Isuzu Modifications/Aftermarket/Accessories
Just want to say thank you for providing us with your Isuzu page with good informaiton. Your link to Japan's Isuzu Owner's Club had another link to a company who sells rear bumper protector called "Rear Tube Guard".
From the Japan's Isuzu Owner's Club page, click:
RV Square & Factory ZIG
Parts
Bighorn (Trooper) - EXTERIOR
Then, click the second film icon from the top.
It's hard to see how it's mounted to the vehicle, but at 32,000 yen (about $260?), very expensive option.
...Eiji...
-mike
-mike
I had someone forget to put their van in park and ram me when stopped in front of a school when I was in our Windstar van. No real effect but I worry about something like that with the trooper. I think the bar would stop any damage in that case.
-mike
Can you ping isuzu-suvs.com? That is weird that you can't reach it.
-mike
http://isuzu-suvs.com
I really like Yakima racks. I have one on my pickup that's seen lots of use. They have a solid line of accessories to haul anything you want. I'm not crazy about the Q-tower setup though. The towers sit on the roof surface and are fastened down by brackets (clips) that slide into the space between the top of the door and the door frame. It looks like there may be other mounting options (bolt down, track, etc.)in the catalog.
Has anyone installed a Yakima rack on their Trooper, and if so, what mounting method did you use, and how is it working out?
All that said, there is another option for more permanent mounting: under the rubber strips on the roof, there are 3 locations on each side with threaded holes for receiving bolts. www.overlander.com is one vendor that sells mounts for racks onto these holes. I researched it a little, but as I said, I was looking for a removable rack.
HTH,
Pat.
Was anyone else disappointed? I am not disappointed much with the bar itself except that it seems too light to survive actually "nudging" anything. I received mine with no mounting instructions, and incomplete and IMO inadequate mounting hardware. Maybe it can be chalked up to differences(?) in the 95 Trooper vs. Jackeroo, but there were no nuts supplied for the wimpy soft-steel 8mm bolts, and in general what was supplied did not fit - the bolts and washers were too small and of inadequate strength to hold the bar on well. Guess I'll make a trip to the hardware store to get some grade 8 bolts, washers and yes, nuts, of the appropriate size to hold the bar on solidly. About instructions, I figured out where the bar mounts and can put it on, I just feel like when you buy a DIY product, there should be some install instructions if only to confirm that you're doin' it right.
All-in-all a good product, just frustrated with the install process and thought the bar would be heavier.
Honestly,
Pat.
Questions:
1. K&N AirFilter. Improves HP and mileage? Really worth it?
2. Shocks. Any value in just changing the shocks alone? Not doing springs/torsion bars, etc? After reading posts here, if I change them, I'll go with Rancho 9000 or OME. Not looking for lift, just better handling.
3. Factory Stereo. Mine w/ 6 cd changer works(lucky, I know) and I like the way it looks. I am upgrading to Polk speakers however. And wish the system had a little more clarity. Anyone added an amp instead of changing head unit?
Thanks again!
Pat, I love my ECB and was very immpressed with its weight and thickness. I lucked out and had the guys at local 4 Wheel Parts put it on for a mere $30. They used their own hardware, not ECB's and the bar is on rock solid. We can compare in a few weeks when I see you at the trail ride. But you're absolutely right about the instructions.. a major disappointment and totally vague. It wouldn't cost them much for a graphic artist to create some line art drawings.
-mike
Anyhow, after locating some extra big & thick washers and 8mm nuts, the bar is on. I'm still going to replace all the mounting hardware with larger grade 8 stuff to be sure the thing stays on.
Even though I have some concerns, I would still recommend the product to anyone, though with the following caveat: Pre-98 Trooper owners beware - you'll probably have to get your own mounting hardware and figure out how to mount the bar on your own.
Pat.
I recommend the K&N air filter. At only $45 at Performanceparts it's not very expensive and will pay for itself over time as you just clean it and reinstall instead of buying a new one. As far as horsepower gain, I think it's very minimal.
I think shocks alone will make a difference. I own a 2000 Trooper S and personally I like the factory ride, but a bit stiffer shock wouldn't hurt. I've switched from factory shocks to Bilstens on my last Jeep and it was a huge difference. I'd check out a shock like the Monroe or Gabriel as they make a lot of the off-road shocks themselves. Many times an off-road shock is nothing more than your regular shock with a fancy sticker and name on it, oh and of course a hefty increase in price.
Let me know how the speakers work out. Where are you buying them, Crutchfield? I have the same setup as you and it's by far the best sounding factory unit I've ever owned. I'm curious if the speakers will really make that much of a difference, I've read mixed reviews.
RADMAN:
I like Thule racks myself. Owned one for some time on my Jeeps and it held up great. I can't decide whether to go with a Thule on my Trooper or a permanent rack like what Duktrooper has, I really like his.
I think the "very large" hole you are referring to is the tie-down point that all cars have for transporting from the factory. For my 99, the kit came with a large alloy "washer plate" designed to cover that hole for mounting the bolt...sounds like your kit could have used it too.
I don't have much basis for comparison, but the tube seems pretty heavy-duty to me...must be around one-eighth inch thick on the tube wall.
There should have been wrapped up tightly looking like packing material, the Bolts, Nuts, Washers, Instructions, and 2 Aluminum/SS plates to cover those holes when attaching. When I did my buddy's last week, it was in a separate pouch, so that I'd bet is the problem. I shook his good today, and that thing isn't going anywhere, at least not until the tubing gives way!
-mike
1. What speakers did you upgrade to?
2. Improvement or not?
3. Any other stereo mods suggested e.g. adding an amp?
TIA!
Dunno what folder this belongs in, but I received a JD Power satisfaction survey the other day. Since they included a nice, new, crisp $1 bill in it, I filled it out and mailed it back. Bunch of questions about vehicle, dealer, etc. Most of 'em wanted a rating from 1 (lousy) to 10 (excellent). I gave the vehicle a 10, dealer a 3, and delivery prep a 2. I also checked "definitely" about whether or not I'd buy the vehicle again. The letter said the survey results will be out in August. If I can find it, and remember, I'll post the URL of the survey when it's available. Oh yeah, my dealer was Pohanka Olds-Isuzu in Marlow Heights, Maryland. They make the stereotypical used car salesman look good!
Charlie
P.S. I'm the one with the TOD decal on the rear window of a 2-wheel drive. I crawled under it the other day and see some strange hardware that doesn't look like it belongs. No transfer case and front drive axles, tho. Anyone else (more knowledgeable about these things) ever looked under their truck?
C
-mike
First, a Pioneer Premier 730 head unit, which has a built in crossover. The front speakers actually sound pretty good once you remove the low frequencies. Next, a Rockford Fosgate bd1000 amp mounted under the driver's seat. Finally, 3 JL Audio 10w3s in a sealed, floor-firing box that sits right behind the back seat. The system now ROCKS! The next thing to do is to add an amp to the front speakers, but that'll have to wait until next month
Check out http://63.105.28.12/trooper/ for a hastily-constructed bandwith-hogging set of pics.
Sue
-mike
-Sue
About a month ago, I decided to put larger speakers in rear and went with Alpine 5.25". They fit in snugly(yes, I had to drill holes) and the improvement sitting in the rear seat was mostly in the way of extra volume. The 4" speakers, I don't care what brand, just can't fill up the large cavernous area of a Trooper. I don't think you can go wrong with Alpine, Polk, Infinity, or Clarion....all reputable brands and popular with Hifi auto shops.
Thanks for all the help, guys.
Pat.
Mike, sounds like this is and might continue to be a problem for ECB buyers who want to DIY. Do you think there's any chance the mates at ECB could provide more graphic/photo info.
-mike
-mike
Mike, I reviewed the install pics you have on your site and the mounting tabs on your bar are way different than mine. Your install looks as though the tabs extend straight out from the bar; my tabs are L-shaped and bolt flush against a bracket mounted on the end of the frame. I am sure your scanned instructions will still help, even if only for seeing what hardware was provided.
Even after all this, I think I can spend maybe $5 on some 3/8" or 1/2" grade 8 nuts, bolts, and some mojo washers, and crank up the drill; I think that'll do the trick. :-)
Pat.
I also e-mailed Tony over at ECB and asked him to put some more in-depth instructions together possibly with pics for future deliveries. I am planning on replacing the lock washers on my installation in the next few weeks, when I do I'll take step by step instructions on how to do the install.
-mike
-mike
By the way, anyone know the output power rating on the stock head unit??
MMM big moonroof, biggest of any SUV!
-mike
As far as good prices for the racks and component it would be well worth your time and effort to check out Ebay and Yahoo auctions as long as you don't mind the equipment being a little used.
I am using a 1999 as a reference.
The answer is 3!!! Yes three. There is one in the firewall which is sounded for the alarm only and there are 2 more behind the bumper. You would think that with that many horns, it would be alittle more impressive.
Pete
http://www.suvtech.com/isuzu_trooper.htm
How do you see the ones behind the bumper. I've looked on my '99 trooper and haven't found any accept the one on the right side of the firewall.
