Best Regards,
Shipo
Best Regards,
Shipo
DL
Interesting....my son just took his 320i in last night for the same problem.
The temp went from 32 F to 60F overnight so when the dealer started the car he could not hear anything. May have to leave it overnight again.
Does replacing the crank case vent valve cures the issue?
Webby
Then I noticed looking over some old paperwork that my former 1999 323i had the same repair done under warranty.
It does seem a bit odd to me that a I4 and I6 developed the identical problem.
Good Luck,
DL
UPDATE: Just talked to the BMW service folks. Apparently this does happen in extreme cold every now and then. All we need to do is to "reset" or "reinitialize" the key. He walked me through it over the phone, and it's very simple. For some reason it seems to be important to be using both keys (master & slave, though telling the two apart visually is impossible) at the same time.
1. Grab both keys, unlock the door(s), insert the master key into the ignition.
2. Turn the key to position #2 (just before the engine is engaged) and leave there for a few seconds.
3. Remove the key. Press and hold the "unlock door" key. While holding this key, slowly press and release the center lock key (BMW logo) three times. Release all keys.
4. You should hear the car doors lock and unlock.
5. Repeat the key combination with the slave key (don't need to put it in the ignition.
6. Congrats! Your keys have been reset/reinitialized. No need to motor down to the local BMW dealership.
Now, while I haven't bothered to check yet, I'm sure I also lost the seat/other settings on my keys. Oh well....
Adawaal
does anybody else have the same problem and how do you resolve it?
I have contacted BMWUSA and my dealer, so far they have not told me what to do with it yet. and it has been for a while.
etc.
I think you left out the part where you have to do this by the light of a full moon, and then walk around the car counterclockwise three times while holding a key in each hand and chanting the words to "Deutchland Uber Alles", backwards. :-)
I pulled out my car a few days ago (after it had been sitting in cold weather for almost a week), and I immediately noticed that the brakes were pulsing / shaking whenever I touched the pedal. Felt like a warped rotor at the front right wheel, as the brakes were difficult to modulate and I couldn't stop the car smoothly.
Drove for 200 miles with this problem and it remained--the higher the speed the worse it got. But the next morning, I start the car and it was completely gone.
It's a 2002 with about 25k miles, and it's a manual so I use engine braking quite a lot--no reason for a warped rotor at this stage.
The only thing I could think of: there were several sudden temperature changes cold to warm and back all in a few days. Could that have had anything to do with this?
I'd like to have the car checked out, but I just don't have time to deal with the dealer these days.
Is this a one-time problem, or might it be something more serious? I appreciate any help.
Don't ask me how I know....
Thing is, the car was doing it all through the 200 miles, as bad at the end as at the beginning.
Next day it was gone.
Yes I know how to match revs.
The chief machanics of my dealership droved my car for two weeks (500 miles), and BMW sent a field engineer to the dealership to check the computer memory in my car. They do not think that this car has problems. The hypothesis now is that my foot was somehow touching the gas pedal when the problem occurred. I have driven cars in U.S. and Europe since 1971 for half a million miles, but I never saw this problem with cars I owned or I rented. I must admit that I did not own a German car before. I understand that most cars have the gas pedal hanging from the top, unlike the BMW 3-series.
I have had my car back, and I hope that they are correct and that the problem will not show up again in the next equivalent period (4000 miles). I thank my dealership (Capital Cities Imported Cars, Albany NY) and BMW North America for their help.
How big is the dent in your 330? I would recommend having a paintless dent shop such as dent busters look at it too. I had my son-in-law's Mercedes 500SL in to a dent busters shop and the result was like new! I have had several of my cars to paintless shops and have always had great success. If the dent is really large, they may not be able to help you and a body shop is the only solution.. If you are going to have a body shop work on your car, call several independent garages that do mechanical work on BMW's and Mercedes and ask them where they would recommend you taking your new BMW for body work. Usually they know of the best body shop in town. Dealers will of course recommend themselves and they are not always the top shop! Your warranty should not be affected.
If you have to pick between the two... don't do it over $210... Ask around, and find out who does the best work.. Bad paint work on a BMW will kill the trade-in value.. (well.. any paint work, but bad work is worse).
But, choose the best one... whether it turns out to be the BMW dealer or not, is not important to your warranty or anything else..
regards,
kyfdx
Thanks for the advice. The dent isn't big, but it did crack the paint down to the metal, so I believe a dentless repair won't work.
1) on oil: I have a 2005 330i, now with about 6k miles (mostly highway) -- the oil has become darker and more sludgy than when I first looked at the dipstick -- hardly unusual -- but it seems darker and more sludgy than my past (non-BMW) cars -- so for those who have the experience, is this anything to worry about (other than perhaps getting an oil change at 7500 miles, even if I have to pay for it, just to be safe?)
2) on performance: I am interested in upgrading the acceleration at lower speeds (in first and second gear) and have been canvassing other websites about Dinan upgrades -- specifically the CAI (cold air intake), throttle upgrade and relevant software (Dinan seems to insist that the three go together. There is good and bad here: installing Dinan doesn't interfere with the BMW warranty but, on the other hand, is a bit pricey -- my questions, for those who have the upgrades, are: 1) does it work? not just psychologically but actually (assuming there is a difference...) and 2) would one also have to get the free flow exhaust upgrade (the anxiety being that the other upgrades may hurt the engine without a proper exhaust outlet)
thanks in advance!
I have the 325xi and each time the weather is cold, I heart his shrilling/shrieking noise coming from the drive belt area. but then it goes away after a frew minutes.
the dealer told me it's normal for this type of car especially when the weather is cold.
should i believe him or not?
I have a 325xi and it's quiet as a mouse (well, except for that nice throaty exhaust note ).
The owner's manual describes how this works, but then there is another paragraph marked by the icon they use for settings that are changeable by the dealer. The language in that paragraph says "After giving an ice warning, the display returns to the previous setting." I thought this meant the dealer could change the computer so that it would return to the previous display after giving the ice warning, but my dealer says no, that isn't possible. The "service advisor" went and talked to someone else, came back and said he heard it "from the highest authority," whatever that means. Did I misunderstand the owner's manual? Anyone else familiar with this issue? It's a minor thing, really, but it has been bugging me for 2 winters.
That said, I've never tried to have mine changed.. I bought mine used, and just stick with what was programmed... Mine is programmed to show the temperature as the default setting at start-up anyway... so, obviously, I don't have that problem...
I am hoping that the new E90 uses the methodology of the E39 and not the E46.
Best Regards,
Shipo
I have a 2005 RED 325xi..picked it up in Nov..The car reflects a weird "glare off the paint"...and also has a zillion circular motions on the paint. like using a "ruff" buffer in detail..
I brought it back...they shined it up..looked great...had it washed..(brushless place)..all the problems back..
brought it back..and they did a full detail..I spoke with the detail supervisor, and he said I should check with car washes first, to see what detergent they use....
I left saying to myself..I doubt if many BMW owners have to go threw THIS.
Had it washed again, by hand ...and its all back..I called customer service BMW USA, and she sent me back to the repair manager..who said that the regional guy who had seen it prior, said "thats normal for red paint,,like black paint"..
I am going back in two weeks to have a belt replaced...I am losing my patience..I had a red subaru for 5 years...was fine...any one else have problems with red paint in 05?..any suggestions where I should go for assistance?..The person at BMW USA said the dealership could authorize that the car be repainted.."under warranty"..but I tend to think it will be the regional guys decision...and he saw no problem with it..pls help!
Th
I hope you find a satisfactory resolution. I love the look of the red.
Seems fairly typical for a 3-series..
at 15k oil service 15913mi, tech noted brake pad thickness as lf/rf 10mm and lr/rr 12mm.On inspI
31714mi, tech noted brake pad thickness as lf/rf 12mm and lr/rr 10mm? Well lets see, one could assume that the inspI tech just transposed the #'s(which suspiously match the #'s of the first tech), but obviously my pads would have worn down in the 15801mi. between these measurements. So my question before I return is, what instrument do I use to measure the brake pads,from what point to what point do I measure and what is BMW's minimum for replacing pads/rotors? TIA for your help...Steve/o2'330cic
from service papers:
0054586 reprogram gms egs module
771wpb94
fc:0024230100
note: performed sib 24-04-03 to reprogram egs for harsh 3-2, 2-1 down shift
It could be something as simple as one tech who doesn't know how to accurately measure pad thickness..
I'd then ask the service manager to have his most experienced mechanic re-check it..
I don't know how old your car is, but if it is still less than 3-years old, this is important, as replacement pads are free until then..
If it turns out they are okay, but getting close.. I'd pay for the maintenance extension to 4yr/50K ($399).. Brakes alone will cost that much.
regards,
kyfdx
-Paul
Other 3-series owners seem to like Pirelli P-Zero Nero A/S..
-Paul
In my 2002 Accord coupe I had 2 replaced under warranty ( belts shifted )and then I had to move the wheels in every possible configuration to get it correct.
I am done with Michelin's.
The Pirelli's snows are great and am installing Pirelli's P Zero Nero M and S in April.
Webby
-Paul
Webby
That is true !
Webby
