Now you understand why I could justify buying another one even expecting to have lots of repairs. New 2002 Silhouette stickered $29K and we paid $21.5K out the door.
-mike
-mike
Looks like it's time for a trip to the dealer for a warranty repair. Seems I saw a post or two a few weeks back on this. Anyone know what the problem / fix is?
-mike
-mike
-mike
How hard would it be to swap an entire used 3.5L engine into my manual 5 speed Trooper? Would the new 3.5L engine computer play nice with my manual transmission and other accesories?
I just had another attack of the tick. It makes me mad when it happens. I control it by changing oil, drive 500 miles, if still ticking change oil again... When the problem is gone it stays gone for maybe 10K to 20K miles. When it happens I get real unhappy and want to do something to make the tick go away forever. I don't think $3000 (installed) for new parts of the same design is a good value.
Thank You
BoxTrooper
-mike
Is that something you really want to do? Why not just sell yours and look for a clean newer model? Likely it will be cheaper and far less hassle. Haven't most people with the 'tick' problem (was a good tv show, don't know why they cancelled it) fixed it with a changeover to synthetic oil?
Swapping out a motor isn't the same as back in the 60's and 70's.
MK
