Isuzu Modifications/Aftermarket/Accessories
My $.02 worth.
Dave
-mike
Dave
Dave
Also I'm personal friends with matt from http://independent4x.com so if you guys find stuff there you want, let me know and I can arrange it.
-mike
-mike
The new tires also changed the performance of TOD on sand. In the past deep sand would bog down the system, I was able to hit deep stuff, and when the system bogged down, I gave it more gas, and pulled out most of the time. I still had to use 4 low in some remote spots and a couple of times to back-up to prevent getting stuck. Overall a good improvement...worth $500? I guess so, but as a fun add-on, not necessary, I was able to go to all the same places with stock tires, just more 4 low and tire spinning.
-mike
However, I had the stock tires (Goodyear Wrangler AP in Oz) replaced with BFG A/T's before I took delivery of the car, and aired down all round to 20PSI when on soft sand.
-mike
How do you like your new boulder bars? They look great on your truck. I'm in the market for a pair. Is the anything you would do differently?
-mike
Additionally, if you've got one, how is the wind noise?
Thanks for your help.
Wind noise is OK...I added a fairing to my trooper and it cut the wind noise from the rack down a lot, worth the $50 cost. The road noise through the truck on the highway is another story.
The rack itself is great. I carry bikes, box carriers lumber, canoe's, etc. It can handle a lot. I also go offroading with an empty box carrier still attached with no problems. A lot of bouncing over sand dunes and the rack or box don't come loose or are noticeable. I am huge thule fan. Both are good. I have found the best prices at outdoorsports.com
Also, I will be conducting an experiment for the next few weeks to see if I can get the same results on improving gas mileage as I had on my other vehicles.
Unfortunately I didn't get the specific model. But I'm guessing that it is the Narva Maxim 180/85. Available as either a fog lamp or long range spotlight.
In the past, someone on this forum has mentioned that Troopers are pre-wired for fog lights. I think you can find the wires behind the knock-out for the fog lamp switch. With a relay and OEM switch ordered from Isuzu, you can achieve a factory look if desired. I priced the switch and relay from St. Charles Isuzu for around $100 but I never went any further.
Good Luck
The auction was a public one, the vehicle was owned by the president of a .com company that was liquidated. I paid $9,345 plus tax.
Thanks for the fog light advice, I intend to add it the weekend after labor day.
You mentioned a part # for a brake light kit, but I cannot find the message. What was that #? Does this harness snap into a plug next to the jack mount? Calmini is shipping my new rear bumper this week. I will try to get pictures of the install if anyone is interested.
-mike
But before I do this, I usually spray epoxy paint on exposed surfaces. If I see rust, I spray it with Muratic acid, which is a strong reducer. This mixture survived salty roads w/o even surface rust on covered areas.
It is important to inspect once a year. I have owned some old Citroens for over 15 years now, never had a rust problem. Cost per car is under $50.
While you're under the truck, don't forget to treat the rubber parts (such as boots, etc..) with a vinyl spry to prevent rubber from cracking.
Picked up some 6mmx25mm bolts, locking washers and silicon sealant yesterday and continued installation of the overlander rack. I learned several things during the installation process:
1. metric bolts can be difficult to find, even at the local Home Depot.
2. Putting the rack together was the easy part.
3. You shouldn't start a project at 8 p.m. in a poorly lit driveway.
4. Even though the directions say that you don't need to cut sections of the roof molding strips for my2000 and newer Troopers, you DO.
5. Don't tighten down the mounting brackets to the roof until the rack is attached.
I made a couple minor errors that cost me some time. The total duration of last nights installation was 3.5 hrs (yes I finished at 11:30 p.m.). Add that to the 1/2 hour it took to assemble the rack the total came to 4 hrs. This does not include the time to go to 3 hardware stores to find the correct bolts that didn't come with the mounting hardware.
A few observations: This rack looks great and works great. Very solidly constructed with very little weight since its all aluminum. This is a BIG rack (50" x 60") and adds about 8.75" to the height of the Trooper (69" total height). I strapped a 9' surfboard on top and had enough room to put a second board right next to it or some coolers or what ever without any problem. Driving on the road up to 75 mph I could barely hear any additional wind noise over what you normally hear. With the board on top I still didn't hear any additional wind noise. I'll report how it affects fuel economy after I've gone through a couple of tanks of gas with the rack on (currently get 17 mpg in mixed driving). What I've also found is that the basket portion can be fairly easily removed leaving just the cross bars.
I know there have been lots of questions in the past regarding what roof rack to get for the Trooper. I originally picked this one because I liked the idea of the mounts being screwed in to the factory holes on the roof and not potentially damaging the door seals with the Yakima or Thule towers. I also like the ability of hauling additional cargo in the basket when taking the family on long trips. It looks like I'll also be able to use some of the Yakima attachments that I already own (bike and ski carrier) with some minor modifications to the attachment brackets. I hope this helps anyone else out there that might be looking for an alternative to the Thule or the Yakima. I'll give an update on long term usefulness, convenience, etc. at a later date. Sorry for the long message.
MWWST
-mike
MWWST
I also got a good craftsman torque wrench out of the deal...so total cost was $389 + $75...not bad considering the dealer wanted $730 to put them on, and $450 to to sell them to me uninstalled.
The instructions had one mistake...they said use a 10mm combo wrench, and you actually needed a 13mm wrench, the same size as the socket. I also found it easier to tighten everything up using a screwdriver type socket driver, and then just about 3/4 a turn with the torque wrench to set all the bolts.
I am posting this here too because I don't think anyone over there appreciates installing accessories yourself.
Independent 4x4, I forget the url but he has rocker bars that protect against rocks offroad and don't significantly reduce ride height, however I don't know how good they are as a step? You can look on paisan's site....isuzu-suvs.com for a link to that site.
If you do any offroading they are a good idea over the typical side steps that will get ripped off.
-mike
-mike
I took off my stock "bug shield" as the plastic in the wrap around sides was too thin and "flapped" or rattled at higher speeds and/or in cross winds. It was impossible to wash/wax underneath so it had to be removed each time.
Needless to say, it was "ditched". However, this has left even more surface area especially on the hood sheet metal exposed to the tons of flying gravel up here in Calgary, Alberta, Canada.
I have had zero luck finding a front-end bra for my stock 2K Trooper. Not a good feeling when Isuzu doesn't even carry one.
I would appreciate any leads.
Thanks, 2KT2.
-mike
http://www.partscheap.com/Troopera.htm
I don't know if they have any in stock but they show it on their site.
If you do get deflector, I second the Lund Interceptor recommendation.
I don't know if these are available in the US. I replaced my standard headlight bulbs (H4 in Australia) with Narva Plus 50 bulbs. I'm stunned at the difference.
The new bulbs put out approx 50% more light at the same wattage as the standard bulbs (55w/60w). For $30AUS, it is a worthwhile and noticeable improvement to the Jackaroo/Trooper headlights.
For more info -
http://www.narva.com.au/Globes16.html
Does anyone have some information documenting the actual lumen output of the various bulbs?
