Isuzu Modifications/Aftermarket/Accessories
-mike
Every Thursday, 7:00-8:00pmPT/10:00-11:00pm ET
Your Community Leaders are paisan and arktrooper1
-mike
-mike
-mike
Unfortunately they were about 50% more for a Trooper ($75 each) than for a Blazer ($50 each), so I went with the OME shocks instead...which BTW I also like very much.
-mike
Steve- Any advise on a web-dealer for OME shocks? Would you rate them as good as your Bilsteins setting price aside? I need to get this right as I am in the dog house over new shocks on a 11 month old vehicle.
The shocks will be a very big improvement for you. Well worth the $300. Also I'd do the Poly Bushings on the sway bars ($20 from JC Whiteny and about 1hr of time under your truck) Those 2 items will increase the handling by a lot.
-mike
Also, the best price and shipping I've found on the web is at central4wd.com - 69.95 + 8.95 shipping. Anyone know of a better deal?
Barbara
-mike
For road use I would give a slight edge to Bilstein. For more all-around and off-road use I would give a slight edge to OME. The monotube design of Bilstein is more vulnerable to impact damage off-road. The OMEs are extremely beefy and ruggedly built, and offer nearly as good a highway ride as the Bilsteins. The Bilsteins might last longer, if their literature can be believed.
I don't think you could go wrong with either one, though.
-mike
...Eiji...
(To administrator of this board: I am not associated with this shop. If this is considered to be an advertisement and is not appropriate for this section, please remove the post.)
I hope you and your vehicle are well. Eiji, if you are interested, I am now selling a Supercharger Kit that directly bolts to your engine and produces an additional 65 HP at the rear wheels, quite impressive. They sell for $2750.00 and installation runs around $750.00. Shoot me an e-mail with your thoughts.
Best regards and have a nice year end.
Keith Andreasen
Andreasen's Japanese Car and SUV Center
The Supercharger kits are for 9/97 on 3.2 and 3.5 engines. The kit requires very little modifications and replaces the existing intake manifold assembly. Torque is increased 20% and horsepower at the rear wheels is increased 65 hp. boost is approximately 5.1 psi. Cost is $2850.00 + shipping.
Best regards,
Keith Andreasen
Chief Engineer
Land Motor
MK
-mike
They certainly look good! They just make the truck look a whole lot beefier. They fit the wheel wells without sticking out and give about an 1" of lift. Quite an appearance transformation!
On the road, they seem to handle at least as well as the original Bridgestones, probably better. They make a little more noise, not a big deal at this point. They ride slightly rougher, not a big deal and barely noticeable. The speedometer is off by about 7%, but, so what. You just sort of adjust for it, without really thinking a lot about it.
I definitely noticed a reduction in acceleration. It just doesn't get off the line quite as quickly as with the smaller tires (not that it was ever a rocket ship). Now that they've been on a while, it's not an issue, as I've gotten used to it. Oddly, it seems more comfortable climbing high speed highway grades. I can put it in 3rd gear, which is now higher. It seems to make 3rd perfect for many mountain roads.
As for the spare tire, I traded my stock unused 245/70 for a good used 265/75 spare(hopefully won't have to use it). No charge. I don't use the spare tire cover(it won't fit) and think it looks just fine without it(more rugged than with that foo-foo plastic thing).
In retrospect, would I make the switch to the 265/75's again? Yes. When you need new rubber, go for it. You'll like it.
For the 2002 models for example:
the Durango RT uses 275/60R17 Goodyear Wrangler HP's,
the Envoy uses 245/65R17 Michelin Cross-Terrain's,
the Jeep Grand Cherokee Limited uses 235/65R17 Michelin LTX A/S,
the LandRover Freelander uses 225/55R17 Pirelli Scorpion's (don't know the specific tire, if it's the AT or not),
and the Mercedes ML500 uses 275/55R17 Continental 4X4 Contact's.
I think the Axiom also uses a 17, but more of a street or all-season type tire.
So, we'll see over the next year what's out there.
MK
-mike
The 265/75-16 Scorpion AT's should have about:
Sidewall (section) height: 7 3/4".
Overall height: 31 1/2".
Rev's per mile: 658.
Going with 265/70-17's provides:
Sidewall (section) height: 7 1/3".
Stock 245/70-16's:
Sidewall (section) height: 6 3/4".
Overall height: 29 1/2".
Rev's per mile: 704.
Going to the 17 does limit the choice and add a lot of $$ since new rims are in order, so I will probably stick to 16's on the stock rim.
Looking at 265/70-16's gets me closer to stock (losing some lift from the 265/75's), but I'll still pick up about 1/2 inch. Maybe looking at 265/70-16's. There are the Scorpion ST's and the Michelin LTX in that size. That gives me with 265/70-16's:
Overall height: 30 1/2".
Rev's per mile: 680.
I don't think that the 265's should be a problem on the stock 7" rim, as I'm sure you'd all attest to. The Scorpion AT's you guy's are running look and perform great, I'm sure. I have to look closer at the ST vs AT and see the differences in construction (passenger vs LT) and tread design. That would determine the 70 vs 75 aspect ratio decision.
Thanks Paisan and gprodick for the info. and advice. The Isuzu forum is probably one of the most active on the Edmund's site. Generally I work on Thursday evening, but when I can, I'll participate in the chat.
MK
-mike
-mike
I also did alignment, and "Toe" had to be adjusted. Is it due to lifting 1.5" or so? Someone mentioned here that alignment isn't necessary after the OME mod. Could that be off before the modificaiton?
Lifting the front end required to almost max out the torsion bar, and the front end got about 1-1/4" lift (measuring at the frame). The rear end got 1-1/2" lift. For those of you did the mod before, were you able to level by just turning the torsion bar alone?
...Eiji...
-mike
...Eiji...
-mike
Thanks - Barbara
-mike
-mike
I'm not sure how your "ISC" shocks / sensors are tied to your PCM but I'm assuming that having the system disabled by running non-ISC shocks would not have any affect on the rest of your electronic system other than throwing a code. However, you may have to install the new Bilsteins at all 4 corners to avoid the rear shocks (IF sensor equipped) trying to default to a full hard firm setting if it senses a "system failure" w/ the fronts "unplugged". A lot of these systems can be disabled by pulling the appropriate fuse & then you may be able to tell what your ISC shocks actually do.
Other list members will probably be able to provide more specific info related to your application.
ISC basically is an electrically controlled re-valving of the rear shocks based on user input. There is a switch on the dash that is "normal or sport" and in sport mode it stiffens the shocks. The wires you see are to activate the servos in the rear shocks to change the valving. That is how it was explained by my friend who is an Isuzu dealer. So basically by disconnecting them you shouldn't throw off any electronics, nor should there be an error code, basically it will be like flipping a light switch w/o a bulb in the socket.
-mike
If I understand you correctly, the fronts DO NOT have ISC but there is a sensor that connects to the back which DO have ISC. If I replace THE FRONTS ONLY with Bilstein, will that disable the ISC in the rear leaving me with crappy shocks back there as well? I really can't afford to replace both right now. If I replace only the front, do I have to remove the sensors from the back as well? There isn't a separate fuse for the ISC so does this mean the light on the dash will stay on?
Also, the Bilstein shock have a different shaped shaft on them. The stock shocks and all the hardware that secures the shock to the truck is round with a flat side and place on the end to connect the sensor. The Bilsteins are round with no connection. The guys at the shop didn't think it would provide a tight fit if the shapes were different.
I also called the dealer who said the shocks shouldn't wear out after only 18000 miles and should be covered under warranty, but the only thing they could put on were the stock shocks and they didn't know of any gas shocks that worked with the ISC.
AAARRRGGGG!
My best suggestion would be to put all 4 in at one time. I'm pretty sure the ISC only works in the rear but I'm placing a call to my buddy to get more details. I'll report back ASAP on that.
-mike
http://www.coopertires.com/tire_cooper/ltsuv.asp?id=206
Another tire that was a finalist for me was the Bridgestone Winter Dueler. They're worth checking out. They cost more than the Coopers and aren't studdable - but should work fine where studs aren't allowed. Similar to the Blizzak but designed from the ground up for the SUV market.
I've had good experiences with Cooper snow tires (this is my 5th set on various vehicles) and expect this set to do as well or better than previous models. It's a brand new design for Cooper and they've been selling very well in our market. There's been a large void in the SUV / Light Truck snow tire market and Cooper and Bridgestone should do very well here with their offerings.
Now if it would just snow - I'm ready!
Charlie
I've been through three shocks already (including OEM)on my '99 Passport. The Bilstein had superior handling but transmitted all the bits and pebbles on the road, very annoying and tiring on long drives.
The Monroe matic is more comfortable but after 20K miles, it is not very good in controlling wheel oscillation and can bottom at times.
I am thinking of buying Tokico trekmaster shocks ($200 for set of 4). It is a bit less expensive than Bilstein but the force-velocity curve promises a more car-like ride and the low drag design means that it can ignore minor undulations (the one that cause road noise and annoyance on long drives). It also has a dual compression blow-off valves which can take sharp bumps without much jolting to the car.
