BMW 3-Series Maintenance and Repair
14142444647105
  • msh1msh1 Member Posts: 1
    Good day, all. I am considering the purchase of a 1994 325iC on which I might be able to get a fantastic deal. The car will likely need a new top in the next year or so and I'm trying to get a handle on how much this will cost.
    While I like to do my own basic maintenance (changing fluids and brake pads) I know that this is most definitely NOT a do-it-yourself job, so I think I'm probably looking at a large number for that new top.
    Any guidance as to ballpark cost for an installed new top on a '94? Thanks for the assistance.
    MSH
  • holeinoneholeinone Member Posts: 48
    Hi I'm back. The "Check Engine Soon" light came back on, and so I had the ODB read at Auto Zone. They told me my Coolant Temperature Sensor is bad. Does anyone know how to replace it? Or do I have to bring it to my dealer? TIA.
  • qin107qin107 Member Posts: 1
    I just had this done on my 2000 BMW 328i on the Rear Right window.
    The parts was $130 and they charged labor of 1.5 hours at $80/hour.
    I paid approx $260 to get this done.
  • canada3canada3 Member Posts: 2
    Folks,
    I am not going any whare with BMW
    on this transmission issue (reverse gear problem),
    and can you please reply how you resolved this
    unfortunate problem.
    Please read my former request:-
    Hello everyone,
    As it seems common, I’ve a reverse gear problem on my BMW 323i-2000,
    and getting mixed messages from different BMW dealerships.
    Some think it’s minor and some major Transmission problem.
    I’ve also contacted BMW Canada to complain and, they seem
    to be aware of the problem. They suggest I go to Dealership
    gor service and let the manager contact them.
    I am a bit worried, and can any one of you let me know how
    you resolved this reverse gear problem. Money wise and
    also the procedures. Did BMW pay part of the cost?
    Thanks in Advance!
  • gordonwdgordonwd Member Posts: 337
    This is one of my pet peeves with current vehicles. They have all these systems to monitor and warn you about the operating condition of the car, but it seems that more than half the time a warning is diagnosed as a bad sensor! So apparently the engines are more reliable than the system that is supposed to be monitoring them. Seems like it should be the other way around. ;)
  • ximbriximbri Member Posts: 7
    Hello all!
    I have a 01 330i SP/PP. I purchased this vehicle used about two months ago and since then have been trying to pinpoint a location in the backseat of the vehicle where a rattle is coming from. I had thought it might have been the back seats or cushions, so I’ve taken the back seat apart and found everything secure and sound (as well as $4.00!). Now I am wondering if it might be the ‘third-eye’ taillight in the rear window. The trim is secure, however when I tap the trim with my fingers it makes a rattle sound. I took the trim down and did not see anything loose. The pilar trim pieces (with the reading lamps) make the same sound, however I don't know how to remove them.
    Anyone have any suggestions of other locations in the rear of the vehicle I might be able to check for rattles? I can’t seem to find this one and it’s riving me nuts!
    The rattle only sounds when I go over a ‘rippled' or a very bad bumpy road. “We have bad roads here in Seattle”.
    The rattle sounds rather like as if you rapidly tap your finger nail to your desktop. Thanks to all in advance for any suggestions!
    Ximloe
    I hope you're right. I have scheduled for service with the dealer in 2 weeks. They told me it would cost me $500. I whined at the price. They responded that the part costs like $20 but the estimated labor is 4+ hours. :cry::cry::cry:
    My 325xi also rattles but it's somewhere in the front. It started when I had the front brake pads and rotors were replaced. I went back twice but all they check were brakes and saw nothing wrong. Very annoying.
    My 325xi is breaking down. Just right after the 4 year warranty expires. Surprise.
  • harleybikerharleybiker Member Posts: 3
    This is my first experience with Run Flat Tires, which are on my 2006 325i. Let me tell you, avoid them like the plague if you can! My tires are BridgeStone Turanza EL 42, 205/55 R16 (RFT)
    I love the car, handling, acceleration, and have gotten used to it's looks. But I had a flat tire warning come on the other day, and drove cautiously at 45 MPH to my local dealer 10 miles away. The shock came when I was told that Run Flat Tires should not be repaired (according to BMW) because of damage to the tire sidewalls by driving on them with low tire pressure. Can you believe it? What good are they?
    I would much rather have my spare tire & wheel, tire wrench and jack back so I could replace the tire myself, and get it repaired without the expense of buying a new tire whenever one goes flat..
    These tires also ride harder than standard tires, which I'm sure you all know. So I was stuck with buying a new Run Flat Tire (which the dealer fortunately had in stock) at a price of $229.34 installed.
    I might add that I checked with a local Bridgestone Tire Dealer, and he could have saved me $5.00, but it would have taken him two days to get it from the warehouse.
    Run Flat Tires.....a step back, certainly not progress! :mad:
  • rhmassrhmass Member Posts: 263
    Concern for the run flat tire is the only reservation when we ordered our 06 330i. However there is no way you could have gotten around this "problem" as they are the only type of tires equipped for all 06 3 series. Like you, I'd rather have tires the old fashin way with the spare. So each time the tire leaks our air, it will a $200 problem, and that's when you are lucky enough to find a replacement. This may prove to be very profitable for dealers. There is unconfirmed rumor BMW is replacing the run flat in 07.
  • potemkinpotemkin Member Posts: 195
    True, but I think it's better to replace a $20 sensor every once then pay big bucks to rebuild an engine 'cause there wasn't a sensor to tell you that something is wrong.
    "Seems like it should be the other way around."
    Are you sure you'd prefer the un-reliable engine over the faulty sensor? ;) I'm usually happy to hear that the problem is just a faulty sensor. Of course, no problem, no warning would be best.
  • gabriellgabriell Member Posts: 1
    Well, everithing indicates that my car's transmission (automatic) is dead, and the car is only 37K miles. The guarantee expired and I am callig BMWUSA customer service to try to get some kind of compensation for this. Questions that I have:
    how to put pressure on BMW to pay for the new transmission? (other than this, my car is in very good shape)
    if BMW doesn't cover anything, is it advisable to go to a mechanic (not the dealer) and try to repair it, or replace it for a second-hand one?
    Any other advice is welcome
  • manvee1manvee1 Member Posts: 3
    Replaced all 4 brakes and rotors at 20k miles last yr (under warrantee).
    Now a yr later @45k miles (the 20k + another 25k highway miles), all 4 brakes and rotors need replacement again. (Warrantee for brakes ran out at 36k). I dont ride the brakes.
    Is this what others experience?
    Dealer says this is expected but im concerned this will turn into an unnecessarily expensive habit. Of all the cars ive driven in the past this is the 1st ive seen to go through rotors that fast. Now i know where all that brake dust comes from on the 325 models.
    Though I like the 3 series a lot (minus how it handles in the snow) Im beginning to eye the audi convert now...
    concerned bmw fan/owner.
    If you aren't tracking the car you can get away with replacing the rotors at every other pad change-replacing pads/rotors on a BMW is a simple DIY job. Axxis Deluxe Plus pads would be an excellent choice if you want to nearly eliminate brake dust. Brembo makes a good aftermarket rotor. If DIY isn't an option then find a good independent BMW shop.
    Thanks for swift response div2.
    Im in the process of lokin 4 a good/reliable garage in central nj/nyc
  • tiki2tiki2 Member Posts: 7
    Hey Thanks Div2 and kyfdx I am glad some one knows where to go as I am for sure alittle lost with this one..Mopar yes can get that BMW ?? Well...But anyway thanks ppl. T :shades: :shades: :shades:
    My solution to the Run Flat Tire problem was to purchase a tire inflator that is powered through the cigarette lighter, and a can of tire sealant & aerosol. At least if gives me a chance to temporarily seal the tire and drive to a BMW dealer with the tire inflated fully, to have the tire repaired without damaging the tire sidewalls, by driving with low tire pressure. I figure it's worth a try. I found a good portable 12V cigarette lighter powered tire inflator at Sears, for $43. The can of tire sealant can be found in most Auto Stores. Hopefully this will help me avoid spending $229.34 for another new tire if I have another flat.
    I sure hope BMW wises up and gets rid of the Run Flat Tires!
  • kyfdxkyfdx Moderator Posts: 265,419
    I could be wrong, but I thought once you use that tire sealant, then the tire is basically done for, anyway.... I think once the inside is all gunked up, you can't do anything with it?
    The tire sealant is designed to get you home, without changing the tire... on a non runflat....but, I don't think the tire is any good afterwards.. I think the only way to save a runflat tire, is to carry a spare, and change it when it goes flat..
    I may be wrong... it happens daily.. ;)
    regards,
    kyfdx
  • lv2srflv2srf Member Posts: 2
    :sick: I have searched the internet over and over and have found many complaints of transmission reverse failure. I have recently purchased a 2001 330i with 44k that had this same problem. In all the places that I found stating this type of failure (reverse gone) I could not find any one specifically stating the manufacturer of the failing transmissions. Here’s what I’ve found so far.
    The failing transmission (at least in my case) was a ZF-5HP19 auto-step
    I dropped the pan to have a look at the extent of the damage…Here is what I found.
    First I drained the fluid which was an opaque charcoal black…but it did not smell burned.
    Next I removed the pan…I was shocked to find a 4” chunk of what once was a gear and several more ½” pieces but not enough to make up the entire gear.
    Not being able to locate the remaining shards I called it a total loss due to the probability of further future damage even if rebuilt then put the pan back on feeling defeated.
    My concern is that I don’t want to get another rebuilt ZF and have the same problem in another 40k.
    My question is of the many that have received a new transmission have any experienced the issue again or has anyone successfully swapped a ZF for a GM?
  • lbflbf Member Posts: 1
    Hi guys,
    Just wanna see if anyone had/has a similiar problem. I have a 325 Ci, 2004. Cylinder misfire occured 3 times, the fault was found in the system and bunch of other computer/electrical problems have been happening as well. I was told that the car can't be fixed and that I have a lemon car! Trying to find what's the best way to go with, ether hire a lawyer or try to deal with BMW North America although I already feel mistreated when I talk to them! Anyone if had similar problem please HELP!
    Thanks a bunch!
    I have the same idea about keeping a tire inflator in the trunk for emergency. Since the tire sensor is supposed to inform you when the tire is beginning to lose air, by inflating air at the early stage and keep close monitoring may save the tire. While BMW manual says the tire can't be repaired/patched, the salesman said the tire company thinks otherwise. There will be a lot to learn about these tires being the owner of the new 3 series.
    Since BMW has taken into consideration of these "stiff" tires in designing the suspension, I don't think they will consider change to other more conventional tires shortly, unless there is outcry there from consumers.
  • armandarmand Member Posts: 178
    Does anyone know of a quality radio that could replace the awful one in my 2005 325 XiT?
  • car_rmcar_rm Member Posts: 47
    lbf,
    Was it the dealer that told you that you had a lemon? End of last year, I dealt with my 2003 325i through a lemon law attorney. After learning that BMW was buying the car back, I met with the customer service manager at the dealership, her 1st question was why didn't I go directly to her (no one I dealt with told me she existed!). The attorney should not cost anything out of your pocket if you go that route but will be paid by BMW/dealership.
    Go talk to the customer service manager at the dealership. If things don't seem right, then go to a lawyer.
    Good luck
  • treepushertreepusher Member Posts: 16
    I'm having a problem with my (2005 330i) self-leveling xenons. The lights drop when initializing, but occasionally fail to return to a normal pitch. The road in front of the car is illuminated brilliantly for all of twenty feet, but driving without the brights on is dangerous at any speed over a crawl, because I literally can't see the road (or anything else) more than a single car-length ahead of me. The dealer was unable to find a problem, and most of the time the lights do level themselves properly. Shutting down the engine and restarting the car doesn't make a difference once the problem occurs, as the lights still won't level. Sitting in my garage with the engine off and ignition in position 2, I can hear a motor straining to lift the lights after the initial drop (and see the lights bounce fractionally on the wall ahead with the sound of the motor). Presumably there's a motor trying and failing to lift the lamps up. Was just at the dealer service dept. yesterday, who said nothing was wrong and 'reset' the mechanism, but same problem again tonight, first time with the lights on. (And this isn't an aiming problem or 'xenon line' here. When they level properly, they're great and I can see fine). Any suggestions? TIA
    Can't help you specifically... but since it's under warrantee, I'd take it to another dealer. If they can't find the problem, contact BMW-NA. This is a major safety hazard that needs to be addressed.
    How to contact BMW-NA regarding warranty issues? Does anyone have its mailing addresss? TIA.
    Have you checked the web site for contact info?
    http://www.bmwusa.com
    Thanks Karen. That was the first place I looked but I couldn't find it. On second look I do find it under the BMW USA tab. Thanks!
    Whoops! Sorry, I meant to put in a link but got distracted by a bright shiny object.
    This will take you directly to the contact page:
    BMW contact
  • glovedincglovedinc Member Posts: 2
    Hi guys,
    Need some advices on 2002 325XI.
    I'm about close to make a decision on 2002 325XI. The mileage is low (around 15K miles). The only thing that bother me is the long term maintenance. I heard ppl always complain about problems comes after the warranty. Also, will the 4WD cause a lot of problems in a long run? thanks.
    You should check out Edmund's nifty software called: True Cost to Own
    You can compare the 2002 Bimmer to other similar cars also out of warranty (same age) and compare maintenance costs with say a Camry or Acura etc. etc.
    Thanks for the heads up :)
    It is very useful.
  • huwhuw Member Posts: 1
    I have owned a BMW 318TI Compact 2000 for about a year and apart from a few minor problems the car has been good. I have recently started experiencing a problem where the rear tyres are not wearing evenly. The inside of the rear tyres are wearing much quicker than the outside. I took the car to a garage who did the 4-wheel alignment who told me the rear wheels were severely out, but told me there was no way of adjusting the alignment on the rear wheels on this model car. They also told me that to adjust this problem it might be necessary to replace the rear suspension with adjustable suspension and that was to be very expensive. What I do not understand is that the first set of rear tyres that I replaced wore down quickly but evenly, so the problem seems to have started occurring since that. Can anybody please shed some light onto my problem???
  • sirdarby1sirdarby1 Member Posts: 36
    Hey guys:
    2 ques.
    The vinyl piping surrounding the rear window of my black cloth top is beginning to pull away. What type of glue should I use and repair process.
    Also the brown lining on the inside is falling out. Is it time for a new top. I have a black 328ica.
    If replacement is eminent, who in Atlanta does a good cost effective job. Can they refurbish the top? Dealer is charging $3,000.
    Please advise.
    other than these things, top looks new.
    We own the 2002 wagon form of the xi you are considering. At about 23,000 miles, it has only needed regular maintenance (all covered by BMW). We have purchased the extended maintenance program and probably will consider the extended warranty as we keep our cars for at least 10 years. The all wheel drive hasn't given us any problem. With four winter tires, you'll be able to go anywhere in snow.
    If you enjoy driving, you'll love the BMW you are considering.
    glove, i took my 325xi delivery in july of 2001. since then, i have done 2 oil changes, 1 brake fluid change, front brake rotors/pads change, stablizer link replaced, and the thermostat replaced. The latter 2 replacements happen just as my warranty expired!!!!!
    Anyone out there. Where is the stablizer link located? Is it possible that it was knocked loose while replacing the front brakes? TIA.
    You seem to have missed two oil changes (BMW offers annual oil change) and one coolant change (every four years). Maintenance is crucial to keep up with reliability of any vehicle.
    Hi rhmass, this is one of my complains. My free maintenance was only for 30,000miles/3 years. I don't drive a lot, only the daily commute which is short. Right before my 3 year expired, I called my dealer if I could have the oil serviced. They said NO because the service indicator was NOT lit yet. 2 weeks later, I found out from the manual that I could still request oil change if it's been more than 1 year since the last oil change. Of course both the dealer and BMW NA refused to give me the free oil change!!
    As for the coolant change, I don't think my plan covers it. But the parts should be covered for 4 years. Once again, I missed the deadline by 2 weeks. Once again neither the dealer nor BMW NA were willing to give me the grace period.
    I will NOT buy another BMW, just by principle. As far as I'm concerned, they don't care once you bought the car. They think the car sells itself and hold their noses high. I've had enough of that. Audi or Mecedez next.
    I am sorry you had such an unpleasant experience. However there appears to be some discrepancies here. I own the same year of the 3 series as you do , except in wagon form. There is NO service indicator light for my car, but the miles left for service which is numerical. It shows "miles left for service" when the car is started. Also the allowance for annual oil change with less than 15,000 miles is not listed in the manual, as you said, but rather an "understood" kind of policy BMW dealers adopt as practice. You probably could have argued for that.
    In general, I think the quality of service rests with the dealer's service Dept. rather than the brand of the vehicle.
  • erickplerickpl Member Posts: 2,735
    isn't a whole lot different in my experiences.
    Heck change the oil yourself. I can do it w/o even getting under the car by using a MityVac fluid extractor and buying the filter from BMW directly. I use Mobil 1 and do it every 7500 miles because I DO put a lot of miles on that car.
    My 2002 325xi has 98,000 miles on it and I've only had a few minor issues with it:
    Computer failure right after purchase - replaced and no problems since
    Window regulators - replaced under warranty, now can do it myself next time.
    Exhaust sensor bad - replaced.
    Not bad.
    My experiences with Mercedes (sales admittedly) have me thinking that they think they are the best and their service is not included in the price as far as I can remember, like BMW's is.
    Audi is a bit better with service as it is included 4/50,000, but the dealership around here is a smaller dealership and if you need parts for ANYTHING, they'll probably have to order them - and they are more focussed on selling Beetles and Passats instead of A6's and A8's.
    My BMW dealer in Cali was INCREDIBLE to me and treated me extremely well. The dealer here where I live now in Alabama has a less than stellar record with me at this point. So not all dealers are created equal.
    -Paul
  • akajimboakajimbo Member Posts: 10
    Hi. First time posting here. I bought a 2001 330Ci couple of months ago and the car was in fantastic condition in every way until this morning. This morning, the car just won't start. On a quick look, battery was seemingly ok as remote unlocked the car and electrical systems were on. I don't hear cranking sound turning the engine and it feels like everything in the drivetrain is completely dead.
    The car is with AT transmission and has around 56K miles. I live in California so I don't think morning temperature was an issue. Prior to this morning, there was not a slight symptom of this failure happening.
    Is this a starter motor problem? I can't even see where is it located. If starter is in fact a problem, would you recommend to take the car to the dealership or can I just take the car to a local repair shop for replace/fix the starter? Closest BMW dealer is about 25 miles away.
    Can other failures (like fuel injection system or some failure in the security systems) cause this problem? Or should I be concerned about some major problems in the drivetrain?
    Your help and advice will be much appreciated.
    A weak battery can open doors and light small light but still not move the starter motor a fraction of an inch.
    could be any number of problems. I don't see why a regular shop can't diagnose something like this.
    First you charge the battery, and clean the cables. Then check the starter by bypassing the ignition switch (use remote starter switch). Then if that's okay you have to look for things like automatic transmission neutral safety switch. Also various fuses, etc. Takes some patience but I bet the answer isn't too complicated once you get there.
    Thanks Mr Shiftright for the advice. I will start with the battery check first and try others. Hopefully, it's not anything major
  • selmselm Member Posts: 122
    Not to be a smart mouth, but how do you shift right? I am getting a new 3 series 6 speed manual through ED but my wife does not know how to drive a man. trans. She says she wants to learn how just in case of emergency, I personally think she wants to drive on the autobahn too. She is asking me a lot of questions that my answer is, " I don't know, I just feel it." So I ask you and others out there, what is the correct way to shift? She has asked me things like: do you have to push the clutch all the way in or just far enough for it to engage? And many more like that. My current car's owner manual says all the way in, so that is what I told her although I do take shortcuts on occasion. Any pointers on how to teach someone to drive a manual?
    The first thing I would do is clean the battery cables/terminals and then load test the battery. My money's on the battery. For what it's worth, BMW batteries are not truly maintenance free; the electrolyte level needs to be checked every six months. I've followed that regimen on my 1995 318ti and 1997 528i-and both still have their original BMW batteries. If your battery is bad, don't waste your money on a BMW replacement battery; for some reason they never last as long as the OEM units. Buy an Interstate Mega-Tron. I think your car uses an MTP-91.
    I'd do two things so that you aren't replacing clutches every 3 months.
    One, I'd teach her what a tachometer is and how to use it as a shifting aid.
    Two, I'd teach her how a clutch works (I can see her eyelids closing as you sit there at the kitchen table with two dinner plates). That way she knows what is going on as she works the pedal and the shift lever.
    By using the tach she will never short-shift or over rev, and by knowing how a clutch works she won't ride on the clutch pedal or try to hold the car on a hill with the clutch----all clutch killing habits.
    Thanks. I hope this will help. The last time we tried she stalled the car walked oout of it and said "I don't know why anyone would want to drive one of these things." Alright, I will stop digressing and let the forum continue for its original purpose.
  • odessitodessit Member Posts: 140
    Mr Shiftright. I know that I am off the topic but it seems like you can explain things very good. I never drove stick before and now trying to get a feel of steptronic in manual mode (I have 325i 2006). Can you give a short lesson please? If you don’t want to waste space here simply email me. I am driving in manual mode few weeks now and think I got it more or less. But still prefer to see some guidelines and suggestion from someone who really knows how to do it. Simply afraid to break the transmission. Also want to do it right to keep gas consumption to a minimum.
    mike
    This is also a tachometer issue....you can't break anything with a tiptronic (oops, that's Porsche) as the computer won't let you over-rev or downshift at the wrong time. Some manumatics are really slick--they actually reve the engine for you as you downshift so that your engine and transmissions speeds are matched.
    So just watch your tach and shift before red-line each time. It's pretty simple. As for downshifting, you just have to experiment...the idea is that when you are say in 4th gear, you watch your tach and if it drops too low ("too low" is different say for your car than mine, which is a V8)...let's just say in your car 2,000 rpm is "too low",....then you downshift and you'll see the tach jump up to...oh maybe 3,300 or so....whatever...the idea is to use the tach to learn what is "too low" in any gear and what is "too high"...personally, if you are over 4,000 rpm in any gear, downshifting gets tricky, as you'll run way up over 5,000...which is okay for a BMW certainly but you want to avoid what we call "compression braking"....where you downshift at a high rpm and the engine braking is severe.
    I never recommend downshifting to "brake" a car....if you have a red light or stop sign or a stopped car in front of you, don't be downshifting to slow the car down. Downshifting is to gain advantage for some purpose
    So don't pick a low gear unless you are going to DO something with it.
    Thanks a lot. This is very much appreciated.
