Isuzu Modifications/Aftermarket/Accessories
Just another source of info for someone looking at new shocks.
Charlie
-mike
-mike
-mike
-mike
-mike
-mike
-mike
Fog, Euro, Pointed
The Fog is a widespread beam the illuminates close in, and wide.
Euro is less wide and much further out.
Pointed (forgot the actual term) goes very far but has a narrow beam.
I choses the euro cause it was a nice cross.
-mike
-mike
Paisan when you put your buddy's bar on let me know if you have any problems. I will be curious to see if maybe my brackets were faulty or something. Also believe it or not my nudge bar has already suffered its first casualty.
It looked like the passenger side bracket will fit snuggly in there. It was too cold to try to line up the driver side one.
What did you hit, or what hit you?
-mike
-mike
-mike
-mike
Any suggestions? Any brands people like? I am looking at cobra, but uniden may be just as good? How about FRS? Would I be better off spending $40 on a pair of FRS radios?
-mike
I am thinking about mounting an antenna either off the rear bumper (tall whip) or medium length from behind the spare. I understand you should use about 18' of coax for best reception, so I was thinking about running the wire under the carpet to the rear and possibly out one of the tether holes in the rear cargo area (that is for a bumper mount).
-mike
-mike
I can't see how a bumper mount could work with the rear doors, unless maybe if it was on the extreme end of the bumper.
-mike
1. Using a portable CB package, radio and magnetic antenna, not mounted permanently - and only putting it in the vehicle when I need it. I have one made by Uniden I've used in another vehicle. Coax runs out through window, up to the roof. Get to enjoy wind noise with this setup.
2. Permanently installed radio and roof mount antenna with a quick release for when I want to haul something on a Yakima rack. Have to drill a hole in the roof for the mounting bracket. Antenna is in best position for optimal performance.
3. Glass mount antenna like for a cell phone if there is such a thing for a CB.
4. Using a stainless steel antenna bracket that fits in the small gap between the hood and the fender (have this setup on my 93 Chevy pickup and it works great). Looks like there's room to fit one on my Trooper. Non destructive install.
5. Mounting antenna on rear quarter panel. Have to drill a hole to mount the bracket. Can install a pretty tall antenna here and not have serious over height problems.
With CB antennas, generally taller is better. All the shorter ones are loaded versions of the taller ones, in some multiple of the optimal length (109" ?) i.e. 1/2 or 1/4 the optimal length to receive the 109 inch wave frequency.
Whatever antenna you end up with, make sure you get it tuned for optimal performance. Any CB shop can do this for you. Basically they hook up a SWR meter to your antenna coax, key the mike, then make adjustments to the length of the antenna to optimize the match between your radio and antenna. Tuning can make a dramatic difference in performance.
I like the off road style antennas better (Fire Stix?). They're stronger, more flexible, and take a lot of abuse. I also like the quick disconnect brackets for when I want it out of the way.
My 2 cents for what it's worth : )
Radman
-mike
Do you just slam the door on the coax so you don't have to run it through an open window?
In my post above, the Uniden portable I use is not a hand held, it's a regular (small) permanent mount radio - I just don't mount it. It plugs into a cig lighter, antenna goes up on the roof, and I find a place somewhere to stick the radio where I can reach the mic and hear the speaker.
I'll try to snap some shots to put up of the cb install and the antenna as it stands now.
-mike
-mike
Best local price is $62.95 ea plus 8% tax for the shocks. Haven't been able to find a manufacturer for the bushing kit yet.
Love my 2000S but prefer less body lean and a little firmer ride with less bounce.
It used to be that Rancho offered a buy 3 get 1 free spring time sale. That didn't happen last year but who knows they may bring it back and you could wait and get a better deal.
As to the bushings, that has been written up many times (including prices, part numbers, instructions, vendors and glowing tributes to the improvements). I suggest you check these archives or Paisan's site.
-mike
On a side note, the brackets fit 100% correctly, and all the bolts fit as well. Not sure what the deal was with some of the people not having them fit properly.
-mike
