-mike
-mike
I also got a fuse kit for add-on accessories. I haven't used it yet, but it seems like the easiest way to wire up my CB, just pop it in a 10 AMP fuse, and then you can run both off the same connector. It provides a hot output for whatever new accessory you are putting in.
They also had computers there for reading engine codes, all for under $50. I didn't see any Isuzu specific they had several GM types, but I also didn't really look too hard.
www.auterraweb.com is where you find it. You can downlad the software and run it in demo mode so you can see what it's capable of.
Don't forget to get the Isuzu dtc database.
Savvas
For our 98 Trooper, the charge is $89.95 for changing the filter, fluid, and gasket, performing a leak test, and a road test. Does 90 bucks for this seem reasonable? I didn't think to ask if they drop the pan as part of this service. I seem to recall folks mentioning here that dropping the pan is a good idea?
I'm gonna try to stop at AutoZone today and check out their free CEL diagnostic service and see what it's all about.
I can appreciate the peace of mind that comes with having the service performed by the dealer, but 220 bucks for trans service sounds outrageous. 90 bucks is so much less that I'm almost worried about it being TOO cheap. However, I think the 220 is a little out of whack even for dealer service. I thought someone - maybe duktrooper - mentioned a while back that his trans service was $150 at the dealer. That would make $90 seem reasonable and not 'too good to be true.'
-mike
-mike
Most car manufacturers discovered some time ago that a complete exchange to new fluid in a flush was much more beneficial than just doing a filter change & is generally what they recommend. As long as the filter doesn't get sufficient dirt loading to reduce the flow rate, a filter change wouldn't be necessary in normal service for some time, IMO. As the filter traps more "dirt", the filtration efficiency actually improves up to its limits / dirt loading capacity (larger micron holes in the filter media are plugged-up first).
-mike
The car only had 40,000km but it is classified as being in severe service because of lots of repeated short trips.
Anyway, at almost 66,000 miles it seemed like a good maintenance item for our Trooper. However, I've heard many folks advocate NEVER touching the transmission fluid, especially after the vehicle is pretty old and/or has lots of miles. I don't know the rationale - perhaps the risk of stirring up contaminants or burned fluid or other gunk (that's a technical term) when doing a flush?
I need to remember to ask the shop to confirm that they drop the pan, explain HOW their procedure is done (high-speed flush, low-speed flush, etc.), clarify what % of fluid is removed, clarify whether the filter is cleaned (i.e. metal mesh) or replaced, state their thoughts on using synthetic ATF, and the cost difference if I supply my own Mobil 1 ATF (I'm considering it).
In my area, price for a trans flush at a quickie lube shop starts around $50-60.
Lady hooked up scan tool to Troop, pulled 2 codes, and cleared them which caused the CEL to go off. She said the 2 codes were the same, but I was thinking she may have had trouble getting the 2nd code to display on the scan tool. The code I got was:
P1441. Scan tool said it was a dealer-specific DTC (diagnostic trouble code). The computer in the store said the code was "evaporative emission (EVAP) system flow during non-purge Chevrolet only."
This sounds consistent with not tightening gas cap enough. Hopefully, that was the cause of the CEL. We'll see if the CEL returns. Hopefully not.
It was teh gas cap on mine.
-mike
BTW, Mike.... that OBDII connector I asked you about before. Doesn't seem to be in the same location on the RHD Jackaroos as it is on the LHD Troopers. I'm none the wiser. Can't find it anywhere, on the left or right of the car. Inside the car or under the bonnet.
-mike
FWIW here is an online listing of Isuzu codes -
http://www.batauto.com/isuzu/iszuobd2.html
Over in the other forum section you asked a question about maufacturers withholding codes here is an article on that. Basically they are trying to keep some OBDII diagnostic codes secret so their dealers can get more shop business.
http://www.cnn.com/2002/TECH/ptech/06/24/diagnosing.cars.ap/index.html
I read on other board SUV/Isuzu Rodeo message # 692 around 6/12/02 that Isuzu will upgrade ABS. Is this correct? If it is, can I get it done after I took the car to a non-Isuzu dealer to work on it? If I can do it, how do I go about it?
Take the car to an Isuzu dealer to do the ABS upgrade. Shouldn't be any harder than that.
As to a new sensor blowing out the condensor, get that in writing and take them to court. I know I have never owned a vehicle that has a sensor that is supposed to check for something and then blow the compressor if certain conditions are met. Sounds like maybe they put in the wrong sensor. In any event, my take is that the rest of the repair is on them.
Unfortunately, you do seem to fall outside this realm. $700 could or could not be reasonable depending on what the "other stuff" is.
$950 seems a bit high for parts of the AC system.
Bring your truck to an Isuzu dealer for the upgrade on the ABS. But call to make sure they have the parts before bringing it in.
-mike
-mike
I am going to another place that has the Hunter GSP9700 Balancer (I was going to buy from them but they were $20 more per tire, now it seems like a bargain). Anyway this machine and shop is better equipped to do SUV tires. It is going to cost me an extra $30-50 to have all tires re-done. A small cost, vibration heats up tires...heat causes them to fail...then you have an exploder not trooper.
I do like the tires. They handle great, wet/dry, are quiet, except at 70-75 and up. Only regret was trying to save a buck, rather than go to the right shop the first time.
Can somebody answer?
I'm just trying to find out if somehow they damaged the compressor when they put the new valve in and they are making me pay for it.
I did not mentioned that the dealer did repack the drive shaft under warranty few weeks back because of cluck noise during 1st to 2nd gear shift, I think they just re-greased the slip yolk that goes into the tranny, they dropped the drive shaft, can they do something wrong during this process ? If they did do somthing wrong, it would make more sense to have this shake at all speed. It would be hard to go back and tell them " there is vib over 80 mph", they will probably tell me not to drive so fast. Any other ideas. thanks
Calvin
Bob Jane T-Marts in Australia have a system called ProBase balancing. What they do is a balance of the wheel without the tyre on, to find the high point of the wheel itself. They then do a balance of the tyre without the wheel, to find the high point of the tyre. They then install the tyre on to the rim so the two high points oppose each other. Then they do a balance of the whole assembly. This way they need only install a minimal amount of weights to balance it all out, reducing the spinning weight that may otherwise be there.
I'm getting a wheel alignment and balance done at this place on Saturday morning. They guarantee that they will get rid of the problems I've been having with the "follow the crown" steering and off centre steering wheel, and I can get a follow up balance and alignment every 10,000kms for $25.
My view is if any problems start after something has changed, then that last change is most likely to be the culprit or has at least brought to the surface another underlying problem that was previously hidden. So I think the driveshaft is your best starting point.
Comes from my computer industry background!
So take your choice - bad diagnosis by the shop or lousy repair? Either way I still say the rest of the repair should be on the shop.
As a next step you may want to try posting your story on airconditiong.com's BB and get their expert's feedback. http://aircondition.com/wwwboard/
In adddition, take it to another AC shop and get their opinion. They could find something proving incompetence by the Honda dealer (e.g. wrong refrigerant charge, wrong part, etc.).
Lastly, won't any Honda dealer honor the repair warranty? If so, take it to another one and see if they find a problem with the original repair/will honor the warranty of a "repaired AC" system.
Good luck and keep us posted
As a longshot option you could have a plugging fuel filter. When at high speeds the vehicle will momentarily starve for fuel causing more of a bucking feeling. I had that happen once on a Toyota.
I am going to bring the $50 bill to the firestone place for some compensation. What a joke, the Firestone place balanced the tires 3 times. Also, this shop pointed out that they were using the wrong weights (non-coated)...they put teflon coated weights on, supposedly to protect the alloy wheel.
If they put in a new DS, how would they match (align) the front(tranny) and the differetial ? or don't have to. thanks
If they order a new driveshaft for some reason, it should be exactly the correct length provided they get it from Isuzu. They do not have to realign the tranny or diff. It should also come correctly balanced. They still however can install it out of phase.
Do yourself a favor read up on driveshaft phasing and then talk to the shop to see if they have a clue. It sounds like they don't.
Got my wheel alignment done yesterday. Steering wheel is now back to centre in the straight. Following the crown of the road has been vastly reduced, and the trim height reset. Before they started, they told me that the tendency to follow the crown won't be eliminated totally because the BFG's A/Ts will be contributing to it.
If the scrubbing on the outer edge of the front left tyre, and the inner edge of the front right has been eliminated, then I'll get another 10-15,000km out of these BFG's. That'll take them past 60,000km.
I don't recall the plug socket size, I think it is the smaller of the two standard sizes.
AS far as other stuff, just get a small tube of anti-seize lube for the plug threads.
The plug swap on this engine is probably easier than any vehicle I have ever had.
http://www.fastriceracing.com/wwwroot/Personalpages/DaveC/Instructions/bearingrepack.htm
-Ryan
They have been running fine for 13K miles now...
