Isuzu Prices Paid and Buying Experience
http://www.isuzu-suvs.com/images/99trooperwarranty.PDF
However my opinion is that you should put that $1200 in a separate bank account and use it if you need repairs. If not, then you have that money to yourself. I doubt you will need a warranty repair for $1200? Let's say the tranny goes? $500? I guess engine failure would be a big one, but that might be caused by lack of oil or something dumb, and then not a warranty item. (I mention the oil thing because some of these trucks burn up to 1 qt./1000 miles - normal, but people who don't know, don't check and then voila - engine problem)
-mike
I don't think there were any major problems with the 2000 year. Be advised that these trucks burn some oil, just normal behavior, there is a clunk that is audible when coming to a stop light and the transmission shifts from 3/2 to L, and that these are trucks not cars and the drive as such.
In regards to the transmission, yes a complete end to end replacement is probably more than I said, however, I cannot forsee such a major failure, so in my mind worst case is one of the components failing, so less than $2K, maybe more than $500?
-mike
Makes you wonder.
A TOD unit went unsold at $50 - http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&cate- gory=46104&item=2422695552
Just some food for thought should the time come for a major overhaul.
That said, I think Troopers are fully able to go a half million miles. The chassis is very solid. The suspension is easy and inexpensive to upgrade (I suggest OME suspension upgrade kits) so it rides like new.
There isn't a towing package for the Troopers that I am aware of, just a hitch. Some people add an axtra transmission cooler from a third party. Ask how heavy the trailer and how often the towing, heavy ( >3500Lb.) towing miles count double for wear on the tow vehicle.
BTW many of the miles are miles driven on Hwy from Arkansas to Alabama and then Alabama to Florida and also day to day work.
Debbie
