Buick Rainier, Chevy TrailBlazer, GMC Envoy
1228229231233234352
    Every automatic electric trailer brake controller I have ever wired had the following connections:
    +12VDC
    Brake light switch (to activate trailer brakes)
    Back up light switch (to keep trailer brakes off when backing)
    Output wire to trailer brakes
    Return (ground)
    I assume that the wire called stop/turn lamps goes to the brake light switch, but why you would want it connected to the turn signals also escapes me.
    The one that says trailer connector I assume is the output to the trailer brakes so it would go to the trailer connector for that purpose. Remember that the trailer brakes are not applied fully when you press the brake pedal but are applied gradually over a set time period, since the trailer brakes would lock up if applied fully. The time period and the braking force are usually adjustable on most controllers so you can tailor it for the weight of the trailer your towing.
    Many also have a button on the front that will fully apply the trailer brakes when pushed. This is for emergency or test only. I used to test the trailer brakes by just getting the trailer moving very slowly and then pressing the button. When my head hit the steering wheel I knew the brakes were working (just kidding about the steering wheel).
  • tblazedtblazed Member Posts: 945
    Just started noticing these new Shell ads that claim you will get better mileage using their gas. Anyone using this stuff notice any difference? Around here the Shells, Exxons Chevrons etc. typically run 2-10¢ higher than the typical WalMart-Sams-QuikTrip-Racetrac lower cost stations. It would have to be a pretty significant boost in MPG to make up the cost difference. Those owners of triplets with the DIC ought to see a difference right away if the claim is true.
  • lurker01lurker01 Member Posts: 103
    <begin soap box mode>
    They all buy it from the same pipeline, the same refinery. The ONLY difference is the "additives" they dump in the truck before they fill up and deliver it.
    I once heard a guy say he would never buy ARCO gas because they water it down... Water, eh? If I had a truck that would run on water, I'd be a zillionaire. Unfortunatly, my Envoy still runs on plain old 'watered down' ARCO regular.
    Gas is a commodity people. It should be government regulated, like electricity. It's not like you have a choice in whether you buy it or not. The price is all supply side economics, because the demand is constant. Ever notice how it goes up in price real fast when there is 'speculation' that there *could* be a shortage, but when the shortage never happens, does the price go back down? Do we get a refund? No. We just eat it and the oil companies get even fatter.
    Vote with your dollar. Buy the cheapest gas you can. Put those idiots with their Techron, Superite, Whateveron crap out of business.
    </end soap box mode>
  • njohnw4njohnw4 Member Posts: 4
    I got my 2003 North Face Trailblazer a month ago and have been reading all 12000 posts. I have learned many things about the triplets and hope I don't have any of the common problems.
  • twinrottstwinrotts Member Posts: 161
    I stopped by my Chevy dealer after pulling down the harness. He was not certain how to wire either as they have never installed a controller in a TB.
    I am amazed he took so much time with me but he did. He went to his computer and stared search electrical schematics. Could not find exactly what he was looking for but gave me a recommendation based on his best guess and general knowledge.
    Now that I am done, I think he was correct. As the Hot and Grnd were clearly ided on the Chevy harness, that left only two wires to get right. He recommended I use the darker of the 2 blue TB wires as the brake circuit. It was a gauge equal to the hot lead and much heavier than the light blue unused wire.
    He then popped my hood and opened the fuse box to make sure that the aux brake fuse was in place. It was.
    He also showed me where to connect the red hot lead available under the hood to keep 12V flowing to the trailer for powering 12V accessories while in transit ie propane/12V refrigerator.
    BTW: For those interested, on the TB brake circuit: Orange is hot, black is grnd, darker blue is brakes, light blue is for the stop light
    That's why I asked specifically if anyone had tried the Shell "reformulated" for higher mileage stuff, since their new ad campaign came out. I know the base gasoline is the same and there are minimum injector, intake valve, and combustion chamber deposit cleaner additives mandated by the EPA. I wanted to know isf anyone had actually verified Shell's claims and if they noticed any significant mileage gain in their triplet. I personally always buy the cheapest price at the highest volume stations.
  • xntrickxntrick Member Posts: 27
    sorry if this has been discussed but I did do a search though perhaps I didn't use the proper terminology? Upon starting in the morning (usually), I will hear a "clack, clack" seemingly originating in the steering column?? Any comments or suggestions.
    regards,
    Les Akins
    Upon cold start maybe you are hearing the tachometer and gages resetting themselves? Mine makes a noise when the gages set themselves to "0" just before I start the engine.
    I always hear a one or two engine knocks when I restart the engine when it's hot. Sounds like an uncontrolled detonation in a cylinder or two just as it starts and I release the key. A friend says his TB his does that too. In fact he's the one that first pointed it out to me . He had that checked at the dealer - "normal for this model" is what he was told. It's very consistant. I don't like the sound of it either.
    See it here:
    First Drive: 2004 GMC Envoy XUV - The Sky's the Limit
    Talk about it in 2004 Envoy XUV.
    this is louder and sounds electrical. It has just started after 20,000 miles and I've not heard it before this. This does not occur with every start up, mostly in the morning.
    Sorry for editing in another line to the orig post. I realized you said cold startup.
    Does the noise happen when the gages reset? Some people including my friend with a TB have had the inst cluster get noisy after 20K mi or so. Also there's an interlock solenoid inside the steering column that keeps you from turning the key to OFF and removing it unless the shift is in PARK. You normally shouldn't notice it. Maybe your noise has something to do with that.
  • scottc454scottc454 Member Posts: 356
    Going against my natural response of assuming the new Shell campaign is a crock:
    I just read through an article about the new Shell stuff. It said it could add 125 miles per year to a vehicle driven 12500 miles per year.
    That equates to a 1% increase in gas mileage.
    1% is way too small to try and verify.
    If I average 18mpg, that'd take it to 18.18.
    I saw that too, on Shell's web site a while ago. The typical 2¢ minimum difference (usually more) in price between the typical Shell gas price and the cheaper stuff down the street would not pay for the 1% claimed difference in MPG - so much for that. No miracle juice for the triplets. I see more than 1% variance between tanks of gas. Sam's gas here is usually 10-12¢/gal cheaper than the brand-names. And it burns good too.
  • mmcgee1mmcgee1 Member Posts: 3
    Has anyone installed the GM engine block heater on a triplet? I see GM sells as an accessary and would like to install one before next winter. Just curious if it is difficult to install. Any help would be appreciated.
  • crosley4crosley4 Member Posts: 295
    You can do more for fuel mileage by keeping your tires properly aired up, the fuel, air filters clean/replaced
    and do not forget the most important thing.... control your right foot on the gas pedal. if that is the foot you use. :)
  • duffster03duffster03 Member Posts: 3
    After reading some of the postings and noticing some 1-2 intermittent shifting shutter, I decided to check my trans. Drove it home 40min on a 90 deg day, parked it on a level, and the fluid level was on the cold cross hatches. The fluid was brownish and smelt burned. My vehicle has the tow package and should be able to haul to 6k lbs the most it has ever done is 1500 lbs for 100 miles. I based on the posting looked at the cooling lines routing, and it's sitting on top of the catalytic. It's my understanding that the catalytic can turn cherry red when sitting in traffic. That's got to put the temp at around 1k F. It's going to the dealer Monday for diagnostic. Has anyone else had this pleasure? Does anybody have a fix? Seems that the dealer doesn't want to admit that's the cause. I'd rather have it be that then some internal tranny problem that my linger after warranty.
    When I first got my Envoy the best it would do is 14.7 Hiway driving gingerly. Recently it's been getting 18 Hiway and I can goose it some. I attribute this to the warmer temperatures and the fact that I started using Red Line oil in the whole 2WD system the vehicle is 4WD (also changed the rear end fluid Red Line). The vehicle has the towing package which means that it has a 4:10 rear, not easy on gas.
  • dindakdindak Member Posts: 6,632
    My parents are just about to pull the trigger on either a TB or an Envoy. Aside from the cosmetics is there any big difference betewwn the two. They said they were told there are some kind of air shocks on the Envoy that make it a smoother ride.
    Any comments would be appreciated.
    "air shocks on the Envoy that make it a smoother ride." On SOME Envoys. Thats the autolevelling suspenson and it's an option. Mechanically they are pretty much identical except for some options. Other than that, how many Chevy dealers vs GMC dealers do you have around for service related issues? I have a Trailblazer and actually prefer the plain no-frills interior. I also prefer the front end of the TB. It doesn't resemble anything else on the road. I always have to look for the GMC logo when I see an Envoy from a distance. The front styling looks kinda like a darn FORD to me. And I prefer the tail light styling on the TB too. But everyone has different tastes and needs, and that's the great thing about the choices available.
  • acl1966acl1966 Member Posts: 24
    I haven't posted on this board in a long time but I do read it often. Had the recall done on my '02 Envoy SLT on Monday. Also had the dealer check a problem I encountered since last winter. There were some posts back then with the same problem. When starting the vehicle after sitting for over 24 hours, I got a popping sound from the radio's rear speakers. It was at first intermittent but got worse during the last two months. If the vehicle sat more than two days, the battery would hardly turn over the engine and the DIC lost its programming. A load test was done on the battery and it failed. New battery installed under warranty. The old battery discharging caused the speakers to make the popping noise. The problem has been fixed. This was not the vehicle's fault, but mine. The vehicle doesn't get driven much (purchased 9/6/01, built 8/24/01)and sits for long periods of time in the garage. It's a great vehicle, with the 1SK package and has been trouble free. The old battery never gave up entirely but was on its way out. Now I know if I hear that popping noise from the radio speakers at startup in the future, that's the warning sign that the battery will not hold a charge. Also, I saw two 2004 Envoy SLT's at the dealer. The factory running boards have been cheapened. The rubber grip strips on top have been deleted. Looks very cheap. P.S., I have a company car which I drive every day to work, that's why the Envoy doesn't get used much.
    There is one Chev dealer and one GMC dealer where they live so I don't think service is an issue. I like the TB better in terms of looks also, but they seem to think the Envoy looks more upscale. Thanx for the post!
  • aldan93aldan93 Member Posts: 202
    I was told by just changing the diffy fluid in front and read to synthetic, would also help with gas mileage, please care to comment, what kind is best?
    Just curious is anyone using Mobil 1? I see no other advantage since all my other cars were fine with just plain 5W30, 7 quarts at 3.99+ a quart seems excessive, or do you go 5000 between changes with the synthetic, I go the basic 3k with my valvoline 5W30.
  • allenrallenr Member Posts: 89
    The driver&#146;s seat in my 02 Bravada got damage somehow. The bottom center panel has a bad spot. Looking for the best way to get it repaired. Could there be a part number for just the seat bottom cover? Or should I take it to an upholstery shop?
    Allen
  • gam2gam2 Member Posts: 316
    The diffs already have synthetics, so why bother?
    GAM
    I would find it hard if not impossible to believe that any reduction in coefficient of friction with synthetic gear oil would make any measurable difference in gas mileage. Synthetics are best for very high temperature situations where regular oil would oxidize or fail. Been down the Mobil 1, Amzoil, etc. synthetic road (was even an Amzoil dealer for a while in '82-'88 just so I could get the stuff cheaper) and any perceived difference simply did not justify the additional cost. The engine oil gets dirty just as fast regardless. I use Quaker State 10W-30 (now supposedly with newer friction reducers) and change it every 4 months. I also enrolled my TB in Quaker State's 10 year 250,000 mile engine warranty. With the current "SL" API rating that all quality motor oils now have, plus the 7-qt capacity of the 4.2, the least of my concerns is breaking down the engine oil from excessive heat. My 2¢ worth.
  • nuyorkahnuyorkah Member Posts: 100
    "The driver&#146;s seat in my 02 Bravada got damage somehow. The bottom center panel has a bad spot. Looking for the best way to get it repaired. Could there be a part number for just the seat bottom cover? Or should I take it to an upholstery shop?"
    Yes to both. Call your Dealers parts dept. and price the bottom cushion seat cover and also bring it to an upholstery shop to get an estimate. The cover from the Dealer will be a few hundred dollars. Have your VIN# handy when you call the Dealer. You can also ask the Dealer(Service Dept.)if they have a local upholstery shop that they deal with.
  • bobn737bobn737 Member Posts: 1
    I have had my 2002 GMC Envoy 4x4 for a year and a half now. Much better than my former Grand Cheorkee.
    The 270hp I6 is the best feature. This engine keeps pulling at all rpm ranges. And it is almost as smooth as the engine on my BMW 330i. Even at the top of Colorado's Monarch Pass 11000', (13000' density altitde due to warm temps,) there was power to spare going up the steep grades. Driving through CO and UT in warm weather/high altitde (density altitudes around 8000') the highway milage is around 23mpg doing 70mph. Down in Dallas at low altitude, I get around 20 mpg on the highway, 18 in the city.
    The Load Leveling Air Suspension is a must have! It makes the vehicle "tight" when road manuevering. Without it (such as on the Trailblazer) there is too much body lean. Best of all, it absorbs punishing dirt roads and rough trails.
    The 4x4 system works great as well. It is a real 4x4 system with low gearing, which works better than the all wheel drive systems of other vehicles. It pulled me through a deep rutted muddy double track on top of Grand Mesa, 10600.' The "Auto" function worked wonders in our last ice storm. I left all the other cars behind me, including AWD [non-permissible content removed] SUVs, when the light turned green. And the ABS brakes worked well on ice also.
    My only wish is that the Envoy had another inch or two of clearance. I bottomed out (barely) on a double track trail in Moab, UT.
    And no, I am not a GM salesman or employee.....just a happy mountain biking adventurer.
    Anyone know if the std GM load leveling system ie Envoy or Bravada, can be installed in the TB.
    Better yet how about a system that allows you to lower or raise the truck depending on driving conditions???
  • n7donn7don Member Posts: 188
    About to take delivery of an '03 Envoy and considering a Tekonsha Prodigy controller. I've noticed Tekonsha has an option for GM '03 direct wiring hookup. Anyone with personal experience with this hookup? I've installed a couple controllers on other vehicles and have had to "hunt" for the correct wire that actuates the brake lights.
  • hardhawkhardhawk Member Posts: 702
    To the poster whose parents are considering a TB or Envoy. I say either one is a winner. I chose the Envoy because my wife & I think it looks a lot more upscale than the TB and had some equipment that was not available on the TB. That being said, there are many who prefer the looks of the TB over the Envoy. That's fine with me and that's why they make both. The looks, interior luxury, and additional equipment were what did it for us in favor of the Envoy. Which ever one your parents choose, they will get a fine vehicle. Of course, if you really want to confuse them, tell them to wait for the new Buick Ranier due out this fall!
  • cparise1cparise1 Member Posts: 109
    Envoy owner. Mine is 13 months since new, Envoy XL SLT May '02 build date.
    IMHO best features are ride (I recommend ECAS), Bose, auto climate control, power, and handling. After more than a year of ownership and 21K miles it looks inside and out like it was just driven out of the show room. Leather isn't worn a bit, but I treat it monthly.
    In the one Wisconsin winter I've driven it, its been unstoppable and extremely sure footed. Only broke the tires loose once, but I drive conservatively when conditions are poor.
    Happy Motoring
    Chris
  • accountstudentaccountstudent Member Posts: 11
    After owning our 03 TB LS V-6 for 2.5 months I got the chance to drive father in-law's new 03 Mountaineer V-8 AWD and have the following observations:
    1. The inline 6 of the TB has less low end but much more top-end power than the V-8 Mercury.
    2. The TB has a marginally smoother ride.
    3. TB has more wind noise on highway but much less tire and engine howl.
    4. Mountaineer has slightly more cargo space but TB has more front and rear passenger space.
    5. Mercury lacks low range; TB has 2, AWD, and full-time high and low 4WD.
    Conclusion: TB has an overall more solid feel and imho looks much better also. I feel like we made the right choice. In 5000 miles we have only had to get a faulty A/C switch replaced(hopefully no more A/C problems like I have read here about).
    Great forum.
    Adam
  • ross1962ross1962 Member Posts: 229
    "...or do you go 5000 between changes with the synthetic, I go the basic 3k with my valvoline 5W30. "
    You can go a lot more than 5K with the 4.2L. It's 10K max under normal driving conditions. I drive it hard, so I change it around 6-7K.
  • mdeymdey Member Posts: 90
    Sometimes I stray for a week or so, but I thought I would throw in my thoughts this subject.
    First, financing a warranty into your loan is a very bad idea for the reason that one of our friends has experienced. If the company fails, you own a warranty that is worthless. Compound that by the fact that you may be paying $10 to $20 more a month in your car payment, and writing the monthly car payment check can make your blood boil. This is why many states have banned financing warranties and insurance policies when enacting predatory lending legislation.
    My personal opinion is don't buy extended warranties. Instead, self insure. Think about it and do the math. 1). If you keep you car four years, you are spending a minimum of $250 every year to extend the warranty on your car for 65,000 miles. 2). Looking at it differently, you are spending more like $400 a year for the last 2.5 years to extend your warranty 65,000 miles. 3). And the insurance company holds your money for 1.5 years until your original warranty expires. Even if you wait a year or more to buy the extended warranty, 1 and 2 still apply.
    Or, you could just bank that money and save it for the odd major repair bill. I have owned cars for 24 years, and I have never written a check for a repair on a car in excess of $1,000. The tops for me was $800 for brakes on all four wheels, including rotors and drums, on a 4x4. And that was normal maintenance considering the truck had 80,000 miles on it at the time. I have never lost an engine or transmission. It is called maintenance, and if you don't do it, you should. Maintenance is cheaper than repair bills AND warranties.
    Exit soapbox.
    Ok, now that I have vented about warranties, I may have an out-of-warranty repair facing me. My TB LS has 39,000 miles on it and in the last couple of weeks it has started behaving like one of of ignition coils has failed. Has anyone else experienced that particular problem?
    One good reason I prefer to keep my oil changed ahead of schedule and berfore it gets thick and turns black:
    "Engine oil has a major impact upon the camshaft actuation system's responsiveness. Oil temperature, viscosity, and quality can slow and/or inhibit the phaser's ability to reach a desired phase angle."
    This is from the troubleshooting section in the service manual concerning malfunction of the exhaust cam phaser system.
     mdey if you were near D-FW I could loan you a spare coil for testing. I just bought a spare ignition coil off eBay for test purposes just in case something happens like you describe. email me for details. Those are about $80 ea. list, $45 best discounted new price I have found.
  • kpp14kpp14 Member Posts: 62
    I own a April 2002 blk slt Envoy with 46,000 km and no major complaints about anything.
    bobn737....good story
    cparise1...don't you think the leather looks better worn in and a bit wrinkled like a leather jacket?
    One feature I never use is those two small compartments to the left and right of the rear cargo hold. Does anyone know how to put hinges on them to make them more functional and easy to use?
    I have a old (Bell) X and Y band radar detector which I never use but works very well(don't speed to much and never lead the pack at high speeds). We got rid of photo radar (they called it a big money grab and unconstitutional). Our cops use lasers. A lone cop on the side of the road with a 50 ft extent ion cord to his cruiser in the bushes. If you can see a Laser or photo radar they can see you..and by then its pay up time.
    Where are we at with remote detection devices for tell-tale laser signals? My old x and k band was good for several KM.
  • quickdtooquickdtoo Member Posts: 266
    I've had 2 coil modules replaced, 1 @ 5k miles and another @ 12k miles. I now carry a spare, they're easy to replace and cost less than $50 thru gmpartsdirect.com Part#12568062 sells for $42.23 plus about $7 shipping...When they fail, there's no doubt that you're running on 5 cylinders. The cruise control becomes inoperative and the check engine lamp lights up, and you loose a LOT of power. Haven't had to replace one since I bought a spare, murphy's law probably dictates I won't have another failure because I do have a spare! But I'm ready....tim
  • iexplore2000iexplore2000 Member Posts: 237
    Hey Everyone,
    Well... Just wanted to pass along to everyone my critiques of the extended model Trailblazer LT. I was asked to come along with my family from Michigan to Omaha Nebraska for a family reunion this weekend (primarily to drive one of the SUV's).
    My aunt and myself are both triplet owners for the second time around. She just bought a new Chevy Trailblazer LT XL (to replace her shorter model 02 LTZ) last month. Additionally, I bought my Envoy SLT XL V-8 last month as well. We decided to take her Trailblazer along with my father's 02 Yukon Denali to make the trip. After driving 700+ miles, I wanted to share some of my critiques (both good and bad) about the experience.
    With both vehicles complete loaded with luggage and passengers, we set out on our journey without any problems (initially). With me leading the way (b/c of my radar detector), we cruised along running a steady 75 mph. The ride was wonderful.. at 3am, we were essentially king of the road! We ran into a couple of speeders along the way, therefore my dad decided to increase speed to keep up with them! Well.. this is where we encountered our first dilemma. Once I hit the gas and got her up to about 85 mph, it sounded like we were loosing a luggage rack on top of the vehicle. The sound had been increasing with speed. So, I phoned my dad and asked him to slow down to take a look as I drove past. He IMMEDIATELY yelled for us to PULL OVER! Turns out the rear high-mount stop light housing (held on by double-stick tape and a few screws) had begun to dismantle and was two seconds away from blowing off completely! At this point, all of the bolts (with the exception of one) had broken off the deflector unit and looks to be unrepairable. To say the least, we had to break off the last piece and cut the wire to get the piece to come completely off the vehicle.
    We continued our journey motoring along at a fairly good rate of speed. During most of the trip (not resetting the DIC), we averaged about 17.2 mpg fully loaded with luggage and passengers. No one complained at all about seat comfort, and the family kids were very comfortable watching DVD's in the rear.
    During the trip, I noticed that the 6 Cylinder engine seems to bog down quite a bit with a full load of passengers. Even through the hills of Nebraska, I had to kick her out of cruise control because when making even the slightest inclines, the engine would become taxed and downshift into a higher gear causing the RPM's to surge. During a pit stop, I asked my father about the performance of his Denali (considering that he had more weight and adult passengers riding) and he mentioned that there was plenty of power on tap. I kinda figured that he had no issues at all because he could easily blow by us in a heartbeat while I had to floor the TB to keep up with him. I was amazed because truthfully, the Trail Blazer had a hard time keeping up with other vehicles on the road that were attempting to run 75 - 85 mph? Now, I do think that as a former owner of the non-extended models, I felt that the 6 cylinder ran fairly well, but I guess teh extra weight makes a huge difference?
    As I am still in Omaha today, I made a quick journey out to the mall (alone) in the SUV and with the A/C running, the engine still feels mighty sluggish? At a stop light, I can floor the throttle and it lazily pulls away from the light? I do know that she does have the 3.42 rear end in her Trail Blazer, I have the 3.73 and the V-8 in my Envoy.
    Additionally, I think that for those who are stuck between deciding whether or not to get a TB or Envoy, the ECAS (air suspension) makes a huge difference! In addition to my aunts TB, we passed several along the way that were not sitting level, showing that the weight of the passengers and/or luggage made a difference in the vehicles ride height. I could immediately spot an Envoy or Bravada with the ECAS on the road because it did not "sag" in the rear. Once, we passed a guy with an Envoy XL pulling a trailer and loaded with passengers and the Envoy appeared to be very level. Same applies to my father's Denali, it stayed level at all times. Just food for thought for those who may tow items.
    Lastly, the TB's BF Good Rich tires are awesome! I wish that I could add them to my Envoy! The vehicle is not as smooth riding as my Envoy, but the BF Good Rich tires handle a LOT better than the Micheln Cross Terrain tires.
    At any rate, I guess we will make our next journey with my Envoy XL V-8 to compare the difference between the two in terms of overall performance on the XL models. But.. from my initial impressions, the 6 cylinder may be perfect for the regular length models, but i think that the added V-8 power definitely helps the XL models in terms of improving overall performance. All of this for a price of course, while I averaged 17.2 mpg, my father average 14 mpg to keep all of that power on tap!
    Just my initial impressions, love both vehicles but I honestly cannot wait to get home to drive my Envoy!
    IExplore2000
    PS: Does anyone have anything to report concerning long trips in their V-8 models? Would be interested to hear your thoughts!
  • dshepherd3dshepherd3 Member Posts: 194
    I think you will find these are covered for at least 50k because of emissions considerations, especially here in NYS with the Calif. system, check you warranty book here.
    Well I ate my own words, in NYS, we have the Calif emissions but federal coverage, which is 2/24 and 8/80 on the cat and pcm only.
    Warranty coverage is moot when you're miles from any service and on vacation or a weekend away! Mine were replaced under warranty but at no convenience to me. At least I can swap out the bad one until I can get in for service then swap it back at MY convenience! tim
  • celebrimborcelebrimbor Member Posts: 10
    I need new tires. Does anyone have any experience with the Michelin Cross Terrain SUV tires on the triplets? Particularly interested in how they do in snow & sloppy conditions.
    Big premium over the Goodriches and want to make sure they are worth it.
  • tmac8tmac8 Member Posts: 32
    Hi all. Had my 2002 Envoy in last week for the anti-theft recall, and the service manager told me they upgraded the computers to the latest 2003 specs. Sounds good enough, but it seemed to excellerate better before the update. Not a big difference, but noticeable. Just curious if this has been noticed by anyone else who had the computer updates. Think I'll call tomorrow to see if they can change it back. Just saw the GMC commercial with the 2004 XUV with the sliding roof. Definitely unique.
    2002 Envoy SLT here. Owned almost 2 years and 25,000 miles on the Michelins. 2 winters with plenty of snow. Had absolutely zero problem getting through the snow, slush and rain. In fact, I had planned on getting a separate set of wheels and winter tires but found I didn't need them. Quiet ride too. Go to the Tire Rack website and read the reviews on the Cross Terrain as compared to the Goodrich tires. There is quite a difference. Mine have worn evenly and well over the miles and years. I recommend them highly.
    Thanks for the thoughts. They actually want to get an 03 GM Canada is clearing them out now with 0-60 and $1000 extra cash back. The Bravada is a bit out of $$ range for them.
    They are not supposed to go in and do PCM updates unless there is a specific problem to be addressed. It clearly states that in the GM service manual. Sometimes new problems or undesirable effects will result. Sounds to me like the service dep't was looking for things to do so they could log more labor time. I also have been told that once the old programming is overwritten they can't go back. I had good results when I had mine reprogrammed back in Feb because I had several issues specific to the updates. It does seem to idle at a very slightly lower RPM now though, and results in a little more vibration at idle. A friend with an otherwise identical TB (except for the rear gear ratio difference) had his done and he hates the way it runs now.
    "cparise1...don't you think the leather looks better worn in and a bit wrinkled like a leather jacket?"
    It depends on exactly what it will look like at the time, but it looks like its going to be a very graceful transition from new looking to a worn in appearance. I will be happy with the leather jacket look and feel too. So for me, it looks like getting the leather interior was a good choice. My wife still prefers cloth no matter what.
    Happy Motoring,
    Chris
  • elevatorguyelevatorguy Member Posts: 87
    Anyone here using an EGR bug deflector? If so, which model and do you like it? I am looking for a no-drill unit that doesn't use the rubber bumpers on the hood either. I like the style of the EGR shields and I am going to order their window visors. On their website, they show pictures of 4 "different" bug deflectors. 3 of them look exactly the same to me. By the way, they pictures of the bug guards on a TrailBlazer and it looks SHARP. If anyone is interested, go to www.egrgroup.com and have a look. If anyone has an EGR product or knows anything about them, please post back here.
    Thanks in advance,
    Todd
