BMW 3-Series Maintenance and Repair
I have a 2000 323i with 5-speed manual transmission which had a "rear clunk" from the first day. I am curious to see if many 5-speed manual E46s have a similar problem. Let me explain the problem (by the way this is an intermittent problem, ie., it does not happen all the time; but occurs may be 70 to 80 % of the time): when I shift gears and let the clutch go, I hear a clunk or thud or "thunk" from the rear (probably from somewhere in the vicinity of rear axle). If I release the clutch quickly, the sound is loud. If I release the clutch very slowly (slipping the clutch), I still hear the clunk.
I do not know if this is related or not but when the car is stationary and I shift gears, I hear some clicking noises from the rear (I think the sound comes from the same area).
My final question is directed to those who had noisy (clicking, chattering) driver's seat belt tensioner and had the tensioner replaced. Does the replacement of the tensioner solve the problem or the new tensioner is noisy like the original one?
I asked BMWNA about these problems (bmwusa.com Owner's Circle) about ten days ago. Even though they claim that they respond in one day, I have not heard from them yet.
Thank you in advance to those who respond.
P.S. Silver Nubira is my wife's car!
The second place to check is with the E-46 owners on
Bimmer.org. I have an E-36, and I've found the board quite helpful. If this is a common problem, odds are high that someone there will have some experience, and, hopefully, an answer for you....good luck
Most car companies have code letters for their models. For instance, the Golf/Jetta/New Beetle are built on what VW calls the A4 chassis. Camaros anf Firebirds ride on the F-Body chassis by GM, etc.
bnormann
Maintenance & epair Message Board
Im not thrilled with the long throw shifter anyway, so Im going to probably take it out and get a UUC motorwerks short shifter and maybe at that time, remove the little switch too. Hope you get your baby all sorted out.
DanF
Dont understand how dealer says its the way you drive, think glass especially windshields has to be by law a certain thickness with a plastic layer inbetween (the "safety" feature so it wont shatter in a million pieces).
Dont know of anyone else having similar problems, probably just being at the wrong place at the wrong time.. Hope this goes away for you..
Ive treated all my glass for years with a product called Rain-X which fills in all the microscopic pores in glass with a film that makes the surface very slick so alot of things that heretofore would smack the glass hard, may bounce off instead. Maybe this will help somewhat. It doesnt build up or make the glass less clear, does wonders on raindrops, at speed they just shear off and you dont have to use wipers as much..Available everywhere, I saw it at a Raleys/Bel-Air Supermarket.
Good luck!
DanF
Later
-Chris
PS. I really really don't think that BMW have flexing frames to make the windshield break.. This is by far the most rigid car I ever owned, and I but a new one every year.
Car is great other than having to have done a complete brake job front and rear at 20k, and the dealer having repaired a floor leak(airbag recall) and ball joints due to sqeaking.
I complained to BMW Canada about the brakes and got the usual explanation about driving habits etc etc which I don't buy.
I have owned 5 volvo's and never had to do a complete brake job as described with such short service.
When having my other car (Volvo 850) serviced at an independant garage who also does a lot of BMW work, they explained the dealers don't want any complaints if they resurface so they figure if you own a bimmer you can pay the extra coin. Mechanic also say's BMW's are known for ball joint problems....comments.....other than that great vehicle everything BMW promises
Have anyone out there been experiencing this problem?
The Harmon Kardon system doesn't even come close to the clarity and range of the factory-installed Bose system in my previous car, a Nissan Maxima. The BMW system lacks midrange precision and has a truly horrible bass range. Even my old Toyota Corolla in college sounded better. We've all paid a pretty penny for our BMWs -- I wish they had put as much effort into the sound system as they have into the superb driving experience.
I need some advices...
Thanks,Stanley
Thanks,Stanley
Has anyone experienced this problem and does any one think I might have a shot at getting BMW to take care of the expense? Otherwise its a great machine.
I wonder if this "rear clunk" is generated by by some problem in the rear suspension since when one engages the clutch, rear suspension is subjected to a sudden loading.
I have not taken the car to my dealer yet (hoping that the noise will disappear by itself!). But based on my previous experience with a local Toyota dealer I know that service advisors or managers are generally not interested in work that reqire locating noises, etc. because usually they are not reimbursed for the time they spend for locating the cause of such noises. Instead, they turn deaf and cannot hear noises or they say that such noises are "normal."
-Both of the front and rear brakes have been replaced (pads and rotors), as recommended by the dealer shop after inspection, with the odometer read at around 34K. That was unbelievable!
-Car would not start. It started out randomly/rarely months ago and gradually became more frequently. The dealer shop replaced the "control box" in the instrument cluster and also found a "loose cable that was not making proper contact". After this fix, the car would start up all the time, but the odometer read about 8K miles less then when I brought the car into the shop. Now, the car has just been fixed. They told me that there was a bulletin from the manufacturer stating that if the battery is disconnected the odometer reading will reduce, and it will keeps on reducing each time the battery is disconnected, until it reaches 0 miles (I figured they must have disconnected the battery when they replaced the "control box"). They also told me that the bulletin does describe necessary steps to re-program the odometer (something like that) so that it won't change the next time the battery is disconnected. Seems like a power loss would cause the odometer to go beserk, on cars that have not been serviced for such a bulletin.
Have anyone out there ever heard of such a thing? If indeed there is a bulletin, why that has not been a "recall" as it sounds like a serious defect problem? Or did the service advisor bullsh*t me? The "BMW Experience" I've had is all but wonderful.
I am concerned about the automatic transmission though. When the car first started in
cold weather, I typically drive with caution and keep a light touch on the gas.
1st and 2nd gear seem to shift around 2K RPMs but when it comes time to go from
3rd to D it won't shift until the RPM have reached about 3500. This seems really high
Even if I let off the gas doing 35 MPH it will not shift into the higher gears.
Is this a feature or a problem? WHen the car warms up the shifting still seems hard
from 3rd to D but not at low speeds. I think the car is still under factory warranty.
It's in service date in 6/97 and is has 35K miles.
Has anyone had a similar experience with their car and what did you do?
tom
-Chris
For instance, in San Francisco certain Fords need new brake pads every 6 weeks....but they are taxicabs and the hills are steep and the drivers aggressive, so there you go....perfect explanation.
Another case--some people burn out clutches, others (like me) have never burned out a clutch in their lives. How is that explained?
This is NOT to say that BMWs don't have chronic problems...some models definitely have...but it's not something that a car magazine is likely to discover...at best, they only drive one or two cars of a certain type, and they aren't about to make a sweeping generalization based on that slim evidence.
It would be better to look at, say, Road and Track's owner surveys....if say, 10% of the owners of 528s reported a transmission glitch, that would definitely point to something. But if 2% do, I wouldn't think that is an indication of a chronic problem.
More like a statistical probability....on every car made by humans, some are going to screw up...it is inevitable as death and taxes.
Would you know if there's any difference on brakes between your 95 and the new-body style (99 and later) models? If there is a difference, or if you don't know, wouldn't it be unfair to make such comparison? It seems difficult for me to be convinced that it is "driving habit" that's causing the brakes to get worn out so soon. Personally, I don't think my driving habit has really changed for the past 15+ years - if anything, I am driving much less aggressive now that I am older than years ago. My other car, a 95 Mazda Millenia S (supercharged) has more than 50K miles yet still no sign of needing new brakes. My previous cars, Nissan Maxima and Acura Legend, never needed new brakes (not even pads) before 50K.
To rascal8,
True. After all, this is a "BMW 3-Series (E46) Problem" forum, and so if you don't find people complain about their car's problems here I am not sure what else you would find them. However, keep in mind that not ALL people who have problems would go in here and post them up or share them with us. Statistics should not exist here. Thus, understandably, the problems I have had with my car might be one-owner specific. That's so unfortunate!
Question for all: How do they actually survey and/or evaluate cars? Do they actually take on many different kinds of roads, under all kinds of weather, traffic, loadings, etc.? Do they actually drive stop-and-go, shift-and-park, all the stuff an ordinary driver would have to go through everyday? Do they actually do all that over and over again, racking the mileage well pass 30K or so? Lastly, can you be so sure that they are not biased, eventhough they claim that they are not? (yeah, you'd probably say that...they better not b/c their reputation is on the line!). What would be a better evaluator then yourself, the one who's actually owning and driving the car everyday?
-Chris
