-mike
Edit: $168/tire v. $99/tire
-mike
Any ideas? How do you check/change the thermostat? BTW didn't burn any oil in 2000 miles, with 4 long highway road trip days.
I have pushed my 1995.5 Trooper engine really hard, pedal to the floor for many minutes in some cases and I have never had the temperature go up noticeably on the gage. On my 1984 Trooper the temoperature went up to 2/3 when the water pump was about worn out (145K miles or so). It also was losing radiator fluid by a slow drip from the water pump bearing that would dry on the engine so the ground stayed dry while the reservoir went gradually down.
I'd venture to say it's either the fan clutch, T-stat or H20 pump. Since it's only at high speeds I'd recon that it's the H20 Pump or T-stat though.
-mike
With OME's, Ranchos, etc, most are twin tube. The piston tube is actually inside another outer tube. So you can mildly dent the outer tube without affecting the operation of the shock.
Another less obvious but somewhat common problem is too much antifreeze. While some is beneficial too high a percentage can reduce your cooling efficiency.
As to how to check the thermostat, that is typically done by having it out of the car and noting its operation in hot water. Thus, this is not an easy one to do as you have to remove the part.
I don't really know how to flow check a water pump. FWIW I just look for leaks and listen for unusual grinding noises from the running pump. If the pump is bad you might as well do the timing belt and idler pulley as the incremental labor is not all that much. Similarly, when it comes time to do the timing belt/idler pulley you might as well do the water pump.
Still, last month I went white water rafting in the Kern and had 4 people, with the back pretty heavily loaded, going over the Grapevine (steep grade), in 95+ degrees, A/C on high, and doing 75-80 the whole trip, and the temp gauge never budged.
Now my wife's Blazer is a different story altogether...
Try imagining a pump that is only working at partial capacity (or partially opened t-stat for that matter). Such reduced flows might work with low engine heat loads but are not enough to keep the engine cool when it is loaded down. Just remember that the amout of gas you are burning is more of less the heat load on the engine. Going downhill or sitting still burns very little gas resulting in an unloaded/cool engine. Going uphill full of people and gear burns a lot of gas and can load up the cooling system.
Check your fluid levels and condition and let us know what you find.
For the record, my 1999 has never even come close to overheating in 110's.
It didn't overheat, but got very close to the "red zone" (even though there is no red). Backing off caused it to be OK. I plan of going in to the dealer for the next oil change now, so I will see what they can find. I haven't had a chance to check the radiator fan blades? It is possible that dust/dirt/mud is all over...I did a good amount of oversand and offroading on my vacation.
In any event the dealer may be able to pinpoint your problem.
Locate the receiver/drier. It is a slim, black canister shape that is connected in-line to the air con pipes, mounted vertically and has a small circular sight glass on top. On my 2000, it is located behind the front grill just in front of the radiator. Make sure you have a clear view of the sight glass. You may need to remove the grille to do this.
Switch the air con off and start the engine. While you are looking at the sight glass, you will need to get someone else to switch the aircon on. You should see some foaming occur in the sight glass for a moment and it should then clear up. If this is so, then you probably don't need a recharge.
If however the foaming persists and doesn't clear up within 5 seconds, or you get no foaming at all, then the gas is probably low and you need a recharge.
Hope this helps.
FYI I have used Mobil 1 5W-30 since the first oil change.
I wanted to know if anyone has experienced with this problem and their solution/recommendation without going to the dealer and getting a big cost on repair?
thanks,
hus060
My mechanic (non-dealer) said he hasn't seen this problem with other Troopers he's worked on, but I just wanted to post this info for other Trooper owners. Below is the link to the pictures.
http://community.webshots.com/user/emiura/
...Eiji...
-mike
And the thinness of Mobil One 5W30 is actually an asset in the winter in Minnesota!
thought the lean reading might be a plugged fuel filter, so they changed that. No change in symptoms. I had heard that Bosch plugs
might cause an occasional misfire, confusing the O2 sensor, so I put in NGK platinums and a new air filter at the same time. No change. Any clues as to what to check? Sorry for the long post, thought the details might help.
KCinMN
Perhaps one explanation for why my 98 Trooper consumes so much oil is that I always use 5W30, whereas many folks use something thicker (10W30, etc.)?
Sorry I don't have a 95 to give you specific advice, but here goes my attempt at general advice, use at your discretion -
Are you sure you got all the 02 sensors? Some Isuzus have more than 1.
My next suspect would be a malfunctioning fuel injector. I would first try a couple of doses of fuel injector cleaner.
Also, I think it is possible for a spent or plugged cat to fool the system into running rich. If you were running rich for quite some time before the 02 sensor change, you could have fouled the converter. Now with a fouled cat you have tricked the system into running rich again (and also fouling the new 02 sensor making the problem even worse).
KCinMN
I will apologize right now if these are topics that have been beaten to death. I did not find a response on my searches, so I will ask them now.
On saturday, my wife and I test drove and subsequently bought a '00 Amigo, V6, 4WD, AT w/26K miles. We took a short trip with it on Sunday, and truely fell in love with this vehicle. This is our first Isuzu, and we had no idea that an SUV could be so much fun to drive. On Monday while finishing the paperwork on the '00 Amigo, the dealer talked us into trading our '98 Cherokee in on a second Isuzu: a new '02 Rodeo S V6, 4wd. So, now in the matter of 4 days, I have two Isuzu's and really don't know much at all about them (was a Jeep man, hehe) :-)
Ok, now on to my questions:
1. Where can I get a cheap yet complete service manual that covers these 2 vehicles? Does Chilson offer one? I do most of my own maintenance, and found the owners manual to be grossly inadequate.
2. I have lived several frigid places the past few years. I have converted all of my vehicles to synthetic fluids (Amsoil/ Mobil 1)in the AT, engine, diffs, transfer cases, etc. Are there any known issues with synthetics in these vehicles- especially the AT?
3. The seat material on both of my Isuzu's seems to be pretty light duty. Does anyone have a good recommendation for a "stock looking" seat cover for these vehicles??
4. I tow snowmobiles all winter. Usually no more than 3000 pounds. Can anyone make a recommendation for a good hitch (non OEM) that I can use with my Rodeo? My Rodeo has the spare under the rear end of the vehicle (which concerns me)...
5. My Rodeo S came with a stereo AM/FM cassette which seems to work ok...sounds ok....not great but not bad. I have seen that there is a Isuzu CD player that can be installed in the spot below this stereo...Is there a cheap place to get one for my '02 Rodeo? Is it worth it since I am on a budget? Or should I just scrap the whole OEM stereo concept for something different? Remember, I am on a budget!!
Any help from you "experts" is invaluable!!!
Ziemann
(Wisconsin)
2. Not aware of known issues with synthetic fluids in these vehicles. I put synthetic fluids into the differentials and the TOD (4WD) system, but not the A/T.
3. www.wetokole.com makes some really cool-looking seat covers made out of neoprene (wet suit material). They don't look stock and they aren't cheap, but I've heard good things and they look sharp on the web site. Definitely a custom fit, but not a stock look.
How did the salesman talk you into buying a 2nd vehicle when you weren't planning on it?
2. synthetic fluids, Can't hurt. I have it in my diffy.
3. Yup, they do look pretty cheap. and Wet Okole is the only place the I know of that sell them.
4. Hitch? 1800hitchit.com should have what you need.
5. If your looking for the OEM CD changer you can get a used one at www.car-parts.com BUT you will also need a new Isuzu head. There are 2 types of head units one has CD ability to hook up to the cd changer. Costwise, I would just drop 150 - 200 on a new head unit with CD player built in. I only had a cassette to begin with in my 2000 Amigo. I switched mine out and was amazed at the sound impovement even with the stock speakers.
good luck!
-Ryan
(Madison, WI)
And from what I understand from previous discussions that St. Charles Isuzu is the cheapest source for asseccories??
Ziemann
(recovering Chesehead- going to relapse in Dec.)
www.stcharlesauto.com
www.partscheap.com
KCinMN
-mike
sdc2, Is the fuel pressure regualtor part of the fuel pump? and what did you end up doing, dealer or you did it your self?
Eiji,
It is always difficult to determine where a leak is coming from without seeing the vehicle, however, the only place I have seen leaks in the area he is descibing is from either the oil cooler o-ring, the head gasket or the valve cover gasket.
Keith Andreasen
So I wonder what caused this? Could it have been flooded, I doubt it since I don't give it gas when I crank it? The throttle cable for idling could have been messed up? Maybe it is a sign of something more serious? It didn't re-occur and I went out on several errands yesterday?
-mike
