Visitor Agreement.
-mike
Just to stay on topic, I saw a Red WRX Sedan ('04) in a dealer's showroom on Long Island tonight. Very sharp color.
9/21...ok, just keep reminding me:)
I've only noticed this once on my first Outback a couple of years ago, after making a hard turn in a confined space. Everything was back to normal a couple hours later.
Craig
Rob
I drove into work from NJ actually, took me 1/4 the time it normally does flew right into wall-street w/o a problem.
We'll keep reminding you about the 21st
And to keep it on topic, drove my SVX to work last thurs
-mike
B
Ladnek
-mike
-mike
Like I said a few posts back, I have seen this before, but it was never permanent.
Craig
Don
I guess I probably don't do enough hard turns or U turns to notice this problem.
Craig
I am not sure that ~10 degrees of variation is "little". The dealer (Flemington in NJ) was much more helpful and agreed to install aftermarket bushings at no cost if I provided the bushings. Irvine Subaru actually stocks and sells the bushings for $25.
Anyone get cold steam out their vents when using the AC without the recirc off?
Do your rear tires wear faster than the fronts?
Should I be posting in the repair/maint. section instead of here?
Don
I also had my A/C freeze up recently on a hot and humid day, and was wondering if this is worth taking in for service?
Paul
Yes, you should get your A/C checked if it's freezing up. I believe there was a TSB from Subaru on this for '02 models.
Subaru says that a "little movement is normal".
Definitely worth a try. Do you know for a fact that the aftermarket bushings are more rigid?
I bet it's more than 10deg if it's bothering you. 10deg is not a whole lot (1/36 of the whole wheel).
This (condenstation) has happened on every car I have owned with AC. It's because of the humidity in the outside air.
I'll answer this in the context of my other Subarus, since my WRX only has 3K on it. Yes, I notice that the tires wear differently front to back (can't say which is more), but it should not be an issue if you rotate every 7500 miles as called for in the owner's manual. If you stick to this schedule, the tires should be pretty evenly worn by the time you have to replace them.
A local alignment speciality shop told me that the wider the tires, the more pronounced the effect. He's seen several WRXs with wide tires and the steering wheel well beyond 10 degrees off center.
Ken
-juice
Try taking a U-turn and then drive straight. See if your steering wheel is centered.
It doesn't happen with every Subie, but a lot of them.
Ken
Paul
-juice
probably the threads on your tires countered the quirk
-Dave
Speak with Diane (Svc Mgr) if you still have concerns. Yes, you can also post in Subaru Crew: Maint. Patti from SoA checks these boards and knows Diane. You're in good hands at Flemington IMHO.
-Dennis
Based on what I've read, between my previous adjustments, this ought to take me up to 280-300hp range.. muaahahaha >:-)
-akwrx
I usually do the equivalent of a double-clutch, and it slides in.
Craig
Make: SUBARU Model: IMPREZA Year: 2002
(TSB) Service Bulletin Number: 10-72-02
Summary Description: COUNTERMEASURE TO PREVENT ICING IN THE EVAPORATOR ON AIR CONDITIONED VEHICLES
There is a possibility that icing could occur in the evaporator core of air conditioned equipped Impreza vehicles. During operation under warm, high humidity conditions the customer would notice a diminished output of air from the dash vents causing the cabin temperature to rise.
Also, this PDF doc from Subaru, written for use by Subaru mechanics, goes into greater detail about this A/C problem. Read PAGE 2: "Evaporator Icing Countermeasure."
-tom
Thank you very much, that information is very helpful!
Paul
(ps, I ordered from worldoneperformance.com they had great prices and great customer service -- if you email them directly, they might be able to give you a better deal than published on their website.)
-Dave
Now if you run out of time while doing the installation put in the down pipe first and see what that does, then remove it and put in the uppipe, followed by both okay? just kidding about the partial installations but please do post your results.
Don
Going to do the install myself... waiting until the uppipe gets here next week to just do it all in one shot. The numbers I've seen thrown around are +10whp for the uppipe, plus it should also help the spool greatly, and TurboXS claims +26whp for the turboback. It's certainly cheaper to just do the downpipe, I was convinced by the guys on clubwrx to do the uppipe too while I'm working on the downpipe, you have to remove almost all the same parts anyhow, and I wanted to do the full TurboXS kit instead of just a downpipe.
stoner420: You should replace all the gaskets when putting on a new exhaust. They're only a couple bucks apiece from any of the Subaru wholesaler sites (www.subaruwrxparts.com or www.subaruparts.com) and are cheap insurance from having to re-do the entire install because you have a leaking exhaust.
get all gaskets, new, don't skim...
well, you should be able to get away with the old donut-gasket.
-Dave
I was actually going to wait until the uppipe comes next week and then install everything next weekend, but then I realized this is a long weekend and maybe it'd be good practice to install just the turboback first..........
-mike
Plus I got them on a 7/100,000 extended no deductible for bottom dollar! I couldn't pass it up. After scouring the boards for so long it's encouraging all the helpful information people throw out around here. Thanks for helping me make my decision easier. I had my folder and the invoice numbers they were showing matched all my research. Man I am a happy man today.
Thank you everyone.
Doug
Bob
This thing is AWESOME!! Third gear is a monster! The sound is... YES!!
BTW, the uppipe install looks like it will be even more of a @#$#@$, but should really bring this thing to the next level.. I'll probably end up waiting a few weeks now before doing that, anyhow, this was good practice, at least I'll have a little more of a clue for next time..
Some pics available here: http://wrx.claud9.com/turboback/
PS Congrats Doug #10052, hope you enjoy it, go easy for the breakin period ;-)
-mike
Howard - Congrats on the install. Hey now, more power. Good pics too!
-Dennis
Let us know your ongoing experience with the exhaust mods. sounds like something I would want to do in the future.
edit: thanks for the great pictures!
Craig
I installed STi shifter trim this weekend, and a Subaru/Momo shift knob. They look great (need to take pics). The shift knob is about 1" lower than stock. Combined with the short shifter, it makes for nice quick throws. Now, I need to ditch the armrest extension -- it keeps getting in the way of my elbow.
I also installed a DIY grounding kit on the engine. Got some 8ga silver "StreetWires" from Crutcfield (99 cents a foot) along with ring terminals and heat shrink tube from DigiKey. Total parts was about $25, including shipping. Spent about 3 hours fitting, cutting, soldering, and attaching the kit. Some people claim a small HP gain and smoother acceleration. The only thing I notice is that the engine seems much smoother when engine-braking. But, it was a fun easy project, and cost a heck of a lot less than the commercial grounding kits I have seen advertised (for equal or lesser quality than my job).
Now, I need to work on the 17" rims next.....
Still thinking about that Prodrive muffler too, or an STi muffler.... Rallispec has some takeoff STi mufflers for $250, which looks like a good deal.
Craig
