My 2000S w/67K is going to need a few preventive things in the near future. I use MB1/Isuzu filter every 10k. I changed all trans/diffy/TOD fluids at 45K. Tires at 50k. Air filters as needed (2 so far). I think it will be time soon for brakes and bearing repack. I may do the brakes even if they have a little life left in them just so they can repack the bearings on the same trip to save a little on labor. I think I need the "propeller shaft lube" front and and back. That is probably way over due. Coolant should probably be changed out, it is original. Do we have regular coolant or Dexcool? Can any body suggest anything else? What am I missing? My miles are mostly hwy with some NYC/Philly/DC thrown in. I am trying to "hit" the important things while avoiding the smorgasbord approach of the matinence schedule. Thanks in advance for anyones suggestions! Cheers to all.
I have no idea what you would get for $50. There are no rubber boots involved with a front wheel bearing repack. Like already noted, that is about a 3 hour job and no shop will do that amount of work for that amount of money.
If you DIY just be prepared to have to use quite a bit of force to remove the large allen head hub bolts. No big deal just have exactly the right size wrench so when you apply the force you don't strip anything. Also, the 3 brass screws holding on the hub nuts are very easy to strip especially if installed very tightly from the factory.
Propeller (drive) shaft lube takes 10 seconds with a grease gun, just hit the zerc on the u-joint.
You might have a lot of life left in your brakes, I would have them looked at for expected life remaining. The rear brakes typically go first on Troopers.
Wheel bearings probably need repack. I would swap out the tranny fluid also, and change the sparkplugs so they don't weld themselves into the block.
I have read nothing but bad reports about using Bosch multi-tip plugs in Isuzu service.
Lastly, most long service plugs come pre-coated with an antisieze compound. I know Champions do. I have also read that using too much of the wrong antisieze (ones for low temperature service?) can cause problems. I guess the point is that at most you should only need to add a little bit of a proper antisieze.
What about your power steering fluid. You can get all the old fluid out by popping off a hose. Or, just remove the reservoir basket and turkey baster out some old fluid and add new fluid every other oil change or so.
Presumably you will replace the brake fluid with your brake work.
Case 1: You only need new pads. In this case having the calipers off for the bearing work saves the time needed to take off the wheels and the 2 bolts holding each caliper. How much credit would a shop give you for this? As a point of reference, most any shop will pull your tires to check your brakes (or fix a flat) for free. At that point they are only 4 bolts away from having the calipers off. So how much "credit" do you think they will give you for those 4 bolts? I suspect than answer is not much.
Case2: You need rotor work. In this case having the rotors already off probably saves an hour of labor. They can either give you that credit or consider it a lucky break for them.
I suggest you first call the shop and get a brakes only price. Call back a day later and get the bearing repack price. Then ask for a package price and see what they say. (FWIW, I would use their response as a gauge of how "honest" the shop is. IMO the more of the package savings they keep the more likely they are going to try and sell you unneeded brake and/or bearing work. Again, this is just my .02$ but if they tried to tell me there was no cost savings I wouldn't argue with them. I would use it as my cue to go to another shop.)
-mike
-mike
Another thing I noticed is that the 2002's are listed as coming with a tire wrench and spark plug wrench? That would mean the lugs and plugs are the same size? and not 5/8"?
-mike
As far as lugs, IIRC mine are 19mm, don't know if that is close to 5/8" or not.
There is no mention of it in the manual, but I guess that it's for the spark plugs. It doesn't fit the wheel nuts, and it is separate to the wheel nut wrench.
By the way, my calculator converted 5/8" to 15.875 millimeters.
Anyone else with a similar experience?
The dealer's explanation is that a little leakage is 'normal' and to be expected after the bearings are repacked (???). I can't believe that TWO dealers said this. The charge by the dealer was $100 for the repack and included replacing the spindle grease seals. The second dealer said that the bearings looked fine.
It sounds like they might be using a cheap grease that is prematurely failing and running after 10k mis. A good grease designed for the higher heat loads of disc brake cars should stay thick and in place for many, many miles. You might ask the current dealer what they are using.
FWIW I would have 2 concerns about having a shop do the work. First given Isuzu's reputation for easily stripped lugs I would be sure they properly retorqued the lug nuts. Second, the hub nut is held on by three brass set-screws. The heads on these are easy to strip. The concern being that the next time you have to get at the bearings you have to first deal with a stripped screw head or two. I guess the only way to know the shop didn't mess them up is to check as the hub nuts are reinstalled. Either that or go back with a hardened stainless screw, but good luck finding the right one.
-mike
Does anyone know if the middle grease fitting on the DS is for lubing the slip yolk ? thanks a bunch.
Last week it started not starting like it used to. It always fired up almost instantly, but last week it would crank for like 5 seconds before even popping, and then it would sometimes die a few seconds after starting. Sometimes I could smell raw gas after starting. Driveability was fine once it was running.
The service rep said it was probably the fuel pressure regulator, which made sense (except for the raw gas smell). If the regulator doesn't maintain pressure in the fuel rail while the vehicle is off, then the fuel pump has to re-pressurize the system while you crank to start.
Anyway it did turn out to be the fuel pressure regulator as suspected. It was leaking into a vacuum line somehow, which accounted for the raw gas smell.
Hope this is helpful, don't know how common this problem is.
Cause mine is like that too but I don't get the gas smell.
-mike
The dealer replaced the "fuel sending unit", that was listed on the work order, and reprogrammed the computer. It works fine now.
This is a standard procedure for my Gen II SHO & this condition is not uncommon in other FI engines, AFAIK.
-mike
Hmmm, I'm ready for winter right now to beat the heat. Anyone up for a cool run to the Pole for R&R?
Errr...that idea just got shot down by my AWA...disregard.
Anyway, got it back from the dealer last night, and now it starts immediately again, just like before.
There was not a check engine light, but apparently there was a code that required clearing according to the work order.
The raw gas smell was due to the leaked gas running through the EGR valve.
Also, I asked them about doing a wheel bearing repack, and he recommended waiting until the brakes need work, because it is a relatively small additional cost to do during a brake job, but a large cost to do by itself. Imagine that, a dealer recommending NOT to do maintenance!
-mike
Dealer didn't want to touch it (and told me a replacement was over $600), so I contacted American Isuzu and they are starting a case file. Anyone had success with this? I talked to a guy at Al & Ed's (a SoCal stereo dealer) and he said they have heard of lots of problems with these changers. He had an aftermarket replacement (newer model, same size, supposedly less problems) for about $600.
On a happy note, just replaced my stock Duelers (starting to look very worn, and tread depth very shallow) with Michelin Cross-Terrains, 265/70/16 (the biggest you can get while keeping the same rims). Very nice looking and have a very thick tread. Seems quiet on the freeways, and am going to the mountains this weekend, so will see if I notice a difference. Pretty good price too, $134 apiece (which beats Tirerack.com) from America's Tire/Discount Tire.
The 6-disc changers are about 50% good and 50% get errors like that. They should replace it w/o a problem even at 600 miles over the limit.
-mike
The thing about the changer, it has been temperemental before (no skipping though), like not reading certain discs, etc., but always turned out fine. Sure wish I would have had it changed out back then - would've saved me the hassle
-mike
