Isuzu Owners Maintenance and Repair
in Isuzu
I couldn't resist taking the first post of the new Maintenance & Repair area of the Isuzu Owners Club.
As a matter of general info, I run synthetic blend oil in my engine (Castrol Syntec Blend or Valvoline Durablend), 5W30, genuine Isuzu filter, changed every 3000-3500 miles. I can't really justify spending the extra money on full synthetic.
I change my oil myself, and the next time I do I'll also be swapping out the TOD fluid (it's only 2 quarts) and putting Valvoline Durablend auto transmission fluid in there.
My Trooper has 38,000 miles on it and I just love it.
Jason
98 Trooper, Detroit area
Jason
1) Recall #2 on the fuel hose
2) Synthetic Oil Change I'm going to be going to the 7500 mile interval which will be nice cause Since June I've put on 14,000 miles and changing it every 3000-3500 has been almost a monthly affair!
3) I'm having my TOD whine checked out and trying to see why the Check engine/TOD light came on last week
4) Having them clean out the squirters for the wipers (I filled em up by accident when I waxed it a month ago, so only 1 nozzle on each side would work)
5) Having them check the whine in the front end that I may or may not hear (I think that I may be hearing things because others mentioned a whine)
-mike
Mechanical before any other mod/s. Head was rebuild 4 months ago and it leaks a quart of oil every 4-500 miles, looks like about every place from the head down. It's 5 degrees (-35 windchill) in Nebraska with 12 inches of snow. So we are just watch oil level and enjoying now, but.... I do want to correct, any suggestions on trouble areas for 2.3? Also a little vibration in 1st under acceleration (input shaft?) Looking for some disc. parts (tan cargo cover, some interior/dash stuff, Any suggestions in DE Nebraska?
Look forward to participation. (This is 8th 4x4, had an 89 trooper in 89, and also have a 98 Explode).
tks
-mike
I'm leaving tonight to go home upstate NY to the adirondack mts. My truck is in the dealer here in NY/NJ and it looks like it'll need to stay overnight. We are expecting at least a foot of snow over the next 24-48hrs up there and want to have my or a 4wd vehicle for the trip. Will Isuzu give me a loaner trooper? One of the reasons I bought my trooper was for the TOD for use in the Mts. and snow... We shall see what happens...
-mike
I had washed my car in a cold evening(two days before) and kept it in the garage(unheated)... I'll go to work, but when
starting it after hours it would start with a jolt when releasing the clutch(I've had it last winter as well)...
But, next morning, it got worse, it wouldn't move at all, even after releasing the clutch almost completely(this time I was
afraid to release it completely, considering the high revs, some cluncks, the previous jolts and the fact that I couldn't
move the car my hand either)...No hand brake engaged
I'll take it out of 4hi, put it in 4 No, then in 4 hi again, then in 2wd(After starting to two it. I've stopped the towing truck,
re started the engine, just to make sure that the 4hi light went off)... But as the towing truck was turning out of my drive,
we heard one loud CLANK and I was sure that my dealer would find the truck in perfect shape(which he did)
He even kept the truck outsideover night and re started it, no problems at 8 am next morning(but on milder weather)...
They say they've "checked everything"...:) Not reproducible...
It's not only that now I'm afraid to wash the truck when it's cold, but I'm afraid something might be damaged anyhow...
Even if we're careful not to put in 4hi when there are patches of dry asphalt, etc, etc
I also kind of thought that the clutch ride was too long(at least compared to my sedan), but then the dealer let me test
drive a brand new 2000 and he drove my '99 and the clutches behaved in a very similar manner...
My '99 has only 22.000 km on it and it is a frustrating issue to have in the back on your mind... E.g. the next day I had to
drive 200km one way and we got freezing rain and some snow on the way back and you are afraid that the truck might
give up on you (OK it only manifested so far at start-up, but still)...
Any hints?
My dealer is 417 Saturn-Saab-Isuzu in Ottawa, Canada...
-mike
-mike
They pulled the code from the engine ECU because that is the "check" light that came on. Although after a re-boot er re-start, it was fine.
-mike
PS: GPM, do you want to be a co-spokesperson for the Isuzu forum? We need 2 or 3 spokes people and so far I got ARK Troop and me, you post almost as much as me so what do you say?
I think I stretched the hood release cable tonight. I was checking the oil and the hood was frozen shut. Well, I pulled the handle all the way and it didn't open. I gave it a minute with the engine running and it popped up. It still works, but it feels like it's stretched 1/2 and inch.
-mike
prevent one from making copies like my wife's Toyota. I thought
that true when the first time I had a key made it did not work. Went to Wally World this week and made a couple more -- 1 works, the other does not. I guess making keys for the Trooper may take several
attempts before one gets a working copy.
Another question, I'm going to hide a key on the Trooper in case I lock my keys in it again but have not
found a suitable spot - ideas?
-mike
I called the dealer and they'll cover it. Can't wait to get this one fixed.
Steve
-mike
Isuzu Forum Spokesman
Edmunds Isuzu Forum
IA Trooper Homepage
-mike
Edmunds Isuzu Forum
IA Trooper Homepage
-mike
Edmunds Isuzu Forum
IA Trooper Homepage
-mike
Mike
http://www.gmpowertrain.com/transmissions/index.htm
I don't know of any widespread problems with the tranny's.
-mike
http://www.iace.com/ia/trooper
Transmission was made in France. Do you think the French
versions are GM too?
-mike
I have a question. In October I bought a used 95 Isuzu Rodeo from a dealer. It was love at first sight. I'd been looking for 8 months to find an SUV with a stick shift and no airbag. I own an 85 Honda Accord that has 140,000 miles on it and it still has a nice, tight, shift pattern. The Isuzu was really lazy in comparison. Sometimes I'd find myself in 5th gear instead of 3rd, or trying to grind my way into 2nd instead of 4th....Needless to say, I didn't like that. A couple of weeks ago, the Isuzu got totaled by a red-light runner. Now, I am looking for an SUV again.....I had been told by the dealer that the loose shift pattern in the Isuzu is normal.... Is it, or was the mechanic too busy to fix it? I would like to get an Isuzu again, but don't want to deal with that horrible traveling gearshift again.
-mike
I've found my windows fogging up, and sure enough the recirc is on. Let me know if this helps.
Andy
-mike
The Rodeo and Passport are built by Isuzu in the USA, and I don't mean to badmouth the Rodeo but its reliability/quality does not seem to be very high. The Trooper seems to have outstanding reliability/build quality, but it's made at a different plant (in Japan) than the Rodeo/Passport. It seems strange that Honda would be willing to risk its reputation for quality vehicles by badging a Rodeo as a Passport, but Honda has had some downturns in the quality of its own vehicles in the last few years anyway (e.g. Odyssey).
And paisan, I know your Rodeo was rock solid but I'm just speaking in general
The passport also gets less warranty, no roof rack, and a higher price.
-mike
-mike
By the way, I bougth a Passport.
-mike
