Jim
-mike
transmission drip - something cracked, I did not understand what exactly, but sounded like nothing major - the mechanic said that many Troopers have that. Transmission drip was fixed same day, rusted rotors - next day. All being fixed under warranty. Anyone had similar experiences? tx
Overall there is a lot of surface rust on the underside of my truck (the A Arms, Frame rails, etc), I assume/hope this is nothing more than surface rust such as found on building girders?
Has anyone else noticed any additional sound in TOD 4WD?
What I did on my '99 Passport was put a bottle of Chevron Techron fuel system cleaner on a near empty tank (2x). This solved the problem plus power and economy also improved.
What you are hearing is the fuel igniting before the piston is in the proper position. The explosion in the combustion chamber is trying to force the piston to go the wrong way (slightly). I'm not sure how soon that your engine will be damaged by this, but this much I can guarantee - this problem is not helping the life expectancy of your engine.
David
That is the best thing you can do when you get an answer from a dealer that doesn't seem right.
-mike
If the barrier had been higher and hit the spare, maybe there would have been some appreciable damage, but despite what the IIHS says, a 5 MPH crash where the bumper worked and there was no significant damage.
-mike
Hey Pinoy99, are you gonna come to the Sept 15th Pine Barrens Trail Ride?
-mike
-mike
Has anyone noticed any additional rumble (very slight) with TOD engaged? It seems to me that I could not tell any difference before but can now.
-mike
I was at Pines last June, we went in off Rt206 South just after the Ranger Station on the left side. That side has one very deep water crossing, where my truck with 285's saw water up to the top of my headlights(actually fogged for a few days).
That is also the place where Matt toasted his air pump. I think this run also led to my rear pinion seal leak(fixed under warranty).
Another section is off Rt70 but I can't recall exactly the location at the moment...gotta look at the map.
I don't have the Calmini bumper so no personal experience(yet!) but it is powder coated so I'm suspecting it will actually hold better than oem.
HTH
-mike
I'd appreciate it!
KarenS
Owner's Clubs
http://www.pureisuzu.com/rear_bumpers.htm
KarenS
Owner's Clubs
Of course this bumper would need a really good paint job or be made of rust resistant metal. The color should match the unpainted bumper dark grey so that it goes with all colors of Troopers.
Another inovation for added utility in a rear bumper would be removeable support for a roof rack bar, the top of the roof rack bar could gently clamp to the built in air deflector with a contoured clamp. The contoured clamp needs no moving parts, just slip it over the air deflector and secure down at the bumber attaching points. Then add the Yakima or Thule over door front roof rack bars for an expedition rack that can quickly be removed to turn the Trooper back into a commute to work car. The vertical bars could be curved forward a little to match the rear profile of the Trooper. Maybe even add ladder in front of the small door or a ladder as foot holds perpendicular to the rear of the Trooper that allows both doors to open. Then the same support ataching points could be used for small items like a basket in front of the small door to hold an extra tank of gas or a trash bag full of stinky diapers etc..
How about mounting holes for LED lights like those used on trucks and even a powerful back up light for those who have tinted glass that need a lot of light to back up at night. The LED lights would use the trailer hitch plug for power since they would not be needed when towing.
Build this utility bumper and I will buy it. It could sell as a bumper with optional accessories.
The air compressor mounting place would be protected from the elements and out of view. Another option would be just a larger air tank that would hold enough air to reinflate all four tires from sand pressure to a reasonable road pressure. It could actually be a removeable scuba tank. Maybe the aircompressor could be mounted on the bottom of the Trooper below the rear seats. to allow both a compressor and the larger tank.
-mike
-mike
All kidding aside, an external cooler is great for fishing, bait is messy and smelly, when someone is getting a sandwich out and knock the bait fish into the vehicle, or water from the live eels gets inside, it takes a lot of lysol to get it out. And the compressor, wow, that would be nice, it is bad enough letting the air in and out of the tires for sand driving, but when you are 15 miles from an air pump it puts a lot of wear on your tires. Of course this is all just fun talk, but it has some merits.
What sort of front bumper would be a look good and work good with it?
I forgot to include that the weight of the bumpers should be as light as possible while providing the needed functioanlity. A solid piece of railroad track on each end would be indestructable but the Trooper would handle very poorly with all that weight at the ends.
A jerry-can holder would be good too. The inside of the small rear door would be a great spot for a jerry-can, but somehow worked into the exterior would be better. Not only for Gas, but water.
A solid rear step. I am 240 (hoping to get back to my fighting weight of 210 someday) and climbing around while working on the roof rack is worrisome...one more beer and cheesesteak combo and the next time I step on it the bumper rips right off :-).
-mike
In terms of the bumpers I guess I wonder how black goes with the other two-tone color on the trooper S in '99. My trooper is black so it would probably be ok, but then I'd want a balck steel front on as well. Not sure I'm into all that yet.
Also, I can't visualize very well how a bumper that comes out to the spare would look, but it would be very practical
Finally, I did get the cargo carrier that goes into the hitch from Harbor Freight Tools. It does a great job, and can hold a whole cooler of your favorite beverage with ease.
-mike
BTW, this compressor looks good and supposedly doesn't take forever to fill a tire. Anyone use these after airing down?
http://shop.store.yahoo.com/rodi/achd-275.html
-mike
I don't think html likes the curvy quotes (not "straight" quotes) that MS Word displays, if you have Word configured that way.
I think the original Bridgestone Dueler 684s on our 98 Trooper, now with 51k miles, have been showing some cracks in-between the treads for quite a while now. I didn't consider this a potential safety issue; perhaps I should have?
So what are you folks using-- Isuzu, Pure One, Mobil1, etc.? Post the filter as well as your Trooper's model year.
erinsquared: you said you use synthetic fluids in your Trooper, and "the best oil filter I can find" What's the best oil filter you've found for the Trooper? I'm using the Isuzu brand filter based on the recommendation of the expert Isuzu mechanic Jake over on www.itog.com.
