Isuzu Modifications/Aftermarket/Accessories
-mike
I have joined the list of 15 waiting for the rear bumpers from calmini. I am so disappointed with their customer service that this will be my first and last purchase from them. All improvements listed above will be ordered from indy4x when they return on the 27th.
Will I need to provide any special adjustment numbers to the tire shop for the re alignment?
Good luck with the Calmini order, I got rubbed the wrong way by them when I bought my truck and ordered some stuff especially their customer service or lack thereof. I only buy from them if what I want is absolutely not available anywhere else or I can't get Matt @ indy4x to build it.
At this point I'm gonna hold off on the alignment til after I do the sway aways cause it would need it after that.
-mike
http://www.ecb-usa.com/images/Jackaroo%20Flyer1.pdf
Well, while in Moab I installed the prototype DOR Tie Rod Shieldz on my 99 Trooper. The concern was if they would fit and not rub on the shocks, as they tend to do on first gen Troopers.
I am happy to report they fit just fine, no rubbing whatsoever.
-mike
Bruce Anderson's Trooper broke a tie rod on the Golden Steps on Sunday. It really is a good idea to strengthen this area.
-mike
I am leaning towards getting the Dueler A/T 693's, P265/70R16. I am going to do the spare also. I think that the risk of being a long way away with a 1/2" smaller tire justifies the extra $100 cost. I have read a lot of good things about the BFG's, however I ride mostly on pavement, and they are LT tires, Q speed rating, and I have read that some people have easily hydroplaned at highway speeds.
-mike
Otherwise, a great tire if you don't mind a firmer ride than you are used to.
That is not the reason why I am moving towards the Bridgestones. Actually, now that we have a SMV, I doubt the trooper will see too much action other than me using it on weekends (I ride my bicycle to work). Currently I drive mostly on pavement, offroading consists of a few weeks on the beach in the summer, and maybe 5 or 6 other trips s year. I think a P rated tire is a better choice, I am at odds with getting too much tire. I want something that is capable offroad, but also a good daily driver. That is why I am leaning towards the Bridgestones.
I am not sure of the Dueler's capabilities. They might not be any better than the stock 684's, but with a noisier tread. That is why I haven't made a final decision. My truck is back from the shop today or tomorrow, so I will be doing this in the next weeks time.
I appreciate the input on the BFG's. Were the BFG 265/75 on a lifted or non-lifted trooper? Did they fit well on the stock rims?
-mike
At times I can suffer from OCD. I appreciate the help, I think this is an important decision.
FWIW, I think my handling improved after adding 265/75 Michelins. Then again it could be the tire itself or it is just all in my mind.
Paisan, this may be information that goes into the FAQ part of you web site.
-mike
-mike
sidewall: 7.8
Radius: 15.8
Diameter: 31.6
circumference: 99.4
Revs/mi: 637
7.3% slower than stock
265-70-16
sidewall: 7.3
Radius: 15.3
Diameter: 30.6
circumference: 96.2
Revs/mi: 659
3.7% slower than stock
275-70-16
sidewall: 7.6
Radius: 15.6
Diameter: 31.2
circumference: 97.9
Revs/mi: 647
5.6% slower than stock
245-70-16
sidewall: 6.8
Radius: 14.8
Diameter: 29.5
circumference: 92.7
Revs/mi: 684
I felt that the added size would help overall, but I wanted to avoid too much % of speedometer error and loss of power due to gearing change and the added weight of the larger tires (size isn't the only issue, weight makes it harder to move a tire off line too).
I had a 4banger Nissan that I went from stock 215/75-15 (27" tall) to 30/9.50, not too bad of power loss; but going to 31/10.50's (4" over stock and added weight) suddenly huge difference in power. Up grades in 3rd gear and 40mph. I even had 3-piece wheels that were far lighter than the stock steel wheels.
We'll see how it goes, they are going on this weekend or on Monday. I certainly won't miss the stock Bridgestone's. Not bad off road, but horrible on snow and wet roads.
Next go around will probably be 275/70's with a 1" or 2" lift.
Anyone have experience with the polyurethane coil spring spacers? I'd likely go with new torsion bars since the front end is so soft, but no problems with the back end. I think stock rear articulation is fine for my needs.
Like I said I have not had any problems. I do not however tow a trailer or load up with tons of gear and passengers. Therefore maybe I am not your best trouble free reference source.
If you don't need a more aggressive tire and/or every millimeter of ground clearance, a P275/70 may be a good choice for you.
Cool truck in the post above, I have seen and wondered about the JAOS skid plates before? Are they lighter than the stock? What is the advantage of them. The trooper comes with pretty good armor, stock. I like the ladder. I wonder what the weight rating is on it?
BTW, I like the wheels on that JAOS Trooper picture.
Also, interesting mouldings on the bottom of the rear bumper to accomodate dual exhausts pipes.
On the subject of tyres - I reckon that is the one area of 4WD'ing that you can write an essay on and not be able to come to a conclusion that can convince the writer of the essay!
On the subject of tyres, Sawas_e I think you are right in that a conclusion would not convince the writer of the essay on tires.
But, can we quantify that the choices are 245/75/16 thru 275/70/16 and most of the preferences posted here are either the Bridgestones, Pirelli, BF Goodrich, and Michelin?
This is still a wide range of selections - have I left any brands out?
'Also, interesting mouldings on the bottom of the rear bumper to accomodate dual exhausts pipes.'
I swear that I once saw a Trooper, or was it a slx, that had dual exhaust. This was back in 97/98 IIRC in southern california headed towards the desert. I never did figure out what was up with that. I can only speculate that perhaps the DOHC 3.2L or the new 3.5L might have gotten it around that time, but as I recall it had a soft tire cover (3.2 suggestion). Has anyone else ever seen a dual exhaust Trooper?
You can get some very interesting results just by improving the 3.5's breathing.
My .02
Where did the 3" pipe originate?
I would still be concerned about reducing the torque using a single 3" exhaust system with the DOHC 3.5L in the Trooper - needs all it can make to move that box lower in the rev range as opposed to developing peak horsepower up top.
-mike
Count on 45~50k out of the Bridgestones and that is with regular rotations. I changed mine at 48k.
In regard to power loss and fuel consumption: I replaced my Bridgestones with P265/70/16 Michelins and my mileage has dropped to ~15mpg(highway), 13.5mpg(city)-> very disappointing. These tires do consume a little more power than the stock tires. I am now experimenting with tire pressures.
I rotated the 4 tires on average every 7,500-miles or so. The spare was kept out of the loop.
Overall I was happy with the Bridgestones, but we replaced them with Michelin LTX M/S in stock 245/70/16 size.
