A potential "problem" I've experienced (haven't seen it mentioned) is with the a/c. During especially hot days, say 95+ F, I've noticed that the vents will blow only warm air when I've been sitting motionless in traffic any longer than a minute or two. When I begin to move again the a/c tends to pick up again. Even when moving (again, on really hot days) it has a tendency to fluctuate in temperature from nice and frosty to just not cutting it. Also, on these days it sometimes takes a long time (almost 10 minutes) for the air to really cool down.
Now, I understand that a really hot day is going to tax the system a lot more than your average summer day but, under the same circumstances, my girlfriend's 1999 Chevy Blazer's system blasts cold air in just a minute or two and never shows any of these same symptoms I've described. I also don't recall ever having the same problem with my former '94 525i.
Am I simply expecting too much from the a/c or could there be something wrong here? Any suggestions you guys might have will be greatly appreciated.
-SmoothOperator
As for your 328i, I also have a 1999 328i (5-Speed) and while I have in fact noticed that the air coming from the dash vents when sitting at idle on a hot day (we hit something like 110 on the NY Thruway a month or so back) is not frigid, it is however, certainly cool enough by my judgment. So, a few things come to mind:
1) Make sure that the little wheel between the two dash vents above the radio shows three blue dots. Anything other than that will be mixing in warm air.
2) Make sure that the "Recirculate" button is lit.
3) If the above two do not have the desired effect, you might want to schedule a service call to see if you are low on refrigerant.
4) The only other thing that I can think of is the fact that you have an automatic transmission. I wonder where the tranny cooler is located, I suppose it is possible that an engineer in Munich had a brain fart and placed said tranny cooler in front of the A/C Condenser (not very likely though).
Let us know how you make out.
Best Regards,
Shipo
secondly, have you contacted bmwna?
as far as the actual car problem itself, we'll need a little more input (i.e. any other noises, high temeperature readings or whatever) before it stopped running? any oil on the ground once it stopped running? and so on?
-Chris
Also odd that Toyota would provide a rental and fix a car that was broken by obvious user error.
Over-reving the engine is not covered by the warranty.
I'm surprised that there were only manual transmissions available, or that the dealer wouldn't order one from another state....
Hitting the off-ramp at 75 mph with 3 people in the car and counting on the transmission to slow you down by engine braking? Brave man.
I also know that loaners are not a BMW policy but vary from dealership to dealership. My dealer, for example, only gives loaners to those who purchased the car there. Was the dealership where you sent your car for inspection and repair the dealership where you purchased it?
Also, you might start checking the net for a rebuilt engine. It is going to be pretty expensive (if you can find one for a 2001), but less than BMW will charge you for a new engine.
Just out of curiousity ...were you driving the Toyota when it blew its engine?
However it won't do you a bit of good when you put the transmission into too low a gear. It is the transmission spinning the engine then. The engine still gets spun too fast, whether there is any gas coming in from the fuel injectors or not.
Nothing but the clutch can save the engine if you get too low a gear, and then you'd better be darn fast.
Don't come yelling (IN ALL CAPS) at us because we are skeptical about a somewhat unbelievable story... I mean look at what you are telling us:
1. Your engine blew up.
2. It's not your fault, you didn't miss a downshift.
3. BMW is shirking all responsibility.
4. You just happen (within the same week) to have been in the car when someone did miss a downshift and blew their engine...
5. Upon which Toyota, out of the goodness of their hearts, agrees to fix the car and provide a loaner, no questions asked.
The obvious intended conclusion being that Toyota is a better, more caring car manufacturer than BMW; and that BMWs just blow up for no good reason, while it takes an obvious user error to damage a toyota.
I'm not saying it's a duck. I'm just saying that it quacks like a duck, and swims like a duck, and water beads off it's back just like a duck...
I would imagine that, if BMW is denying your claim, that you should consult with an attorney. However, just out of curiousity, please tell us more about the details of how your car 'stalled' when the engine stopped. You had said you were exiting a ramp at 75 mph and downshifted to 4th. What did the Tachometer do? How did the engine sound? Did the car lurch or buck? Did steam or smoke come out from under the hood either then or after you stopped? Tell us the details.
Here is a link to a site for used BMW engines. they don't list a 2001, but perhaps they could help you find one.
http://www.bavengine.com/engine.html
I don't buy it. My friend has a 2001 325i with 7K miles and is perfectly aligned.
Is there any truth to this? Thanks for the help.
if the 330 you have is pulling to the right, how is handling at freeway speeds. if it pulls hard at freeway speeds, then we can only imagine how it would be on the autobahn. they are feeding you a bunch of BS, and it needs to be fixed, so what's their problem. no doubt i'm going to print your post and bring it to the dealer. i feel bad that i'm able to benefit from some of the posts here, but i feel that we all share our findings to help each other. when i see my dealer, i'll ask him what info they have to help you out.
Why a competent dealer would refuse to do the most basic trouble-shooting [which is what the two steps above are in this case] is beyond me. Escalate within the dealership, or pick another dealer to do the work. These cars do not wander into the weeds on their own...
I didn't figure a 40K car would ever do anything other than drive straight as an arrow.
We're retired and within easy walking distance of most of life's needs and even amenities; the cars are routinely jacked up at all four points to make sure the tires don't flat-spot. None of these has ever shown any noticeable drain in that period of time, even with the alarms activated.
Something is clearly amiss; you need a competent servicer to hook up a tester to check for the source of the runoff.
seal around driver and passenger windows in the 2-door coupe? While I have not experienced leaking, I have noticed several gaps in the rubber
seal...
Adam
My question is does anyone know which is true? Should the oil change be covered as a service maintenance? Also, I was told that someone had posted a similar question and had listed the official bmw service posting. If so, can that person tell me the posting number and when the changes was in effect?
Any clarification on this would be greatly appreciated.
Thanks a bunch,
Patricia
As the oil change interval, tell your dealer to reference bulletin 00-04-01. They should change the oil, but not reset the service indicator.
I will greatly appreciate anyone comments on what could be wrong. Car has 78,000 miles -- I bought it about 6 months ago so don't know about past maintenance or repairs (seems to have been nicely driven and maintained). If it matters, the car is from the Chicago area.
badger 11
Best Regards,
Shipo
I have a 2000 323i manual with sport pkg. and 38k miles. Great car. No problems... except recently...
A couple months ago a high pitched whining noise started coming from the HVAC (Heating Ventilation Air Conditioning) vents. This occurs with or without the A/C, heat, etc etc. It seems to disappear when the dash vents are disengaged. The noise is present with the stereo on or off. This is a physical whistling noise, not electronic. It comes and goes. Sometimes it will appear from nowhere and then suddenly go quiet - for no reason!
BMW replaced the fan blower unit, and that did not do a thing. Then, they replaced the heater core. That fixed the problem for about a week or so. Now it is back with a vengeance.
This is the type of noise that will drive you coo-coo (or to the message boards, at least). My dealer (who has been WONDERFUL and is putting forth great effort) has admitted he is out of ideas. He consulted the last time on the phone with the BMW factory rep to no avail. Our next move is to have a personal inspection by the factory rep, Scott. Scott covers the area I live in (St Louis) and visits each dealer about once per month. So, the next time he is in we will all take a look (or rather listen) to the problem.
Has ANYONE experienced this???? If you have, you can definately sympathize with me.
Thanks for the feedback and any suggestions - I am desparately open to anything. Gotta get this fixed before I hit 50k miles......
HELP ME!
Greg
Thanks for your advice - it seems so obviously logical - I wonder why the mechanics and/or BMW specialists overlooked this possible cause.
Any other advice from anyone out there would still be appreciated.
I'll let you know how it turned out so maybe we can save someone else a headache like this out there.
Whenever I can, I try to point the mechanic in the direction I'D LIKE THEM TO START; I never try to tell them how to do their jobs, but when they take multiple unsuccessful cracks at it, it's time to think outside the box a little. Often the techs can get real focused on one aspect of the problem and not think of all of the others. Having said that, I do think the idea of getting a factory rep involved is a good one. Three times is more than enough...please come back and let us know how it turns out, whether positive or negative.
Best Regards,
Shipo
Anyway, it seems the alignment is improved; however, the steering wheel still sits off to the left (i.e., imagine looking at your wristwatch when the time is 10:55). This is how the "centering" feels. This may be nit-picky, but it is thoroughly annoying and every time I get in the car, it's the only thing I think about. I don't even want to drive the car any longer.
I have tried calling the service mgr at the dealership, but we continue to play phone tag, and each time I call and ask to speak with him directly, I get the voice mail.
I have had the car for 18 days now, and it will be going to the dealership for the 4th time tomorrow morning--for the same problem. This will entail the 6th day of work on this car.
I wonder if BMWFS will let me take 33% off of my payments???????
For all the BMW-lovers out there, I'd never buy another one, nor recommend one to anyone. It's very unfortunate that some people save money for quite a while to get one of these over-priced machines and then have nothing but trouble. This experience has soured me on BMW forever. I guess next time I won't buy a car based on over-blown and baseless hype. Audi may not have the "name" BMW has, but for a few grand less and far more features, I'll live with it.
Wait, forget that. Instead, quickly trade this POS in and get rid of it. Seriously. I'm in the market for a really low mile 3 series where some other poor slob has already taken the initial depreciation hit.
Course, we all know Audis are perfect and something like this would never happen on one of them....
If you paid for my car, then I wouldn't mind the problem. But since it's my money and it isn't perfect, then it's a problem. Those of us who drive "new" rather than "used" require a certain level of perfection--esp. with a so-called luxury car. If it isn't or can't be perfect, then it's flawed.
Maybe too many years of buying "used" have diminished the expectations?
The crux of the issue is how "fun" these cars are "supposed" to be to drive. When quality/warranty issues (4 times in 18 days of ownership) cheapen this suuposed "fun," buyers are left wondering what all the hype is about!!!
One area I've been dissappointed by is tire wear. I have "normal" tires without a sports package and am looking at replacing the rear tires very soon. On my other FWD I've had 52k and 61k off tires with similar treadwear ratings.
Does anyone have any advice for decent wearing and good performing tires?
I have heard that BMW used Continental tires for some of their non SP cars, and that they suffer from early wear. What do you have on your car?
Best Regards,
Shipo
So it would be foolish of them to equipt a car with hard tires and lose the performance rating game!
Best Regards,
Shipo
But you're right 5% difference in Performance to average M+S is only important if you escape rearending someone.
The thing people forget is ABS is calibrated assumming factory tires [friction coefficient]
As for ABS braking systems being calibrated, what's up with that? ABS systems have sensors to determine if any individual tire is slipping and adjusts accordingly. End of story. The tire and its compound and how well said compound will grip a warm dry road has absolutely nothing to do with when the computer tells the ABS system to kick in.
Best Regards,
Shipo
